    4. Server Cannot start inMem-objects on port 9001
      apollon77 @Dieter_P last edited by
      @dieter_p Dann bitte "Iob custom" aufrufen und die Ausgabe zeigen. kannst DU mit CTRL-C abbrechen. Und bitte auch zeigen was ein "iob start" im ioBroker log bringt
        Dieter_P @apollon77 last edited by Dieter_P
        @apollon77 said in Server Cannot start inMem-objects on port 9001:
        Iob custom
        Danke. Der Befehl "custom" fehlt oder ich mach was falsch
        pi@raspberrypi:~ $ iob custom
        iobroker [command]
        Commands:
          iobroker setup                                               Setup ioBroker
          iobroker start [all|<adapter>.<instance>]                    Starts the js-controller or a specified adapter instance
          iobroker stop [<adapter>.<instance>]                         stops the js-controller or a specified adapter instance
          iobroker restart [<adapter>.<instance>]                      Restarts js-controller or a specified adapter instance  [aliases: r]
          iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
          iobroker info                                                Shows the host info
          iobroker logs [<adapter>]                                    Monitor log
          iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
          iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
          iobroker rebuild [<module>]                                  Rebuild all native modules or path
          iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
          iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
          iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
          iobroker update [<repositoryUrl>]                            Update repository and list adapters
          iobroker upgrade                                             Upgrade management
          iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
          iobroker object                                              Object management  [aliases: o]
          iobroker state                                               State management  [aliases: s]
          iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
          iobroker list <type> [<filter>]                              List all entries, like objects
          iobroker chmod <mode> <file>                                 Change file rights
          iobroker chown <user> <group> <file>                         Change file ownership
          iobroker touch <file>                                        Touch file
          iobroker rm <file>                                           Remove file
          iobroker file                                                File management
          iobroker user                                                User commands
          iobroker group                                               group management
          iobroker host <hostname>                                     Set host to given hostname
          iobroker set <adapter>.<instance>                            Change settings of adapter config
          iobroker license <license.file or license.text>              Update license by given file
          iobroker cert                                                Certificate management
          iobroker clean <yes>                                         Clears all objects and states
          iobroker backup                                              Create backup
          iobroker restore <backup name or path>                       Restore a specified backup
          iobroker validate <backup name or path>                      Validate a specified backup
          iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
          iobroker repo [<name>]                                       Show repo information
          iobroker uuid                                                Show uuid of the installation  [aliases: id]
          iobroker unsetup                                             Reset license, installation secret and language
          iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
          iobroker multihost                                           Multihost management
          iobroker compact                                             compact group management
          iobroker plugin                                              Plugin management
          iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
        Options:
          --help  Show help  [boolean]
        pi@raspberrypi:~ $ iob info
        No connection to databases possible ...
        pi@raspberrypi:~ $ iob start
        pi@raspberrypi:~ $ iob status
        Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
        pi@raspberrypi:~ $
          Thomas Braun Most Active @Dieter_P last edited by
          @dieter_p
          iobroker setup custom
          D apollon77 2 Replies Last reply Reply Quote 1
            Dieter_P @Thomas Braun last edited by Dieter_P
            @thomas-braun said in Server Cannot start inMem-objects on port 9001:
            pi@raspberrypi:~ $ iobroker setup custom
            Current configuration:
            - Objects database:
              - Type: jsonl
              - Host/Unix Socket: 127.0.0.1
              - Port: 9001
            - States database:
              - Type: jsonl
              - Port: 9000
            - Data Directory: ../../iobroker-data/
            Type of objects DB [(j)sonl, (f)ile, (r)edis, ...], default [jsonl]:
              Thomas Braun Most Active @Dieter_P last edited by Thomas Braun
              @dieter_p
              Und wie sieht ein Start im LogFile aus?
              Mit
              tail -f /opt/iobroker/log/iobroker.current.log
              in einer zweiten Session nachschauen.
                Hab die MAC Adressen mal "angepasst" die sollten hier doch nichts zu beitragen, oder?
                2022-07-08 10:24:44.819  - info: host.raspberrypi iobroker _restart
                2022-07-08 10:24:53.399  - info: host.raspberrypi iobroker.js-controller version 4.0.23 js-controller starting
                2022-07-08 10:24:53.424  - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                2022-07-08 10:24:53.427  - info: host.raspberrypi hostname: raspberrypi, node: v14.19.3
                2022-07-08 10:24:53.429  - info: host.raspberrypi ip addresses: 192.168.0.38 2a02:908:13b7:xxxx:xxxx:4331:xxxxx:82ad fe80::xxx:b07e:xxxx:49ba 10.0.1.2
                2022-07-08 10:25:23.502  - error: host.raspberrypi No connection to databases possible, restart
                2022-07-08 10:25:23.559  - info: host.raspberrypi iobroker _restart
                  @dieter_p
                  Läuft das im Docker oder sowas?
                    Nein ganz klassisch auf nem RPI2 nur mit SD-Karte und nem ZigbeeStick.
                    Installiert über die Installationsanleitung aus der Doku hier.
                      apollon77 @Thomas Braun last edited by
                      @thomas-braun ÄÄähhmm ja .. danke ...war zu spät gestern Abend am Handy. Sorry
                        @dieter_p Komisch ... zeig mal "ip a" Ausgabe (hoffe das geht da). Ich will mal die Netzwerkinterfaces sehen. Weil erste Vermutung ist das die 127.0.0.1 whyever nicht auf sich selbst auflöst
                          @apollon77
                          Thx. Warum das jetzt auf einmal auftritt kommt mir auch komisch vor. Diese Konfig läuft so unverändert ca seit 1 Jahr inkl. Wireguard
                          pi@raspberrypi:~ $ ip a
                          1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
                              link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
                              inet 127.0.0.1/8 scope host lo
                                 valid_lft forever preferred_lft forever
                              inet6 ::1/128 scope host
                          2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
                              link/ether b8:27:xx:c2:xx:be brd ff:ff:ff:ff:ff:ff
                              inet 192.168.0.38/24 brd 192.168.0.255 scope global noprefixroute eth0
                              inet6 2a02:xxx:13b7:xxxx:64ad:4331:xxxx:82ad/64 scope global dynamic mngtmpaddr noprefixroute
                                 valid_lft 68729sec preferred_lft 25529sec
                              inet6 fe80::xxx:b07e:xxxx:49ba/64 scope link
                          3: wgclient0: <POINTOPOINT,NOARP,UP,LOWER_UP> mtu 1420 qdisc noqueue state UNKNOWN group default qlen 1000
                              link/none
                              inet 10.0.1.2/24 scope global wgclient0
                            Also das ganze funktioniert so. ioBroker startet und startet die DB auf dem Port 9000 und 9001 und die "Listenen" auf der IP (127.0.01 in deinem Fall) die angegeben ist. Sobald die DB gestartet ist versucht ein DB-Client in der Software sich darauf zu verbinden. Und DAS geht bei dir nicht, deswegen sagt der Client nach 30s ... da passt was net. Meine Vermutung ist das er bei diesem "eigentlich lokalen" verbindungsversuch nicht "lokal" rumkommt und daher das Listen auf 127.0.01 es blockt.
                            Auch wenn ich nicht verstehe warum die 127.0.01 nicht geht (vllt hat Thomas noch ne Idee), ändere mal in /opt/iobroker/iobroker-data/iobroker.json in den objects und state Abschnitten die 127.0.01 gegen 0.0.0.0 und versuch dann mal. Damit "Listened" er auf "egal woher die verbindung kommt". Wenn das geht hast Du nen Workaround ...
                              Vielen Dank auch für Deine für mich verständliche Erklärung! In Object und states angepasst aber leider immer noch der Zugriffsfehler:
                              pi@raspberrypi:~ $ sudo nano /opt/iobroker/iobroker-data/iobroker.json
                              pi@raspberrypi:~ $ iob stop
                              pi@raspberrypi:~ $
                              • Glasfaser
                                Glasfaser @Dieter_P last edited by
                                @dieter_p sagte in Server Cannot start inMem-objects on port 9001:
                                Auf dem Pi läuft noch ein WireGuard Client
                                Komischerweise ist er bei dir nicht aufgelistet !?
                                Kannst du das nochmal zeigen :
                                sudo netstat -ntlp | grep LISTEN
                                  Dieter_P @Glasfaser last edited by
                                  @glasfaser said in Server Cannot start inMem-objects on port 9001:
                                  pi@raspberrypi:~ $ sudo netstat -ntlp | grep LISTEN
                                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      443/sshd
                                  tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      329/cupsd
                                  tcp6       0      0 :::22                   :::*                    LISTEN      443/sshd
                                  tcp6       0      0 ::1:631                 :::*                    LISTEN      329/cupsd
                                  Funktionieren, sollte er da ich auch über den Tunnel aktuell arbeiten kann.
                                  • Glasfaser
                                    Wie hast du denn gerade Zugriff auf deinem Pi !?
                                      Dieter_P @Glasfaser last edited by Dieter_P
                                      @glasfaser
                                      Auf diesen Pi direkt im lokalen Netz über Putty
                                      Wireguard verbindet bei mir 2 Netze. Ich sitze lokal im Netz des IOBroker der aktuell probleme macht. Da gibt es auch Routingtabellen ins andere Netz die aber liegen jeweils auf den Clients und nicht zentral am RPI da das nicht so einfach war, wenn ich das noch richtig zusammen bekomme.
                                      Das aber alles unverändert seit ca. 1 Jahr wo es lief.
                                        @dieter_p Lass iobroker mal bitte aus ... und dann iob status. eil jetzt ists wieder anderer Fehler. Zeig mal den Inhalt von /opt/iobroker/iobroker-data/ bitte
                                          pi@raspberrypi:/opt/iobroker/iobroker-data $ ls -l
                                          insgesamt 636684
                                          drwxrwxr-x+   2 iobroker iobroker      4096 Mär 11 08:42 backitup
                                          drwxrwxr-x+   2 iobroker iobroker      4096 Jul  7 14:13 backup-objects
                                          drwxrwxr-x+   3 iobroker iobroker      4096 Jan 10 12:58 esphome.0
                                          drwxrwxr-x+  23 iobroker iobroker      4096 Jan  7 13:19 files
                                          drwxrwxr-x+ 253 iobroker iobroker      4096 Jul  7 00:13 history
                                          -rw-rwxr--+   1 iobroker iobroker      5124 Jul  8 11:28 iobroker.json
                                          -rw-rwxr--+   1 iobroker iobroker         3 Jul  7 15:19 notifications.json
                                          -rw-rwxr--+   1 iobroker iobroker   6255293 Mär 11 09:16 objects.json.bak.migrated
                                          -rw-rwxr--+   1 iobroker iobroker 628237946 Jul  7 15:17 objects.jsonl
                                          -rw-rwxr--+   1 iobroker iobroker   6255293 Mär 11 09:16 objects.json.migrated
                                          -rw-rwxr--+   1 iobroker iobroker    458322 Mär 11 09:17 states.json.bak.migrated
                                          -rw-rwxr--+   1 iobroker iobroker         0 Feb  4 19:44 states.json.broken
                                          -rw-rwxr--+   1 iobroker iobroker  10235951 Jul  7 15:19 states.jsonl
                                          -rw-rwxr--+   1 iobroker iobroker    458322 Mär 11 09:17 states.json.migrated
                                          drwxrwxr-x+   2 iobroker iobroker     12288 Jul  7 15:19 zigbee_0
                                            @dieter_p Sieht auch gut aus. So langsam gehen mir die ideen aus. "Iob fix "hattest Du versucht falls rechtemäßig was verbogen ist?
                                            Also : iobroker bitte ausschalten, dann schauen das im Logfile innerhalb von 2-3 Minuten NICHTS rein kommt ... ann nochmals iob status bitte versuchen
                                            Glasfaser D 2 Replies Last reply Reply Quote 0
                                            429
                                            81550
