    • simatec
      simatec Developer Most Active @Thomas Braun last edited by
      @thomas-braun Kannst du mal bitte in Backitup ein Issue anlegen, wie man über Paketmanager die influx-cli installiert
      Also speziell für influxdb2.
      Dann passe ich die Doku an.
      Damals gab es noch kein offizielles Paket
        Thomas Braun Most Active @MCU last edited by Thomas Braun
        @mcu
        https://docs.influxdata.com/influxdb/v1.8/introduction/install/
        Leg dir das Repo an, da ist auch influxdb2 drin. Und dann installierst du das sauber.
        Und kratz das wieder aus /usr/local/bin raus.
        • simatec
          simatec Developer Most Active @MCU last edited by
          @mcu
          Was kommt denn, wenn du influx in der Konsole aufrufst?
            MCU @simatec last edited by
            @simatec
            influx
            NAME:
               influx - Influx Client
            USAGE:
               influx [command]
            COMMANDS:
               version              Print the influx CLI version
               write                Write points to InfluxDB
               bucket               Bucket management commands
               completion           Generates completion scripts
               query                Execute a Flux query
               config               Config management commands
               org, organization    Organization management commands
               delete               Delete points from InfluxDB
               user                 User management commands
               task                 Task management commands
               telegrafs            List Telegraf configuration(s). Subcommands manage Telegraf configurations.
               dashboards           List Dashboard(s).
               export               Export existing resources as a template
               secret               Secret management commands
               v1                   InfluxDB v1 management commands
               auth, authorization  Authorization management commands
               apply                Apply a template to manage resources
               stacks               List stack(s) and associated templates. Subcommands manage stacks.
               template             Summarize the provided template
               bucket-schema        Bucket schema management commands
               ping                 Check the InfluxDB /health endpoint
               setup                Setup instance with initial user, org, bucket
               backup               Backup database
               restore              Restores a backup directory to InfluxDB
               remote               Remote connection management commands
               replication          Replication stream management commands
               server-config        Display server config
               help, h              Shows a list of commands or help for one command
            GLOBAL OPTIONS:
               --help, -h  show help
            • simatec
              @mcu na geht doch.
              Dan sollte es auch in Backitup gehen.
              Falls die influx aus irgend einem Grund von Backitup nicht gefunden wird, trage den kompletten Pfad in der Config ein
                @simatec So?
                Thomas Braun simatec 2 Replies Last reply Reply Quote 0
                  @mcu
                  Ich würde es über den Paketmanager machen. Das fällt dir früher oder später sonst wieder auf die Füße.
                    MCU @Thomas Braun last edited by
                    @thomas-braun Da fehlt mir das Wissen. Wie gehe ich über den Paketmanager?
                      @mcu
                      Repo anlegen:
                      wget -q https://repos.influxdata.com/influxdb.key
                      echo '23a1c8836f0afc5ed24e0486339d7cc8f6790b83886c4c96995b88a061c5bb5d influxdb.key' | sha256sum -c && cat influxdb.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdb.gpg > /dev/null
                      echo 'deb [signed-by=/etc/apt/trusted.gpg.d/influxdb.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
                      Dann das übliche Installations-Prozedere:
                      sudo apt update
                      sudo apt install PAKETNAME
                        @thomas-braun Das habe ich doch bei der Installation von influxdb2 schon so gemacht?
                        apt install sudo curl gpg gnupg2 wget -y
                        sudo apt-get update && sudo apt-get install influxdb2
                          @mcu
                          Und warum installierst du dann den client nicht auch daraus?
                          Stattdessen verhunzt du dir die dpkg-Datenbank.
                          apt policy influxdb2-cli
                          bringt?
                            MCU @Thomas Braun last edited by MCU
                            @thomas-braun So?
                            sudo apt update && sudo apt install influxdb2-cli
                            Get:1 http://security.debian.org bullseye-security InRelease [44.1 kB]
                            Get:2 http://ftp.debian.org/debian bullseye InRelease [116 kB]
                            Get:3 https://repos.influxdata.com/debian stable InRelease [4645 B]
                            Get:4 http://ftp.debian.org/debian bullseye-updates InRelease [39.4 kB]
                            Get:5 http://security.debian.org bullseye-security/main amd64 Packages [164 kB]
                            Get:6 https://repos.influxdata.com/debian stable/main amd64 Packages [1263 B]
                            Get:7 http://security.debian.org bullseye-security/main Translation-en [103 kB]
                            Get:8 http://ftp.debian.org/debian bullseye/main amd64 Packages [8182 kB]
                            Get:9 http://ftp.debian.org/debian bullseye/main Translation-en [6243 kB]
                            Get:10 http://ftp.debian.org/debian bullseye/contrib amd64 Packages [50.6 kB]
                            Get:11 http://ftp.debian.org/debian bullseye/contrib Translation-en [46.9 kB]
                            Fetched 15.0 MB in 2s (7736 kB/s)
                            Reading package lists... Done
                            Building dependency tree... Done
                            12 packages can be upgraded. Run 'apt list --upgradable' to see them.
                            N: Repository 'http://ftp.debian.org/debian bullseye InRelease' changed its 'Version' value from '11.3' to '11.4'
                            influxdb2-cli is already the newest version (2.3.0).
                            0 upgraded, 0 newly installed, 0 to remove and 12 not upgraded.
                            influxdb2-cli:
                              Installed: 2.3.0
                              Candidate: 2.3.0
                              Version table:
                             *** 2.3.0 500
                                    500 https://repos.influxdata.com/debian stable/main amd64 Packages
                                    100 /var/lib/dpkg/status
                              @mcu sagte in Test Adapter ioBroker.backitup v2.4.x:
                              ist also bereits installiert.
                              which influx
                              liefert?
                              Hau die 12 Updates rein...
                                sudo apt update
                                [sudo] password for prox:
                                Hit:1 http://ftp.debian.org/debian bullseye InRelease
                                Hit:2 http://security.debian.org bullseye-security InRelease
                                Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
                                Hit:4 https://repos.influxdata.com/debian stable InRelease
                                All packages are up to date.
                                which influx
                                /usr/local/bin/influx
                                  sudo rm /usr/local/bin/influx
                                  exit
                                  Wieder einloggen und dann nochmal
                                  which influx
                                  Und warum hast du nodejs nicht als Repo? Das ist wichtig! (Ah, das ist nicht die Dose mit dem ioBroker...)
                                  • simatec
                                    @mcu nich influxd … nur influx
                                      which influx
                                      /usr/bin/influx
                                        MCU @simatec last edited by MCU
                                        @simatec
                                          @mcu
                                          rm influxdb2*
                                          apt policy influxdb*
                                            @thomas-braun sagte in Test Adapter ioBroker.backitup v2.4.x:
                                            rm influxdb2*
                                            rm influxdb2*
                                            rm: cannot remove 'influxdb2-client-2.3.0-linux-amd64': Is a directory
                                            mit sudo?
                                            N: Unable to locate package influxdb.key
                                            N: Couldn't find any package by glob 'influxdb.key'
                                            N: Unable to locate package influxdb2-client-2.3.0-linux-amd64
                                            N: Couldn't find any package by glob 'influxdb2-client-2.3.0-linux-amd64'
                                            170
                                            2780
                                            2376330
