      MCU @simatec last edited by
      @simatec Bringt keinen Unterschied.
      • simatec
        simatec Developer Most Active @Thomas Braun last edited by
        @thomas-braun Kannst du mal bitte in Backitup ein Issue anlegen, wie man über Paketmanager die influx-cli installiert
        Also speziell für influxdb2.
        Dann passe ich die Doku an.
        Damals gab es noch kein offizielles Paket
          Thomas Braun Most Active @MCU last edited by Thomas Braun
          @mcu
          https://docs.influxdata.com/influxdb/v1.8/introduction/install/
          Leg dir das Repo an, da ist auch influxdb2 drin. Und dann installierst du das sauber.
          Und kratz das wieder aus /usr/local/bin raus.
          • simatec
            simatec Developer Most Active @MCU last edited by
            @mcu
            Was kommt denn, wenn du influx in der Konsole aufrufst?
              @simatec
              influx
              NAME:
                 influx - Influx Client
              USAGE:
                 influx [command]
              COMMANDS:
                 version              Print the influx CLI version
                 write                Write points to InfluxDB
                 bucket               Bucket management commands
                 completion           Generates completion scripts
                 query                Execute a Flux query
                 config               Config management commands
                 org, organization    Organization management commands
                 delete               Delete points from InfluxDB
                 user                 User management commands
                 task                 Task management commands
                 telegrafs            List Telegraf configuration(s). Subcommands manage Telegraf configurations.
                 dashboards           List Dashboard(s).
                 export               Export existing resources as a template
                 secret               Secret management commands
                 v1                   InfluxDB v1 management commands
                 auth, authorization  Authorization management commands
                 apply                Apply a template to manage resources
                 stacks               List stack(s) and associated templates. Subcommands manage stacks.
                 template             Summarize the provided template
                 bucket-schema        Bucket schema management commands
                 ping                 Check the InfluxDB /health endpoint
                 setup                Setup instance with initial user, org, bucket
                 backup               Backup database
                 restore              Restores a backup directory to InfluxDB
                 remote               Remote connection management commands
                 replication          Replication stream management commands
                 server-config        Display server config
                 help, h              Shows a list of commands or help for one command
              GLOBAL OPTIONS:
                 --help, -h  show help
              • simatec
                @mcu na geht doch.
                Dan sollte es auch in Backitup gehen.
                Falls die influx aus irgend einem Grund von Backitup nicht gefunden wird, trage den kompletten Pfad in der Config ein
                  @simatec So?
                  Thomas Braun simatec 2 Replies Last reply Reply Quote 0
                    @mcu
                    Ich würde es über den Paketmanager machen. Das fällt dir früher oder später sonst wieder auf die Füße.
                      MCU @Thomas Braun last edited by
                      @thomas-braun Da fehlt mir das Wissen. Wie gehe ich über den Paketmanager?
                        @mcu
                        Repo anlegen:
                        wget -q https://repos.influxdata.com/influxdb.key
                        echo '23a1c8836f0afc5ed24e0486339d7cc8f6790b83886c4c96995b88a061c5bb5d influxdb.key' | sha256sum -c && cat influxdb.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdb.gpg > /dev/null
                        echo 'deb [signed-by=/etc/apt/trusted.gpg.d/influxdb.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
                        Dann das übliche Installations-Prozedere:
                        sudo apt update
                        sudo apt install PAKETNAME
                          @thomas-braun Das habe ich doch bei der Installation von influxdb2 schon so gemacht?
                          apt install sudo curl gpg gnupg2 wget -y
                          sudo apt-get update && sudo apt-get install influxdb2
                            @mcu
                            Und warum installierst du dann den client nicht auch daraus?
                            Stattdessen verhunzt du dir die dpkg-Datenbank.
                            apt policy influxdb2-cli
                            bringt?
                              MCU @Thomas Braun last edited by MCU
                              @thomas-braun So?
                              sudo apt update && sudo apt install influxdb2-cli
                              Get:1 http://security.debian.org bullseye-security InRelease [44.1 kB]
                              Get:2 http://ftp.debian.org/debian bullseye InRelease [116 kB]
                              Get:3 https://repos.influxdata.com/debian stable InRelease [4645 B]
                              Get:4 http://ftp.debian.org/debian bullseye-updates InRelease [39.4 kB]
                              Get:5 http://security.debian.org bullseye-security/main amd64 Packages [164 kB]
                              Get:6 https://repos.influxdata.com/debian stable/main amd64 Packages [1263 B]
                              Get:7 http://security.debian.org bullseye-security/main Translation-en [103 kB]
                              Get:8 http://ftp.debian.org/debian bullseye/main amd64 Packages [8182 kB]
                              Get:9 http://ftp.debian.org/debian bullseye/main Translation-en [6243 kB]
                              Get:10 http://ftp.debian.org/debian bullseye/contrib amd64 Packages [50.6 kB]
                              Get:11 http://ftp.debian.org/debian bullseye/contrib Translation-en [46.9 kB]
                              Fetched 15.0 MB in 2s (7736 kB/s)
                              Reading package lists... Done
                              Building dependency tree... Done
                              12 packages can be upgraded. Run 'apt list --upgradable' to see them.
                              N: Repository 'http://ftp.debian.org/debian bullseye InRelease' changed its 'Version' value from '11.3' to '11.4'
                              influxdb2-cli is already the newest version (2.3.0).
                              0 upgraded, 0 newly installed, 0 to remove and 12 not upgraded.
                              influxdb2-cli:
                                Installed: 2.3.0
                                Candidate: 2.3.0
                                Version table:
                               *** 2.3.0 500
                                      500 https://repos.influxdata.com/debian stable/main amd64 Packages
                                      100 /var/lib/dpkg/status
                                @mcu sagte in Test Adapter ioBroker.backitup v2.4.x:
                                ist also bereits installiert.
                                which influx
                                liefert?
                                Hau die 12 Updates rein...
                                  sudo apt update
                                  [sudo] password for prox:
                                  Hit:1 http://ftp.debian.org/debian bullseye InRelease
                                  Hit:2 http://security.debian.org bullseye-security InRelease
                                  Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
                                  Hit:4 https://repos.influxdata.com/debian stable InRelease
                                  All packages are up to date.
                                  which influx
                                  /usr/local/bin/influx
                                    sudo rm /usr/local/bin/influx
                                    exit
                                    Wieder einloggen und dann nochmal
                                    which influx
                                    Und warum hast du nodejs nicht als Repo? Das ist wichtig! (Ah, das ist nicht die Dose mit dem ioBroker...)
                                    • simatec
                                      @mcu nich influxd … nur influx
                                        which influx
                                        /usr/bin/influx
                                          MCU @simatec last edited by MCU
                                          @simatec
                                            @mcu
                                            rm influxdb2*
                                            apt policy influxdb*
                                            170
                                            2780
                                            2377391
