    4. Alpha Testing: OCPP Wallbox Adapter
      MoonlanderPi @Glasfaser last edited by
      @glasfaser
      Sorry gelobe Besserung
      pi@iobroker-pi:~ $ iobroker debug ocpp
      Debugger listening on ws://127.0.0.1:9229/9525d1f9-4e6e-4427-8085-06d0c63aa0a6
      For help, see: https://nodejs.org/en/docs/inspector
      2022-07-08 19:11:02.689  - debug: ocpp.0 (1506) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2022-07-08 19:11:02.785  - debug: ocpp.0 (1506) Objects client ready ... initialize now
      2022-07-08 19:11:02.790  - debug: ocpp.0 (1506) Objects create System PubSub Client
      2022-07-08 19:11:02.793  - debug: ocpp.0 (1506) Objects create User PubSub Client
      2022-07-08 19:11:02.873  - debug: ocpp.0 (1506) Objects client initialize lua scripts
      2022-07-08 19:11:02.885  - debug: ocpp.0 (1506) Objects connected to redis: 127.0.0.1:9001
      2022-07-08 19:11:02.944  - debug: ocpp.0 (1506) Redis States: Use Redis connection: 127.0.0.1:9000
      2022-07-08 19:11:02.969  - debug: ocpp.0 (1506) States create System PubSub Client
      2022-07-08 19:11:02.973  - debug: ocpp.0 (1506) States create User PubSub Client
      2022-07-08 19:11:03.032  - debug: ocpp.0 (1506) States connected to redis: 127.0.0.1:9000
      2022-07-08 19:11:03.124  - error: ocpp.0 (1506) adapter disabled
      2022-07-08 19:11:03.428  - info: ocpp.0 (1506) starting. Version 0.4.0 in /opt/iobroker/node_modules/iobroker.ocpp, node: v14.20.0, js-controller: 4.0.23
      2022-07-08 19:11:03.508  - info: ocpp.0 (1506) Starting OCPP Server
      [winston] Attempt to write logs with no transports, which can increase memory usage: {"message":"Listen on default host:9220","level":"debug"}
      2022-07-08 19:11:03.611  - info: ocpp.0 (1506) Server listening on port 9220
      2022-07-08 19:11:04.000  - debug: ocpp.0 (1506) Connection from "/C2011601CNYEYPES" with credentials "undefined", protocol: "http", OCPP: ocpp1.6
      2022-07-08 19:11:04.002  - info: ocpp.0 (1506) New valid connection from "/C2011601CNYEYPES" (http/ocpp1.6)
      [winston] Attempt to write logs with no transports, which can increase memory usage: {"url":"/C2011601CNYEYPES","protocol":"ocpp1.6","isValid":true,"headers":{"connection":"Upgrade","host":"192.168.178.49:9220","sec-websocket-key":"TSCsoaMNHeBhvENtnKEFqQ==","sec-websocket-protocol":"ocpp1.6","sec-websocket-version":"13","upgrade":"websocket"},"level":"info","message":"[OCPP] Request for connect \"/C2011601CNYEYPES\" (ocpp1.6) - Valid identifier. Headers: {\"connection\":\"Upgrade\",\"host\":\"192.168.178.49:9220\",\"sec-websocket-key\":\"TSCsoaMNHeBhvENtnKEFqQ==\",\"sec-websocket-protocol\":\"ocpp1.6\",\"sec-websocket-version\":\"13\",\"upgrade\":\"websocket\"}"}
      [winston] Attempt to write logs with no transports, which can increase memory usage: {"ip":"::ffff:192.168.178.93","protocol":"ocpp1.6","url":"/C2011601CNYEYPES","level":"info","message":"[OCPP] New connection from \"::ffff:192.168.178.93\", protocol \"ocpp1.6\", url \"/C2011601CNYEYPES\""}
      [winston] Attempt to write logs with no transports, which can increase memory usage: {"url":"/C2011601CNYEYPES","message":"[OCPP] Received message: [2,\"11286\",\"BootNotification\",{\"firmwareVersion\":\"1.1.1807.1-2.2.10.23\",\"imsi\":\"460010912121001\",\"chargePointModel\":\"C2EU\",\"chargePointSerialNumber\":\"C2011601CNYEYPES\",\"chargePointVendor\":\"XC\"}] [2,\"11286\",\"BootNotification\",{\"firmwareVersion\":\"1.1.1807.1-2.2.10.23\",\"imsi\":\"460010912121001\",\"chargePointModel\":\"C2EU\",\"chargePointSerialNumber\":\"C2011601CNYEYPES\",\"chargePointVendor\":\"XC\"}]","level":"info"}
      2022-07-08 19:11:04.152  - info: ocpp.0 (1506) New device connected: "/C2011601CNYEYPES"
      2022-07-08 19:11:04.155  - info: ocpp.0 (1506) Requesting StatusNotification from "/C2011601CNYEYPES"
      [winston] Attempt to write logs with no transports, which can increase memory usage: {"url":"/C2011601CNYEYPES","message":"[OCPP] Sending message: [2,\"b71c38c0-1566-4148-b827-47f709a490ef\",\"TriggerMessage\",{\"requestedMessage\":\"StatusNotification\"}] [2,\"b71c38c0-1566-4148-b827-47f709a490ef\",\"TriggerMessage\",{\"requestedMessage\":\"StatusNotification\"}]","level":"info"}
      [winston] Attempt to write logs with no transports, which can increase memory usage: {"url":"/C2011601CNYEYPES","message":"[OCPP] Received response: [3,\"b71c38c0-1566-4148-b827-47f709a490ef\",{\"status\":\"Accepted\"}] [3,\"b71c38c0-1566-4148-b827-47f709a490ef\",{\"status\":\"Accepted\"}]","level":"info"}
      [winston] Attempt to write logs with no transports, which can increase memory usage: {"url":"/C2011601CNYEYPES","message":"[OCPP] Received message: [2,\"11287\",\"StatusNotification\",{\"errorCode\":\"NoError\",\"timestamp\":\"2022-07-08T17:11:03+00:00\",\"connectorId\":1,\"status\":\"Finishing\"}] [2,\"11287\",\"StatusNotification\",{\"errorCode\":\"NoError\",\"timestamp\":\"2022-07-08T17:11:03+00:00\",\"connectorId\":1,\"status\":\"Finishing\"}]","level":"info"}
      2022-07-08 19:11:04.213  - debug: ocpp.0 (1506) {"errorCode":"NoError","timestamp":"2022-07-08T17:11:03+00:00","connectorId":1,"status":"Finishing","commandOcpp":"StatusNotification"}
      2022-07-08 19:11:04.214  - info: ocpp.0 (1506) Received Status Notification from "/C2011601CNYEYPES": Finishing
      [winston] Attempt to write logs with no transports, which can increase memory usage: {"url":"/C2011601CNYEYPES","message":"[OCPP] Sending response: [3,\"11287\",{}] [3,\"11287\",{}]","level":"info"}
      2022-07-08 19:11:04.338  - debug: ocpp.0 (1506) {"firmwareVersion":"1.1.1807.1-2.2.10.23","imsi":"460010912121001","chargePointModel":"C2EU","chargePointSerialNumber":"C2011601CNYEYPES","chargePointVendor":"XC","commandOcpp":"BootNotification"}
      2022-07-08 19:11:04.340  - info: ocpp.0 (1506) Received boot notification from "/C2011601CNYEYPES"
      [winston] Attempt to write logs with no transports, which can increase memory usage: {"url":"/C2011601CNYEYPES","message":"[OCPP] Sending response: [3,\"11286\",{\"status\":\"Accepted\",\"currentTime\":\"2022-07-08T17:11:04.363Z\",\"interval\":55}] [3,\"11286\",{\"status\":\"Accepted\",\"currentTime\":\"2022-07-08T17:11:04.363Z\",\"interval\":55}]","level":"info"}
      [winston] Attempt to write logs with no transports, which can increase memory usage: {"url":"/C2011601CNYEYPES","message":"[OCPP] Received message: [2,\"11288\",\"StatusNotification\",{\"connectorId\":1,\"timestamp\":\"2022-07-08T17:11:04+00:00\",\"errorCode\":\"NoError\",\"status\":\"Finishing\"}] [2,\"11288\",\"StatusNotification\",{\"connectorId\":1,\"timestamp\":\"2022-07-08T17:11:04+00:00\",\"errorCode\":\"NoError\",\"status\":\"Finishing\"}]","level":"info"}
      2022-07-08 19:11:04.578  - debug: ocpp.0 (1506) {"connectorId":1,"timestamp":"2022-07-08T17:11:04+00:00","errorCode":"NoError","status":"Finishing","commandOcpp":"StatusNotification"}
      2022-07-08 19:11:04.581  - info: ocpp.0 (1506) Received Status Notification from "/C2011601CNYEYPES": Finishing
      [winston] Attempt to write logs with no transports, which can increase memory usage: {"url":"/C2011601CNYEYPES","message":"[OCPP] Sending response: [3,\"11288\",{}] [3,\"11288\",{}]","level":"info"}
      [winston] Attempt to write logs with no transports, which can increase memory usage: {"url":"/C2011601CNYEYPES","message":"[OCPP] Received message: [2,\"11289\",\"Heartbeat\",{}] [2,\"11289\",\"Heartbeat\",{}]","level":"info"}
      2022-07-08 19:11:04.625  - debug: ocpp.0 (1506) {"commandOcpp":"Heartbeat"}
      2022-07-08 19:11:04.627  - debug: ocpp.0 (1506) Received heartbeat from "/C2011601CNYEYPES"
      [winston] Attempt to write logs with no transports, which can increase memory usage: {"url":"/C2011601CNYEYPES","message":"[OCPP] Sending response: [3,\"11289\",{\"currentTime\":\"2022-07-08T17:11:04.630Z\"}] [3,\"11289\",{\"currentTime\":\"2022-07-08T17:11:04.630Z\"}]","level":"info"}
      2022-07-08 19:11:05.212  - info: ocpp.0 (1506) Requesting MeterValues from "/C2011601CNYEYPES"
      [winston] Attempt to write logs with no transports, which can increase memory usage: {"url":"/C2011601CNYEYPES","message":"[OCPP] Sending message: [2,\"bd690c97-9bca-4451-a945-d0b289f30f8b\",\"TriggerMessage\",{\"requestedMessage\":\"MeterValues\"}] [2,\"bd690c97-9bca-4451-a945-d0b289f30f8b\",\"TriggerMessage\",{\"requestedMessage\":\"MeterValues\"}]","level":"info"}
      [winston] Attempt to write logs with no transports, which can increase memory usage: {"url":"/C2011601CNYEYPES","message":"[OCPP] Received response: [3,\"bd690c97-9bca-4451-a945-d0b289f30f8b\",{\"status\":\"Accepted\"}] [3,\"bd690c97-9bca-4451-a945-d0b289f30f8b\",{\"status\":\"Accepted\"}]","level":"info"}
      [winston] Attempt to write logs with no transports, which can increase memory usage: {"url":"/C2011601CNYEYPES","message":"[OCPP] Received message: [2,\"11290\",\"MeterValues\",{\"connectorId\":1,\"meterValue\":[{\"timestamp\":\"2022-07-08T17:11:04+00:00\",\"sampledValue\":[{\"context\":\"Trigger\",\"value\":\"43.0\",\"unit\":\"Celsius\",\"measurand\":\"Temperature\",\"format\":\"Raw\",\"location\":\"Body\"},{\"context\":\"Trigger\",\"value\":\"0.0\",\"unit\":\"A\",\"measurand\":\"Current.Import\",\"format\":\"Raw\",\"location\":\"Outlet\",\"phase\":\"L1\"},{\"context\":\"Trigger\",\"value\":\"234.3\",\"unit\":\"V\",\"measurand\":\"Voltage\",\"format\":\"Raw\",\"location\":\"Outlet\",\"phase\":\"L1\"},{\"context\":\"Trigger\",\"value\":\"0.0\",\"unit\":\"kW\",\"measurand\":\"Power.Active.Import\",\"format\":\"Raw\",\"location\":\"Outlet\"},{\"context\":\"Trigger\",\"value\":\"6340\",\"unit\":\"Wh\",\"measurand\":\"Energy.Active.Import.Register\",\"format\":\"Raw\",\"location\":\"Outlet\"}]}]}] [2,\"11290\",\"MeterValues\",{\"connectorId\":1,\"meterValue\":[{\"timestamp\":\"2022-07-08T17:11:04+00:00\",\"sampledValue\":[{\"context\":\"Trigger\",\"value\":\"43.0\",\"unit\":\"Celsius\",\"measurand\":\"Temperature\",\"format\":\"Raw\",\"location\":\"Body\"},{\"context\":\"Trigger\",\"value\":\"0.0\",\"unit\":\"A\",\"measurand\":\"Current.Import\",\"format\":\"Raw\",\"location\":\"Outlet\",\"phase\":\"L1\"},{\"context\":\"Trigger\",\"value\":\"234.3\",\"unit\":\"V\",\"measurand\":\"Voltage\",\"format\":\"Raw\",\"location\":\"Outlet\",\"phase\":\"L1\"},{\"context\":\"Trigger\",\"value\":\"0.0\",\"unit\":\"kW\",\"measurand\":\"Power.Active.Import\",\"format\":\"Raw\",\"location\":\"Outlet\"},{\"context\":\"Trigger\",\"value\":\"6340\",\"unit\":\"Wh\",\"measurand\":\"Energy.Active.Import.Register\",\"format\":\"Raw\",\"location\":\"Outlet\"}]}]}]","level":"info"}
      2022-07-08 19:11:05.304  - debug: ocpp.0 (1506) {"connectorId":1,"meterValue":[{"timestamp":"2022-07-08T17:11:04+00:00","sampledValue":[{"context":"Trigger","value":"43.0","unit":"Celsius","measurand":"Temperature","format":"Raw","location":"Body"},{"context":"Trigger","value":"0.0","unit":"A","measurand":"Current.Import","format":"Raw","location":"Outlet","phase":"L1"},{"context":"Trigger","value":"234.3","unit":"V","measurand":"Voltage","format":"Raw","location":"Outlet","phase":"L1"},{"context":"Trigger","value":"0.0","unit":"kW","measurand":"Power.Active.Import","format":"Raw","location":"Outlet"},{"context":"Trigger","value":"6340","unit":"Wh","measurand":"Energy.Active.Import.Register","format":"Raw","location":"Outlet"}]}],"commandOcpp":"MeterValues"}
      2022-07-08 19:11:05.307  - info: ocpp.0 (1506) Received MeterValues from "/C2011601CNYEYPES"
      [winston] Attempt to write logs with no transports, which can increase memory usage: {"url":"/C2011601CNYEYPES","message":"[OCPP] Sending response: [3,\"11290\",{}] [3,\"11290\",{}]","level":"info"}
      2022-07-08 19:11:06.297  - info: ocpp.0 (1506) Sending GetConfiguration to "/C2011601CNYEYPES"
      2022-07-08 19:11:59.453  - debug: ocpp.0 (1506) {"commandOcpp":"Heartbeat"}
      2022-07-08 19:11:59.456  - debug: ocpp.0 (1506) Received heartbeat from "/C2011601CNYEYPES"
      2022-07-08 19:12:09.710  - debug: ocpp.0 (1506) Sending SetChargingProfile for /C2011601CNYEYPES
      2022-07-08 19:12:54.459  - debug: ocpp.0 (1506) {"commandOcpp":"Heartbeat"}
      2022-07-08 19:12:54.461  - debug: ocpp.0 (1506) Received heartbeat from "/C2011601CNYEYPES"
      Glasfaser 1 Reply Last reply Reply Quote 1
        MoonlanderPi last edited by
        Was mir auffällt das die Zeit nicht zusammen passt.
        Wie reagiert OCPP darauf. wüsste auch nicht wie ich die an der Box einstellen sollte.
        Müsste dann eher den ioBroker auf die UTC bringen 😲
        • Glasfaser
          Glasfaser @MoonlanderPi last edited by
          @moonlanderpi sagte in Alpha Testing: OCPP Wallbox Adapter:
          @glasfaser
          Bitte auch die anderen dazu auch änderen , die du zuvor eingestellt hast !
            Thomas Braun Most Active @MoonlanderPi last edited by
            Was meinst du? Die Wallbox läuft auf Z-Zeit. Das ist aber vollkommen i. O., würde ich sagen.
              So habe jetzt mal überall rumgespielt und geloggt.
              Es scheint alles irgendwie eine Reaktion auszulösen.
              Nur das ChargeLimit verläuft im Sand.
              Wenn ich TransaktionActive schalte, sendet er auch den eingestellten Limit Wert mit habe ich gesehen. Das ändert nur an der Box nichts da diese stoppt wenn ich da spiele.
              Vielleicht kann da jemand was aus dem Log lesen.
              Bin da echt ratlos
              2022-07-08 19:22:04.531  - debug: ocpp.0 (1506) {"commandOcpp":"Heartbeat"}
              2022-07-08 19:22:04.534  - debug: ocpp.0 (1506) Received heartbeat from "/C2011601CNYEYPES"
              2022-07-08 19:22:24.979  - debug: ocpp.0 (1506) Sending RemoteStartTransaction for /C2011601CNYEYPES: {"connectorId":1,"idTag":"1","chargingProfile":{"chargingProfileId":1,"stackLevel":0,"chargingProfilePurpose":"TxDefaultProfile","chargingProfileKind":"Recurring","recurrencyKind":"Daily","chargingSchedule":{"duration":86400,"startSchedule":"2013-01-01T00:00Z","chargingRateUnit":"A","chargingSchedulePeriod":[{"startPeriod":0,"limit":6}]}}}
              2022-07-08 19:22:59.532  - debug: ocpp.0 (1506) {"commandOcpp":"Heartbeat"}
              2022-07-08 19:22:59.534  - debug: ocpp.0 (1506) Received heartbeat from "/C2011601CNYEYPES"
              2022-07-08 19:23:13.013  - debug: ocpp.0 (1506) Sending SetChargingProfile for /C2011601CNYEYPES
              2022-07-08 19:23:21.697  - debug: ocpp.0 (1506) Sending RemoteStopTransaction for /C2011601CNYEYPES
              2022-07-08 19:23:34.709  - debug: ocpp.0 (1506) Sending RemoteStartTransaction for /C2011601CNYEYPES: {"connectorId":1,"idTag":"1","chargingProfile":{"chargingProfileId":1,"stackLevel":0,"chargingProfilePurpose":"TxDefaultProfile","chargingProfileKind":"Recurring","recurrencyKind":"Daily","chargingSchedule":{"duration":86400,"startSchedule":"2013-01-01T00:00Z","chargingRateUnit":"A","chargingSchedulePeriod":[{"startPeriod":0,"limit":8}]}}}
              2022-07-08 19:23:54.545  - debug: ocpp.0 (1506) {"commandOcpp":"Heartbeat"}
              2022-07-08 19:23:54.546  - debug: ocpp.0 (1506) Received heartbeat from "/C2011601CNYEYPES"
              2022-07-08 19:24:49.557  - debug: ocpp.0 (1506) {"commandOcpp":"Heartbeat"}
              2022-07-08 19:24:49.559  - debug: ocpp.0 (1506) Received heartbeat from "/C2011601CNYEYPES"
              2022-07-08 19:25:44.560  - debug: ocpp.0 (1506) {"commandOcpp":"Heartbeat"}
              2022-07-08 19:25:44.562  - debug: ocpp.0 (1506) Received heartbeat from "/C2011601CNYEYPES"
              2022-07-08 19:26:39.575  - debug: ocpp.0 (1506) {"commandOcpp":"Heartbeat"}
              2022-07-08 19:26:39.577  - debug: ocpp.0 (1506) Received heartbeat from "/C2011601CNYEYPES"
              2022-07-08 19:27:34.583  - debug: ocpp.0 (1506) {"commandOcpp":"Heartbeat"}
              2022-07-08 19:27:34.585  - debug: ocpp.0 (1506) Received heartbeat from "/C2011601CNYEYPES"
              2022-07-08 19:28:29.594  - debug: ocpp.0 (1506) {"commandOcpp":"Heartbeat"}
              2022-07-08 19:28:29.596  - debug: ocpp.0 (1506) Received heartbeat from "/C2011601CNYEYPES"
              2022-07-08 19:28:32.846  - debug: ocpp.0 (1506) {"connectorId":1,"timestamp":"2022-07-08T17:28:32+00:00","errorCode":"NoError","status":"Available","commandOcpp":"StatusNotification"}
              2022-07-08 19:28:32.847  - info: ocpp.0 (1506) Received Status Notification from "/C2011601CNYEYPES": Available
              2022-07-08 19:28:44.783  - debug: ocpp.0 (1506) {"connectorId":1,"timestamp":"2022-07-08T17:28:44+00:00","errorCode":"NoError","status":"Preparing","commandOcpp":"StatusNotification"}
              2022-07-08 19:28:44.786  - info: ocpp.0 (1506) Received Status Notification from "/C2011601CNYEYPES": Preparing
              2022-07-08 19:29:24.599  - debug: ocpp.0 (1506) {"commandOcpp":"Heartbeat"}
              2022-07-08 19:29:24.601  - debug: ocpp.0 (1506) Received heartbeat from "/C2011601CNYEYPES"
              2022-07-08 19:29:37.288  - debug: ocpp.0 (1506) {"timestamp":"2022-07-08T17:29:36+00:00","idTag":"C7131506","connectorId":1,"meterStart":6340,"commandOcpp":"StartTransaction"}
              2022-07-08 19:29:37.290  - info: ocpp.0 (1506) Received Start transaction from "/C2011601CNYEYPES"
              2022-07-08 19:29:37.394  - debug: ocpp.0 (1506) {"connectorId":1,"timestamp":"2022-07-08T17:29:36+00:00","errorCode":"NoError","status":"Charging","commandOcpp":"StatusNotification"}
              2022-07-08 19:29:37.396  - info: ocpp.0 (1506) Received Status Notification from "/C2011601CNYEYPES": Charging
              2022-07-08 19:30:01.418  - debug: ocpp.0 (1506) {"connectorId":1,"meterValue":[{"timestamp":"2022-07-08T17:30:00+00:00","sampledValue":[{"value":"47.0","context":"Sample.Clock","unit":"Celsius","measurand":"Temperature","format":"Raw","location":"Body"},{"value":"9.81","context":"Sample.Clock","unit":"A","measurand":"Current.Import","format":"Raw","phase":"L1","location":"Outlet"},{"value":"225.0","context":"Sample.Clock","unit":"V","measurand":"Voltage","format":"Raw","phase":"L1","location":"Outlet"},{"value":"2.198","context":"Sample.Clock","unit":"kW","measurand":"Power.Active.Import","format":"Raw","location":"Outlet"},{"value":"6350","context":"Sample.Clock","unit":"Wh","measurand":"Energy.Active.Import.Register","format":"Raw","location":"Outlet"}]}],"transactionId":1,"commandOcpp":"MeterValues"}
              2022-07-08 19:30:01.421  - info: ocpp.0 (1506) Received MeterValues from "/C2011601CNYEYPES"
              2022-07-08 19:30:19.603  - debug: ocpp.0 (1506) {"commandOcpp":"Heartbeat"}
              2022-07-08 19:30:19.606  - debug: ocpp.0 (1506) Received heartbeat from "/C2011601CNYEYPES"
              2022-07-08 19:30:37.385  - debug: ocpp.0 (1506) {"connectorId":1,"meterValue":[{"timestamp":"2022-07-08T17:30:36+00:00","sampledValue":[{"value":"47.0","context":"Sample.Periodic","unit":"Celsius","measurand":"Temperature","format":"Raw","location":"Body"},{"value":"9.95","context":"Sample.Periodic","unit":"A","measurand":"Current.Import","format":"Raw","phase":"L1","location":"Outlet"},{"value":"224.9","context":"Sample.Periodic","unit":"V","measurand":"Voltage","format":"Raw","phase":"L1","location":"Outlet"},{"value":"2.227","context":"Sample.Periodic","unit":"kW","measurand":"Power.Active.Import","format":"Raw","location":"Outlet"},{"value":"6380","context":"Sample.Periodic","unit":"Wh","measurand":"Energy.Active.Import.Register","format":"Raw","location":"Outlet"}]}],"transactionId":1,"commandOcpp":"MeterValues"}
              2022-07-08 19:30:37.387  - info: ocpp.0 (1506) Received MeterValues from "/C2011601CNYEYPES"
              2022-07-08 19:31:14.603  - debug: ocpp.0 (1506) {"commandOcpp":"Heartbeat"}
              2022-07-08 19:31:14.604  - debug: ocpp.0 (1506) Received heartbeat from "/C2011601CNYEYPES"
              2022-07-08 19:31:37.587  - debug: ocpp.0 (1506) {"connectorId":1,"meterValue":[{"timestamp":"2022-07-08T17:31:37+00:00","sampledValue":[{"value":"45.0","context":"Sample.Periodic","unit":"Celsius","measurand":"Temperature","format":"Raw","location":"Body"},{"value":"10.02","context":"Sample.Periodic","unit":"A","measurand":"Current.Import","format":"Raw","phase":"L1","location":"Outlet"},{"value":"225.8","context":"Sample.Periodic","unit":"V","measurand":"Voltage","format":"Raw","phase":"L1","location":"Outlet"},{"value":"2.253","context":"Sample.Periodic","unit":"kW","measurand":"Power.Active.Import","format":"Raw","location":"Outlet"},{"value":"6410","context":"Sample.Periodic","unit":"Wh","measurand":"Energy.Active.Import.Register","format":"Raw","location":"Outlet"}]}],"transactionId":1,"commandOcpp":"MeterValues"}
              2022-07-08 19:31:37.589  - info: ocpp.0 (1506) Received MeterValues from "/C2011601CNYEYPES"
              2022-07-08 19:32:09.619  - debug: ocpp.0 (1506) {"commandOcpp":"Heartbeat"}
              2022-07-08 19:32:09.621  - debug: ocpp.0 (1506) Received heartbeat from "/C2011601CNYEYPES"
              2022-07-08 19:32:37.760  - debug: ocpp.0 (1506) {"connectorId":1,"meterValue":[{"timestamp":"2022-07-08T17:32:37+00:00","sampledValue":[{"value":"43.0","context":"Sample.Periodic","unit":"Celsius","measurand":"Temperature","format":"Raw","location":"Body"},{"value":"9.94","context":"Sample.Periodic","unit":"A","measurand":"Current.Import","format":"Raw","phase":"L1","location":"Outlet"},{"value":"225.2","context":"Sample.Periodic","unit":"V","measurand":"Voltage","format":"Raw","phase":"L1","location":"Outlet"},{"value":"2.229","context":"Sample.Periodic","unit":"kW","measurand":"Power.Active.Import","format":"Raw","location":"Outlet"},{"value":"6450","context":"Sample.Periodic","unit":"Wh","measurand":"Energy.Active.Import.Register","format":"Raw","location":"Outlet"}]}],"transactionId":1,"commandOcpp":"MeterValues"}
              2022-07-08 19:32:37.762  - info: ocpp.0 (1506) Received MeterValues from "/C2011601CNYEYPES"
              2022-07-08 19:32:42.762  - debug: ocpp.0 (1506) Sending SetChargingProfile for /C2011601CNYEYPES
              2022-07-08 19:33:04.620  - debug: ocpp.0 (1506) {"commandOcpp":"Heartbeat"}
              2022-07-08 19:33:04.623  - debug: ocpp.0 (1506) Received heartbeat from "/C2011601CNYEYPES"
              2022-07-08 19:33:37.860  - debug: ocpp.0 (1506) {"connectorId":1,"meterValue":[{"timestamp":"2022-07-08T17:33:37+00:00","sampledValue":[{"value":"42.0","context":"Sample.Periodic","unit":"Celsius","measurand":"Temperature","format":"Raw","location":"Body"},{"value":"9.9","context":"Sample.Periodic","unit":"A","measurand":"Current.Import","format":"Raw","phase":"L1","location":"Outlet"},{"value":"224.5","context":"Sample.Periodic","unit":"V","measurand":"Voltage","format":"Raw","phase":"L1","location":"Outlet"},{"value":"2.215","context":"Sample.Periodic","unit":"kW","measurand":"Power.Active.Import","format":"Raw","location":"Outlet"},{"value":"6490","context":"Sample.Periodic","unit":"Wh","measurand":"Energy.Active.Import.Register","format":"Raw","location":"Outlet"}]}],"transactionId":1,"commandOcpp":"MeterValues"}
              2022-07-08 19:33:37.862  - info: ocpp.0 (1506) Received MeterValues from "/C2011601CNYEYPES"
              2022-07-08 19:33:59.648  - debug: ocpp.0 (1506) {"commandOcpp":"Heartbeat"}
              2022-07-08 19:33:59.651  - debug: ocpp.0 (1506) Received heartbeat from "/C2011601CNYEYPES"
              2022-07-08 19:34:08.486  - debug: ocpp.0 (1506) Sending RemoteStopTransaction for /C2011601CNYEYPES
              2022-07-08 19:34:09.804  - debug: ocpp.0 (1506) {"timestamp":"2022-07-08T17:34:08+00:00","transactionData":[{"timestamp":"2022-07-08T17:30:00+00:00","sampledValue":[{"context":"Sample.Clock","value":"47.0","unit":"Celsius","measurand":"Temperature","format":"Raw","location":"Body"},{"context":"Sample.Clock","value":"9.81","unit":"A","measurand":"Current.Import","format":"Raw","location":"Outlet","phase":"L1"},{"context":"Sample.Clock","value":"225.0","unit":"V","measurand":"Voltage","format":"Raw","location":"Outlet","phase":"L1"},{"context":"Sample.Clock","value":"2.198","unit":"kW","measurand":"Power.Active.Import","format":"Raw","location":"Outlet"},{"context":"Sample.Clock","value":"6350","unit":"Wh","measurand":"Energy.Active.Import.Register","format":"Raw","location":"Outlet"}]},{"timestamp":"2022-07-08T17:30:36+00:00","sampledValue":[{"context":"Sample.Periodic","value":"47.0","unit":"Celsius","measurand":"Temperature","format":"Raw","location":"Body"},{"context":"Sample.Periodic","value":"9.95","unit":"A","measurand":"Current.Import","format":"Raw","location":"Outlet","phase":"L1"},{"context":"Sample.Periodic","value":"224.9","unit":"V","measurand":"Voltage","format":"Raw","location":"Outlet","phase":"L1"},{"context":"Sample.Periodic","value":"2.227","unit":"kW","measurand":"Power.Active.Import","format":"Raw","location":"Outlet"},{"context":"Sample.Periodic","value":"6380","unit":"Wh","measurand":"Energy.Active.Import.Register","format":"Raw","location":"Outlet"}]},{"timestamp":"2022-07-08T17:31:37+00:00","sampledValue":[{"context":"Sample.Periodic","value":"45.0","unit":"Celsius","measurand":"Temperature","format":"Raw","location":"Body"},{"context":"Sample.Periodic","value":"10.02","unit":"A","measurand":"Current.Import","format":"Raw","location":"Outlet","phase":"L1"},{"context":"Sample.Periodic","value":"225.8","unit":"V","measurand":"Voltage","format":"Raw","location":"Outlet","phase":"L1"},{"context":"Sample.Periodic","value":"2.253","unit":"kW","measurand":"Power.Active.Import","format":"Raw","location":"Outlet"},{"context":"Sample.Periodic","value":"6410","unit":"Wh","measurand":"Energy.Active.Import.Register","format":"Raw","location":"Outlet"}]},{"timestamp":"2022-07-08T17:32:37+00:00","sampledValue":[{"context":"Sample.Periodic","value":"43.0","unit":"Celsius","measurand":"Temperature","format":"Raw","location":"Body"},{"context":"Sample.Periodic","value":"9.94","unit":"A","measurand":"Current.Import","format":"Raw","location":"Outlet","phase":"L1"},{"context":"Sample.Periodic","value":"225.2","unit":"V","measurand":"Voltage","format":"Raw","location":"Outlet","phase":"L1"},{"context":"Sample.Periodic","value":"2.229","unit":"kW","measurand":"Power.Active.Import","format":"Raw","location":"Outlet"},{"context":"Sample.Periodic","value":"6450","unit":"Wh","measurand":"Energy.Active.Import.Register","format":"Raw","location":"Outlet"}]},{"timestamp":"2022-07-08T17:33:37+00:00","sampledValue":[{"context":"Sample.Periodic","value":"42.0","unit":"Celsius","measurand":"Temperature","format":"Raw","location":"Body"},{"context":"Sample.Periodic","value":"9.9","unit":"A","measurand":"Current.Import","format":"Raw","location":"Outlet","phase":"L1"},{"context":"Sample.Periodic","value":"224.5","unit":"V","measurand":"Voltage","format":"Raw","location":"Outlet","phase":"L1"},{"context":"Sample.Periodic","value":"2.215","unit":"kW","measurand":"Power.Active.Import","format":"Raw","location":"Outlet"},{"context":"Sample.Periodic","value":"6490","unit":"Wh","measurand":"Energy.Active.Import.Register","format":"Raw","location":"Outlet"}]}],"meterStop":6510,"transactionId":1,"idTag":"C7131506","reason":"Local","commandOcpp":"StopTransaction"}
              2022-07-08 19:34:09.810  - info: ocpp.0 (1506) Received stop transaction from "/C2011601CNYEYPES"
              2022-07-08 19:34:09.829  - debug: ocpp.0 (1506) {"connectorId":1,"timestamp":"2022-07-08T17:34:09+00:00","errorCode":"NoError","status":"Finishing","commandOcpp":"StatusNotification"}
              2022-07-08 19:34:09.833  - info: ocpp.0 (1506) Received Status Notification from "/C2011601CNYEYPES": Finishing
              2022-07-08 19:34:21.779  - debug: ocpp.0 (1506) Sending RemoteStartTransaction for /C2011601CNYEYPES: {"connectorId":1,"idTag":"1","chargingProfile":{"chargingProfileId":1,"stackLevel":0,"chargingProfilePurpose":"TxDefaultProfile","chargingProfileKind":"Recurring","recurrencyKind":"Daily","chargingSchedule":{"duration":86400,"startSchedule":"2013-01-01T00:00Z","chargingRateUnit":"A","chargingSchedulePeriod":[{"startPeriod":0,"limit":8}]}}}
              2022-07-08 19:34:54.666  - debug: ocpp.0 (1506) {"commandOcpp":"Heartbeat"}
              2022-07-08 19:34:54.668  - debug: ocpp.0 (1506) Received heartbeat from "/C2011601CNYEYPES"
              2022-07-08 19:35:21.726  - debug: ocpp.0 (1506) Sending ChangeAvailability for /C2011601CNYEYPES: Inoperative
              2022-07-08 19:35:22.320  - debug: ocpp.0 (1506) {"connectorId":1,"timestamp":"2022-07-08T17:35:21+00:00","errorCode":"NoError","status":"Unavailable","commandOcpp":"StatusNotification"}
              2022-07-08 19:35:22.322  - info: ocpp.0 (1506) Received Status Notification from "/C2011601CNYEYPES": Unavailable
              2022-07-08 19:35:32.543  - debug: ocpp.0 (1506) Sending RemoteStopTransaction for /C2011601CNYEYPES
              2022-07-08 19:35:45.796  - debug: ocpp.0 (1506) Sending ChangeAvailability for /C2011601CNYEYPES: Operative
              2022-07-08 19:35:46.361  - debug: ocpp.0 (1506) {"connectorId":1,"timestamp":"2022-07-08T17:35:45+00:00","errorCode":"NoError","status":"Finishing","commandOcpp":"StatusNotification"}
              2022-07-08 19:35:46.363  - info: ocpp.0 (1506) Received Status Notification from "/C2011601CNYEYPES": Finishing
              2022-07-08 19:35:49.681  - debug: ocpp.0 (1506) {"commandOcpp":"Heartbeat"}
              2022-07-08 19:35:49.683  - debug: ocpp.0 (1506) Received heartbeat from "/C2011601CNYEYPES"
              2022-07-08 19:35:53.654  - debug: ocpp.0 (1506) Sending RemoteStartTransaction for /C2011601CNYEYPES: {"connectorId":1,"idTag":"1","chargingProfile":{"chargingProfileId":1,"stackLevel":0,"chargingProfilePurpose":"TxDefaultProfile","chargingProfileKind":"Recurring","recurrencyKind":"Daily","chargingSchedule":{"duration":86400,"startSchedule":"2013-01-01T00:00Z","chargingRateUnit":"A","chargingSchedulePeriod":[{"startPeriod":0,"limit":8}]}}}
              2022-07-08 19:36:32.550  - debug: ocpp.0 (1506) Sending ChangeAvailability for /C2011601CNYEYPES: Inoperative
              2022-07-08 19:36:33.094  - debug: ocpp.0 (1506) {"connectorId":1,"timestamp":"2022-07-08T17:36:32+00:00","errorCode":"NoError","status":"Unavailable","commandOcpp":"StatusNotification"}
              2022-07-08 19:36:33.096  - info: ocpp.0 (1506) Received Status Notification from "/C2011601CNYEYPES": Unavailable
              2022-07-08 19:36:39.931  - debug: ocpp.0 (1506) Sending ChangeAvailability for /C2011601CNYEYPES: Operative
              2022-07-08 19:36:40.540  - debug: ocpp.0 (1506) {"connectorId":1,"timestamp":"2022-07-08T17:36:39+00:00","errorCode":"NoError","status":"Finishing","commandOcpp":"StatusNotification"}
              2022-07-08 19:36:40.541  - info: ocpp.0 (1506) Received Status Notification from "/C2011601CNYEYPES": Finishing
              2022-07-08 19:36:44.684  - debug: ocpp.0 (1506) {"commandOcpp":"Heartbeat"}
              2022-07-08 19:36:44.686  - debug: ocpp.0 (1506) Received heartbeat from "/C2011601CNYEYPES"
              2022-07-08 19:37:39.688  - debug: ocpp.0 (1506) {"commandOcpp":"Heartbeat"}
              2022-07-08 19:37:39.690  - debug: ocpp.0 (1506) Received heartbeat from "/C2011601CNYEYPES"
                @glasfaser
                Erledigt
                  MoonlanderPi @Thomas Braun last edited by
                  Kurioserweise ist das auch nur im Protocoll. Hab die Uhrzeit in der Box gecheckt. Die passt.
                    baeckerman83 last edited by baeckerman83
                    Also bei mir geht das mit ChargeLimit ändern plötzlich. Keine Ahnung warum. Was aber ist, es funktioniert bei mir nur wenn ich ein Auto angestöpselt habe und das Auto wirklich lädt.
                    Hat von euch jemand OCPP und NodeRED Adapter im einsetz? Auslegen klappt jetzt mit * statt Namen der Wallbox. Schreiben geht aber nicht mit * und ohne Stern ersetzt NodeRed den / immer durch den *. Wäre hier um einen Tip dankbar. Finde NodeRed einfacher als das JS.
                      MoonlanderPi @baeckerman83 last edited by
                      @baeckerman83
                      Sorry, hab es mit JS gelöst. Finde es mit Blocky sogar viel einfacher als Node.
                      Leider habe ich das senden immernoch nicht hinbekommen.
                      Auto ist angestöpselt und lädt, dennoch wird das Chargelimit ignoriert.
                      Kannst du mal einstellen was du für ein String sendest bzw. bekommst wenn du das Limit gesendet hast?
                        Ich habe leider keine Doku von der Box wie OCPP umgesetzt wurde.
                        Eine Möglichkeit ist eventuell das meine Box Watt statt Ampere braucht.
                        Soweit ich das im OCPP sehe ist es möglich siehe Beispieltelegram.
                        Below you will find an example of a csChargingProfiles sent from the central system to a charge point.
                        “csChargingProfiles”: {
                            “chargingProfileId”: 158798,
                            “chargingProfileKind”: “Absolute”,
                            “chargingProfilePurpose”: “TxProfile”,
                            “chargingSchedule”: {
                                “chargingRateUnit”: “W”,
                                “chargingSchedulePeriod”: [
                                       “limit”: 11000.0,
                                       “startPeriod”: 0
                                       “limit”: 9000.0,
                                       “startPeriod”: 780
                                       “limit”: 4500.0,
                                       “startPeriod”: 1680
                                    “duration”: 1680
                             “stackLevel”: 0,
                             “transactionId”: 339373,
                             “validFrom”: “2020–10–15T14:32:00+00:00”,
                             “validTo”: “2020–10–16T14:15:00+00:00”
                        Gibt es irgendwie eine Möglichkeit im Adapter das mal testweise von "A" auf "W" zu ändern?
                          Also Watt ist es anscheinend auch nicht.
                          Was ich aber bemerkt habe, dass bei RemotetransactionStart, der ID Tag mitgesendet wird.
                          Hab es mal bei der WB getestet, er beginnt nach Status Finishing ert wieder, wenn ich die RFID Karte vorhalte.
                          Den IdTag habe ich auch, aber wie bekomme ich den mitgesendet?
                          Eventuell erwartet die WB das, um Änderungen zu akzeptieren.
                            So hab den IDTag reingebastel. Bringt auch nichts.
                            Stacklevel mal mit 1 probiert leider auch kein Erfolg.
                            Jetzt bin ich echt ratlos was es noch sein könnte.
                            Sending RemoteStartTransaction for /: {"connectorId":1,"idTag":"C7131506","chargingProfile":{"chargingProfileId":1,"stackLevel":1,"chargingProfilePurpose":"TxDefaultProfile","chargingProfileKind":"Recurring","recurrencyKind":"Daily","chargingSchedule":{"duration":86400,"startSchedule":"2013-01-01T00:00Z","chargingRateUnit":"A","chargingSchedulePeriod":[{"startPeriod":0,"limit":8}]}}}
                              derSESO @manuBT last edited by
                              @manubt
                              Wie hast du das in der Elvi aktiviert/eingerichtet?
                              Habe diese Wallbox jetzt auch.
                              Danke.
                              • Meister Mopper
                                Meister Mopper @manuBT last edited by Meister Mopper
                                @manubt sagte in Alpha Testing: OCPP Wallbox Adapter:
                                Der Adapter spricht mit einer EVBox Elvi.
                                Da ich in diesem thread keine weiteren Hinweise gefunden habe, bitte ich mal direkt:
                                Schreibt mir bitte jemand, was man in der App dieser EVBox im Installermenü der Lademanagement Software unter "different backend url" eintragen muss, damit sie mit dem ioBroker kommuniziert?
                                Könnte es diese Syntax sein?
                                ws://<IP_des_ioBroker>:<Port_der_Instanz>
                                edit: Okay, da muss noch ein backslash ans Ende, dann funktioniert es.
                                • Meister Mopper
                                  Meister Mopper @Meister Mopper last edited by Meister Mopper
                                  @foxriver76
                                  So "Er lebt", der Server empfängt heartbeats.
                                  Nach einem Firmwareupdate der EVBox erhalte ich folgendes debug log:
                                  ocpp.0	2022-08-13 18:07:47.235	debug	Received heartbeat from "http://192.168.178.10:9220/XXXXXXXXXXXXX"
                                  ocpp.0	2022-08-13 18:07:47.235	debug	{"commandOcpp":"Heartbeat"}
                                  ocpp.0	2022-08-13 18:06:52.046	debug	Received heartbeat from "http://192.168.178.10:9220/XXXXXXXXXXXXX"
                                  ocpp.0	2022-08-13 18:06:52.046	debug	{"commandOcpp":"Heartbeat"}
                                  ocpp.0	2022-08-13 18:05:57.256	debug	Received heartbeat from "http://192.168.178.10:9220/XXXXXXXXXXXXX"
                                  ocpp.0	2022-08-13 18:05:57.255	debug	{"commandOcpp":"Heartbeat"}
                                  ocpp.0	2022-08-13 18:05:02.138	debug	Received heartbeat from "http://192.168.178.10:9220/XXXXXXXXXXXXX"
                                  ocpp.0	2022-08-13 18:05:02.138	debug	{"commandOcpp":"Heartbeat"}
                                  ocpp.0	2022-08-13 18:04:43.060	warn	Command not implemented from "http://192.168.178.10:9220/XXXXXXXXXXXXX": {"vendorId":"EV-BOX","messageId":"evbStatusNotification","data":"1,SuspendedEV,NoError,No error.,0,Yellow,1,{20,7983,10},{0,0},{B,11883,8634,12272},0,0,450,2022-08-13T16:04:31Z,1,3,{0,0,0,0,0,0,0,0,0},370,0,0,125,0,380,60,0","commandOcpp":"DataTransfer"}
                                  ocpp.0	2022-08-13 18:04:43.059	debug	{"vendorId":"EV-BOX","messageId":"evbStatusNotification","data":"1,SuspendedEV,NoError,No error.,0,Yellow,1,{20,7983,10},{0,0},{B,11883,8634,12272},0,0,450,2022-08-13T16:04:31Z,1,3,{0,0,0,0,0,0,0,0,0},370,0,0,125,0,380,60,0","commandOcpp":"DataTransfer"}
                                  ocpp.0	2022-08-13 18:04:38.070	warn	Command not implemented from "http://192.168.178.10:9220/XXXXXXXXXXXXX": {"vendorId":"EV-BOX","messageId":"evbStatusNotification","data":"1,SuspendedEVSE,NoError,No error.,0,Yellow,1,{20,7982,10},{0,0},{B,11881,8722,9548},0,0,450,2022-08-13T16:04:30Z,1,3,{0,0,0,0,0,0,0,0,0},370,0,0,125,0,380,60,0","commandOcpp":"DataTransfer"}
                                  ocpp.0	2022-08-13 18:04:38.070	debug	{"vendorId":"EV-BOX","messageId":"evbStatusNotification","data":"1,SuspendedEVSE,NoError,No error.,0,Yellow,1,{20,7982,10},{0,0},{B,11881,8722,9548},0,0,450,2022-08-13T16:04:30Z,1,3,{0,0,0,0,0,0,0,0,0},370,0,0,125,0,380,60,0","commandOcpp":"DataTransfer"}
                                  ocpp.0	2022-08-13 18:04:33.048	info	Received Start transaction from "http://192.168.178.10:9220/XXXXXXXXXXXXX"
                                  ocpp.0	2022-08-13 18:04:33.048	debug	{"connectorId":1,"idTag":"048EAB728E6781","timestamp":"2022-08-13T16:04:29Z","meterStart":0,"commandOcpp":"StartTransaction"}
                                  ocpp.0	2022-08-13 18:04:31.169	info	Received Status Notification from "http://192.168.178.10:9220/XXXXXXXXXXXXX": SuspendedEV
                                  ocpp.0	2022-08-13 18:04:31.168	debug	{"connectorId":1,"status":"SuspendedEV","errorCode":"NoError","info":"B;450","timestamp":"2022-08-13T16:04:31Z","commandOcpp":"StatusNotification"}
                                  ocpp.0	2022-08-13 18:04:31.030	info	Received Status Notification from "http://192.168.178.10:9220/XXXXXXXXXXXXX": SuspendedEVSE
                                  ocpp.0	2022-08-13 18:04:31.029	debug	{"connectorId":1,"status":"SuspendedEVSE","errorCode":"NoError","info":"B;450","timestamp":"2022-08-13T16:04:30Z","commandOcpp":"StatusNotification"}
                                  ocpp.0	2022-08-13 18:04:28.207	warn	Command not implemented from "http://192.168.178.10:9220/XXXXXXXXXXXXX": {"vendorId":"EV-BOX","messageId":"evbStatusNotification","data":"1,Preparing,NoError,No error.,0,Off,0,{20,7984,100},{0,0},{B,11872,9164,61568},0,0,450,2022-08-13T16:04:28Z,0,3,{0,0,0,0,0,0,0,0,0},380,0,0,114,0,380,900,0","commandOcpp":"DataTransfer"}
                                  ocpp.0	2022-08-13 18:04:28.206	debug	{"vendorId":"EV-BOX","messageId":"evbStatusNotification","data":"1,Preparing,NoError,No error.,0,Off,0,{20,7984,100},{0,0},{B,11872,9164,61568},0,0,450,2022-08-13T16:04:28Z,0,3,{0,0,0,0,0,0,0,0,0},380,0,0,114,0,380,900,0","commandOcpp":"DataTransfer"}
                                  ocpp.0	2022-08-13 18:04:28.163	info	Received Status Notification from "http://192.168.178.10:9220/XXXXXXXXXXXXX": Preparing
                                  ocpp.0	2022-08-13 18:04:28.163	debug	{"connectorId":1,"status":"Preparing","errorCode":"NoError","timestamp":"2022-08-13T16:04:28Z","commandOcpp":"StatusNotification"}
                                  ocpp.0	2022-08-13 18:04:26.915	info	Received Authorization Request from "http://192.168.178.10:9220/XXXXXXXXXXXXX"
                                  ocpp.0	2022-08-13 18:04:26.915	debug	{"idTag":"048EAB728E6781","commandOcpp":"Authorize"}
                                  ocpp.0	2022-08-13 18:04:21.982	warn	Command not implemented from "http://192.168.178.10:9220/XXXXXXXXXXXXX": {"vendorId":"EV-BOX","messageId":"evbStatusNotification","data":"1,Preparing,NoError,No error.,0,Green,0,{20,7984,100},{0,0},{B,11877,10068,61568},0,0,450,2022-08-13T16:04:21Z,0,3,{0,0,0,0,0,0,0,0,0},380,0,0,114,0,380,900,0","commandOcpp":"DataTransfer"}
                                  ocpp.0	2022-08-13 18:04:21.982	debug	{"vendorId":"EV-BOX","messageId":"evbStatusNotification","data":"1,Preparing,NoError,No error.,0,Green,0,{20,7984,100},{0,0},{B,11877,10068,61568},0,0,450,2022-08-13T16:04:21Z,0,3,{0,0,0,0,0,0,0,0,0},380,0,0,114,0,380,900,0","commandOcpp":"DataTransfer"}
                                  ocpp.0	2022-08-13 18:04:21.942	info	Received Status Notification from "http://192.168.178.10:9220/XXXXXXXXXXXXX": Preparing
                                  ocpp.0	2022-08-13 18:04:21.942	debug	{"connectorId":1,"status":"Preparing","errorCode":"NoError","timestamp":"2022-08-13T16:04:21Z","commandOcpp":"StatusNotification"}
                                  ocpp.0	2022-08-13 18:04:07.047	debug	Received heartbeat from "http://192.168.178.10:9220/XXXXXXXXXXXXX"
                                  ocpp.0	2022-08-13 18:04:07.047	debug	{"commandOcpp":"Heartbeat"}
                                  ocpp.0	2022-08-13 18:03:12.133	debug	Received heartbeat from "http://192.168.178.10:9220/XXXXXXXXXXXXX"
                                  ocpp.0	2022-08-13 18:03:12.133	debug	{"commandOcpp":"Heartbeat"}
                                  ocpp.0	2022-08-13 18:02:17.188	debug	Received heartbeat from "http://192.168.178.10:9220/XXXXXXXXXXXXX"
                                  ocpp.0	2022-08-13 18:02:17.188	debug	{"commandOcpp":"Heartbeat"}
                                  Was hat es aber mit dem log in Zeile 19 auf sich Command not implemented ?
                                  foxriver76 2 Replies Last reply Reply Quote 0
                                  • foxriver76
                                    foxriver76 Developer @Meister Mopper last edited by
                                    @meister-mopper sagte in Alpha Testing: OCPP Wallbox Adapter:
                                    DataTransfer
                                    Die Wallbox sendet DataTransfer Nachrichten, welche ich aktuell nicht behandle. Ich kann mal sehen was man damit anstellen kann. Dafür werde ich mal etwas einbauen, dann benötige ich dein Feedback. Ich gebe dir Bescheid sobald ich es eingebaut habe.
                                    • foxriver76
                                      @meister-mopper Gerne 0.6.0 probieren, es sollte ein Channel mit dataTransfer angelegt werden, der die transferierten Daten enthält.
                                      • Meister Mopper
                                        Meister Mopper @foxriver76 last edited by Meister Mopper
                                        @foxriver76
                                        Super, das warn dataTransfer taucht nicht mehr auf, allerdings bekomme ich immer einen Adapter Neustart, wenn ich transactionActive umstelle true/false.
                                        Im log kommt:
                                        ocpp.0	2022-08-14 16:28:15.966	error	AssertionError [ERR_ASSERTION]: you must provide a joi schema at module.exports.internals.Any.root.reach (/opt/iobroker/node_modules/@ampeco/ocpp-eliftech/node_modules/joi/lib/index.js:200:14) at _loop (/opt/iobroker/node_modules/@ampeco/ocpp-eliftech/dist/helpers.js:58:35) at applyPropertiesValidators (/opt/iobroker/node_modules/@ampeco/ocpp-eliftech/dist/helpers.js:78:16) at RemoteStopTransaction.BaseCommand (/opt/iobroker/node_modules/@ampeco/ocpp-eliftech/dist/commands/BaseCommand.js:32:46) at new RemoteStopTransaction (/opt/iobroker/node_modules/@ampeco/ocpp-eliftech/dist/commands/RemoteStopTransaction.js:46:149) at Ocpp.onStateChange (/opt/iobroker/node_modules/iobroker.ocpp/build/main.js:424:27)
                                        ocpp.0	2022-08-14 16:28:15.966	error	Exception-Code: ERR_ASSERTION: you must provide a joi schema
                                        ocpp.0	2022-08-14 16:28:15.971	info	terminating
                                        ocpp.0	2022-08-14 16:28:15.972	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                        host.iobroker	2022-08-14 16:28:16.608	error	Caught by controller[1]: [winston] Attempt to write logs with no transports {"url":"http://192.168.178.10:9220/XXXXXXXXX","message":"[OCPP] Received message: [2,\"2a8bc2e5-df12-4664-b78f-46cb25c46eac\",\"Heartbeat\",{}] [2,\"2a8bc2e5-df12-4664-b78f-46cb25c46eac\",\"Heartbeat\",{}]","level":"info"}
                                        host.iobroker	2022-08-14 16:28:16.608	error	Caught by controller[1]: [winston] Attempt to write logs with no transports {"url":"http://192.168.178.10:9220/XXXXXXXXX","message":"[OCPP] Sending response: [3,\"2a8bc2e5-df12-4664-b78f-46cb25c46eac\",{\"currentTime\":\"2022-08-14T14:27:49.033Z\"}] [3,\"2a8bc2e5-df12-4664-b78f-46cb25c46eac\",{\"currentTime\":\"2022-08-14T14:27:49.033Z\"}]","level":"info"}
                                        host.iobroker	2022-08-14 16:28:16.609	error	Caught by controller[2]: [winston] Attempt to write logs with no transports {"url":"http://192.168.178.10:9220/XXXXXXXXX","error":1006,"level":"info","message":"[OCPP] Closing socket for http://192.168.178.10:9220/XXXXXXXXX: 1006"}
                                        host.iobroker	2022-08-14 16:28:16.609	error	instance system.adapter.ocpp.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                        ocpp.0	2022-08-14 16:28:47.836	info	starting. Version 0.6.0 (non-npm: foxriver76/ioBroker.ocpp#48303d5b08f18682ed681038d614133990a50c1e) in /opt/iobroker/node_modules/iobroker.ocpp, node: v14.20.0, js-controller: 4.0.23
                                        ocpp.0	2022-08-14 16:28:47.861	info	Starting OCPP Server
                                        ocpp.0	2022-08-14 16:28:47.885	info	Server listening on port 9220
                                        ocpp.0	2022-08-14 16:28:56.214	info	New valid connection from "http://192.168.178.10:9220/XXXXXXXXX" (http/ocpp1.6)
                                        ocpp.0	2022-08-14 16:28:56.264	info	New device connected: "http://192.168.178.10:9220/XXXXXXXXX"
                                        ocpp.0	2022-08-14 16:28:56.265	info	Requesting BootNotification from "http://192.168.178.10:9220/XXXXXXXXX"
                                        ocpp.0	2022-08-14 16:28:56.267	warn	Could not request states of "http://192.168.178.10:9220/XXXXXXXXX": you must provide a joi schema
                                        Dieses Verhalten habe ich auch mit der Version 0.4.0 .
                                        Kann es sein, dass dies die Ursache ist?
                                        Could not request states of "http://192.168.178.10:9220/EVB-XXXXXXXXX": you must provide a joi schema
                                        • foxriver76
                                          Interessant, schaue ich mir an.
                                            @moonlanderpi Kannst du denn an der Wallbox selbst das Chargelimit einstellen? Ich glaube das war es bei mir. Also ich kann es zwischen 6 und 16 einstellen, oder ich stelle die Option aus, dann geht nur 16A.
                                            Da gibt es dann noch eine Option Manuelles einstellen, die musste ich in der App der Terra Box einschalten, sonst konnte auch per OCCP nichts geschickt werden. Vermute zumindest da einen zusammenhang, da seit dem ich das gemacht habe es funktioniert.
                                            31.7k
                                            79.8k
                                            adapter ocpp wallbox
                                            48
                                            440
                                            78122
