      Thomas Braun Most Active @MCU last edited by
      @mcu
      Repo anlegen:
      wget -q https://repos.influxdata.com/influxdb.key
      echo '23a1c8836f0afc5ed24e0486339d7cc8f6790b83886c4c96995b88a061c5bb5d influxdb.key' | sha256sum -c && cat influxdb.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdb.gpg > /dev/null
      echo 'deb [signed-by=/etc/apt/trusted.gpg.d/influxdb.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
      Dann das übliche Installations-Prozedere:
      sudo apt update
      sudo apt install PAKETNAME
        MCU @Thomas Braun last edited by
        @thomas-braun Das habe ich doch bei der Installation von influxdb2 schon so gemacht?
        apt install sudo curl gpg gnupg2 wget -y
        sudo apt-get update && sudo apt-get install influxdb2
          Thomas Braun Most Active @MCU last edited by Thomas Braun
          @mcu
          Und warum installierst du dann den client nicht auch daraus?
          Stattdessen verhunzt du dir die dpkg-Datenbank.
          apt policy influxdb2-cli
          bringt?
            MCU @Thomas Braun last edited by MCU
            @thomas-braun So?
            sudo apt update && sudo apt install influxdb2-cli
            Get:1 http://security.debian.org bullseye-security InRelease [44.1 kB]
            Get:2 http://ftp.debian.org/debian bullseye InRelease [116 kB]
            Get:3 https://repos.influxdata.com/debian stable InRelease [4645 B]
            Get:4 http://ftp.debian.org/debian bullseye-updates InRelease [39.4 kB]
            Get:5 http://security.debian.org bullseye-security/main amd64 Packages [164 kB]
            Get:6 https://repos.influxdata.com/debian stable/main amd64 Packages [1263 B]
            Get:7 http://security.debian.org bullseye-security/main Translation-en [103 kB]
            Get:8 http://ftp.debian.org/debian bullseye/main amd64 Packages [8182 kB]
            Get:9 http://ftp.debian.org/debian bullseye/main Translation-en [6243 kB]
            Get:10 http://ftp.debian.org/debian bullseye/contrib amd64 Packages [50.6 kB]
            Get:11 http://ftp.debian.org/debian bullseye/contrib Translation-en [46.9 kB]
            Fetched 15.0 MB in 2s (7736 kB/s)
            Reading package lists... Done
            Building dependency tree... Done
            12 packages can be upgraded. Run 'apt list --upgradable' to see them.
            N: Repository 'http://ftp.debian.org/debian bullseye InRelease' changed its 'Version' value from '11.3' to '11.4'
            influxdb2-cli is already the newest version (2.3.0).
            0 upgraded, 0 newly installed, 0 to remove and 12 not upgraded.
            influxdb2-cli:
              Installed: 2.3.0
              Candidate: 2.3.0
              Version table:
             *** 2.3.0 500
                    500 https://repos.influxdata.com/debian stable/main amd64 Packages
                    100 /var/lib/dpkg/status
              @mcu sagte in Test Adapter ioBroker.backitup v2.4.x:
              ist also bereits installiert.
              which influx
              liefert?
              Hau die 12 Updates rein...
                sudo apt update
                [sudo] password for prox:
                Hit:1 http://ftp.debian.org/debian bullseye InRelease
                Hit:2 http://security.debian.org bullseye-security InRelease
                Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
                Hit:4 https://repos.influxdata.com/debian stable InRelease
                All packages are up to date.
                which influx
                /usr/local/bin/influx
                  sudo rm /usr/local/bin/influx
                  exit
                  Wieder einloggen und dann nochmal
                  which influx
                  Und warum hast du nodejs nicht als Repo? Das ist wichtig! (Ah, das ist nicht die Dose mit dem ioBroker...)
                  • simatec
                    simatec Developer Most Active @MCU last edited by
                    @mcu nich influxd … nur influx
                      which influx
                      /usr/bin/influx
                        MCU @simatec last edited by MCU
                        @simatec
                          @mcu
                          rm influxdb2*
                          apt policy influxdb*
                            @thomas-braun sagte in Test Adapter ioBroker.backitup v2.4.x:
                            rm influxdb2*
                            rm influxdb2*
                            rm: cannot remove 'influxdb2-client-2.3.0-linux-amd64': Is a directory
                            mit sudo?
                            N: Unable to locate package influxdb.key
                            N: Couldn't find any package by glob 'influxdb.key'
                            N: Unable to locate package influxdb2-client-2.3.0-linux-amd64
                            N: Couldn't find any package by glob 'influxdb2-client-2.3.0-linux-amd64'
                              @mcu
                              ls -la
                              Und bitte vollständige Ein- wie Ausgabezeilen inkl. LogIn-Prompt, damit ich sehe wo du da im Tree stehst.
                                ls -la
                                prox@influxdb:~$ ls -la
                                total 32
                                drwxr-xr-x 3 prox prox 4096 Jul 10 20:41 .
                                drwxr-xr-x 3 root root 4096 Jun 26 07:23 ..
                                -rw------- 1 prox prox 1297 Jul 10 20:37 .bash_history
                                -rw-r--r-- 1 prox prox  220 Jun 26 07:23 .bash_logout
                                -rw-r--r-- 1 prox prox 3526 Jun 26 07:23 .bashrc
                                -rw-r--r-- 1 prox prox  807 Jun 26 07:23 .profile
                                -rw-r--r-- 1 prox prox 3108 May  4  2021 influxdb.key
                                drwxr-xr-x 2 prox prox 4096 Jul 10 19:42 influxdb2-client-2.3.0-linux-amd64
                                prox@influxdb:~$
                                  @mcu
                                  rm -rf influx*
                                    @thomas-braun Geht nur mit sudo rm influx*. OK?
                                    Oder so:
                                    ls -la
                                    total 24
                                    drwxr-xr-x 2 prox prox 4096 Jul 10 20:47 .
                                      @mcu
                                      Nein, das muss auch mit dem user prox funktionieren, dem gehört der Sums ja.
                                      rm -rf influx*
                                        influxdb2-cli:
                                          Installed: 2.3.0
                                          Candidate: 2.3.0
                                          Version table:
                                         *** 2.3.0 500
                                        influxdb-client:
                                          Installed: (none)
                                          Candidate: 1.6.7~rc0-1+b5
                                          Version table:
                                             1.6.7~rc0-1+b5 500
                                                500 http://ftp.debian.org/debian bullseye/main amd64 Packages
                                        influxdb-dev:
                                          Installed: (none)
                                          Candidate: (none)
                                          Version table:
                                        influxdb:
                                          Installed: (none)
                                          Candidate: 1.8.10-1
                                          Version table:
                                             1.8.10-1 500
                                             1.6.7~rc0-1+b5 500
                                        influxdb2:
                                          Installed: 2.3.0-1
                                          Candidate: 2.3.0-1
                                          Version table:
                                         *** 2.3.0-1 500
                                          @mcu
                                          bringt nun?
                                            @mcu @simatec
                                            Muss der client auf dem System mit dem ioBroker installiert sein?
                                            Mir war so.
                                            M simatec 2 Replies Last reply Reply Quote 0
                                            1.0k
                                            170
                                            2780
                                            2376277
