    4. Server Cannot start inMem-objects on port 9001
      Dieter_P @Thomas Braun last edited by Dieter_P
      @thomas-braun said in Server Cannot start inMem-objects on port 9001:
      sudo -H -u iobroker npm install iobroker.js-controller
      das kommt raus:
      pi@raspberrypi:~ $ cd /opt/iobroker
      pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
      > iobroker.js-controller@4.0.21 preinstall /opt/iobroker/node_modules/iobroker.js-controller
      > node lib/preinstallCheck.js
      NPM version: 6.14.17
      > iobroker.js-controller@4.0.21 install /opt/iobroker/node_modules/iobroker.js-controller
      > node iobroker.js setup first
      No connection to databases possible ...
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman/node_modules/fsevents):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/fsevents):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):
      npm ERR! code ELIFECYCLE
      npm ERR! errno 22
      npm ERR! iobroker.js-controller@4.0.21 install: `node iobroker.js setup first`
      npm ERR! Exit status 22
      npm ERR!
      npm ERR! Failed at the iobroker.js-controller@4.0.21 install script.
      npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      npm ERR!     /home/iobroker/.npm/_logs/2022-07-07T14_57_18_192Z-debug.log
        apollon77 @Dieter_P last edited by
        @dieter_p läuft was anderes auf dem Host auf Port 9000 oder 9001?
          Dieter_P @apollon77 last edited by
          @apollon77 said in Server Cannot start inMem-objects on port 9001:
          Versuche mal ob ich das heraus bekomme aber wissentlich nein.
          Auf dem Pi läuft noch ein WireGuard Client aber der nicht auf 9000/9001 und das auch nicht erst seit gestern sondern schon Monate. Sonst ist nichts installiert.
          Thomas Braun Glasfaser 2 Replies Last reply Reply Quote 0
            Thomas Braun Most Active @Dieter_P last edited by Thomas Braun
            @dieter_p
            Kannst ja damit mal schauen:
            sudo netstat -tulpen
            Was mich auch wundert:
            Das müsste eigentlich auf allen Kanälen die 4.0.23 sein. Keine Ahnung wo das bei dir herkommt. Vielleicht aus dem npm cache.
              da scheint nichts zu laufen:
              pi@raspberrypi:~ $ netstat -an | grep 9000
              pi@raspberrypi:~ $ netstat -an | grep 9001
              pi@raspberrypi:~ $ man lsof
              pi@raspberrypi:~ $ lsof -i:9000
              pi@raspberrypi:~ $ lsof -i:9001
              pi@raspberrypi:~ $ sudo netstat -tulpen
              Aktive Internetverbindungen (Nur Server)
              Proto Recv-Q Send-Q Local Address           Foreign Address         State       Benutzer   Inode      PID/Program name
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16710      442/sshd
              tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          14477      287/cupsd
              tcp6       0      0 :::22                   :::*                    LISTEN      0          16712      442/sshd
              tcp6       0      0 ::1:631                 :::*                    LISTEN      0          14476      287/cupsd
              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16749      364/dhcpcd
              udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          14298      371/cups-browsed
              udp        0      0 0.0.0.0:36489           0.0.0.0:*                           108        14190      298/avahi-daemon: r
              udp        0      0 0.0.0.0:48820           0.0.0.0:*                           0          16853      -
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14188      298/avahi-daemon: r
              udp6       0      0 :::48820                :::*                                0          16854      -
              udp6       0      0 :::50885                :::*                                108        14191      298/avahi-daemon: r
              udp6       0      0 :::5353                 :::*                                108        14189      298/avahi-daemon: r
              udp6       0      0 :::546                  :::*                                0          16765      364/dhcpcd
              pi@raspberrypi:~ $
                @dieter_p
                Vermutlich aber eine Desktop-Umgebung am Start.
                  Da Du immer darauf verweist und ich mir bewusst war mit dem RPI2 am Limit zu sein, bin ich mir zu 99,9% sicher nein 😉
                  Edit:
                  pi@raspberrypi:~ $ who -r
                           Runlevel 3   2022-07-07 16:20
                    @dieter_p
                    Den cupsd fängt man sich halt bevorzugt mit einem Desktop ein, deswegen komme ich darauf.
                    npm cache mal gelöscht?
                      @dieter_p
                      Sollte man das forcen?
                      pi@raspberrypi:~ $ sudo npm cache clean
                      npm ERR! As of npm@5, the npm cache self-heals from corruption issues and data extracted from the cache is guaranteed to be valid. If you want to make sure everything is consistent, use 'npm cache verify' instead. On the other hand, if you're debugging an issue with the installer, you can use `npm install --cache /tmp/empty-cache` to use a temporary cache instead of nuking the actual one.
                      npm ERR!
                      npm ERR! If you're sure you want to delete the entire cache, rerun this command with --force.
                      npm ERR!     /root/.npm/_logs/2022-07-07T16_39_18_206Z-debug.log
                      Edit: Durch ein Verify des caches ergab sich keine Änderung:
                      pi@raspberrypi:~ $ npm cache verify
                      Cache verified and compressed (~/.npm/_cacache):
                      Content verified: 1864 (82698644 bytes)
                      Index entries: 2895
                      Finished in 41.415s
                      Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
                      npm ERR! errno 24
                      npm ERR! Exit status 24
                      npm ERR!
                      npm ERR!     /home/iobroker/.npm/_logs/2022-07-07T16_47_48_644Z-debug.log
                      Edit2: Etwas blöd, dass mir erst jetzt auffällt das ich in der Cloud nur BackUps bis zum 02.05.2022 liegen hab. Da scheint schon was länger nicht einwandfrei zu laufen. Sonst wäre eine Neuinstallation sicher der bessere Weg.
                        apollon77 last edited by apollon77
                        Dann ersuch mal Controller auf 4.0.23 ohne die install Skripte.
                        Also
                        cd /opt/iobroker
                        npm i iobroker.js-controller@4.0.23 --ignore-scripts
                        Dann mal
                        iob status Bzw iob update
                        Edit:und vorher sicherstellen das wirklich aus ist. Also auch das im logfile unter /opt/iobroker/log nix neues kommt.
                          @apollon77
                          Danke. Leider noch gleiche Meldungen:
                          pi@raspberrypi:/opt/iobroker/log $ nano iobroker.2022-07-08.log
                          pi@raspberrypi:/opt/iobroker/log $ cd /opt/iobroker
                          pi@raspberrypi:/opt/iobroker $ npm i iobroker.js-controller@4.0.23 --ignore-scripts
                          + iobroker.js-controller@4.0.23
                          added 6 packages from 10 contributors and removed 3 packages in 156.871s
                          87 packages are looking for funding
                            run `npm fund` for details
                          pi@raspberrypi:/opt/iobroker $ cd
                          pi@raspberrypi:~ $ iob status
                          pi@raspberrypi:~ $ iob update
                          pi@raspberrypi:~ $ npm fund
                          /home/pi
                             │      New major version of npm available! 6.14.17 → 8.13.2      │
                             │   Changelog: https://github.com/npm/cli/releases/tag/v8.13.2   │
                             │               Run npm install -g npm to update!                │
                          pi@raspberrypi:~ $
                            @dieter_p Dann bitte "Iob custom" aufrufen und die Ausgabe zeigen. kannst DU mit CTRL-C abbrechen. Und bitte auch zeigen was ein "iob start" im ioBroker log bringt
                              Dieter_P @apollon77 last edited by Dieter_P
                              Iob custom
                              Danke. Der Befehl "custom" fehlt oder ich mach was falsch
                              pi@raspberrypi:~ $ iob custom
                              iobroker [command]
                              Commands:
                                iobroker setup                                               Setup ioBroker
                                iobroker start [all|<adapter>.<instance>]                    Starts the js-controller or a specified adapter instance
                                iobroker stop [<adapter>.<instance>]                         stops the js-controller or a specified adapter instance
                                iobroker restart [<adapter>.<instance>]                      Restarts js-controller or a specified adapter instance  [aliases: r]
                                iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
                                iobroker info                                                Shows the host info
                                iobroker logs [<adapter>]                                    Monitor log
                                iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
                                iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
                                iobroker rebuild [<module>]                                  Rebuild all native modules or path
                                iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
                                iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
                                iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
                                iobroker update [<repositoryUrl>]                            Update repository and list adapters
                                iobroker upgrade                                             Upgrade management
                                iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
                                iobroker object                                              Object management  [aliases: o]
                                iobroker state                                               State management  [aliases: s]
                                iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
                                iobroker list <type> [<filter>]                              List all entries, like objects
                                iobroker chmod <mode> <file>                                 Change file rights
                                iobroker chown <user> <group> <file>                         Change file ownership
                                iobroker touch <file>                                        Touch file
                                iobroker rm <file>                                           Remove file
                                iobroker file                                                File management
                                iobroker user                                                User commands
                                iobroker group                                               group management
                                iobroker host <hostname>                                     Set host to given hostname
                                iobroker set <adapter>.<instance>                            Change settings of adapter config
                                iobroker license <license.file or license.text>              Update license by given file
                                iobroker cert                                                Certificate management
                                iobroker clean <yes>                                         Clears all objects and states
                                iobroker backup                                              Create backup
                                iobroker restore <backup name or path>                       Restore a specified backup
                                iobroker validate <backup name or path>                      Validate a specified backup
                                iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
                                iobroker repo [<name>]                                       Show repo information
                                iobroker uuid                                                Show uuid of the installation  [aliases: id]
                                iobroker unsetup                                             Reset license, installation secret and language
                                iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
                                iobroker multihost                                           Multihost management
                                iobroker compact                                             compact group management
                                iobroker plugin                                              Plugin management
                                iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
                              Options:
                                --help  Show help  [boolean]
                              pi@raspberrypi:~ $ iob info
                              pi@raspberrypi:~ $ iob start
                              pi@raspberrypi:~ $
                                @dieter_p
                                iobroker setup custom
                                D apollon77 2 Replies Last reply Reply Quote 1
                                  pi@raspberrypi:~ $ iobroker setup custom
                                  Current configuration:
                                  - Objects database:
                                    - Type: jsonl
                                    - Host/Unix Socket: 127.0.0.1
                                    - Port: 9001
                                  - States database:
                                    - Type: jsonl
                                    - Port: 9000
                                  - Data Directory: ../../iobroker-data/
                                  Type of objects DB [(j)sonl, (f)ile, (r)edis, ...], default [jsonl]:
                                    @dieter_p
                                    Und wie sieht ein Start im LogFile aus?
                                    Mit
                                    tail -f /opt/iobroker/log/iobroker.current.log
                                    in einer zweiten Session nachschauen.
                                      Hab die MAC Adressen mal "angepasst" die sollten hier doch nichts zu beitragen, oder?
                                      2022-07-08 10:24:44.819  - info: host.raspberrypi iobroker _restart
                                      2022-07-08 10:24:53.399  - info: host.raspberrypi iobroker.js-controller version 4.0.23 js-controller starting
                                      2022-07-08 10:24:53.424  - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                                      2022-07-08 10:24:53.427  - info: host.raspberrypi hostname: raspberrypi, node: v14.19.3
                                      2022-07-08 10:24:53.429  - info: host.raspberrypi ip addresses: 192.168.0.38 2a02:908:13b7:xxxx:xxxx:4331:xxxxx:82ad fe80::xxx:b07e:xxxx:49ba 10.0.1.2
                                      2022-07-08 10:25:23.502  - error: host.raspberrypi No connection to databases possible, restart
                                      2022-07-08 10:25:23.559  - info: host.raspberrypi iobroker _restart
                                        @dieter_p
                                        Läuft das im Docker oder sowas?
                                          Nein ganz klassisch auf nem RPI2 nur mit SD-Karte und nem ZigbeeStick.
                                          Installiert über die Installationsanleitung aus der Doku hier.
                                            apollon77 @Thomas Braun last edited by
                                            @thomas-braun ÄÄähhmm ja .. danke ...war zu spät gestern Abend am Handy. Sorry
                                            429
                                            81548
