    4. VIS von Sigi234
    VIS von Sigi234
      sigi234 Forum Testing Most Active @Sushibomba last edited by sigi234
      @sushibomba sagte in VIS von Sigi234:
      @djmarc75
      Ok danke dir.
      Also ich möchte halt nicht so einen optischen Switch Schalter haben sondern nur ein Button wo ich drauf drücke und er es mir dann farblich anzeigt ob er an ist oder nicht.
      Z.B. grün der Hintergrund vom Button für an und rot oder grau bei aus.
      [{"tpl":"tplVis-materialdesign-Button-Toggle","data":{"oid":"yamaha.0.Realtime.MAIN.STRAIGHT","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","buttonStyle":"outlined","toggleType":"value","stateIfNotTrueValue":"off","vibrateOnMobilDevices":"50","iconPosition":"left","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"valueOff":"Off","valueOn":"On","buttontext":"","image":"power-off","invertImageTrue":false,"iconHeight":"80","imageTrue":"power-on","labelTrue":"","labelWidth":"0","autoLockAfter":"10","lockFilterGrayscale":"30","textFontFamily":"{vis-materialdesign.0.fonts.button.text}","textFontSize":"{vis-materialdesign.0.fontSizes.button.text}","mdwButtonPrimaryColor":"{mode:vis-materialdesign.0.colors.darkTheme;light:vis-materialdesign.0.colors.light.button.default.primary;dark:vis-materialdesign.0.colors.dark.button.default.primary; mode === \"true\" ? dark : light}","mdwButtonSecondaryColor":"{mode:vis-materialdesign.0.colors.darkTheme;light:vis-materialdesign.0.colors.light.button.default.secondary;dark:vis-materialdesign.0.colors.dark.button.default.secondary; mode === \"true\" ? dark : light}","lockIconColor":"{mode:vis-materialdesign.0.colors.darkTheme;light:vis-materialdesign.0.colors.light.button.lock_icon;dark:vis-materialdesign.0.colors.dark.button.lock_icon; mode === \"true\" ? dark : light}","imageTrueColor":"#46fd17","colorBgFalse":"#000000","colorBgTrue":"#24e203"},"style":{"left":"366px","top":"15px","width":"85px","height":"85px","z-index":"4"},"widgetSet":"materialdesign"}]
      Kannst du dir einstellen wie du willst.
        Sushibomba @sigi234 last edited by Sushibomba
        @sigi234
        Vielen Dank aber ich hätte gerne es so wie deine Buttons wie für den "Input Wechsel"
        Also das soll ein View in Widget sein:
        yamaha soundmodis.txt
          Sushibomba last edited by Sushibomba
          @sigi234
          Hast du eigentlich auch ne Programmzeitschrift als View?
          Habe das hier irgendwo schon mal gesehen, aber keine passende View dafür gefunden.
          Und hast du zufällig rausgefunden, warum die Ansteuerung der verschiedenen Internetradio-Sender nicht klappt aber die Tuner-Sender Auswahl funktioniert?
            So mein kleines View in Widget ist nun auch fertig und funktioniert 🙂
            Jetzt klappt nur die Auswahl der Internetradio Streams noch nicht über das Dropdown-Menu.
            viw_yamaha.txt
            PS: Ich glaube ich weiß warum ich die Internet RadioSender nicht über das Dropdown anwählen kann.
            Ich haben den RX-A860 und soweit ich rausgefunden habe, habe ich zwar eine Favoritenliste aber keine Nummern die den jeweiligen Streams zugeordnet sind.
            Scheint es bei den neueren Receivern wohl nicht mehr zu geben. Warum auch immer.
            Hat jemand ne andere Idee welchen Datenpunkt ich anspielen muss dafür?
            Oder gibt es eine Möglichkeit die Möglichkeit die Befehle vom Yamaha auszulesen wenn ich es händisch auswähle?
            sigi234 bahnuhr 2 Replies Last reply Reply Quote 0
              https://www.heimkino-praxis.de/yamaha-netzwerk-steuerung/
              • bahnuhr
                bahnuhr Forum Testing Most Active @Sushibomba last edited by bahnuhr
                @sushibomba
                Kann deiner mussiccast.
                Wenn ja:
                mussiccast Adapter installieren.
                Favoriten im Yamaha benennen
                und dann den DP ...musiccast.0.xxxxx.netusb.presetrecallnumber den Favoriten steuern.
                Und in VIS mit dem entsprechenden mussiccast widget.
                sieht dann so aus:
                  Sushibomba @bahnuhr last edited by
                  @bahnuhr
                  Klasse vielen Dank. Danke auch an @sigi234
                  Allerdings bekomme ich es nicht hin die Favoriten Netradio Sender auf die jeweiligen Slots zu legen 😞
                  Kann mir da jemand noch weiterhelfen?
                  @sigi234 Kurze andere Frage... Welches Widget nutzt du nochmal um Charts wie zum Beispiel bei deinem "Spritpreise" View anzuzeigen?
                  sigi234 1 Reply Last reply Reply Quote -1
                    Vis-materialdesign-Chart-Line-History
                    Oder
                    https://github.com/ioBroker/ioBroker.echarts
                      @sigi234
                      Danke dir 🙂
                        @sigi234
                        Hey Sigi ich habe mir jetzt mein View für die Spritpreise gebaut 🙂
                        Bin eigentlich sehr zufrieden nur wird der letzte Datensatz falsch angezeigt und ich weiß nicht wieso 😞
                        Könntest du mal schauen ob due den Fehler der blauen Linie findest?
                        Es zeigt zwar die richtigen Werte an aber wird optisch zu hoch dargestellt. Heißt die Linie müsste bei den anderen unten verlaufen.
                        view_sprit_mitFehler.txt
                        • DJMarc75
                          DJMarc75 @Sushibomba last edited by
                          @sushibomba Also wenn das ein Panel aus Grafana ist dann musst Du dort (in Grafana) mal nachsehen.
                          Glaub kaum dass @sigi234 da helfen kann weil das nix mit VIS zu tun hat. 😉
                            Sushibomba @DJMarc75 last edited by
                            @djmarc75
                            Ne ist kein Grafana Dashboard. Das ist der Adapter Echarts den er auch verwendet.
                            • DJMarc75
                              DJMarc75 @Sushibomba last edited by DJMarc75
                              Dann eigentlich das selbe
                              @djmarc75 sagte in VIS von Sigi234:
                              EDIT: sorry @sigi234 ... bestimmt kannst Du da helfen aber wäre leicht OT
                                sigi234 Forum Testing Most Active @DJMarc75 last edited by
                                Ok, das wäre im E-Chart Beitrag besser aufgehoben.
                                  @sigi234
                                  OK und welchen Beitrag meinst du da genau?
                                  Noch ne dumme Frage... Wenn ich auf meiner worx View eine Zeit eintragen möchte über das Tablet dann springt er immer in mein Yamaha View sobald die Tastatur auf dem Tablet aufgeht. Nutze den Filly Kiosk Browser und habe keine Ahnung warum er das macht. Ihr ne Idee?
                                  • DJMarc75
                                    Da solltest Du einen eigenen Thread aufmachen (richtige Kategorie auswählen aber vorher bitte die Suchfunktion nutzen obs da schon ne Lösung zu Deinem Problem gibt)
                                    VORHER aber trotzdem in Deinem eCharts nochmal alles auf eventuelle Fehler prüfen. 😉
                                      @djmarc75
                                      Ja habe ich gemacht. Eben bestimmt eine Stunde lang gesucht aber nichts gefunden.
                                      Bzgl. der Suchfunktion komme ich noch nicht so ganz klar hier. Habe noch nicht herausgefunden, wie ich z.b. nur in einem Thema/Threads wie diesem hier suche oder überall und dann evtl. nur in bestimmten Kategorien. Gibt's da irgendwo nen Anleitung hier fürs Forum?
                                      • Glasfaser
                                        Glasfaser @Sushibomba last edited by Glasfaser
                                        in deinen Einstellungen " Suchen innerhalb von Themen aktivieren "
                                        siehe hier als Beispiel , wie ... :
                                        https://forum.iobroker.net/topic/4733/howto-iobroker-unter-docker-auf-synology-diskstation/2146
                                        EDIT :
                                        über den Forum Hilfe Button !
                                          Sushibomba @Glasfaser last edited by
                                          @glasfaser
                                          Vielen Dank 🤗
                                            @sigi234
                                            Versuche mir gerade meine Alexa View zusammen zu basteln.
                                            Wie hast du das mit den Playlist gemacht? Also wo lege ich die an und wie bekomme ich dann diese Logos da rein von den Sendern? Zieht er sich das automatisch?
                                            ode abfrage vis vis projekte
                                            151
                                            1344
                                            597283
