    3. Entwicklung
    4. Adapter: broadlink2
    Adapter: broadlink2
    • BananaJoe
      BananaJoe Most Active @schubs2802 last edited by BananaJoe
      @schubs2802 ich nehme an du steuerst die Datenpunkte mit wahr an?
      Du kannst auch den _SendCode Datenpunkt nehmen, müsste folgender sein:
      broadlink2.0.RM:RMPROPLUS-63-cc-59._SendCode
      Und dort den Code reinschreiben, also den Namen des Datenpunktes des IR-Codes ohne den Pfad davor.
      CODE_b2002a030a130b120a130a130a130a130a130a13a61414090a1314090a130a130a13140914090a13140914080b1314080b1309130b130a120b120b1215080b131409140815081508150914080a13150815080a1315080a130a130a130a1315080a130a130a130a130a130a130a130a130a130a130a130a130a130a130a1315080a13150815080a13150815081508150815081508150715a3a61415080a1314090a130a130a13140915080a13140915080a1314090a130a130a130a130a130a1314090a131508140914091409140914090a13140914080b1314090a1309140a13091414080a130a1409130b120a130a1409130a130b120b120a1409130b120a14091315080a14140815080a13150815091409140914091409140814a4a6131509091414080a130a130b13140815080a13150815080a1315080a130a130a130a130a130a1414080a141409140815081509140815080a13150815080a1414080a130a130a130a1414080b120a130b120a140a120a130a130a130b120a130a130a130b120a130a1315080a13150815080a13150815081508150815081509140715a4a51514080a1315080a130a130a13150815080a13150815080a1315080a130a130a130a130a130a1315080a131509140815081508150815080a13150914080a1315080a130a130a130a1315080a130a130a130a130a130a130a130a130a130a130a130a130a130a130a1315080a13150815080a13150815081508150815081508150715a4a51415080a1315080a130a130a13150815080a13150815080a1315080a130a130a130a130a130a1315080a131508150815081508150815080a13150815080a1315080a130a130a130a1315080a130a130a130a130a130a130a130a130a130a130a130a130a130a130a1315080a13150815080a13150815081508150815081509140814a4a51415080a1315080a130a130a14140815080a13150815080a1315080a130a130a130a130a130a1315080a131508150815081508150914080a13150815080a1315080a130a1409130a1315080a130a130a130a130a130a130a130a130a130a130a130a130a130a130a1315080a13150815080a131508150815081508150815081507150005dc0000000000000000000000000000
      Wobei deine schon extrem lang aussehen .... 1.661 Zeichen lang, wow. Meine sind so 180 bis 200 Zeichen lang
        schubs2802 @BananaJoe last edited by
        @bananajoe Danke für deine Hinweise. Werde es mal versuchen umzusetzen.
        Was die länge der Codes angeht, keine Ahnung warum die so lang sind.
        • BananaJoe
          @schubs2802 diese Methode hat auch den Vorteil das man die Codes problemlos auch auf einem anderen Broadlink Gerät senden kann ohne es vorher anlernen zu müssen.
          Ich die Codes immer direkt in meinen Skripten hinterlegt.
          So könnte man sich auch austauschen_ "hier, Code für Sony-Fernseher Model X, Lautstärke auf Mute"
          Eventuell kannst du ja mal testweise einen Code neu anlernen (er macht ja immer einen neuen Datenpunkt) und schauen ob die immer noch so lang werden. Kann auch einfach bei deinem Modell so sein bzw. die Fernbedienung sendet Dauer und keinen kurzen Impuls. Wenn es funktioniert ist das eher von theoretischem Interesse.
            @BananaJoe hab es jetzt so eingerichtet, allerdings erst einmal mit den alten (langen) Codes. Die Ansteuerung klappt schon mal. Mal scheuen, ob es morgen auch noch läuft. Wenn ich einen neuen Code angelernt habe, geb ich noch mal Info 😉
              schubs2802 last edited by schubs2802
              das scheint also nicht die Ursache gewesen zu sein. Meldung kam heute morgen wieder und erst nach einem Adapterneustart ließen sich die Rollos bewegen ihren Dienst zu tun. 😞
              broadlink2.0
              2022-07-09 06:51:03.046	warn	stateChange error invalid id type: RM:RMPROPLUS-63-cc-59._SendCode=RM:RMPROPLUS-63-cc-59 {val: 'CODE_b2002a030a130b120a130a130a130a130a130a13a61414090a1314090a130a130a13140914090a13140914080b1314080b1309130b130a120b120b1215080b131409140815081508150914080a13150815080a1315080a130a130a130a1315080a130a130a130a130a130a130a130a130a130a130a130a130a130a130a1315080a13150815080a13150815081508150815081508150715a3a61415080a1314090a130a130a13140915080a13140915080a1314090a130a130a130a130a130a1314090a131508140914091409140914090a13140914080b1314090a1309140a13091414080a130a1409130b120a130a1409130a130b120b120a1409130b120a14091315080a14140815080a13150815091409140914091409140814a4a6131509091414080a130a130b13140815080a13150815080a1315080a130a130a130a130a130a1414080a141409140815081509140815080a13150815080a1414080a130a130a130a1414080b120a130b120a140a120a130a130a130b120a130a130a130b120a130a1315080a13150815080a13150815081508150815081509140715a4a51514080a1315080a130a130a13150815080a13150815080a1315080a130a130a130a130a130a1315080a131509140815081508150815080a13150914080a1315080a130a130a130a1315080a130a130a130a130a130a130a130a130a130a130a130a130a130a130a1315080a13150815080a13150815081508150815081508150715a4a51415080a1315080a130a130a13150815080a13150815080a1315080a130a130a130a130a130a1315080a131508150815081508150815080a13150815080a1315080a130a130a130a1315080a130a130a130a130a130a130a130a130a130a130a130a130a130a130a1315080a13150815080a13150815081508150815081509140814a4a51415080a1315080a130a130a14140815080a13150815080a1315080a130a130a130a130a130a1315080a131508150815081508150914080a13150815080a1315080a130a1409130a1315080a130a130a130a130a130a130a130a130a130a130a130a130a130a130a1315080a13150815080a131508150815081508150815081507150005dc0000000000000000000000000000',ack: false,ts: 1657342263030,q: 0,c: 'script.js.common.Steuerungen.Rollos_Wohnzimmer',from: 'system.adapter.javascript.0',user: 'system.user.admin',lc: 1657342263030}
              broadlink2.0
              2022-07-09 06:51:03.043	warn	stateChange error invalid id type: RM:RMPROPLUS-63-cc-59._SendCode=RM:RMPROPLUS-63-cc-59 {val: 'CODE_b2002a030a13091409130b120b120b1309130a14a51414090a1315070b130a130a13140914080b13140914080b1314080a130b1309130a130a130a1315080a131508150815081508150815080a13150815080a1315080a130a130a130a130a1315080a130a130a130a130a130a130a130a130a130a130a120b130a130a1314090a13140914090a1314091409140914080a141409140815a3a61414080a1315080a130a130a14140815080a13150815080a1315080a130a130a130a130a130a1315080a131508150815081508150815080a13140915080a1314090a130a130a130a130a1314080b130a130a130a130a130a130a130a130a130914091409130b13091414080a13150914080b1215081508150815080b121508150814a4a51415080a1414080a130a130a13150815080a13150815080a1315080a130a130a130a130a130a1315080a131508150814091508150815080a13140915080a1314090a130a130a130a130a1314090a130a130a130a130a130a130a130a130a130a130a130a130a130a1314090a13140914090a1314091409140914090a131409140814a4a61414090a1314080b120a140914140914080a14140914080a1414080a130a130b120b120b120a1414080a131508150815091408150815080a13150815080a1315080a130a130a130a130a1315080a130a130a130a130a130a130a130a130a130a130a130a130a130a1315080a13150815080a1315081508150815080a141408150814a4a51415080a1414080a130a130a13150815080a13150815080a1315080a130a130a130a130a130a1315080a131508150815081508150815080a13150815080a1315080a130a130a130a130a1315080a130a130a130a130a130a130a130a130a130a130a130a130a130a1315080a13150815080a1315081409140914090a131409150715a3a61415080a1315080a130a130a13150814090a13150815080a1314090a130a130a130a130a130a1314090a131409140914091508140914090a13140914080b1314090a130a130a130a120b1314090a130a120b120b120b130a13091409140a1309130a140a130914091414080b13140914080a1315091409140815080a1315091407150005dc0000000000000000000000000000',ack: false,ts: 1657342263030,q: 0,c: 'script.js.common.Steuerungen.Rollos_Wohnzimmer',from: 'system.adapter.javascript.0',user: 'system.user.admin',lc: 1657342263030}
              broadlink2.0
              2022-07-09 06:51:03.040	warn	stateChange error invalid id type: RM:RMPROPLUS-63-cc-59._SendCode=RM:RMPROPLUS-63-cc-59 {val: 'CODE_b2002a030a130a130a130a130a130a130a130a13a51415080a1315080a130a130a13150815080a13150815080a1315080a130a130a130a130a130a1315080a131409140914091409140914080b13140914090a1314080b130a120b120a140914091414080a130a130a130a130a130a130a130a130a130a130a130a130a1315080a13150815080a1315081508150815080a130a13150715a4a51415080a1315080a130a130a13140914090a13140914090a1315080a130a130a130a130a130a1314090a131409140914091409140914090a13140914080b1314080a140a130914091409130b1215080b120b120a130b120a130b120a130a130b120b120a130b120b1314090914140815080a1315081508150815080a130a13150715a4a51415080a1315080a130a130a13150914080a13150815080a1315080a130a130a130a130a130a1315080a131508150815081508150815080a13150815080a1315080a130a130a130a130a130a1315080a130a130a130a130a130a130a130a130a130a130a130a120b1314090a13140914090a1314091409140914080b130a13140815a3a61414090a1215080b130a120a14140815080a13150815080a1414080a130a130a130a1409130a1315080a131508150815081508150815080a13150815080a1414080a130a130a130a130a130a1315080a130a130a130a130a130a130a130a130a130a130a130a130a1315080a13150815080a1315081508140915080a130a13150715a3a61414090a1315080a130a130a13140915080a13140914090a1315080a130a130a130a130a130a1314090a131409140914091409140914090a13140914090a1314080a14091409130b120a130a1414080b120a130a130a130a140a120a130a130a130a130a130b120a1315080a13150815080b1215081508150815080a130a13150715a4a51415080a1315080a130a130a13150815080a13150815080a1315080a130a130a130a130a130a1315080a131409150814091409140915080a13140914090a1314090a120b130a130a130a130a1314080b120b120b120b1309130b130a130a130a120b1309130b120b1215080b12150914080b1215091408150815080a130a131507150005dc0000000000000000000000000000',ack: false,ts: 1657342263029,q: 0,c: 'script.js.common.Steuerungen.Rollos_Wohnzimmer',from: 'system.adapter.javascript.0',user: 'system.user.admin',lc: 1657342263029}
              broadlink2.0
              2022-07-09 06:51:00.046	warn	stateChange error invalid id type: RM:RMPROPLUS-63-cc-59._SendCode=RM:RMPROPLUS-63-cc-59 {val: 'CODE_b2002a0309130a130a130a130a130a130a130a13a61414080a1414080a1409140913150914080a14140914080a1315080a130a130a130a130a130a1315080a131508150815081508150815080a13150815080a1315080a130a130a130a130a130a130a1314090a130a130a130a130a130a1309130b120b120a130b13091414080a14140914080a1315081508150815080a130a130a1215a4a51415080a1315080a130a130a13150815080a13150815080a1315080a130a130a130a130a130a1314090a131409140914091409140914090a13140914080a1414080b120b120b120b120b120a130b1215080b120a1409130b120b120a130b120a130b120a130a130a1315080a13150815080a1315081508150815080a130a130a1215a4a51415080a1315080a130a130a13150815080a13150815080a1315080a130a130a130a130a130a1314090a131409150814091409140914090a13140914090a1315080a120b120b120b130a130a120b1314080b120b130a130a130a120b120b130a120b120a130b13091414080a1315091409091414091409140914080a130b120a1315a3a61414080a1414080a130a130a13150815090913150815080a1414080a130b120a130a130a130a1414080b131409140815081508150815080a13150815080a1414080b120a130a130a130a130a130a1315080a130a130a130a130a130a130a130a130a130a130a130a1315080a13150815080a1315081508150815080a130a130a1215a4a51415080a1315080a130a130a13150814090a13140915080a1314080b130a130a130a130a130a1314080b131409140914091409140914080b1314091409091315080a140a1309140a120a130a140a1314090a120a130a130a130a130b120b120a130b120b120b120a1315080a13150815080a1315081508150815080a130a130a1215a4a51415080a1315080a130a130a13150815080a13140915080a1315080a130a130a130a130a130a1315070b131409140914091409140914080b1315081409091414080b120b120b120a130b120a130a1315080a130b120a130a130a130a130a130a130a130a130a130a1315080a13150815080a1315081508150815080a130a130a12150005dc0000000000000000000000000000',ack: false,ts: 1657342260028,q: 0,c: 'script.js.common.Steuerungen.Rollos_Wohnzimmer',from: 'system.adapter.javascript.0',user: 'system.user.admin',lc: 1657342260028}``````
              code_text
              Ich werde noch bekloppt 😉
                crunchip Forum Testing Most Active @schubs2802 last edited by
                @schubs2802 sagte in Adapter: broadlink2:
                Ich glaube es war nach dem "großen" Iobroker Update. Dann bekomme ich Fehlermeldungen
                Nach welchem Update?
                error invalid id
                Denke das hat nichts damit zu tun wie gesendet wird, sondern wer, wurde eventuell der broadlink umbenannt bzw wie sind deine Einstellungen?
                  Von V3 auf V4.
                  Umbenannt wurde der Broadlink nicht. Im Gegenteil Adapter deinstalliert, alle alten Objekte gelöscht, Adapter neu installiert und Codes im IOB neu angelernt. Das sogar 2x mit 2 verschiedenen Geräten Gleichen Typs.
                  Die Einstellungen sind wie folgt:
                    Der Adapter läuft den ganzen Tag problemlos durch. Am nächsten Morgen die Meldungen und wenn ich dann den Adapter unter Instanzen neu starte, läuft er wieder.
                      crunchip Forum Testing Most Active @schubs2802 last edited by crunchip
                      @schubs2802 kommt vllt etwas im log in der Nacht?
                      Ich verwende keine Szenen aus dem Adapter Hab das alles via blockly laufen.
                      Weil du geschrieben hattest...läuft schon 3 Jahre, beim Wechsel der Adapter Version auf 2.x musste man doch damals den Broadlink umbennen, bzw wurde dieser ab da anders im Netzwerk erkannt, daher die Frage.
                      Eventuell mal Ip Interface eintragen. In deinem Fall
                      192.168.178.0/24
                        Die Szenen verwende ich aktuell auch nicht.
                        Wann war den der Adapterwechsel? Habe das nicht mehr so auf dem Schirm und definitiv nichts umbenannt. Allerdings wurde der Adapter ja de- und installiert und das war die V 2.x.
                        IP Interface habe ich gerade probiert. Dann kommt folgender Fehler:
                        broadlink2.0
                        2022-07-09 09:28:09.063	warn	RMP, RM:RMPROPLUS-63-cc-59, 78:0f:77:63:cc:59, 192.168.178.32, 智能遥控, fw=38 still waiting for previous command 1148!```
                        code_text
                          Glaub Ende 2019
                          Vllt hängt das Problem auch mit der Firmware zusammen. Hab da nur im Hinterkopf das der 4er da bisserl Probleme bereitet.
                          Vllt stimmt auch der Eintrag Gerätetyp nicht, gibt da auch mehrere Varianten.
                            Soweit ich mich erinnern kann, tritt das Problem seit Umstellung auf die 4er IOB Version auf. Was die Gerätetypeneintragung angeht, habe ich auch schon alle Varianten aus dem Forum versucht 😞 ohne Verbesserung.
                              @schubs2802 wenn du den Gerätetyp aus der Instanz löscht und die Instanz neu startest, was wird denn als Typ im log angezeigt?
                              Die Firmware ist aber auch recht alt, bin mir nicht sicher, aber aktuell ist v56 oder so
                                Das ist die log nach dem Neustart des Adapters:
                                broadlink2.0
                                2022-07-09 12:34:40.958	info	found macs: 78:0f:77:63:cc:59
                                broadlink2.0
                                2022-07-09 12:34:40.958	info	broadlink2.0 started and found 1 devices named RM:RMPROPLUS-63-cc-59
                                broadlink2.0
                                2022-07-09 12:34:40.957	info	Poll every 30 secods.
                                broadlink2.0
                                2022-07-09 12:34:36.494	info	discover [ '192.168.178.32' ] from 0.0.0.0:56749
                                broadlink2.0
                                2022-07-09 12:34:36.490	info	interface to be used: { netmaskBits: 24, address: '192.168.178.49/24', addrs: [ 192, 168, 178, 49 ], cidr: '192.168.178.49/24', bcaddr: '192.168.178.255' }:
                                broadlink2.0
                                2022-07-09 12:34:31.447	info	Device RM:RMPROPLUS-63-cc-59 detected: address=192.168.178.32, mac=78:0f:77:63:cc:59, typ=RMP, id=0x279d devtype=RM3 Pro Plus
                                broadlink2.0
                                2022-07-09 12:34:31.265	info	discover [ '192.168.178.255', '255.255.255.255', '224.0.0.251' ] from 0.0.0.0:54546
                                broadlink2.0
                                2022-07-09 12:34:31.263	info	interface to be used: { netmaskBits: 24, address: '192.168.178.49/24', addrs: [ 192, 168, 178, 49 ], cidr: '192.168.178.49/24', bcaddr: '192.168.178.255'}:
                                broadlink2.0
                                2022-07-09 12:34:31.234	info	Discover Broadlink devices for 10sec on broadlink2.0
                                broadlink2.0
                                2022-07-09 12:34:31.231	info	macObjects: [ '78:0f:77:63:cc:59' ]
                                broadlink2.0
                                2022-07-09 12:34:31.229	info	interface to be used: { netmaskBits: 24, address: '192.168.178.49/24', addrs: [ 192, 168, 178, 49 ], cidr: '192.168.178.49/24', bcaddr: '192.168.178.255'}:
                                broadlink2.0
                                2022-07-09 12:34:31.225	info	broadlink2 has 1 old devices!
                                broadlink2.0
                                2022-07-09 12:34:31.224	info	Devices to rename:
                                broadlink2.0
                                2022-07-09 12:34:31.223	info	Devices to add:
                                broadlink2.0
                                2022-07-09 12:34:31.223	info	Scanning additional IP's: 192.168.178.32
                                broadlink2.0
                                2022-07-09 12:34:31.219	info	broadlink2 initialization started...
                                broadlink2.0
                                2022-07-09 12:34:30.994	info	starting. Version 2.1.5 in /opt/iobroker/node_modules/iobroker.broadlink2, node: v14.19.1, js-controller: 4.0.23
                                host.schubiioBroker
                                2022-07-09 12:34:28.517	info	instance system.adapter.broadlink2.0 started with pid 8670```
                                code_text
                                  Ich nutze den Broadlink RM4 Pro
                                  das passt aber nicht
                                    @crunchip sorry, habe 2. einen 4Pro der ist aktuell ausgemustert. Jetzt hängt der 3 Pro drin.
                                      der 3 Pro drin.
                                      3pro oder 3proplus ? laut log ist es der proplus, den hab ich auch, eingetragen hab ich als Gerätetyp 0x279d=RMP
                                        proplus,. Ich versuch's mal mit den Einstellungen. Mal schauen wie es morgen früh aussieht. Bis jetzt läuft er.
                                        • Ullulaki
                                          Ullulaki last edited by Ullulaki
                                          Uff... was ein Kampf!
                                          Habe mir im Primeday einen Broadlink 4 Pro zugelegt, um meinen Deckenventilator steuern zu können.
                                          Bin hier fast irre geworden mit der Einbindung... ich habe und habe es einfach nicht hin bekommen, es ohne Cloud einzurichten, trotz Versuch mit mehreren Apps & Resets bis zum Umfallen, Fehler im Log war folgender:
                                          Warning: Device discovered which operates in cloud mode and could not be authenticated!Delete device from mobile app, reset device and bring it into WiFi network again but do not assign it any name, room or function, close app immediately
                                          Ich habe alle von Broadlink im Playstore verfügbaren Apps ausprobiert, auf insgesamt drei unterschiedlichen Android-Devices (2x Handy und 1x Tablet), vorher immer das Gerät resettet und beim Einrichten nach Hinzufügen des WLANs abgebrochen.
                                          Schlussendlich hat es mit der "aktuellsten" Broadlink-App (https://play.google.com/store/apps/details?id=cn.com.broadlink.econtrol.international&hl=de&gl=US) funktioniert indem ich das Gerät manuell über das Auswahlmenü der App hinzugefügt habe, sprich: bei der Einbindung in der App taucht ein Popup auf, dass ein Gerät gefunden wurde - dieses schließen und über das Menü die Einrichtung fortsetzen!
                                          Dann nach der WLAN-Einbindung einfach direkt die App komplett schließen und zack, Gerät im Log gefunden:
                                          Unknown UN:0x5213_ec:0b:ae:xx:xx:xx with { address: '192.168.20.14', port: 80, devtype: 21011, oname: '智能遥控', cloud: 0, maco: <Buffer 11 3d 8c ae 0b ec>, mac: 'ec:0b:ae:xx:xx:xx', type: 'unknown', name: 'UN:0x5213_ec:0b:ae:xx:xx:xx', devname: 'UKN', devhex: '0x5213', names: [ '0x5213_ec:0b:ae:xx:xx:xx' ], iname: 'UN:0x5213_ec:0b:ae:xx:xx:xx' }
                                          Zwar noch Unknown aber im Log steht der devtype (in meinem Falle):
                                          devtype: 21011
                                          Da ich einen RM4 Pro habe entsprechend in den Instanzeinstellung des Adapters unter Gerätetyp hinterlegt:
                                          21011=RM4P
                                          (bei allen anderen Varianten habe ich immer wieder den Fehler mit "Unknown" bekommen.)
                                          Jetzt nur noch _LearnRF aktiviert und beim anlernen die gewünschte Taste lange gedrückt halten, bis im Log
                                          found Frequency 1 of 2, you can release button now!
                                          steht. Anschließend die Taste loslassen und noch einmal drücken... et voilà!
                                          Ich war kurz davor in das Teil reinzubeißen... habe jetzt insgesamt 2,5 Stunden dran gesessen... aber vielleicht kann ich zumindest dem Nächsten so eventuell ein wenig den Stress nehmen. 🙂
                                          A B Atifan 3 Replies Last reply Reply Quote 6
                                            Smokey @schubs2802 last edited by Smokey
                                            @ullulaki sagte in Adapter: broadlink2:
                                            @Ullulaki : und wie sich Deine Mühe gelohnt hat. Vielen Dank. Ich dachte schon ich kann die neue App mit dem 4 Pro vergessen. Aber mit Deinem "move" gings dann wirklich. Ist anscheinend selbst dem Entwickler nicht klar. Nur einen winzigen Nachteil: die Remote ist dann auch wirklich in der App nicht drin und nicht komfortabel anlernbar, korrekt? Ist bei mir so. Aber auch gar kein Problem. Wollte nur verstehen, ob ich da vielleicht noch einen Fehler gemacht habe.
                                            Ansonsten Respekt und Danke 🙂
                                            broad2 broadlink rm pro rm3 mini rm4
                                            169
                                            1365
                                            624436
