    4. Alexa2 Adapter 3.13/3.14/3.15/3.16/3.17 (Beta)
      apollon77 last edited by apollon77
      So, und damit der Samstag Nachmittag nicht so langweilig wird hier ein paar neue Spielereien ... Kommt demnächst im Repo
      Featurepack #3 im Moment für Alexa2 - der Fokus dieses mal sollte auch schnell klar sein 🙂
      Changelog der 3.15: -> 3.15.1 ist aktuelle Version
      • (Apollon77) IMPORTANT: Format to specify multiple Details on "New" for Alarms and Reminders changed, see documentation!
      • (Apollon77) Add Alarm/Reminder triggered state per device which will contain the ID of the alarm that got triggered when it is triggered
      • (Apollon77) Add several more fields for Alarms and Reminders to show better the details of the alarm
      • (Apollon77) Allow to cancel Reminders and Alarms as in the Alexa App
      • (Apollon77) Allow to also edit Alarm/Reminder Dates additionally to the times
      • (Apollon77) Allow to set a custom Volume for Reminders and Alarms - it will be set 2s before the expected trigger and restored afterwards
      • (Apollon77) Calculate the "nextTriggerDate" as Timestamp of next expected triggering
      • (Apollon77) Add a JSON-Array with all running timers and the "next id" as state
      • (Apollon77) Allow to stop a timer by ID
      • (Apollon77) Add the days-list of Alarms when configured for recurrency
      • (Apollon77) Add new Commands skill and skillYours to start Skills
      • (Apollon77) Add Notification volume, Ascending Alarm setting and default notification sounds as preferences
      • (Apollon77) Slow down the initialization of all data a bit, so startup could take longer
      F R 2 Replies Last reply Reply Quote 2
        Flugschüler @apollon77 last edited by
        @apollon77 Bei der neuesten version funktionieren bei mir die Commands nicht mehr.
        DJMarc75 apollon77 2 Replies Last reply Reply Quote 0
        • DJMarc75
          DJMarc75 @Flugschüler last edited by
          @flugschüler sagte in Alexa2 Adapter 3.13/3.14/3.15 (Beta):
          Welche Version ???? Welche Commands ????? Sehr informativer Beitrag.............
            apollon77 @Flugschüler last edited by
            @flugschüler Finde den Fehler in Deinem Post ....
            "Warum verhaftet die Polizistin Ihren Freund? Weil er Ihr Herz gestohlen hat..." tusch ... Also den "Joke" hat Madam mir gerade erzählt als ich "Commands.joke" getriggert habe ...
            Um bei der Fehlersuche zu helfen: Details bitte?????!!!!
            • wo gehts nicht? Device Typ? Was spezielles?
            • hast Du gewartet bis der Adapter wirklich voll gestartet war? Wie geschrieben dauert jetzt ggf bissl länger - im Log kommt eine "Subscribed to states" Meldung - erst dann reagiert er auf irgendwas
            • Steht irgendwas im Log?
            Und wenn Du gaaanz sicher bist ... Debug log bitte von so einem Speak call
              @apollon77 Die neueste version ist 3.15 und alle Commands funktionieren bei mir nicht. Im log steht nichts.
                @flugschüler Dann am besten kurz warten bis die 3.15.1 da ist und neu versuchen. Dann Debug log vom Adapterstart und einem Command. Logfile von der Platte kopieren /opt/iobroker/log/...bitte an mich per E-Mail iobroker@fischer-ka.de
                  Eine 3.15.1 ist auf dem Weg mit zwei Adjustments und einem Fix den Sentry gemeldet hat.
                    @apollon77 O.k. dann warte ich bis die 3.15.1 da ist. Installiere mir mittlerweile die 3.14 die funktioniert. Danke für die Info.
                      @flugschüler Ist auf GitHub bzw npm ... Repo aktualisiert gerade
                        Interessant ja auch die Frage wie es bei anderen ist? Geht da noch alles? Commands? Smart Home devices?
                        F DJMarc75 2 Replies Last reply Reply Quote 0
                          fuchs1978 @apollon77 last edited by
                          @apollon77 ich hatte auch die Probleme mit dem Speak Kommando. Da hier aber schon alles gelöst schien, habe ich mich nicht zur Wort gemeldet 😉
                          • DJMarc75
                            DJMarc75 @apollon77 last edited by DJMarc75
                            @apollon77 Jo, geht tatsächlich nichts !
                            Hab 3.15.0 grad installiert
                            mal alle DP in Commands auf True gesetzt.... nada, niente, nüx
                              Wtf. Bitte einer debug log per email. Aber info log States subscribed ist im log nach dem Start?
                                Flugschüler @DJMarc75 last edited by
                                @djmarc75 Bei 3.15.1 geht auch nichts.
                                DJMarc75 F 2 Replies Last reply Reply Quote 0
                                • DJMarc75
                                  OK, aber dann lieber an @apollon77 senden. Ich bin nur ein User (ich liebe Tron 😀 )
                                    fuchs1978 @Flugschüler last edited by
                                    @flugschüler hier ebenso 3.15.1 keine Kommandos
                                      Es ist gerade nur bedingt hilfreich wenn keiner meine Fragen beantwortet, wie "Gibt es eine info Log mit "Subscribing to states..." bei euchnach dem Start? Erst DANACH versuchen
                                      Ansonsten brauche ich bitte unbedingt ein Debug log ... bei mir tut alles
                                      Thomas Braun DJMarc75 F 3 Replies Last reply Reply Quote 0
                                        Thomas Braun Most Active @apollon77 last edited by
                                        @apollon77
                                        2022-07-09 19:49:48.226  - info: host.chet instance system.adapter.alexa2.0 started with pid 260747
                                        2022-07-09 19:49:50.305  - info: alexa2.0 (260747) starting. Version 3.15.1 in /opt/iobroker/node_modules/iobroker.alexa2, node: v18.4.0, js-controller: 4.0.23
                                        2022-07-09 19:49:50.630  - info: alexa2.0 (260747) Proxy IP not set, use first network interface (192.168.178.48) instead
                                        2022-07-09 19:49:55.827  - info: alexa2.0 (260747) Alexa-Push-Connection (macDms = true) established. Disable Polling
                                        Mehr kommt auf Log Level INFO nicht.
                                        Debug schmeißt halt echt viel raus. Muss das erstmal zähmen...
                                        • DJMarc75
                                          @apollon77
                                          alexa2.0
                                          	2022-07-09 19:46:46.429	info	Alexa-Push-Connection (macDms = true) established. Disable Polling
                                          alexa2.0
                                          	2022-07-09 19:46:39.642	info	Proxy IP not set, use first network interface (192.168.178.2) instead
                                          alexa2.0
                                          	2022-07-09 19:46:38.998	info	starting. Version 3.15.0 in /opt/iobroker/node_modules/iobroker.alexa2, node: v16.16.0, js-controller: 4.0.23
                                          alexa2.0
                                          	2022-07-09 19:46:33.126	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                          alexa2.0
                                          	2022-07-09 19:46:33.124	info	terminating
                                          alexa2.0
                                          	2022-07-09 19:46:33.119	info	Got terminate signal TERMINATE_YOURSEL
                                          vollkommen unauffällig....
                                            @apollon77 bei der 14 kommt diese Zeile bei mir in der 15 nichtScreenshot_2022-07-09-19-52-25-326_com.android.chrome.jpg
                                            391
                                            56217
