    4. Server Cannot start inMem-objects on port 9001
      apollon77 last edited by apollon77
      Dann ersuch mal Controller auf 4.0.23 ohne die install Skripte.
      Also
      cd /opt/iobroker
      npm i iobroker.js-controller@4.0.23 --ignore-scripts
      Dann mal
      iob status Bzw iob update
      Edit:und vorher sicherstellen das wirklich aus ist. Also auch das im logfile unter /opt/iobroker/log nix neues kommt.
        Dieter_P @apollon77 last edited by
        @apollon77
        Danke. Leider noch gleiche Meldungen:
        pi@raspberrypi:/opt/iobroker/log $ nano iobroker.2022-07-08.log
        pi@raspberrypi:/opt/iobroker/log $ cd /opt/iobroker
        pi@raspberrypi:/opt/iobroker $ npm i iobroker.js-controller@4.0.23 --ignore-scripts
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/fsevents):
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman/node_modules/fsevents):
        + iobroker.js-controller@4.0.23
        added 6 packages from 10 contributors and removed 3 packages in 156.871s
        87 packages are looking for funding
          run `npm fund` for details
        pi@raspberrypi:/opt/iobroker $ cd
        pi@raspberrypi:~ $ iob status
        No connection to databases possible ...
        pi@raspberrypi:~ $ iob update
        pi@raspberrypi:~ $ npm fund
        /home/pi
           │      New major version of npm available! 6.14.17 → 8.13.2      │
           │   Changelog: https://github.com/npm/cli/releases/tag/v8.13.2   │
           │               Run npm install -g npm to update!                │
        pi@raspberrypi:~ $
          apollon77 @Dieter_P last edited by
          @dieter_p Dann bitte "Iob custom" aufrufen und die Ausgabe zeigen. kannst DU mit CTRL-C abbrechen. Und bitte auch zeigen was ein "iob start" im ioBroker log bringt
            Dieter_P @apollon77 last edited by Dieter_P
            @apollon77 said in Server Cannot start inMem-objects on port 9001:
            Iob custom
            Danke. Der Befehl "custom" fehlt oder ich mach was falsch
            pi@raspberrypi:~ $ iob custom
            iobroker [command]
            Commands:
              iobroker setup                                               Setup ioBroker
              iobroker start [all|<adapter>.<instance>]                    Starts the js-controller or a specified adapter instance
              iobroker stop [<adapter>.<instance>]                         stops the js-controller or a specified adapter instance
              iobroker restart [<adapter>.<instance>]                      Restarts js-controller or a specified adapter instance  [aliases: r]
              iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
              iobroker info                                                Shows the host info
              iobroker logs [<adapter>]                                    Monitor log
              iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
              iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
              iobroker rebuild [<module>]                                  Rebuild all native modules or path
              iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
              iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
              iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
              iobroker update [<repositoryUrl>]                            Update repository and list adapters
              iobroker upgrade                                             Upgrade management
              iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
              iobroker object                                              Object management  [aliases: o]
              iobroker state                                               State management  [aliases: s]
              iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
              iobroker list <type> [<filter>]                              List all entries, like objects
              iobroker chmod <mode> <file>                                 Change file rights
              iobroker chown <user> <group> <file>                         Change file ownership
              iobroker touch <file>                                        Touch file
              iobroker rm <file>                                           Remove file
              iobroker file                                                File management
              iobroker user                                                User commands
              iobroker group                                               group management
              iobroker host <hostname>                                     Set host to given hostname
              iobroker set <adapter>.<instance>                            Change settings of adapter config
              iobroker license <license.file or license.text>              Update license by given file
              iobroker cert                                                Certificate management
              iobroker clean <yes>                                         Clears all objects and states
              iobroker backup                                              Create backup
              iobroker restore <backup name or path>                       Restore a specified backup
              iobroker validate <backup name or path>                      Validate a specified backup
              iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
              iobroker repo [<name>]                                       Show repo information
              iobroker uuid                                                Show uuid of the installation  [aliases: id]
              iobroker unsetup                                             Reset license, installation secret and language
              iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
              iobroker multihost                                           Multihost management
              iobroker compact                                             compact group management
              iobroker plugin                                              Plugin management
              iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
            Options:
              --help  Show help  [boolean]
            pi@raspberrypi:~ $ iob info
            pi@raspberrypi:~ $ iob start
            Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
            pi@raspberrypi:~ $
              Thomas Braun Most Active @Dieter_P last edited by
              @dieter_p
              iobroker setup custom
              D apollon77 2 Replies Last reply Reply Quote 1
                Dieter_P @Thomas Braun last edited by Dieter_P
                @thomas-braun said in Server Cannot start inMem-objects on port 9001:
                pi@raspberrypi:~ $ iobroker setup custom
                Current configuration:
                - Objects database:
                  - Type: jsonl
                  - Host/Unix Socket: 127.0.0.1
                  - Port: 9001
                - States database:
                  - Type: jsonl
                  - Port: 9000
                - Data Directory: ../../iobroker-data/
                Type of objects DB [(j)sonl, (f)ile, (r)edis, ...], default [jsonl]:
                  Thomas Braun Most Active @Dieter_P last edited by Thomas Braun
                  @dieter_p
                  Und wie sieht ein Start im LogFile aus?
                  Mit
                  tail -f /opt/iobroker/log/iobroker.current.log
                  in einer zweiten Session nachschauen.
                    Hab die MAC Adressen mal "angepasst" die sollten hier doch nichts zu beitragen, oder?
                    2022-07-08 10:24:44.819  - info: host.raspberrypi iobroker _restart
                    2022-07-08 10:24:53.399  - info: host.raspberrypi iobroker.js-controller version 4.0.23 js-controller starting
                    2022-07-08 10:24:53.424  - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                    2022-07-08 10:24:53.427  - info: host.raspberrypi hostname: raspberrypi, node: v14.19.3
                    2022-07-08 10:24:53.429  - info: host.raspberrypi ip addresses: 192.168.0.38 2a02:908:13b7:xxxx:xxxx:4331:xxxxx:82ad fe80::xxx:b07e:xxxx:49ba 10.0.1.2
                    2022-07-08 10:25:23.502  - error: host.raspberrypi No connection to databases possible, restart
                    2022-07-08 10:25:23.559  - info: host.raspberrypi iobroker _restart
                      @dieter_p
                      Läuft das im Docker oder sowas?
                        Nein ganz klassisch auf nem RPI2 nur mit SD-Karte und nem ZigbeeStick.
                        Installiert über die Installationsanleitung aus der Doku hier.
                          apollon77 @Thomas Braun last edited by
                          @thomas-braun ÄÄähhmm ja .. danke ...war zu spät gestern Abend am Handy. Sorry
                            @dieter_p Komisch ... zeig mal "ip a" Ausgabe (hoffe das geht da). Ich will mal die Netzwerkinterfaces sehen. Weil erste Vermutung ist das die 127.0.0.1 whyever nicht auf sich selbst auflöst
                              @apollon77
                              Thx. Warum das jetzt auf einmal auftritt kommt mir auch komisch vor. Diese Konfig läuft so unverändert ca seit 1 Jahr inkl. Wireguard
                              pi@raspberrypi:~ $ ip a
                              1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
                                  link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
                                  inet 127.0.0.1/8 scope host lo
                                     valid_lft forever preferred_lft forever
                                  inet6 ::1/128 scope host
                              2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
                                  link/ether b8:27:xx:c2:xx:be brd ff:ff:ff:ff:ff:ff
                                  inet 192.168.0.38/24 brd 192.168.0.255 scope global noprefixroute eth0
                                  inet6 2a02:xxx:13b7:xxxx:64ad:4331:xxxx:82ad/64 scope global dynamic mngtmpaddr noprefixroute
                                     valid_lft 68729sec preferred_lft 25529sec
                                  inet6 fe80::xxx:b07e:xxxx:49ba/64 scope link
                              3: wgclient0: <POINTOPOINT,NOARP,UP,LOWER_UP> mtu 1420 qdisc noqueue state UNKNOWN group default qlen 1000
                                  link/none
                                  inet 10.0.1.2/24 scope global wgclient0
                                Also das ganze funktioniert so. ioBroker startet und startet die DB auf dem Port 9000 und 9001 und die "Listenen" auf der IP (127.0.01 in deinem Fall) die angegeben ist. Sobald die DB gestartet ist versucht ein DB-Client in der Software sich darauf zu verbinden. Und DAS geht bei dir nicht, deswegen sagt der Client nach 30s ... da passt was net. Meine Vermutung ist das er bei diesem "eigentlich lokalen" verbindungsversuch nicht "lokal" rumkommt und daher das Listen auf 127.0.01 es blockt.
                                Auch wenn ich nicht verstehe warum die 127.0.01 nicht geht (vllt hat Thomas noch ne Idee), ändere mal in /opt/iobroker/iobroker-data/iobroker.json in den objects und state Abschnitten die 127.0.01 gegen 0.0.0.0 und versuch dann mal. Damit "Listened" er auf "egal woher die verbindung kommt". Wenn das geht hast Du nen Workaround ...
                                  Vielen Dank auch für Deine für mich verständliche Erklärung! In Object und states angepasst aber leider immer noch der Zugriffsfehler:
                                  pi@raspberrypi:~ $ sudo nano /opt/iobroker/iobroker-data/iobroker.json
                                  pi@raspberrypi:~ $ iob stop
                                  pi@raspberrypi:~ $
                                  • Glasfaser
                                    Glasfaser @Dieter_P last edited by
                                    @dieter_p sagte in Server Cannot start inMem-objects on port 9001:
                                    Auf dem Pi läuft noch ein WireGuard Client
                                    Komischerweise ist er bei dir nicht aufgelistet !?
                                    Kannst du das nochmal zeigen :
                                    sudo netstat -ntlp | grep LISTEN
                                      Dieter_P @Glasfaser last edited by
                                      @glasfaser said in Server Cannot start inMem-objects on port 9001:
                                      pi@raspberrypi:~ $ sudo netstat -ntlp | grep LISTEN
                                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      443/sshd
                                      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      329/cupsd
                                      tcp6       0      0 :::22                   :::*                    LISTEN      443/sshd
                                      tcp6       0      0 ::1:631                 :::*                    LISTEN      329/cupsd
                                      Funktionieren, sollte er da ich auch über den Tunnel aktuell arbeiten kann.
                                      • Glasfaser
                                        Wie hast du denn gerade Zugriff auf deinem Pi !?
                                          Dieter_P @Glasfaser last edited by Dieter_P
                                          @glasfaser
                                          Auf diesen Pi direkt im lokalen Netz über Putty
                                          Wireguard verbindet bei mir 2 Netze. Ich sitze lokal im Netz des IOBroker der aktuell probleme macht. Da gibt es auch Routingtabellen ins andere Netz die aber liegen jeweils auf den Clients und nicht zentral am RPI da das nicht so einfach war, wenn ich das noch richtig zusammen bekomme.
                                          Das aber alles unverändert seit ca. 1 Jahr wo es lief.
                                            @dieter_p Lass iobroker mal bitte aus ... und dann iob status. eil jetzt ists wieder anderer Fehler. Zeig mal den Inhalt von /opt/iobroker/iobroker-data/ bitte
                                            429
                                            81550
