    4. Lidl Silvercrest Smart Button *gelöst*
    • O
      oFbEQnpoLKKl6mbY5e13 @gluecksmann last edited by oFbEQnpoLKKl6mbY5e13
      @gluecksmann
      Bei zweimal Drücken geht der Datenpunkt "off" auf True statt der Datenpunkt "on".
      G K 2 Replies Last reply Reply Quote 0
        gluecksmann @oFbEQnpoLKKl6mbY5e13 last edited by
        @ofbeqnpolkkl6mby5e13
        Ups.... danke... macht ja auch Sinn...
          bigfun_de @gluecksmann last edited by
          Hallo ich habe mir den Button auch gekauft und bekomme ihn nicht gekoppelt.
          Mein System ist ein pi3 mit den deConz-Stick.
          pi@iobroker-pi:~ $ iobroker update -i
          Used repository: stable
          Adapter    "admin"        : 5.3.8    , installed 5.3.8
          Adapter    "backitup"     : 2.4.9    , installed 2.4.9
          Adapter    "denon"        : 1.13.4   , installed 1.13.4
          Adapter    "discovery"    : 3.0.3    , installed 3.0.3
          Adapter    "echarts"      : 1.0.7    , installed 1.0.7
          Adapter    "javascript"   : 5.7.0    , installed 5.7.0
          Adapter    "proxmox"      : 1.3.4    , installed 1.3.4
          Adapter    "zigbee"       : 1.7.5    , installed 1.7.5
          Adapter    "zwave2"       : 2.5.0    , installed 2.5.0
          Wenn ich in Zigbee-Adapter auf pairing gehe, passiert nichts.
          Im log steht:
          Error: Failed to touchlinkReset Error: Touchlink operation already in progress
              at Touchlink.lock (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/touchlink.ts:20:19)
              at Touchlink.factoryResetFirst (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/touchlink.ts:110:14)
              at Controller.touchlinkFactoryResetFirst (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/controller.ts:202:31)
              at ZigbeeController.touchlinkReset (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:913:33)
              at Commands.touchlinkReset (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:156:31)
              at Commands.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:56:30)
              at Zigbee.emit (events.js:412:35)
              at Zigbee.emit (domain.js:475:12)
              at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5824:34)
              at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:322:37). undefined
          Touchlink reset started
          Ich kann den Fehler leider nicht sogrichtig deuten 😞
          Alle anderen Geräte gehen ja.
          • Asgothian
            Asgothian Developer @bigfun_de last edited by
            @bigfun_de der Fehler deutet darauf hin das du mehrfach versucht hast einen touchlink-reset durchzuführen ohne zu warten was passiert.
            Er hat mit dem Gerät selber nichts zu tun.
            A.
              bigfun_de @Asgothian last edited by
              @asgothian
              Danke für die Rückmeldung!
              Wenn die Meldung mit dem Pairing nichts zu tun hat, woran kann es liegen, dass der Button nicht erkannt wird.
              Zur Ergänzung, ich habe den deConz II Stick.
                kamolus @oFbEQnpoLKKl6mbY5e13 last edited by
                @ofbeqnpolkkl6mby5e13 said in Lidl Silvercrest Smart Button *gelöst*:
                @gluecksmann
                Hallo, ich bekomme den script nicht zum laufen
                  kamolus @kamolus last edited by
                  @kamolus said in Lidl Silvercrest Smart Button *gelöst*:
                  @gluecksmann
                  "on/off state of the switch" ist das selbst erzeugte Datapunkt in 0_datauser ?
                  Ändert sich gar nicht.
                  Das funktioniert aber tadellos
                    @gluecksmann
                    • O
                      oFbEQnpoLKKl6mbY5e13 @kamolus last edited by oFbEQnpoLKKl6mbY5e13
                      @kamolus sagte in Lidl Silvercrest Smart Button *gelöst*:
                      "on/off state of the switch" ist das selbst erzeugte >Datapunkt in 0_datauser ?
                      Das ist völlig irrelevant. Hier wird der Datenpunkt ausgewählt, dessen Zustand durch Drücken des Smart Button geändert werden soll.
                      totocotonio 1 Reply Last reply Reply Quote 0
                      • totocotonio
                        totocotonio @oFbEQnpoLKKl6mbY5e13 last edited by totocotonio
                        @ofbeqnpolkkl6mby5e13 Hi,
                        ich habe das gleiche Problem mit dem Ding. Habt ihr schon eine LÖsung gefunden. Klar kann ich auf alles Triggern
                        aber die on/off werte ändern sich trotzdem nicht, das scheint doch noch ein Bug zu sein
                        O K 2 Replies Last reply Reply Quote 0
                        • O
                          oFbEQnpoLKKl6mbY5e13 @totocotonio last edited by oFbEQnpoLKKl6mbY5e13
                          @totocotonio
                          Keine Ahnung, wovon du sprichst, das "Ding" funktioniert hier einwandfrei.
                            kamolus @totocotonio last edited by
                            @totocotonio said in Lidl Silvercrest Smart Button *gelöst*:
                            Funktioniert diese script bei Dir?
                            K totocotonio 2 Replies Last reply Reply Quote 0
                              Das funktioniert schon bei mir, keine Ahnung warum
                              state ändert sich einmal drücken - wahr, zweimal drücken - falsch
                                Das funktioniert schon bei mir, keine Ahnung warum,
                                • O
                                  @kamolus
                                  Weshalb verstehst du nicht, warum es funktioniert?
                                  Kann man so machen, verschwendet aber Funktionalität. Du verwendest 1x und 2x Drücken für Ein- und Ausschalten desselben Gerätes.
                                  Wenn du "toggelst", dann kannst du mit dem Smart Button bis zu drei verschiedene Geräte steuern.
                                    @kamolus
                                    Ich habe ein wenig mit dem Button "gespielt" und festgestellt mein Button "verliert" Verbindung mit dem Iobroker (wenn man so "wild"klickt"). Nix hilft nur neu pairen. Unter Instanzen/zigbee/Geräte im Kachel von Button erscheint beim drücken (wenn alles gut funktioniert) kleine Rechteck für kurze Moment.
                                    Wenn die Verbindung "weg" ist, erscheint diese "Rechteck" nicht und im log kann auch nix sehen, da kann ich den Adapter neu starten oder ganze Iobroker, hilft gar nicht nur Button entfernen und neu Pairen.
                                      @kamolus
                                      Ich habe ein wenig mit dem Button "gespielt" und festgestellt mein Button "verliert" Verbindung mit dem Iobroker (wenn man so "wild klickt"). Nix hilft nur neu pairen. Unter Instanzen/zigbee/Geräte im Kachel von Button erscheint beim drücken (wenn alles gut funktioniert) kleine Rechteck für kurze Moment.
                                      • totocotonio
                                        es schaltet zum Beispiel nicht von false auf true um oder umgekehrt
                                        • totocotonio
                                          totocotonio @kamolus last edited by
                                          @kamolus Hi, ja das funktioniert.
                                          • O
                                            @totocotonio
                                            Du widersprichst dir...
                                            65
                                            6418
