      MCU @Thomas Braun last edited by
      @thomas-braun Das habe ich doch bei der Installation von influxdb2 schon so gemacht?
      apt install sudo curl gpg gnupg2 wget -y
      wget -q https://repos.influxdata.com/influxdb.key
      echo '23a1c8836f0afc5ed24e0486339d7cc8f6790b83886c4c96995b88a061c5bb5d influxdb.key' | sha256sum -c && cat influxdb.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdb.gpg > /dev/null
      echo 'deb [signed-by=/etc/apt/trusted.gpg.d/influxdb.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
      sudo apt-get update && sudo apt-get install influxdb2
        Thomas Braun Most Active @MCU last edited by Thomas Braun
        @mcu
        Und warum installierst du dann den client nicht auch daraus?
        Stattdessen verhunzt du dir die dpkg-Datenbank.
        apt policy influxdb2-cli
        bringt?
          MCU @Thomas Braun last edited by MCU
          @thomas-braun So?
          sudo apt update && sudo apt install influxdb2-cli
          Get:1 http://security.debian.org bullseye-security InRelease [44.1 kB]
          Get:2 http://ftp.debian.org/debian bullseye InRelease [116 kB]
          Get:3 https://repos.influxdata.com/debian stable InRelease [4645 B]
          Get:4 http://ftp.debian.org/debian bullseye-updates InRelease [39.4 kB]
          Get:5 http://security.debian.org bullseye-security/main amd64 Packages [164 kB]
          Get:6 https://repos.influxdata.com/debian stable/main amd64 Packages [1263 B]
          Get:7 http://security.debian.org bullseye-security/main Translation-en [103 kB]
          Get:8 http://ftp.debian.org/debian bullseye/main amd64 Packages [8182 kB]
          Get:9 http://ftp.debian.org/debian bullseye/main Translation-en [6243 kB]
          Get:10 http://ftp.debian.org/debian bullseye/contrib amd64 Packages [50.6 kB]
          Get:11 http://ftp.debian.org/debian bullseye/contrib Translation-en [46.9 kB]
          Fetched 15.0 MB in 2s (7736 kB/s)
          Reading package lists... Done
          Building dependency tree... Done
          12 packages can be upgraded. Run 'apt list --upgradable' to see them.
          N: Repository 'http://ftp.debian.org/debian bullseye InRelease' changed its 'Version' value from '11.3' to '11.4'
          influxdb2-cli is already the newest version (2.3.0).
          0 upgraded, 0 newly installed, 0 to remove and 12 not upgraded.
          influxdb2-cli:
            Installed: 2.3.0
            Candidate: 2.3.0
            Version table:
           *** 2.3.0 500
                  500 https://repos.influxdata.com/debian stable/main amd64 Packages
                  100 /var/lib/dpkg/status
            @mcu sagte in Test Adapter ioBroker.backitup v2.4.x:
            ist also bereits installiert.
            which influx
            liefert?
            Hau die 12 Updates rein...
              sudo apt update
              [sudo] password for prox:
              Hit:1 http://ftp.debian.org/debian bullseye InRelease
              Hit:2 http://security.debian.org bullseye-security InRelease
              Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
              Hit:4 https://repos.influxdata.com/debian stable InRelease
              All packages are up to date.
              which influx
              /usr/local/bin/influx
                sudo rm /usr/local/bin/influx
                exit
                Wieder einloggen und dann nochmal
                which influx
                Und warum hast du nodejs nicht als Repo? Das ist wichtig! (Ah, das ist nicht die Dose mit dem ioBroker...)
                • simatec
                  simatec Developer Most Active @MCU last edited by
                  @mcu nich influxd … nur influx
                    which influx
                    /usr/bin/influx
                      MCU @simatec last edited by MCU
                      @simatec
                        @mcu
                        rm influxdb2*
                        apt policy influxdb*
                          @thomas-braun sagte in Test Adapter ioBroker.backitup v2.4.x:
                          rm influxdb2*
                          rm influxdb2*
                          rm: cannot remove 'influxdb2-client-2.3.0-linux-amd64': Is a directory
                          mit sudo?
                          N: Unable to locate package influxdb.key
                          N: Couldn't find any package by glob 'influxdb.key'
                          N: Unable to locate package influxdb2-client-2.3.0-linux-amd64
                          N: Couldn't find any package by glob 'influxdb2-client-2.3.0-linux-amd64'
                            @mcu
                            ls -la
                            Und bitte vollständige Ein- wie Ausgabezeilen inkl. LogIn-Prompt, damit ich sehe wo du da im Tree stehst.
                              ls -la
                              prox@influxdb:~$ ls -la
                              total 32
                              drwxr-xr-x 3 prox prox 4096 Jul 10 20:41 .
                              drwxr-xr-x 3 root root 4096 Jun 26 07:23 ..
                              -rw------- 1 prox prox 1297 Jul 10 20:37 .bash_history
                              -rw-r--r-- 1 prox prox  220 Jun 26 07:23 .bash_logout
                              -rw-r--r-- 1 prox prox 3526 Jun 26 07:23 .bashrc
                              -rw-r--r-- 1 prox prox  807 Jun 26 07:23 .profile
                              -rw-r--r-- 1 prox prox 3108 May  4  2021 influxdb.key
                              drwxr-xr-x 2 prox prox 4096 Jul 10 19:42 influxdb2-client-2.3.0-linux-amd64
                              prox@influxdb:~$
                                @mcu
                                rm -rf influx*
                                  @thomas-braun Geht nur mit sudo rm influx*. OK?
                                  Oder so:
                                  ls -la
                                  total 24
                                  drwxr-xr-x 2 prox prox 4096 Jul 10 20:47 .
                                    @mcu
                                    Nein, das muss auch mit dem user prox funktionieren, dem gehört der Sums ja.
                                    rm -rf influx*
                                      influxdb2-cli:
                                        Installed: 2.3.0
                                        Candidate: 2.3.0
                                        Version table:
                                       *** 2.3.0 500
                                      influxdb-client:
                                        Installed: (none)
                                        Candidate: 1.6.7~rc0-1+b5
                                        Version table:
                                           1.6.7~rc0-1+b5 500
                                              500 http://ftp.debian.org/debian bullseye/main amd64 Packages
                                      influxdb-dev:
                                        Installed: (none)
                                        Candidate: (none)
                                        Version table:
                                      influxdb:
                                        Installed: (none)
                                        Candidate: 1.8.10-1
                                        Version table:
                                           1.8.10-1 500
                                           1.6.7~rc0-1+b5 500
                                      influxdb2:
                                        Installed: 2.3.0-1
                                        Candidate: 2.3.0-1
                                        Version table:
                                       *** 2.3.0-1 500
                                        @mcu
                                        bringt nun?
                                          @mcu @simatec
                                          Muss der client auf dem System mit dem ioBroker installiert sein?
                                          Mir war so.
                                          M simatec 2 Replies Last reply Reply Quote 0
                                            @thomas-braun Also das auf dem ioBroker-System?
                                            1.0k
                                            170
                                            2780
                                            2376277
