    3. Off Topic
    4. Proxmox
    5. Proxmox VM friert ein
      TronLand @crunchip last edited by
      @crunchip Ahh.. 🙂
      Wer würde denn auch erwarten, dass Logs im generellen Ordner gespeichert werden? 😉
      Ich schaue gleich.
        TronLand @TronLand last edited by
        Da steht ja so gut wie nichts drin für heute. Zumindest nicht bei meiner Einstellung "WARN":
        2022-07-08 00:55:22.377  - warn: hm-rpc.0 (546) State value to set for "hm-rpc.0.000E9569A24263.0.RSSI_DEVICE" has value "128" greater than max "127"
        2022-07-08 05:37:54.296  - warn: hm-rpc.0 (546) State value to set for "hm-rpc.0.00265D898976EF.0.RSSI_DEVICE" has value "128" greater than max "127"
        2022-07-08 05:50:48.584  - warn: hm-rpc.0 (546) State value to set for "hm-rpc.0.0009170993369E.0.RSSI_DEVICE" has value "128" greater than max "127"
        2022-07-08 06:25:41.873  - warn: hm-rpc.0 (546) State value to set for "hm-rpc.0.00201D899333DE.0.RSSI_DEVICE" has value "128" greater than max "127"
        2022-07-08 07:02:08.039  - warn: hm-rpc.0 (546) State value to set for "hm-rpc.0.000313C9933C4A.0.RSSI_DEVICE" has value "128" greater than max "127"
        2022-07-08 18:57:48.511  - warn: node-red.0 (453) 8 Jul 18:57:48 - [warn] Projects disabled : editorTheme.projects.enabled=false
        2022-07-08 18:59:39.472  - warn: host.iobVM "system.host.raspberrypigas" is offline
        2022-07-08 18:59:39.491  - warn: host.iobVM "system.host.ioBroker3" is offline
        2022-07-08 19:30:46.434  - warn: host.iobVM instance system.adapter.mqtt.0 terminated due to SIGTERM
        2022-07-08 19:31:25.243  - warn: node-red.0 (461) 8 Jul 19:31:25 - [warn] Projects disabled : editorTheme.projects.enabled=false
        2022-07-08 19:46:20.828  - warn: host.iobVM "system.host.raspberrypigas" is offline
        2022-07-08 19:46:20.845  - warn: host.iobVM "system.host.ioBroker3" is offline
        2022-07-08 19:55:07.934  - warn: influxdb.0 (494) Store data for 17 points and 0 conflicts
        2022-07-08 19:55:09.360  - warn: host.iobVM instance system.adapter.mqtt.0 terminated due to SIGTERM
        2022-07-08 19:55:15.594  - warn: host.iobVM "system.host.raspberrypigas" is offline
        2022-07-08 19:55:15.608  - warn: host.iobVM "system.host.ioBroker3" is offline
        2022-07-08 19:55:28.203  - warn: node-red.0 (1178) 8 Jul 19:55:28 - [warn] Projects disabled : editorTheme.projects.enabled=false
        Um 18:59 hatte ich ja neu gestartet.
        Glasfaser 2 Replies Last reply Reply Quote 0
        • Glasfaser
          Glasfaser @TronLand last edited by
          @tronland
          Zeige mal was du so hast ... das hast du oben nicht erwähnt !
          Ein/ und Ausgabe davon in Code-Tags </> hier einstellen
          cd /opt/iobroker
          npm ls | grep -E 'github.com|ERR'
          iobroker update -i
          sudo ln -s /usr/bin/node /usr/bin/nodejs
          uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
            TronLand @Glasfaser last edited by
            @glasfaser Der Fehler mit dem ookla repo kommt noch vom Adapter Speedtest.
            admin@iobVM:/opt/iobroker$ npm ls | grep -E 'github.com|ERR'
            ├── iobroker.life360@0.2.17 (git+ssh://git@github.com/migoller/iobroker.life360.git#fb48e5d206f904abaf7a464acb79eb0dfbab52ea)
            admin@iobVM:/opt/iobroker$ iobroker update -i
            Used repository: stable
            Adapter    "admin"        : 5.3.8    , installed 5.3.8
            Adapter    "backitup"     : 2.4.9    , installed 2.4.9
            Adapter    "discovery"    : 3.0.3    , installed 3.0.3
            Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
            Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
            Adapter    "influxdb"     : 2.6.3    , installed 2.6.3
            Adapter    "info"         : 1.9.19   , installed 1.9.19
            Adapter    "javascript"   : 5.7.0    , installed 5.7.0
            Adapter    "mqtt"         : 3.0.6    , installed 3.0.6
            Adapter    "node-red"     : 3.3.1    , installed 3.3.1
            Adapter    "nut"          : 1.5.1    , installed 1.5.1
            Adapter    "pi-hole"      : 1.3.4    , installed 1.3.4
            Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
            Adapter    "wireguard"    : 1.2.1    , installed 1.2.1
            Adapter    "withings"     : 0.0.9    , installed 0.0.7  [Updatable]
            Adapter    "yahka"        : 0.13.1   , installed 0.13.1
            Adapter    "zigbee"       : 1.7.5    , installed 1.7.5
            admin@iobVM:/opt/iobroker$ sudo ln -s /usr/bin/node /usr/bin/nodejs
            [sudo] password for admin:
            ln: failed to create symbolic link '/usr/bin/nodejs': File exists
            admin@iobVM:/opt/iobroker$ uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
            i686
            /usr/bin/nodejs
            /usr/bin/node
            /usr/local/bin/npm
            v12.22.5
            v12.22.5
            8.5.2
            admin
            /opt/iobroker
            Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
            Hit:2 https://deb.nodesource.com/node_16.x bullseye InRelease
            Err:3 https://ookla.bintray.com/debian generic InRelease
              Could not handshake: The TLS connection was non-properly terminated. [IP: 18.196.239.149 443]
            Hit:4 http://ftp.uni-stuttgart.de/debian bullseye InRelease
            Hit:5 https://dl.yarnpkg.com/debian stable InRelease
            Hit:6 http://ftp.uni-stuttgart.de/debian bullseye-updates InRelease
            Hit:7 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
            Reading package lists... Done
            Building dependency tree... Done
            1 package can be upgraded. Run 'apt list --upgradable' to see it.
            W: Failed to fetch https://ookla.bintray.com/debian/dists/generic/InRelease  Could not handshake: The TLS connection was non-properly terminated. [IP: 18.196.239.149 443]
            W: Some index files failed to download. They have been ignored, or old ones used instead.
            nodejs:
              Installed: 12.22.5~dfsg-2~11u1
              Candidate: 12.22.5~dfsg-2~11u1
              Version table:
             *** 12.22.5~dfsg-2~11u1 500
                    500 http://ftp.uni-stuttgart.de/debian bullseye/main i386 Packages
                    500 http://security.debian.org/debian-security bullseye-security/main i386 Packages
                    100 /var/lib/dpkg/status
            Thomas Braun arteck 2 Replies Last reply Reply Quote 0
            • Glasfaser
              Glasfaser last edited by Glasfaser
              @tronland sagte in Proxmox VM friert ein:
              /usr/bin/nodejs
              usr/bin/node
              usr/local/bin/npm
              v12.22.5
              v12.22.5
              8.5.2
              und da ist der Fehler ...
              wie hast du das denn gemacht , da ist ja alles durcheinander
                @glasfaser Wie meinst du das?
                • Glasfaser
                  Glasfaser @TronLand last edited by Glasfaser
                  @tronland
                  das gehört nicht in local nur in bin und die 12 gehört nicht zu NPM 8
                  • Glasfaser
                    @tronland
                    Schau in die Signatur von @thomas-braun , wie man das behebt .
                    Ist nur wieder verwunderlich wie man zu local kommt .
                    wie hast du das gemacht !?
                      @glasfaser: Hmm... Ich hatte vor langer Zeit mal das Problem, dass sich nodejs nicht aktualisieren ließ. Es kam immer, dass die neueste Version schon installiert wurde. Dann ein paar mal iob stop, iob update self , usw.
                      Manuell hab' ich nichts gemacht.
                      Glasfaser Thomas Braun 2 Replies Last reply Reply Quote 0
                        Thomas Braun Most Active @TronLand last edited by
                        i386
                        Die VM ist auf die falsche Architektur eingestellt. Das sollte eine 64-bit-Umgebung sein. Dann würde auch node16 installierbar sein.
                        Die Zeile mit dem
                        Eintrag kannst du löschen, die Quelle gibt es nicht mehr.
                        • Glasfaser
                          Die Befehle haben aber nichts mit Nodejs / NPM zu tun , bzw. das es im local verzeichniss kommt !
                            Doch, npm reingepflügt.
                            • Glasfaser
                              sind diese beiden auch so struppelig !?
                                TronLand @Thomas Braun last edited by
                                @thomas-braun Oh Mist. Wie komm' ich denn auf die 32bit Version? Muss wohl verrutscht sein, als ich das Image ausgewählt habe.
                                Ich Idiot.
                                Okay, ihr habt mir superschnell geholfen! Vielen vielen Dank!!!!!
                                Ich denke, ich verbringe den Abend mit dem Aufsetzen einer neuen VM und dem Einspielen meiner Backups 🙂
                                Ich kann mich echt nicht erinnern, dass ich npm installiert habe. Aber ist ja so.
                                Nochmals vielen vielen Dank für Eure Hilfe!!!
                                Viele Grüße aus Heidelberg!
                                Michael
                                  @glasfaser Eigentlich nicht. Das sind beides Raspberry Pi's. Hab' mit denen eigentlich keine Probleme.
                                  Aber auf denen läuft nicht nicht die 64bit Version.
                                  • Glasfaser
                                    Das wäre auch noch schneller gelaufen ... wenn du schon oben im Start-Thread mehr Infos gehabt hättest .
                                    https://forum.iobroker.net/topic/51555/hinweise-für-gute-forenbeiträge
                                    T Thomas Braun 2 Replies Last reply Reply Quote 0
                                      @glasfaser Ja, weiss ich jetzt auch. Nochmals sorry dafür.
                                      • Glasfaser
                                        würde es aber trotzdem mal prüfen mit der Anfrage die ich oben gestellt habe !
                                          Bei den arm-basierten Geräten ist das (noch) nicht weiter wild, da wird noch das allermeiste auch für 32bit gebacken. i386 wird dahingegen schon geraume Zeit nicht mehr voll bedient.
                                            Thomas Braun Most Active @Glasfaser last edited by
                                            @glasfaser
                                            Im dritten Posting stand es drin:
                                            Debian VM Linux iobVM 5.10.0-14-686-pae
                                            Habs aber auch überlesen.
                                            Glasfaser 1 Reply Last reply Reply Quote 1
                                            81.1k
                                            186
                                            29419
