    4. erledigt! sonoff Adapter legt keine Objekte an
    • ChrisNett
      ChrisNett last edited by ChrisNett
      Systemdata Bitte Ausfüllen
      Hardwaresystem: I5/Proxmox.
      Arbeitsspeicher: 8GB
      Festplattenart: ssd
      Betriebssystem: Ubuntu
      Node-Version: 10.x.x
      Nodejs-Version: 10.x.x
      NPM-Version: 6.x.x
      Installationsart: Skript/Manuell
      Image genutzt: Ja/Nein
      Ort/Name der Imagedatei: Link
      moin, ich habe einen wemos mit tasmota der im sonoff Adapter kein objekte anlegen will
      hier der log vom ioBroker
      980081	2022-07-07 07:36:31.425	debug	[Bodenfeuchte_vorne] Received: BodenfeuchteVorne/SENSOR = {"Time":"2022-07-07T06:36:31","ANALOG":{"Range":8}}
      sonoff.0
      980081	2022-07-07 07:36:31.413	debug	[Bodenfeuchte_vorne] Received: BodenfeuchteVorne/STATE = {"Time":"2022-07-07T06:36:31","Uptime":"0T01:09:21","UptimeSec":4161,"Heap":26,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":3,"Wifi":{"AP":1,"SSId":"MundA-HomeNet-W","BSSId":"B0:F2:08:6B:1A:4E","Channel":1,"Mode":"11n","RSSI":54,"Signal":-73,"LinkCount":1,"Downtime":"0T00:00:05"}}
      sonoff.0
      980081	2022-07-07 07:36:25.942	debug	Client [Bodenfeuchte_vorne] pingreq
      sonoff.0
      980081	2022-07-07 07:36:21.413	debug	[Bodenfeuchte_vorne] Received: BodenfeuchteVorne/SENSOR = {"Time":"2022-07-07T06:36:21","ANALOG":{"Range":8}}
      sonoff.0
      980081	2022-07-07 07:36:21.400	debug	[Bodenfeuchte_vorne] Received: BodenfeuchteVorne/STATE = {"Time":"2022-07-07T06:36:21","Uptime":"0T01:09:11","UptimeSec":4151,"Heap":26,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":3,"Wifi":{"AP":1,"SSId":"MundA-HomeNet-W","BSSId":"B0:F2:08:6B:1A:4E","Channel":1,"Mode":"11n","RSSI":54,"Signal":-73,"LinkCount":1,"Downtime":"0T00:00:05"}}
      der von tasmota
      06:38:01.405 MQT: BodenfeuchteVorne/STATE = {"Time":"2022-07-07T06:38:01","Uptime":"0T01:10:51","UptimeSec":4251,"Heap":26,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":24,"MqttCount":3,"Wifi":{"AP":1,"SSId":"MundA-HomeNet-W","BSSId":"B0:F2:08:6B:1A:4E","Channel":1,"Mode":"11n","RSSI":56,"Signal":-72,"LinkCount":1,"Downtime":"0T00:00:05"}}
      06:38:01.419 MQT: BodenfeuchteVorne/SENSOR = {"Time":"2022-07-07T06:38:01","ANALOG":{"Range":10}}
      und meine eintselungen
      in der Objekten habe ich nur das
      ich habe den objektbaum für diesen esp auch schon mal gelöscht mehr als die beiden Objekte kommt aber nicht
      was habe ich falsch gemacht? sonst klappt das immer wunderbar.
      danke
      Christian
        arteck Developer Most Active @ChrisNett last edited by
        @christian-sandkaulen bitte erstaml das system aktualisieren
        node 10 ist seeeeeeeeeehr alt
        ChrisNett 1 Reply Last reply Reply Quote 0
        • ChrisNett
          ChrisNett @arteck last edited by
          @arteck
          sorry habe wohl nicht alles eingetragen...
            arteck Developer Most Active @ChrisNett last edited by arteck
            @christian-sandkaulen und jetzt zeigmal die Objekte des sonoffs adapter ..aber alle und nicht nur so ein schnipsel
            von sonoff.0 aus
            • ChrisNett
              @arteck
              so ?
                nimm die mal raus
                • ChrisNett
                  @arteck
                  leider nix
                  • ChrisNett
                    ChrisNett @ChrisNett last edited by
                    Ich habe alle drei hacken wieder gesetzt sonst bekomme ich nicht alle daten ... zum beispiel vom auslekopf des smartmeters
                      @christian-sandkaulen hast du alles richtig eingetragen im Tasmota?
                      • ChrisNett
                        @arteck
                        so habe ich alle eingestellt
                          mach im topic
                          %prefix%/%topic%/
                          der user und psw stimmen auch ?
                          • ChrisNett
                            @arteck
                            danke scheinbar war es das muss an der neuen 12.02 Tasmota version liegen den bei den andern wemos mache ich das immer so!
                            klapp!
                              @christian-sandkaulen hmm.. werden die auch aktualisiert ??? die anderen meine ich .. da der topic dafür zuständig ist wie die Daten kommen
                              ih würde an deiner stelle die alle wieder zurück auf den oben genannten topic setzten
                              • ChrisNett
                                @arteck sagte in sonoff Adapter legt keine Objekte an:
                                danke das mache ich dann zur Sicherheit!
                                512
