    • simatec
      simatec Developer Most Active @MCU last edited by
      @mcu leg die mal in /usr/bin
      Bei einigen Systemen wird usr/local/bin nicht richtig erkannt
        MCU @simatec last edited by
        @simatec Bringt keinen Unterschied.
        • simatec
          simatec Developer Most Active @Thomas Braun last edited by
          @thomas-braun Kannst du mal bitte in Backitup ein Issue anlegen, wie man über Paketmanager die influx-cli installiert
          Also speziell für influxdb2.
          Dann passe ich die Doku an.
          Damals gab es noch kein offizielles Paket
            Thomas Braun Most Active @MCU last edited by Thomas Braun
            @mcu
            https://docs.influxdata.com/influxdb/v1.8/introduction/install/
            Leg dir das Repo an, da ist auch influxdb2 drin. Und dann installierst du das sauber.
            Und kratz das wieder aus /usr/local/bin raus.
            • simatec
              @mcu
              Was kommt denn, wenn du influx in der Konsole aufrufst?
                @simatec
                influx
                NAME:
                   influx - Influx Client
                USAGE:
                   influx [command]
                COMMANDS:
                   version              Print the influx CLI version
                   write                Write points to InfluxDB
                   bucket               Bucket management commands
                   completion           Generates completion scripts
                   query                Execute a Flux query
                   config               Config management commands
                   org, organization    Organization management commands
                   delete               Delete points from InfluxDB
                   user                 User management commands
                   task                 Task management commands
                   telegrafs            List Telegraf configuration(s). Subcommands manage Telegraf configurations.
                   dashboards           List Dashboard(s).
                   export               Export existing resources as a template
                   secret               Secret management commands
                   v1                   InfluxDB v1 management commands
                   auth, authorization  Authorization management commands
                   apply                Apply a template to manage resources
                   stacks               List stack(s) and associated templates. Subcommands manage stacks.
                   template             Summarize the provided template
                   bucket-schema        Bucket schema management commands
                   ping                 Check the InfluxDB /health endpoint
                   setup                Setup instance with initial user, org, bucket
                   backup               Backup database
                   restore              Restores a backup directory to InfluxDB
                   remote               Remote connection management commands
                   replication          Replication stream management commands
                   server-config        Display server config
                   help, h              Shows a list of commands or help for one command
                GLOBAL OPTIONS:
                   --help, -h  show help
                • simatec
                  @mcu na geht doch.
                  Dan sollte es auch in Backitup gehen.
                  Falls die influx aus irgend einem Grund von Backitup nicht gefunden wird, trage den kompletten Pfad in der Config ein
                    @simatec So?
                    Thomas Braun simatec 2 Replies Last reply Reply Quote 0
                      @mcu
                      Ich würde es über den Paketmanager machen. Das fällt dir früher oder später sonst wieder auf die Füße.
                        MCU @Thomas Braun last edited by
                        @thomas-braun Da fehlt mir das Wissen. Wie gehe ich über den Paketmanager?
                          @mcu
                          Repo anlegen:
                          wget -q https://repos.influxdata.com/influxdb.key
                          echo '23a1c8836f0afc5ed24e0486339d7cc8f6790b83886c4c96995b88a061c5bb5d influxdb.key' | sha256sum -c && cat influxdb.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdb.gpg > /dev/null
                          echo 'deb [signed-by=/etc/apt/trusted.gpg.d/influxdb.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
                          Dann das übliche Installations-Prozedere:
                          sudo apt update
                          sudo apt install PAKETNAME
                            @thomas-braun Das habe ich doch bei der Installation von influxdb2 schon so gemacht?
                            apt install sudo curl gpg gnupg2 wget -y
                            sudo apt-get update && sudo apt-get install influxdb2
                              @mcu
                              Und warum installierst du dann den client nicht auch daraus?
                              Stattdessen verhunzt du dir die dpkg-Datenbank.
                              apt policy influxdb2-cli
                              bringt?
                                MCU @Thomas Braun last edited by MCU
                                @thomas-braun So?
                                sudo apt update && sudo apt install influxdb2-cli
                                Get:1 http://security.debian.org bullseye-security InRelease [44.1 kB]
                                Get:2 http://ftp.debian.org/debian bullseye InRelease [116 kB]
                                Get:3 https://repos.influxdata.com/debian stable InRelease [4645 B]
                                Get:4 http://ftp.debian.org/debian bullseye-updates InRelease [39.4 kB]
                                Get:5 http://security.debian.org bullseye-security/main amd64 Packages [164 kB]
                                Get:6 https://repos.influxdata.com/debian stable/main amd64 Packages [1263 B]
                                Get:7 http://security.debian.org bullseye-security/main Translation-en [103 kB]
                                Get:8 http://ftp.debian.org/debian bullseye/main amd64 Packages [8182 kB]
                                Get:9 http://ftp.debian.org/debian bullseye/main Translation-en [6243 kB]
                                Get:10 http://ftp.debian.org/debian bullseye/contrib amd64 Packages [50.6 kB]
                                Get:11 http://ftp.debian.org/debian bullseye/contrib Translation-en [46.9 kB]
                                Fetched 15.0 MB in 2s (7736 kB/s)
                                Reading package lists... Done
                                Building dependency tree... Done
                                12 packages can be upgraded. Run 'apt list --upgradable' to see them.
                                N: Repository 'http://ftp.debian.org/debian bullseye InRelease' changed its 'Version' value from '11.3' to '11.4'
                                influxdb2-cli is already the newest version (2.3.0).
                                0 upgraded, 0 newly installed, 0 to remove and 12 not upgraded.
                                influxdb2-cli:
                                  Installed: 2.3.0
                                  Candidate: 2.3.0
                                  Version table:
                                 *** 2.3.0 500
                                        500 https://repos.influxdata.com/debian stable/main amd64 Packages
                                        100 /var/lib/dpkg/status
                                  @mcu sagte in Test Adapter ioBroker.backitup v2.4.x:
                                  ist also bereits installiert.
                                  which influx
                                  liefert?
                                  Hau die 12 Updates rein...
                                    sudo apt update
                                    [sudo] password for prox:
                                    Hit:1 http://ftp.debian.org/debian bullseye InRelease
                                    Hit:2 http://security.debian.org bullseye-security InRelease
                                    Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
                                    Hit:4 https://repos.influxdata.com/debian stable InRelease
                                    All packages are up to date.
                                    which influx
                                    /usr/local/bin/influx
                                      sudo rm /usr/local/bin/influx
                                      exit
                                      Wieder einloggen und dann nochmal
                                      which influx
                                      Und warum hast du nodejs nicht als Repo? Das ist wichtig! (Ah, das ist nicht die Dose mit dem ioBroker...)
                                      • simatec
                                        @mcu nich influxd … nur influx
                                          which influx
                                          /usr/bin/influx
                                            MCU @simatec last edited by MCU
                                            @simatec
                                            170
                                            2779
                                            2305744
