    4. Kein Update mehr möglich mit Node.js 16
    • tobasium
      tobasium last edited by tobasium
      @glasfaser ich bin jetzt nochmal auf 6 zurück, damit kann ich auch wieder Pakete updaten. Aber das ist halt nicht die Lösung
      sudo npm install -g npm@6
      dan npm prune
      root@iobroker:/opt/iobroker# npm ls | grep -E 'github.com|ERR'
      sudo: unable to resolve host iobroker: Name or service not known
      npm ERR! missing: iobroker.js-controller@stable, required by iobroker.inst@3.0.0
      npm ERR! extraneous: error-ex /opt/iobroker/node_modules/error-ex
      npm ERR! error in /opt/iobroker/node_modules/error-ex: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/error-ex/package.json'
      npm ERR! extraneous: iobroker.javascript /opt/iobroker/node_modules/iobroker.javascript
      npm ERR! error in /opt/iobroker/node_modules/iobroker.javascript: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/package.json'
      npm ERR! extraneous: utile /opt/iobroker/node_modules/utile
      npm ERR! error in /opt/iobroker/node_modules/utile: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/utile/package.json'
      npm ERR! extraneous: zigbee-herdsman /opt/iobroker/node_modules/zigbee-herdsman
      npm ERR! error in /opt/iobroker/node_modules/zigbee-herdsman: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/zigbee-herdsman/package.json'
      npm ERR! extraneous: zigbee-herdsman-converters /opt/iobroker/node_modules/zigbee-herdsman-converters
      npm ERR! error in /opt/iobroker/node_modules/zigbee-herdsman-converters: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/zigbee-herdsman-converters/package.json'
      • Glasfaser
        Glasfaser @tobasium last edited by
        @tobasium
        in deiner Liste mit NodeJS 16 ,
        npm ERR! invalid: iobroker.admin@5.3.8 /opt/iobroker/node_modules/iobroker.admin
        npm ERR! invalid: iobroker.backitup@2.4.9 /opt/iobroker/node_modules/iobroker.backitup
        npm ERR! invalid: iobroker.discovery@3.0.3 /opt/iobroker/node_modules/iobroker.discovery
        npm ERR! invalid: iobroker.js-controller@4.0.23 /opt/iobroker/node_modules/iobroker.js-controller
        Versuche mal
        iobroker upgrade admin@5.3.8
        iobroker upgrade backitup@2.4.9
        iobroker upgrade discovery@3.0.3
        iobroker upgrade js-controller@4.0.23
        die extraneous mit
        npm prune
        die Frage wäre auch durch dein hin und her wechseln mit den Versionen ob die 16 überhaupt sauber ist .
        sudo ln -s /usr/bin/node /usr/bin/nodejs
        uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
        tobasium 1 Reply Last reply Reply Quote 0
        • tobasium
          tobasium @Glasfaser last edited by
          @glasfaser sagte in Kein Update mehr möglich mit Node.js 16:
          x86_64
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          v16.16.0
          v16.16.0
          6.14.17
          root
          /opt/iobroker
          Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
          Hit:2 http://deb.debian.org/debian bullseye InRelease
          Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
          Hit:4 https://deb.nodesource.com/node_16.x bullseye InRelease
          Reading package lists... Done
          Building dependency tree... Done
          All packages are up to date.
          nodejs:
            Installed: 16.16.0-deb-1nodesource1
            Candidate: 16.16.0-deb-1nodesource1
            Version table:
           *** 16.16.0-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages
                  100 /var/lib/dpkg/status
               12.22.12~dfsg-1~deb11u1 500
                  500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
               12.22.5~dfsg-2~11u1 500
                  500 http://deb.debian.org/debian bullseye/main amd64 Packages
          • Glasfaser
            @tobasium sagte in Kein Update mehr möglich mit Node.js 16:
            v16.16.0
            6.14.17
            Das passt nicht , zu 16 soll 8 ... sein !!!
            • tobasium
              @glasfaser
              ja ich bin gestern nochmal auf die 6 gegangen. Da nur so die Adpter updates liefen. Bin jetzt wieder auf 8
              root@iobroker:/opt/iobroker# iobroker upgrade js-controller@4.0.23
              Cannot update js-controller using this command. Please use "iobroker upgrade self" instead!
              npm ERR! code ELSPROBLEMS
              npm ERR! extraneous: error-ex@ /opt/iobroker/node_modules/error-ex
              npm ERR! extraneous: utile@ /opt/iobroker/node_modules/utile
              npm ERR! extraneous: zigbee-herdsman-converters@ /opt/iobroker/node_modules/zigbee-herdsman-converters
              npm ERR! extraneous: zigbee-herdsman@ /opt/iobroker/node_modules/zigbee-herdsman
              npm ERR!     /opt/iobroker/.npm/_logs/2022-07-11T06_51_44_458Z-debug-0.log
              • Glasfaser
                Mit NPM 8 auf NPM 6 zu Nodejs 18 Spielt man nicht bzw. die passen nicht zusammen !
                Nodejs 14 mit NPM 6 passt nur zusammen
                pkill -u iobroker
                iobroker upgrade
                dann Container neu starten
                • tobasium
                  @glasfaser hab ich gemacht.
                  npm ERR!     /opt/iobroker/.npm/_logs/2022-07-11T07_23_35_248Z-debug-0.log
                  Thomas Braun Glasfaser 2 Replies Last reply Reply Quote 0
                    Thomas Braun Most Active @tobasium last edited by Thomas Braun
                    @tobasium
                    Lösch die Datei /opt/iobroler/package-lock.json
                    Backup haben zahlt sich aus.
                    • Glasfaser
                      Was ist mit Nodejs / NPM , hast du es jetzt geändert und auch aktualisiert .!
                      • tobasium
                        @glasfaser
                        root@iobroker:/opt/iobroker# uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                        x86_64
                        /usr/bin/nodejs
                        /usr/bin/node
                        /usr/bin/npm
                        v16.16.0
                        v16.16.0
                        8.13.2
                        root
                        /opt/iobroker
                        nodejs:
                          Version table:
                        • Glasfaser
                          Glasfaser @tobasium last edited by Glasfaser
                          v16.16.0
                          8.13.2
                          Er hat immer mit NPM gespielt , bin gerade unterwegs , kannst du bitte nachschauen ... ich meine die 16.16.0 ist nicht aktuell.
                          EDIT
                          8.13.2 ist doch falsch
                            Thomas Braun Most Active @Glasfaser last edited by
                            @glasfaser
                            Container und dann noch von Hand in den Paketen rumpfuschen ist genau meine bevorzugte Konstellation ...
                            • tobasium
                              tobasium @Thomas Braun last edited by
                              @thomas-braun hab ich gemacht, habe auch ein backup
                                @tobasium
                                iobroker restart
                                gemacht?
                                tobasium 2 Replies Last reply Reply Quote 0
                                • tobasium
                                  tobasium @Thomas Braun last edited by tobasium
                                  @thomas-braun ich hab jetzt den ganzen container neu gestartet
                                  • tobasium
                                    @thomas-braun also was mir noch auffällt ich komme mit npm prune auch nicht weiter gefühlt soll ich 100 Ordner umbennen. Ich verzweifel da echt dran:
                                    npm ERR! extraneous: @types/caseless@0.12.2 /opt/iobroker/node_modules/@types/caseless
                                    npm ERR! extraneous: @types/request@2.48.8 /opt/iobroker/node_modules/@types/request
                                    npm ERR! extraneous: @types/tough-cookie@4.0.2 /opt/iobroker/node_modules/@types/tough-cookie
                                    npm ERR! extraneous: coffee-compiler@0.3.2 /opt/iobroker/node_modules/coffee-compiler
                                    npm ERR! extraneous: coffee-script@1.12.7 /opt/iobroker/node_modules/coffee-script
                                    npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
                                    npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors
                                    npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
                                    npm ERR! extraneous: vm2@3.9.10 /opt/iobroker/node_modules/vm2
                                    npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
                                    npm ERR!     /opt/iobroker/.npm/_logs/2022-07-11T08_37_11_257Z-debug-0.log
                                      Nicht umbenennen, löschen.
                                      • tobasium
                                        @thomas-braun gibts da eine Möglichkeit schneller alle Ordner rauszufinden oder wirklich jedesmal npm prune ausführen
                                        root@iobroker:/opt/iobroker# npm prune
                                        npm ERR! code ENOTEMPTY
                                        npm ERR! syscall rename
                                        npm ERR! path /opt/iobroker/node_modules/coffee-compiler
                                        npm ERR! dest /opt/iobroker/node_modules/.coffee-compiler-H6FiAEHY
                                        npm ERR! errno -39
                                        npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/coffee-compiler' -> '/opt/iobroker/node_modules/.coffee-compiler-H6FiAEHY'
                                        npm ERR!     /opt/iobroker/.npm/_logs/2022-07-11T08_39_21_493Z-debug-0.log
                                          @tobasium
                                          Mit prune findest du die zu löschenden Verzeichnisse soweit ich weiß nicht.
                                          Edith:
                                          rm -rf /opt/iobroker/node_modules/.coffee-compiler-H6FiAEHY
                                          • tobasium
                                            @thomas-braun ja das geht aber nicht gut. Verzeichnis ist weg aber jetzt kommt der hier. lösche ich jetzt ist der io tot
                                            npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
                                            npm ERR! dest /opt/iobroker/node_modules/.iobroker.js-controller-7Q8bmsba
                                            npm ERR! errno -39
                                            npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.js-controller' -> '/opt/iobroker/node_modules/.iobroker.js-controller-7Q8bmsba'
                                            npm ERR!     /opt/iobroker/.npm/_logs/2022-07-11T08_42_43_262Z-debug-0.log
                                            node js
                                            16
                                            335
                                            38917
