    4. Orange Pi Plus 2e
    Orange Pi Plus 2e
    • Blackmike
      Blackmike last edited by
      so,emin orange ist nu auch angekommen…
      aber somanche probleme:
      ich hab hormorans image genommen.
      beim adapter update wirft der immer:
      iobroker	2017-05-31 22:42:50.954	info	exit 0
      iobroker	2017-05-31 22:42:50.911	info	Adapter "socketio" updated
      iobroker	2017-05-31 22:42:50.836	info	upload [0] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/index.html index.html text/html
      iobroker	2017-05-31 22:42:50.680	info	upload [1] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/socketio.png socketio.png image/png
      iobroker	2017-05-31 22:42:50.644	info	got /opt/iobroker/node_modules/iobroker.socketio/admin
      iobroker	2017-05-31 22:42:01.686	info	npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.socketio"
      iobroker	2017-05-31 22:42:01.608	info	SKIPPING OPTIONAL DEPENDENCY: Exit status 1
      iobroker	2017-05-31 22:42:01.600	info	optional SKIPPING OPTIONAL DEPENDENCY: mdns@2.3.3 install: `node-gyp rebuild`npm WARN optional
      iobroker	2017-05-31 22:42:01.597	info	WARN optional SKIPPING OPTIONAL DEPENDENCY: mdns@2.3.3 (node_modules/mdns):npm WARN
      iobroker	2017-05-31 22:42:01.595	info	npm
      iobroker	2017-05-31 22:41:54.504	info	gyp ERR! node-gyp -v v3.4.0gyp ERR! not ok
      iobroker	2017-05-31 22:41:54.499	info	gyp ERR! node -v v6.10.2
      iobroker	2017-05-31 22:41:54.499	info	ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/mdns
      iobroker	2017-05-31 22:41:54.497	info	ERR! System Linux 3.4.113-sun8igyp
      iobroker	2017-05-31 22:41:54.494	info	ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:215:12)gyp
      iobroker	2017-05-31 22:41:54.491	info	gyp
      iobroker	2017-05-31 22:41:54.491	info	gyp ERR! stack at ChildProcess.emit (events.js:191:7)
      iobroker	2017-05-31 22:41:54.491	info	gyp ERR! stack at emitTwo (events.js:106:13)
      iobroker	2017-05-31 22:41:54.491	info	ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
      iobroker	2017-05-31 22:41:54.488	info	gyp
      iobroker	2017-05-31 22:41:54.472	info	ERR! build error
      iobroker	2017-05-31 22:41:54.469	info
      iobroker	2017-05-31 22:41:54.463	info	gyp
      iobroker	2017-05-31 22:41:54.450	info	make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Error 1
      iobroker	2017-05-31 22:41:52.804	info	compilation terminated.
      iobroker	2017-05-31 22:41:52.799	info	^
      iobroker	2017-05-31 22:41:52.799	info	#include
      iobroker	2017-05-31 22:41:52.799	info	In file included from ../src/dns_sd.cpp:1:0:../src/mdns.hpp:32:20: fatal error: dns_sd.h: No such file or directory
      admin.0	2017-05-31 22:41:06.349	info	Repository received successfully.
      iobroker	2017-05-31 22:40:48.567	info	npm install iobroker.socketio@1.7.5 --production --prefix "/opt/iobroker" (System call)
      iobroker	2017-05-31 22:40:45.059	info	upgrade socketio
      was kann das sein ? recht ratlos bin
        PrinzEisenherz1 last edited by
        Probier mal folgendes
        sudo apt-get install libavahi-compat-libdnssd-dev
        Und dann nochmal socket.io updaten
        • Blackmike
          werd ich morgen sofort probieren…
          das mit socket.io war aber nur exemplarishc, die errors warf der bei jedem adapterupdate
            Bist du sicher dass das errors sind?
            Ich sehe nur Skipping optional dep und WARN.
            Rainer
            • Blackmike
              wäre das egal, wenn da die warn drinstehen ?
                Hi zusammen.
                Da ich mittlerweile auch im Besitz eines OPI bin wollte ich natürlich meine bisherigen Adapter nutzen.
                Darunter ist auch der rpi2.
                Da gibt es aber zum einen die falsche Anzeige der Temperatur, die 1k-Fehlermeldung im log, und die GPIOs werden da nicht unterstützt (glaube ich zumindest hier gelesen zu haben).
                Ok, GPIOs nutze ich persönlich nicht. Kann ich also verschmerzen.
                Worauf ich jetzt hinaus will ist, das ich mich hingesetzt habe, ne Kopie vom rpi2 auf meinen Git gelegt habe und diesen angepasst habe (hoffe mal ich bekomme da jetzt nicht ärger vom Urheber).
                Ich hab die Bezeichnungen geändert auf OPI, GPIOs entfernt, 1k-Fehler bereinigt, Temperatur wird jetzt richtig angezeigt, die Funktion "Raspberry" hab ich rausgenommen (Auslesen Kernspannung),
                sdcard hab ich umbenannt in emmc.
                Wer möchte kann sich das gerne installieren.
                cd /opt/iobroker
                iobroker stop
                npm install https://github.com/PrinzEisenherz1/iobroker.opi/tarball/master --production
                iobroker upload opi
                iobroker start
                Sieht jetzt unter ioBroker so aus
                Johnny
                  Schön!
                  Ich habe sowas auch für den pine64 gemacht auch wenn ich kein js kann 😄
                  http://forum.iobroker.net/viewtopic.php … =20#p40193
                  Rainer
                    lubeda last edited by
                    Klasse das "Monitoring-Modul" habe nur eine Kleinigkeit im Log gesehen:
                      Vielen Dank, @PrinzEisenherz, hab da Teil installiert und mir erlaubt im Eingangspost auf Deinen Beitrag zu verlinken.
                        @lubeda:
                        opi.PNG `
                        Muss ich mir später nochmal ankucken. Bei mir taucht der Fehler nicht auf aber schau nochmal nach.
                        @klassisch
                        Super,danke!
                        • Blackmike
                          dir auch mal vielen Dank… Ich habs auch mal ausprobiert... läuft... soweit.
                          bei mir ist es ein anderer Error:
                          opi.0	2017-06-01 21:12:45.591	error	Cannot evaluate: total used free shared buff/cache available Mem: 2062608 505872 1521136 5000 35600 1528914 Swap: 131068
                          ich hab mir dir objecte mal eingeschaut.
                          memory_available beschreibt er wohl nicht….
                          das ist das raw von memory_available
                            "common": {
                              "name": "opi.0.memory.memory_available",
                              "state": "state",
                              "role": "value",
                              "type": "mixed",
                              "read": true,
                              "write": true
                            "native": {},
                            "acl": {
                              "object": 1638,
                              "owner": "system.user.admin",
                              "state": 1638
                            "_id": "opi.0.memory.memory_available",
                            "type": "state"
                          gruss, Black
                            Ich schau mir das morgen mal an!
                              Habe den Fehler mit der cpu_freq gefunden.
                              Bei mir läuft iobroker mit dem User iobroker. Die Frequenz ist bei dem Image aus dem Forum nur für Root lesbar, der rest geht auch so!?
                              ls -l  /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq
                              -r-------- 1 root root 4096 Jun  2 17:41 /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq
                              So gehts es dann:
                              sudo chmod 444  /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq
                                Alles klar, danke für die Rückmeldung
                                  knopers1 last edited by
                                  hmm. ich kämpfe mit der Installation. Ganz genu, wird jetzt min. eine 4.x Version von node.js benötigt!
                                  ich habe zuvor eine alte geladen, jedoch läuft IOBroker damit wie Sack Nüsse…
                                  wget http://download.iobroker.net/nodejs0_12_6_armhf.deb
                                  dpkg -i nodejs0_12_6_armhf.deb
                                  rm nodejs0_12_6_armhf.deb
                                  Wie kann ich eine neuere Node Version installieren?
                                    paul53 last edited by
                                    @knopers1:
                                    Wie kann ich eine neuere Node Version installieren? `
                                    Deinstallation einer alten und Installation einer neuen Node Version ist http://www.iobroker.net/docu/?page_id=5106&lang=de#Installation_Nodejs beschrieben.
                                      danke, jetzt geht es weiter… 😛
                                      bei mir taucht ein Lizenz Fehler im Log auf...
                                      vis.0 2017-06-04 08:18:02.000 error No license found for vis. Please get one on https://iobroker.net !
                                      Momentan lufen zwei Systeme gleichzeitig RPI und Orange PI
                                      Unter dem Link https://iobroker.net soll man sich eine Lizense besorgen können. Beim Eingabe der E-Mail Adresse kommt ein Fehler, dass bereits die Mailadresse existiert...
                                      Was tun?
                                        habt Ihr den RFLink-Adapter am laufen? Ich sehe die USB Schnittstelle nicht!
                                        root@orangepiplus2e:~# node -v
                                        v4.2.1
                                        root@orangepiplus2e:~# v4.2.1^C
                                        root@orangepiplus2e:~# npm -v
                                        2.14.7
                                        Wie komme ich auf Node 6 ??? Kannjemand Helfen?
                                          @knopers1:
                                          Wie komme ich auf Node 6 ??? `
                                          Selbst deine 4.2 ist nicht die neueste in der 4er Reihe. Die solltest du wenigstens updaten.
                                          Ansonsten
                                          http://www.iobroker.net/docu/?page_id=5 … ion_Nodejs
                                          Und dort 4.x gegen 6.x austauschen.
                                          @knopers1:
                                          habt Ihr den RFLink-Adapter am laufen? Ich sehe die USB Schnittstelle nicht! `
                                          Ich habe ähnliche Probleme bei dem Tinkerboard.
                                          Du bist zwar bereits root, versuche es dennoch mal mit einem zusätzlichen sudo bei der Installation des Adapters. Beim pine64 hatte das geholfen.
                                          Hast du die Version aus Github genommen?
                                          Rainer
                                            @Homoran:
                                            @knopers1:
                                            Ansonsten
                                            @knopers1:
                                            Rainer `
                                            danke Rainer.
                                            o.k,
                                            bin jetzt auf Node 6
                                            v6.10.3
                                            3.10.10
                                            Den RFLink Adapter habe ich gelöscht und erneut installiert.
                                            Im Log kommt ein Fehler:
                                            rflink.0 2017-06-04 13:05:41.533 warn Module serialport is not available
                                            Den Adapter habe ich aus dem IOBroker Admin installiert….
                                            Wie kann ich den Adapter aus der Konsole installieren?
                                            610
                                            164612
