    4. Sonoff NSPanel
    Sonoff NSPanel
      joBr99 @Armilar last edited by
      Toll ist der Sensor nicht, aber komplett falsch ist er (wenn der adcparam eingestellt ist) auch nicht, allerdings hat da auch jeder nen anderen wert, damit es halbwegs passt ...
      https://github.com/joBr99/nspanel-lovelace-ui/issues/144
      bkbartk created this issue in joBr99/nspanel-lovelace-ui
      closed correct AdcParam #144
        TT-Tom @Armilar last edited by
        @armilar
        Okay ich war nur wegen dem CPU Sensor besorgt. Nutzen wollte ich sie nicht.
        Gruß Tom
        • Wal
          Wal Developer last edited by
           TFT EU STABLE Version   : FlashNextion http://nspanel.pky.eu/lovelace-ui/github/nspanel-v3.1.0.tft
          Gibt es auch eine US nspanel.tft ?
            TT-Tom last edited by TT-Tom
            ich habe eine Frage zu den Hardware Button. Ich habe in der Konsole den String aus dem Script eingegeben. Leider ohne Erfolg. Das sind die Zeilen aus dem Log Tasmota.
            17:40:43.249 CMD: Rule2 on Button1#state do Publish %topic%/%prefix%/RESULT {"CustomRecv":"event,button1"} endon on Button2#state do Publish %topic%/%prefix%/RESULT {"CustomRecv":"event,button2"} endon
            17:40:43.267 RUL: Stored uncompressed, would compress from 177 to 81 (-54%)
            17:40:43.279 MQT: SmartHome/NSPanel_1/stat/RESULT = {"Rule2":{"State":"ON","Once":"OFF","StopOnError":"OFF","Length":177,"Free":334,"Rules":"on Button1#state do Publish %topic%/%prefix%/RESULT {\"CustomRecv\":\"event,button1\"} endon on Button2#state do Publish %topic%/%prefix%/RESULT {\"CustomRecv\":\"event,button2\"} endon"}}
            17:40:56.653 CMD: Rule2 1
            17:40:56.668 MQT: SmartHome/NSPanel_1/stat/RESULT = {"Rule2":{"State":"ON","Once":"OFF","StopOnError":"OFF","Length":177,"Free":334,"Rules":"on Button1#state do Publish %topic%/%prefix%/RESULT {\"CustomRecv\":\"event,button1\"} endon on Button2#state do Publish %topic%/%prefix%/RESULT {\"CustomRecv\":\"event,button2\"} endon"}}
            17:41:00.880 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
            17:41:10.848 RUL: BUTTON1#STATE performs "Publish NSPanel_1/%prefix%/RESULT {"CustomRecv":"event,button1"}"
            17:41:10.862 MQT: NSPanel_1/%prefix%/RESULT = {"CustomRecv":"event,button1"}
            Was mich wundert ist das der %prefix% nicht auf gelöst wird.
            Gruß Tom
            • Armilar
              Armilar Most Active Forum Testing @TT-Tom last edited by Armilar
              @tt-tom sagte in Sonoff NSPanel:
              Gruß Tom
              Mich nicht 😉 . Versuche mal:
              Rule2 on Button1#state do Publish SmartHome/NSPanel_1/tele/RESULT {"CustomRecv":"event,button1"} endon on Button2#state do Publish SmartHome/NSPanel_1/tele/RESULT {"CustomRecv":"event,button2"} endon
              Danach
              Rule2 1
              NSPanel_1 = /%topic%/
              tele = /%prefix%/
              Du kannst das aber auch direkt in "Klarschrift" verwenden. Man wechselt ja nicht täglich die Adapter- oder die MQTT-Einstellungen, sondern in der Regel nur einmal.
                joBr99 @Wal last edited by joBr99
                @wal said in Sonoff NSPanel:
                EU Version: FlashNextion http://nspanel.pky.eu/lovelace-ui/github/nspanel-v3.1.0.tft
                US Landscape Version: FlashNextion http://nspanel.pky.eu/lovelace-ui/github/nspanel-us-l-v3.1.0.tft
                US Portrait Version: FlashNextion http://nspanel.pky.eu/lovelace-ui/github/nspanel-us-p-v3.1.0.tft
                Sollte funktionieren, nur das AutoUpdate ist vermutlich mit dem ioBroker Skript kaputt, da die US Version da nicht implementiert ist.
                Armilar 1 Reply Last reply Reply Quote 1
                • Armilar
                  Armilar Most Active Forum Testing @joBr99 last edited by
                  @jobr99 sagte in Sonoff NSPanel:
                  Die Zeile lässt sich ja schnell tauschen. Denke auch, dass das funktioniert. 👍
                  Wal 1 Reply Last reply Reply Quote 1
                  • Wal
                    Wal Developer @Armilar last edited by Wal
                    @armilar ,
                    hat gefunzt danke.
                    edit: sorry, jobr99 natürlich.
                    Habe es zwar schon mal gelesen, aber doppelt gemoppelt hält länger.
                    Mit "SetOption73 on" kann man die Relais von den Hardwareschaltern entkoppeln und mit zwei neuen Objekten im MQTT Adapter
                    cmnd/POWER1
                    cmnd/POWER2
                    kann man die Relais über MQTT schalten.
                    Edit:
                    Die Buttons kann man mit einer Regel als Objekt einbinden.
                    Rule2
                    on Button1#state do Backlog Publish Wohnzimmer/%topic%/stat/BUTTON1 true;RuleTimer1 1 endon
                    on Button2#state do Backlog Publish Wohnzimmer/%topic%/stat/BUTTON2 true;RuleTimer2 1 endon
                    on Rules#Timer=1 do Publish Wohnzimmer/%topic%/stat/BUTTON1 false endon
                    on Rules#Timer=2 do Publish Wohnzimmer/%topic%/stat/BUTTON2 false endon
                    Rule2 1
                    den Objektpfad eurem NSPanel anpassen.
                    • MichaelF
                      MichaelF last edited by MichaelF
                      ich bin auch grade Fleißig am nachbauen. Hab jetzt soweit alle Fehlermeldungen vom Script weg.
                      Datenpunkte sind da und Funktionieren auch allerdings bekomme ich das Display nicht dazu bewegt mir was anderes außer "Waiting for content" anzuzeigen.
                      Der Datenpunkt CustomSend habe ich via Mqtt Explorer angelegt und er Funktioniert meine ich auch :
                      Gegangen bin ich nach der Anleitung hier im Thread, bis eigentlich der Screensaver angezeigt werden soll das tut er aber nicht.
                      Vielleicht einer ein Tipp wo ich anfangen kann zu suchen ?
                      • Armilar
                        Armilar Most Active Forum Testing @MichaelF last edited by
                        @michaelf
                        wie ist deine Config-Einstellung?
                            panelRecvTopic: "mqtt.3.tele.tasmota_C82F70.RESULT",       //anpassen
                            panelSendTopic: "mqtt.3.cmnd.tasmota_C82F70.CustomSend",   //anpassen
                        so?
                        MichaelF 1 Reply Last reply Reply Quote 0
                        • MichaelF
                          MichaelF @Armilar last edited by
                          @armilar said in Sonoff NSPanel:
                          @michaelf
                          so?
                          Ja sollte passen
                          • Armilar
                            Armilar Most Active Forum Testing @MichaelF last edited by Armilar
                            @michaelf sagte in Sonoff NSPanel:
                            @michaelf
                            so?
                            Ja sollte passen
                            Sieht eigentlich gut aus. Wenn nichts verdreht wurde, dann sollte das Script jetzt zumindest mal jede Minute in den CustomSend - Datenpunkt deiner mqtt.3 - Adapterinstanz schreiben. Und das ist auch schon passiert gem. deines ersten Screenshots
                            Mach mal das Panel stromlos und Stecker wieder rein. Irgendwie hängt es zwischen mqtt.3. und Panel
                            • MichaelF
                              MichaelF @Armilar last edited by MichaelF
                              @michaelf
                              so?
                              Ja sollte passen
                              Also alle Minute kommt :
                              time~19:38
                              Sonst :
                              entityUpd~Büro 2~0|1~delete~~~~~~delete~~~~~~delete~~~~~~delete~~~~~~delete~~~~~~delete~~~~~
                              Muss ich beim Mqtt ein Benutzername und Passwort vergeben?, weil das hab ich nicht.
                              • Armilar
                                @michaelf
                                so?
                                Ja sollte passen
                                time~19:38
                                Sonst :
                                Eben. Das ist auch okay so. Genau das macht das Skript. Die Zeit wird in den CustomSend geschrieben und mqtt transportiert es zum Panel. entityUpd ist auch okay so, solange die Aliase fehlen müsste das Panel zumindest die Überschrift der Seite bringen. Ich sag es mal so - am TS-Skript liegt es nicht...
                                Eher zwischen deinem mqtt.3. Adapter und dem Panel
                                Zeigt das Panel etwas an, wenn du die Nachrichten mit dem MQTT-Explorrer sendest? Obwohl es ist ja faktisch das gleiche wie die Daten vom Skript
                                • MichaelF
                                  @michaelf
                                  so?
                                  Ja sollte passen
                                  time~19:38
                                  Sonst :
                                  Eventuell hier was zu sehen ?
                                    TT-Tom @MichaelF last edited by TT-Tom
                                    @michaelf
                                    Du hast in tasmota Benutzer und Passwort vergeben, diese müssen auch in mqtt3 eingetragen werden
                                    • MichaelF
                                      nein das wird da immer angezeigt.
                                      Habe aber grade mal ein Benutzer und Passwort vergeben, verbindet aber trotzdem nur Waiting for content......
                                        @michaelf
                                        Mqtt3 hat aber jetzt eine Verbindung. Starte das Script nochmal neu
                                        • MichaelF
                                          Hab ich, ändert sich leider nichts.
                                            @michaelf
                                            Fehler gefunden deine Einstellung vom mqtt Server da steht MQTT.0 da muss mqtt.3 rein
                                            Maske zum bekanntgegeben eigener State
                                            1.0k
                                            1548
                                            630909
