    4. Server Cannot start inMem-objects on port 9001
      Thomas Braun Most Active @Dieter_P last edited by
      @dieter_p
      Vermutlich aber eine Desktop-Umgebung am Start.
        Dieter_P @Thomas Braun last edited by Dieter_P
        Da Du immer darauf verweist und ich mir bewusst war mit dem RPI2 am Limit zu sein, bin ich mir zu 99,9% sicher nein 😉
        Edit:
        pi@raspberrypi:~ $ who -r
                 Runlevel 3   2022-07-07 16:20
          @dieter_p
          Den cupsd fängt man sich halt bevorzugt mit einem Desktop ein, deswegen komme ich darauf.
          npm cache mal gelöscht?
            @thomas-braun said in Server Cannot start inMem-objects on port 9001:
            @dieter_p
            Sollte man das forcen?
            pi@raspberrypi:~ $ sudo npm cache clean
            npm ERR! As of npm@5, the npm cache self-heals from corruption issues and data extracted from the cache is guaranteed to be valid. If you want to make sure everything is consistent, use 'npm cache verify' instead. On the other hand, if you're debugging an issue with the installer, you can use `npm install --cache /tmp/empty-cache` to use a temporary cache instead of nuking the actual one.
            npm ERR!
            npm ERR! If you're sure you want to delete the entire cache, rerun this command with --force.
            npm ERR!     /root/.npm/_logs/2022-07-07T16_39_18_206Z-debug.log
            Edit: Durch ein Verify des caches ergab sich keine Änderung:
            pi@raspberrypi:~ $ npm cache verify
            Cache verified and compressed (~/.npm/_cacache):
            Content verified: 1864 (82698644 bytes)
            Index entries: 2895
            Finished in 41.415s
            pi@raspberrypi:~ $ cd /opt/iobroker
            pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
            > iobroker.js-controller@4.0.21 preinstall /opt/iobroker/node_modules/iobroker.js-controller
            > node lib/preinstallCheck.js
            NPM version: 6.14.17
            > iobroker.js-controller@4.0.21 install /opt/iobroker/node_modules/iobroker.js-controller
            > node iobroker.js setup first
            Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman/node_modules/fsevents):
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/fsevents):
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):
            npm ERR! code ELIFECYCLE
            npm ERR! errno 24
            npm ERR! iobroker.js-controller@4.0.21 install: `node iobroker.js setup first`
            npm ERR! Exit status 24
            npm ERR!
            npm ERR! Failed at the iobroker.js-controller@4.0.21 install script.
            npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
            npm ERR!     /home/iobroker/.npm/_logs/2022-07-07T16_47_48_644Z-debug.log
            Edit2: Etwas blöd, dass mir erst jetzt auffällt das ich in der Cloud nur BackUps bis zum 02.05.2022 liegen hab. Da scheint schon was länger nicht einwandfrei zu laufen. Sonst wäre eine Neuinstallation sicher der bessere Weg.
              apollon77 last edited by apollon77
              Dann ersuch mal Controller auf 4.0.23 ohne die install Skripte.
              Also
              cd /opt/iobroker
              npm i iobroker.js-controller@4.0.23 --ignore-scripts
              Dann mal
              iob status Bzw iob update
              Edit:und vorher sicherstellen das wirklich aus ist. Also auch das im logfile unter /opt/iobroker/log nix neues kommt.
                Dieter_P @apollon77 last edited by
                @apollon77
                Danke. Leider noch gleiche Meldungen:
                pi@raspberrypi:/opt/iobroker/log $ nano iobroker.2022-07-08.log
                pi@raspberrypi:/opt/iobroker/log $ cd /opt/iobroker
                pi@raspberrypi:/opt/iobroker $ npm i iobroker.js-controller@4.0.23 --ignore-scripts
                + iobroker.js-controller@4.0.23
                added 6 packages from 10 contributors and removed 3 packages in 156.871s
                87 packages are looking for funding
                  run `npm fund` for details
                pi@raspberrypi:/opt/iobroker $ cd
                pi@raspberrypi:~ $ iob status
                No connection to databases possible ...
                pi@raspberrypi:~ $ iob update
                pi@raspberrypi:~ $ npm fund
                /home/pi
                   │      New major version of npm available! 6.14.17 → 8.13.2      │
                   │   Changelog: https://github.com/npm/cli/releases/tag/v8.13.2   │
                   │               Run npm install -g npm to update!                │
                pi@raspberrypi:~ $
                  apollon77 @Dieter_P last edited by
                  @dieter_p Dann bitte "Iob custom" aufrufen und die Ausgabe zeigen. kannst DU mit CTRL-C abbrechen. Und bitte auch zeigen was ein "iob start" im ioBroker log bringt
                    Dieter_P @apollon77 last edited by Dieter_P
                    @apollon77 said in Server Cannot start inMem-objects on port 9001:
                    Iob custom
                    Danke. Der Befehl "custom" fehlt oder ich mach was falsch
                    pi@raspberrypi:~ $ iob custom
                    iobroker [command]
                    Commands:
                      iobroker setup                                               Setup ioBroker
                      iobroker start [all|<adapter>.<instance>]                    Starts the js-controller or a specified adapter instance
                      iobroker stop [<adapter>.<instance>]                         stops the js-controller or a specified adapter instance
                      iobroker restart [<adapter>.<instance>]                      Restarts js-controller or a specified adapter instance  [aliases: r]
                      iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
                      iobroker info                                                Shows the host info
                      iobroker logs [<adapter>]                                    Monitor log
                      iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
                      iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
                      iobroker rebuild [<module>]                                  Rebuild all native modules or path
                      iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
                      iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
                      iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
                      iobroker update [<repositoryUrl>]                            Update repository and list adapters
                      iobroker upgrade                                             Upgrade management
                      iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
                      iobroker object                                              Object management  [aliases: o]
                      iobroker state                                               State management  [aliases: s]
                      iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
                      iobroker list <type> [<filter>]                              List all entries, like objects
                      iobroker chmod <mode> <file>                                 Change file rights
                      iobroker chown <user> <group> <file>                         Change file ownership
                      iobroker touch <file>                                        Touch file
                      iobroker rm <file>                                           Remove file
                      iobroker file                                                File management
                      iobroker user                                                User commands
                      iobroker group                                               group management
                      iobroker host <hostname>                                     Set host to given hostname
                      iobroker set <adapter>.<instance>                            Change settings of adapter config
                      iobroker license <license.file or license.text>              Update license by given file
                      iobroker cert                                                Certificate management
                      iobroker clean <yes>                                         Clears all objects and states
                      iobroker backup                                              Create backup
                      iobroker restore <backup name or path>                       Restore a specified backup
                      iobroker validate <backup name or path>                      Validate a specified backup
                      iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
                      iobroker repo [<name>]                                       Show repo information
                      iobroker uuid                                                Show uuid of the installation  [aliases: id]
                      iobroker unsetup                                             Reset license, installation secret and language
                      iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
                      iobroker multihost                                           Multihost management
                      iobroker compact                                             compact group management
                      iobroker plugin                                              Plugin management
                      iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
                    Options:
                      --help  Show help  [boolean]
                    pi@raspberrypi:~ $ iob info
                    pi@raspberrypi:~ $ iob start
                    pi@raspberrypi:~ $
                      @dieter_p
                      iobroker setup custom
                      D apollon77 2 Replies Last reply Reply Quote 1
                        pi@raspberrypi:~ $ iobroker setup custom
                        Current configuration:
                        - Objects database:
                          - Type: jsonl
                          - Host/Unix Socket: 127.0.0.1
                          - Port: 9001
                        - States database:
                          - Type: jsonl
                          - Port: 9000
                        - Data Directory: ../../iobroker-data/
                        Type of objects DB [(j)sonl, (f)ile, (r)edis, ...], default [jsonl]:
                          Thomas Braun Most Active @Dieter_P last edited by Thomas Braun
                          @dieter_p
                          Und wie sieht ein Start im LogFile aus?
                          Mit
                          tail -f /opt/iobroker/log/iobroker.current.log
                          in einer zweiten Session nachschauen.
                            Hab die MAC Adressen mal "angepasst" die sollten hier doch nichts zu beitragen, oder?
                            2022-07-08 10:24:44.819  - info: host.raspberrypi iobroker _restart
                            2022-07-08 10:24:53.399  - info: host.raspberrypi iobroker.js-controller version 4.0.23 js-controller starting
                            2022-07-08 10:24:53.424  - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                            2022-07-08 10:24:53.427  - info: host.raspberrypi hostname: raspberrypi, node: v14.19.3
                            2022-07-08 10:24:53.429  - info: host.raspberrypi ip addresses: 192.168.0.38 2a02:908:13b7:xxxx:xxxx:4331:xxxxx:82ad fe80::xxx:b07e:xxxx:49ba 10.0.1.2
                            2022-07-08 10:25:23.502  - error: host.raspberrypi No connection to databases possible, restart
                            2022-07-08 10:25:23.559  - info: host.raspberrypi iobroker _restart
                              @dieter_p
                              Läuft das im Docker oder sowas?
                                Nein ganz klassisch auf nem RPI2 nur mit SD-Karte und nem ZigbeeStick.
                                Installiert über die Installationsanleitung aus der Doku hier.
                                  apollon77 @Thomas Braun last edited by
                                  @thomas-braun ÄÄähhmm ja .. danke ...war zu spät gestern Abend am Handy. Sorry
                                    @dieter_p Komisch ... zeig mal "ip a" Ausgabe (hoffe das geht da). Ich will mal die Netzwerkinterfaces sehen. Weil erste Vermutung ist das die 127.0.0.1 whyever nicht auf sich selbst auflöst
                                      @apollon77
                                      Thx. Warum das jetzt auf einmal auftritt kommt mir auch komisch vor. Diese Konfig läuft so unverändert ca seit 1 Jahr inkl. Wireguard
                                      pi@raspberrypi:~ $ ip a
                                      1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
                                          link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
                                          inet 127.0.0.1/8 scope host lo
                                             valid_lft forever preferred_lft forever
                                          inet6 ::1/128 scope host
                                      2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
                                          link/ether b8:27:xx:c2:xx:be brd ff:ff:ff:ff:ff:ff
                                          inet 192.168.0.38/24 brd 192.168.0.255 scope global noprefixroute eth0
                                          inet6 2a02:xxx:13b7:xxxx:64ad:4331:xxxx:82ad/64 scope global dynamic mngtmpaddr noprefixroute
                                             valid_lft 68729sec preferred_lft 25529sec
                                          inet6 fe80::xxx:b07e:xxxx:49ba/64 scope link
                                      3: wgclient0: <POINTOPOINT,NOARP,UP,LOWER_UP> mtu 1420 qdisc noqueue state UNKNOWN group default qlen 1000
                                          link/none
                                          inet 10.0.1.2/24 scope global wgclient0
                                        Also das ganze funktioniert so. ioBroker startet und startet die DB auf dem Port 9000 und 9001 und die "Listenen" auf der IP (127.0.01 in deinem Fall) die angegeben ist. Sobald die DB gestartet ist versucht ein DB-Client in der Software sich darauf zu verbinden. Und DAS geht bei dir nicht, deswegen sagt der Client nach 30s ... da passt was net. Meine Vermutung ist das er bei diesem "eigentlich lokalen" verbindungsversuch nicht "lokal" rumkommt und daher das Listen auf 127.0.01 es blockt.
                                        Auch wenn ich nicht verstehe warum die 127.0.01 nicht geht (vllt hat Thomas noch ne Idee), ändere mal in /opt/iobroker/iobroker-data/iobroker.json in den objects und state Abschnitten die 127.0.01 gegen 0.0.0.0 und versuch dann mal. Damit "Listened" er auf "egal woher die verbindung kommt". Wenn das geht hast Du nen Workaround ...
                                          Vielen Dank auch für Deine für mich verständliche Erklärung! In Object und states angepasst aber leider immer noch der Zugriffsfehler:
                                          pi@raspberrypi:~ $ sudo nano /opt/iobroker/iobroker-data/iobroker.json
                                          pi@raspberrypi:~ $ iob stop
                                          pi@raspberrypi:~ $
                                          • Glasfaser
                                            Glasfaser @Dieter_P last edited by
                                            @dieter_p sagte in Server Cannot start inMem-objects on port 9001:
                                            Auf dem Pi läuft noch ein WireGuard Client
                                            Komischerweise ist er bei dir nicht aufgelistet !?
                                            Kannst du das nochmal zeigen :
                                            sudo netstat -ntlp | grep LISTEN
                                            429
                                            81550
