    3. Off Topic
    4. Proxmox
    5. Proxmox VM friert ein
      crunchip Forum Testing Most Active @TronLand last edited by
      @tronland das ist ja auch in /opt/iobroker/log
        TronLand @crunchip last edited by
        @crunchip Ahh.. 🙂
        Wer würde denn auch erwarten, dass Logs im generellen Ordner gespeichert werden? 😉
        Ich schaue gleich.
          TronLand @TronLand last edited by
          Da steht ja so gut wie nichts drin für heute. Zumindest nicht bei meiner Einstellung "WARN":
          2022-07-08 00:55:22.377  - warn: hm-rpc.0 (546) State value to set for "hm-rpc.0.000E9569A24263.0.RSSI_DEVICE" has value "128" greater than max "127"
          2022-07-08 05:37:54.296  - warn: hm-rpc.0 (546) State value to set for "hm-rpc.0.00265D898976EF.0.RSSI_DEVICE" has value "128" greater than max "127"
          2022-07-08 05:50:48.584  - warn: hm-rpc.0 (546) State value to set for "hm-rpc.0.0009170993369E.0.RSSI_DEVICE" has value "128" greater than max "127"
          2022-07-08 06:25:41.873  - warn: hm-rpc.0 (546) State value to set for "hm-rpc.0.00201D899333DE.0.RSSI_DEVICE" has value "128" greater than max "127"
          2022-07-08 07:02:08.039  - warn: hm-rpc.0 (546) State value to set for "hm-rpc.0.000313C9933C4A.0.RSSI_DEVICE" has value "128" greater than max "127"
          2022-07-08 18:57:48.511  - warn: node-red.0 (453) 8 Jul 18:57:48 - [warn] Projects disabled : editorTheme.projects.enabled=false
          2022-07-08 18:59:39.472  - warn: host.iobVM "system.host.raspberrypigas" is offline
          2022-07-08 18:59:39.491  - warn: host.iobVM "system.host.ioBroker3" is offline
          2022-07-08 19:30:46.434  - warn: host.iobVM instance system.adapter.mqtt.0 terminated due to SIGTERM
          2022-07-08 19:31:25.243  - warn: node-red.0 (461) 8 Jul 19:31:25 - [warn] Projects disabled : editorTheme.projects.enabled=false
          2022-07-08 19:46:20.828  - warn: host.iobVM "system.host.raspberrypigas" is offline
          2022-07-08 19:46:20.845  - warn: host.iobVM "system.host.ioBroker3" is offline
          2022-07-08 19:55:07.934  - warn: influxdb.0 (494) Store data for 17 points and 0 conflicts
          2022-07-08 19:55:09.360  - warn: host.iobVM instance system.adapter.mqtt.0 terminated due to SIGTERM
          2022-07-08 19:55:15.594  - warn: host.iobVM "system.host.raspberrypigas" is offline
          2022-07-08 19:55:15.608  - warn: host.iobVM "system.host.ioBroker3" is offline
          2022-07-08 19:55:28.203  - warn: node-red.0 (1178) 8 Jul 19:55:28 - [warn] Projects disabled : editorTheme.projects.enabled=false
          Um 18:59 hatte ich ja neu gestartet.
          Glasfaser 2 Replies Last reply Reply Quote 0
          • Glasfaser
            Glasfaser @TronLand last edited by
            @tronland
            Zeige mal was du so hast ... das hast du oben nicht erwähnt !
            Ein/ und Ausgabe davon in Code-Tags </> hier einstellen
            cd /opt/iobroker
            npm ls | grep -E 'github.com|ERR'
            iobroker update -i
            sudo ln -s /usr/bin/node /usr/bin/nodejs
            uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
              TronLand @Glasfaser last edited by
              @glasfaser Der Fehler mit dem ookla repo kommt noch vom Adapter Speedtest.
              admin@iobVM:/opt/iobroker$ npm ls | grep -E 'github.com|ERR'
              ├── iobroker.life360@0.2.17 (git+ssh://git@github.com/migoller/iobroker.life360.git#fb48e5d206f904abaf7a464acb79eb0dfbab52ea)
              admin@iobVM:/opt/iobroker$ iobroker update -i
              Used repository: stable
              Adapter    "admin"        : 5.3.8    , installed 5.3.8
              Adapter    "backitup"     : 2.4.9    , installed 2.4.9
              Adapter    "discovery"    : 3.0.3    , installed 3.0.3
              Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
              Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
              Adapter    "influxdb"     : 2.6.3    , installed 2.6.3
              Adapter    "info"         : 1.9.19   , installed 1.9.19
              Adapter    "javascript"   : 5.7.0    , installed 5.7.0
              Adapter    "mqtt"         : 3.0.6    , installed 3.0.6
              Adapter    "node-red"     : 3.3.1    , installed 3.3.1
              Adapter    "nut"          : 1.5.1    , installed 1.5.1
              Adapter    "pi-hole"      : 1.3.4    , installed 1.3.4
              Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
              Adapter    "wireguard"    : 1.2.1    , installed 1.2.1
              Adapter    "withings"     : 0.0.9    , installed 0.0.7  [Updatable]
              Adapter    "yahka"        : 0.13.1   , installed 0.13.1
              Adapter    "zigbee"       : 1.7.5    , installed 1.7.5
              admin@iobVM:/opt/iobroker$ sudo ln -s /usr/bin/node /usr/bin/nodejs
              [sudo] password for admin:
              ln: failed to create symbolic link '/usr/bin/nodejs': File exists
              admin@iobVM:/opt/iobroker$ uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
              i686
              /usr/bin/nodejs
              /usr/bin/node
              /usr/local/bin/npm
              v12.22.5
              v12.22.5
              8.5.2
              admin
              /opt/iobroker
              Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
              Hit:2 https://deb.nodesource.com/node_16.x bullseye InRelease
              Err:3 https://ookla.bintray.com/debian generic InRelease
                Could not handshake: The TLS connection was non-properly terminated. [IP: 18.196.239.149 443]
              Hit:4 http://ftp.uni-stuttgart.de/debian bullseye InRelease
              Hit:5 https://dl.yarnpkg.com/debian stable InRelease
              Hit:6 http://ftp.uni-stuttgart.de/debian bullseye-updates InRelease
              Hit:7 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
              Reading package lists... Done
              Building dependency tree... Done
              1 package can be upgraded. Run 'apt list --upgradable' to see it.
              W: Failed to fetch https://ookla.bintray.com/debian/dists/generic/InRelease  Could not handshake: The TLS connection was non-properly terminated. [IP: 18.196.239.149 443]
              W: Some index files failed to download. They have been ignored, or old ones used instead.
              nodejs:
                Installed: 12.22.5~dfsg-2~11u1
                Candidate: 12.22.5~dfsg-2~11u1
                Version table:
               *** 12.22.5~dfsg-2~11u1 500
                      500 http://ftp.uni-stuttgart.de/debian bullseye/main i386 Packages
                      500 http://security.debian.org/debian-security bullseye-security/main i386 Packages
                      100 /var/lib/dpkg/status
              Thomas Braun arteck 2 Replies Last reply Reply Quote 0
              • Glasfaser
                Glasfaser last edited by Glasfaser
                @tronland sagte in Proxmox VM friert ein:
                /usr/bin/nodejs
                usr/bin/node
                usr/local/bin/npm
                v12.22.5
                v12.22.5
                8.5.2
                und da ist der Fehler ...
                wie hast du das denn gemacht , da ist ja alles durcheinander
                  @glasfaser Wie meinst du das?
                  • Glasfaser
                    Glasfaser @TronLand last edited by Glasfaser
                    @tronland
                    das gehört nicht in local nur in bin und die 12 gehört nicht zu NPM 8
                    • Glasfaser
                      @tronland
                      Schau in die Signatur von @thomas-braun , wie man das behebt .
                      Ist nur wieder verwunderlich wie man zu local kommt .
                      wie hast du das gemacht !?
                        @glasfaser: Hmm... Ich hatte vor langer Zeit mal das Problem, dass sich nodejs nicht aktualisieren ließ. Es kam immer, dass die neueste Version schon installiert wurde. Dann ein paar mal iob stop, iob update self , usw.
                        Manuell hab' ich nichts gemacht.
                        Glasfaser Thomas Braun 2 Replies Last reply Reply Quote 0
                          Thomas Braun Most Active @TronLand last edited by
                          i386
                          Die VM ist auf die falsche Architektur eingestellt. Das sollte eine 64-bit-Umgebung sein. Dann würde auch node16 installierbar sein.
                          Die Zeile mit dem
                          Eintrag kannst du löschen, die Quelle gibt es nicht mehr.
                          • Glasfaser
                            Die Befehle haben aber nichts mit Nodejs / NPM zu tun , bzw. das es im local verzeichniss kommt !
                              Doch, npm reingepflügt.
                              • Glasfaser
                                sind diese beiden auch so struppelig !?
                                  TronLand @Thomas Braun last edited by
                                  @thomas-braun Oh Mist. Wie komm' ich denn auf die 32bit Version? Muss wohl verrutscht sein, als ich das Image ausgewählt habe.
                                  Ich Idiot.
                                  Okay, ihr habt mir superschnell geholfen! Vielen vielen Dank!!!!!
                                  Ich denke, ich verbringe den Abend mit dem Aufsetzen einer neuen VM und dem Einspielen meiner Backups 🙂
                                  Ich kann mich echt nicht erinnern, dass ich npm installiert habe. Aber ist ja so.
                                  Nochmals vielen vielen Dank für Eure Hilfe!!!
                                  Viele Grüße aus Heidelberg!
                                  Michael
                                    @glasfaser Eigentlich nicht. Das sind beides Raspberry Pi's. Hab' mit denen eigentlich keine Probleme.
                                    Aber auf denen läuft nicht nicht die 64bit Version.
                                    • Glasfaser
                                      Das wäre auch noch schneller gelaufen ... wenn du schon oben im Start-Thread mehr Infos gehabt hättest .
                                      https://forum.iobroker.net/topic/51555/hinweise-für-gute-forenbeiträge
                                      T Thomas Braun 2 Replies Last reply Reply Quote 0
                                        @glasfaser Ja, weiss ich jetzt auch. Nochmals sorry dafür.
                                        • Glasfaser
                                          würde es aber trotzdem mal prüfen mit der Anfrage die ich oben gestellt habe !
                                            Bei den arm-basierten Geräten ist das (noch) nicht weiter wild, da wird noch das allermeiste auch für 32bit gebacken. i386 wird dahingegen schon geraume Zeit nicht mehr voll bedient.
                                            81.1k
                                            186
                                            29424
