    4. KNX Adapter überholt
      my-knx-shop last edited by
      Problem ist bekannt. Bitte abwarten …. es fehlen Ordner und Dateien !
        dalmabrain last edited by
        Danke für die Info….Das erklärt es 🙂
          Max2106 last edited by
          KNX adapter bekomme ich nicht zum laufen.
          Schon mehr fach neu istalliert.
          Im LOG file steht:
          host.KNXbroker 2017-06-02 15:39:36.481 info Restart adapter system.adapter.knx.0 because enabled
          host.KNXbroker 2017-06-02 15:39:36.481 error instance system.adapter.knx.0 terminated with code 8 (node.js: Cannot find module)
          host.KNXbroker 2017-06-02 15:39:36.271 info instance system.adapter.knx.0 started with pid 13389
          host.KNXbroker 2017-06-02 15:39:35.987 info Restart adapter system.adapter.knx.0 because enabled
          host.KNXbroker 2017-06-02 15:39:35.987 error instance system.adapter.knx.0 terminated with code 8 (node.js: Cannot find module)
          host.KNXbroker 2017-06-02 15:39:35.760 info instance system.adapter.knx.0 started with pid 13387
          host.KNXbroker 2017-06-02 15:39:32.250 info Restart adapter system.adapter.knx.0 because enabled
          host.KNXbroker 2017-06-02 15:39:32.250 error instance system.adapter.knx.0 terminated with code 8 (node.js: Cannot find module)
          host.KNXbroker 2017-06-02 15:39:31.999 info instance system.adapter.knx.0 started with pid 13385
          host.KNXbroker 2017-06-02 15:39:17.869 info Restart adapter system.adapter.knx.0 because enabled
          host.KNXbroker 2017-06-02 15:39:17.869 error instance system.adapter.knx.0 terminated with code 8 (node.js: Cannot find module)
          host.KNXbroker 2017-06-02 15:39:17.637 info instance system.adapter.knx.0 started with pid 13383
          host.KNXbroker 2017-06-02 15:39:06.259 info Restart adapter system.adapter.knx.0 because enabled
          host.KNXbroker 2017-06-02 15:39:06.258 error instance system.adapter.knx.0 terminated with code 8 (node.js: Cannot find module)
          host.KNXbroker 2017-06-02 15:39:06.047 info instance system.adapter.knx.0 started with pid 13381
          host.KNXbroker 2017-06-02 15:39:05.738 info Restart adapter system.adapter.knx.0 because enabled
          host.KNXbroker 2017-06-02 15:39:05.737 error instance system.adapter.knx.0 terminated with code 8 (node.js: Cannot find module)
          Jemand eine Idee?
          Besten Dank
            Mal ne andere Frage. Ließt du auch was hier geschrieben wird ? Ich habe 2 Beiträge über deinem doch geschrieben, dass es aktuell nicht mit der Version die zur Zeit online ist, funktioniert !
            Also bitte abwarten bis dieses wieder korrigiert ist. Dann wird Chefkoch009 uns sicher kurz informieren.
              Applefrank last edited by
              Hallo
              Ich habe die Kommunikation über Meinen Gira knx Router hin bekommen.
              Kann über den Iobroker schalten, dimmen etc. aber das mit den Status bekomme ich nicht hin.
              Vielleicht hat ja jemand einen Tipp.
                @Applefrank:
                Hallo
                Vielleicht hat ja jemand einen Tipp. `
                Wann hast du den KNX Adapter denn installiert gehabt ?
                  Habe den vor ca eine Woche installiert
                    @Max2106:
                    Im LOG file steht:
                    Jemand eine Idee?
                    Besten Dank `
                      vielleicht ist es sinnvoll, bei den Adptern den link fuer den KNX Adapter 0.8.3 zu hinterlegen, bis die neue Version ohne Probleme laueft.
                        Hallo Max,
                        Was bitte soll das jetzt?
                        Vollzitat von deinem eigenen Post, auf den bereits geantwortet wurde?
                        Rainer
                          Sorry, ist versehentlich passiert.
                          Soll nicht wieder vorkommen.
                          Herrscht ein rauher Ton hier.
                          Gruss, Max
                            @Max2106:
                            Herrscht ein rauher Ton hier. `
                            Nö, nur wenn außer dem eigenen Post nur noch ein weiteres mal der selbe ohne Zusatzinformationen gepostet wird, wird man doch wohl mal fragen dürfen.
                            Deswegen musst du mir nicht gleich zweimal meinen Post als Vollzitat ohne weitere Informationen als PN schicken.
                            Und zu deiner letzten Frage:
                            Hast du hier mal gelesen
                            http://www.iobroker.net/docu/?page_id=5 … stallieren
                            Punkt 4
                            Rainer
                              Stupidman last edited by
                              UPDATE zu meinem Raspi Schnittstellenproblem.
                              ES LÄUFT !!!
                              Kurz bevor ich den Raspi in den Teich werfen wollte habe ich mal den KNX Adapter Version 0.8.3 installiert. (Vorgängerversion)
                              Damit klappt es jetzt ENDLICH und die erste Testlampe gehorcht auf´s Wort.
                              IK FREU MIR !!
                                @chefkoch009:
                                @fuchs1978: normaler Weise hat das wert dimmen den dpt 5.001. Du verwendest den dpt 3, welcher für das schrittdimmen ist, also dimmen z.b. über einen Taster. Weiterhin sehe ich bei dir keine Antwortadressen. Beim dimmen lege ich üblicher Weise 5 mittelgruppen an:
                                schalten,
                                Schalten Status,
                                Dimmen,
                                Dimmen wert und
                                dimmen wert Status.
                                Wenn in den Gruppenadressen alles verknüpft ist und die Datenpunkttypen richtig zugeordnet sind, dann wird es funktionieren. Bei Fragen stehe ich zur Verfügung `
                                … Welches Objekt verwendest Du dann im IoBroker? Ich möchte meine Lampe dimmen und im ETS ist DPT5.001 eingestellt. Weiterhin habe ich genau wie von Dir besprechen alle Mittelgruppen erstellt:
                                schalten,
                                Schalten Status,
                                Dimmen,
                                Dimmen wert und
                                dimmen wert Status
                                Aber irgendwie funktioniert es null.
                                • cvidal
                                  @chefkoch009:
                                  Ich hoffe deine Fragen damit beantwortet zu haben. Solltest du nicht weiterkommen, würde ich mir dein Projekt gern Mal anschauen.
                                  VG
                                  chefkoch009 `
                                  Hi Zusammen bei mir läuft Zustand anzeigen meiner Jalousienen jetzt auch, ich habe in der ETS Zustand als Objekt Programmiert mir ist nachher erst aufgefallen das der Aktor auch Position anzeigen hat… Also alles gut.
                                  So für mich ist es soweit erstmal komplett fertig mit KNX, ich habe keinerlei Probleme mehr mit dem Adapter 0.8.3
                                  Danke für eure Hilfe und Geduld.
                                  • cvidal
                                    Hallo Dalmabrain,
                                    bekommst du den Adapter überhaupt ans laufen, grüne Anzeige unter Instanzen? Es läuft nichts ist schwer ein zuordnen.
                                    Gruß Christian
                                    • chefkoch009
                                      chefkoch009 Developer last edited by
                                      Hallo cvidal,
                                      es gibt in der 0.8.4er Version einen Fehler. Ich arbeite daran, diesen zu beheben. Bitte benutze solange die Version 0.8.3.
                                      Vielen Dank für die Geduld und das Verständniss bis zum Erscheinen der neuen Version.
                                      VG
                                      chefkoch009
                                      • cvidal
                                        @ Chefkoch009
                                        Ja das ist mir bewusst ich habe es ja am laufen mit 8.3 die frage hatte ich eigentlich an Dalmabrain gestellt, sollte keine Fehlermeldung an KNX 8.4 sein.
                                        @Dalmabrain
                                        Versuch es mal mit Version 8.3 dann sollte es laufen.
                                        Gruß Christian
                                          @cvidal
                                          Ja der Adapter 0.8.3 läuft und ich kann auch einfache Schaltvorgänge machen..Licht ein und aus ist kein Problem. Komplizierter wird es wenn ich Dimmen möchte…Da habe ich mal die Dimmer der HQwidgets genommen. Aber irgendwie kann ich dort den Dimmwert nicht übertragen. Im ETS ist alles vorhanden...Ich habe für die enstprechende Lampe eine GA für Schalten, eine für Dimmen, eine für dne Dimmwert und eine für die Rückmeldung des Dimmwerts.
                                          Egal was ich mache, ich bekomme das Dimmen über IoBroker nicht hin 😞
                                          Wie machst Du das?
                                          • cvidal
                                            @ dalmabrain
                                            Hallo, da kann ich leider nicht weiterhelfen ich habe keinen Dimmaktor verbaut.
                                            Ich habe als einzige Dimmbare leuchte von Milight das dazugehörige Widget genommen.
                                            Eventuell mal testen?
                                            Gruß Christian
                                            1043
                                            346311
