    4. Solarman PV, Bosswerk MI & Deye
      Silversurfer 0 @Silversurfer 0 last edited by Silversurfer 0
      @silversurfer-0 said in [Neuer Adapter] Solarman PV, Bosswerk MI600:
      git@github.com:raschy/ioBroker.solarmanpv.git
      Also ich habe den code jetzt direkt nach /opt/iobroker/node_modules mit git gecloned. Das funktioniert.
      solarmanpv.0
      2022-06-28 13:12:36.797	info	Terminated (NO_ERROR): Without reason
      solarmanpv.0
      2022-06-28 13:12:36.682	info	[updateDeviceData] AC_RDT_T1 Data: 32.10 Unit: ℃ Name: AC Radiator Temp
      solarmanpv.0
      2022-06-28 13:12:36.680	info	[updateDeviceData] Etdy_ge0 Data: 0.60 Unit: kWh Name: Daily Production(Active)
      solarmanpv.0
      2022-06-28 13:12:36.678	info	[updateDeviceData] Et_ge0 Data: 314.60 Unit: kWh Name: Total Production(Active)
      solarmanpv.0
      2022-06-28 13:12:36.676	info	[updateDeviceData] APo_t1 Data: 216 Unit: W Name: Total AC Output Power(Active)
      solarmanpv.0
      2022-06-28 13:12:36.674	info	[updateDeviceData] AV1 Data: 236.00 Unit: V Name: AC Voltage 1
      solarmanpv.0
      2022-06-28 13:12:36.672	info	[updateDeviceData] DP2 Data: 95.41 Unit: W Name: DC Power PV2
      solarmanpv.0
      2022-06-28 13:12:36.670	info	[updateDeviceData] DP1 Data: 118.40 Unit: W Name: DC Power PV1
      solarmanpv.0
      2022-06-28 13:12:36.668	info	[updateDeviceData] DC2 Data: 2.90 Unit: A Name: DC Current PV2
      solarmanpv.0
      2022-06-28 13:12:36.666	info	[updateDeviceData] DC1 Data: 3.70 Unit: A Name: DC Current PV1
      solarmanpv.0
      2022-06-28 13:12:36.663	info	[updateDeviceData] DV2 Data: 32.90 Unit: V Name: DC Voltage PV2
      solarmanpv.0
      2022-06-28 13:12:36.660	info	[updateDeviceData] DV1 Data: 32.00 Unit: V Name: DC Voltage PV1
      solarmanpv.0
      2022-06-28 13:12:36.259	info	[updateStationData] lastUpdateTime : Tue Jun 28 2022 13:01:07 GMT+0200 (Central European Summer Time)
      solarmanpv.0
      2022-06-28 13:12:36.247	info	[updateStationData] generationPower : 216
      solarmanpv.0
      2022-06-28 13:12:35.939	info	Device ID: 123456
      solarmanpv.0
      2022-06-28 13:12:35.937	info	Device SN: 123456
      solarmanpv.0
      2022-06-28 13:12:35.622	info	Station ID: 123456
      solarmanpv.0
      2022-06-28 13:12:33.586	info	starting. Version 0.0.9 (non-npm: raschy/ioBroker.solarmanpv#603db2acc9142c1d7a6d0102d80774b3add3a9f8) in /opt/iobroker/node_modules/iobroker.solarmanpv, node: v12.22.12, js-controller: 4.0.23
        @silversurfer-0 BTW: Wenn das Passwort nicht stimmt, ist die Fehlermeldung nicht wirklich aussagefähig.
        • Rene55
          Rene55 @Silversurfer 0 last edited by
          @silversurfer-0 sagte in [Neuer Adapter] Solarman PV, Bosswerk MI600:
          Stimmt, da müssen noch ein paar Dinge abgefangen werden. Ich wollte erstmal die Reaktionen/Verbesserungsvorschläge abwarten.
          (Ich gehe davon aus, das die DeviceSN überarbeitet wurde.)
          Also Adapter läuft und bringt die Werte?
            Silversurfer 0 @Rene55 last edited by
            @rene55
            Ja soweit so gut.
              smartalex last edited by smartalex
              ich habe erst seit wenige Tage den Wechselrichter im Einsatz und freue mich das da jemand sich die Mühe für einen Adapter macht.
              Danke Dafür.
              Nun mein erstes Feedback dazu.
              • Installation hat geklappt über die Katze / Benutzerdefiniert. Nur mit dem kleinen Manko, dass die Installation scheinbar nicht zu Ende geführt wurde und sich das Fenster nicht schloss, aber unter Adapter war er dann da und ich musste nur noch eine Instanz hinzufügen.
              • Nach der Einrichtung wurden die Datenpunkte alle angelegt und die erstern Werte geschrieben. Leider habe ich dann aber nur noch Fehlermeldungen im Log.
              @Rene55 Vielleicht kannst Du damit etwas anfangen?
              Viele Grüße
              • Rene55
                Rene55 @smartalex last edited by
                @smartalex Dass der Adapter bei der Installation nicht sauber abschließt, habe ich auch schon festgestellt, hab aber noch keine Ahnung warum.
                Die Fehlermeldung bedeutet, dass der Server nicht erreichbar ist. Da mein Adapter heute keine Warnungen hatte, muss ich davon ausgehen, dass deine Installation Probleme mit dem Internet hat und den Server nicht erreicht. Die Credentials hast du richtig eingetragen?
                  Romantikus1977 @Rene55 last edited by
                  @rene55 Erstmal vielen Dank, dass sich jemand der BOSSWERK Thematik annimmt. Schließe gerade meine Anlage an und werde den Adapter dann danken testen / nutzen.
                  • Rene55
                    Rene55 @Romantikus1977 last edited by
                    @romantikus1977 Ja freut mich. Derzeit ist das Release 0.0.11 aktuell.
                      Janideluxe @Rene55 last edited by
                      @rene55
                      erstmal vielen Dank für den coolen Adapter. Unser Bosswerk Wechselrichter läuft nun auch damit.
                      Kleine Frage, der Adapter "müllt" ziemlich mein Log zu, gibts ne Möglichkeit, dass der Adapter weniger Info Logs erzeugt?
                      Thomas Braun Rene55 2 Replies Last reply Reply Quote 0
                        Thomas Braun Most Active @Janideluxe last edited by
                        @janideluxe sagte in [Neuer Adapter] Solarman PV, Bosswerk MI600:
                        LogLevel auf Warnung oder Fehler setzen.
                        • Rene55
                          Rene55 @Janideluxe last edited by
                          @janideluxe Der Adapter ist ja noch in der Testphase daher ist der sehr gesprächig. Aber so wie Thomas Braun sagt, im Adapter einfach auf 'error' umschalten - dann sollte fast Ruhe sein.
                            Reiner1962 @Rene55 last edited by
                            @rene55 Hey Rene, vielen Dank für die Arbeit. Die Installation lief ganz normal ab und die Fragen von Solarman waren exakt die gleichen 🙂
                            Was bei mir aber derzeit nicht funzt.... Ich habe 2 Balkonkraftwerke und das Adapter mit der Instanz gibt mir nur eins aus.
                            Eine Idee?
                            Grüße aus Niedersachsen
                            Rene55 S 2 Replies Last reply Reply Quote 0
                            • Rene55
                              Rene55 @Reiner1962 last edited by Rene55
                              @reiner1962 Da haben wir das Problem 🤤 . Ich hab natürlich nur ein BKW und hab mich darauf gestürzt. Es gibt eine Anfrage an die API, bei der die Anzahl der Plants zurückgegeben wird. Da gäbe es die Möglichkeit, auf mehrere zu erweitern - was ich aber nicht testen kann, da ich nur eine habe.
                              Alternative wäre natürlich eine zweite Instanz. (BTW: sind denn mehrere BKW in NS zulässig?)
                                Silversurfer 0 @Reiner1962 last edited by Silversurfer 0
                                @reiner1962 Nach dem aktuellen Design des Adapters benötigst du eine 2. Instanz
                                  Eine Idee?
                                    @rene55 Na ich habe ein Haus mit 2 Anschlüssen ( Zähler). Dann gehen natürlich 2 Balkonkraftwerke :-). Die 2te Instanz habe ich versucht, aber die Daten von Solarman sind dabei ja gleich und dann wird immer nur das erste BK gefunden/eingetragen 😞
                                    • Rene55
                                      @reiner1962 Ja tatsächlich bringt eine zweite Instanz mit den gleichen Secrets nichts, weil der Adapter immer auf "Station 1" abfragt. Hättest du den Mut, wir deine Daten zukommen zu lassen, dann könnte ich versuchen, den auf mehrere BKW zu erweitern?
                                        Japp kein Ding. Aber wie nur an Dich? Habe ich noch nie in Foren gemacht 🙂
                                          @rene55
                                          schick mir ne Mail an reiner.witzel@gmail.com, dann sende ich Dir app_id & app_secret . Sollte reichen 🙂
                                          • Rene55
                                            An alle Tester: es ist eine neue Version 0.0.14 auf Github, die auch mehrere Balkonkraftwerke mit dem gleichen Account (Danke an @Reiner1962) auslesen kann.
                                            jetz
                                            67
                                            564
                                            134626
