    4. Kein Update mehr möglich mit Node.js 16
    • Glasfaser
      Glasfaser @tobasium last edited by
      @tobasium
      in deiner Liste mit NodeJS 16 ,
      npm ERR! invalid: iobroker.admin@5.3.8 /opt/iobroker/node_modules/iobroker.admin
      npm ERR! invalid: iobroker.backitup@2.4.9 /opt/iobroker/node_modules/iobroker.backitup
      npm ERR! invalid: iobroker.discovery@3.0.3 /opt/iobroker/node_modules/iobroker.discovery
      npm ERR! invalid: iobroker.js-controller@4.0.23 /opt/iobroker/node_modules/iobroker.js-controller
      Versuche mal
      iobroker upgrade admin@5.3.8
      iobroker upgrade backitup@2.4.9
      iobroker upgrade discovery@3.0.3
      iobroker upgrade js-controller@4.0.23
      die extraneous mit
      npm prune
      sudo npm install -g npm@6
      die Frage wäre auch durch dein hin und her wechseln mit den Versionen ob die 16 überhaupt sauber ist .
      sudo ln -s /usr/bin/node /usr/bin/nodejs
      uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      tobasium 1 Reply Last reply Reply Quote 0
      • tobasium
        tobasium @Glasfaser last edited by
        @glasfaser sagte in Kein Update mehr möglich mit Node.js 16:
        x86_64
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v16.16.0
        v16.16.0
        sudo: unable to resolve host iobroker: Name or service not known
        6.14.17
        root
        /opt/iobroker
        Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:2 http://deb.debian.org/debian bullseye InRelease
        Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:4 https://deb.nodesource.com/node_16.x bullseye InRelease
        Reading package lists... Done
        Building dependency tree... Done
        All packages are up to date.
        nodejs:
          Installed: 16.16.0-deb-1nodesource1
          Candidate: 16.16.0-deb-1nodesource1
          Version table:
         *** 16.16.0-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages
                100 /var/lib/dpkg/status
             12.22.12~dfsg-1~deb11u1 500
                500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
             12.22.5~dfsg-2~11u1 500
                500 http://deb.debian.org/debian bullseye/main amd64 Packages
        • Glasfaser
          @tobasium sagte in Kein Update mehr möglich mit Node.js 16:
          v16.16.0
          6.14.17
          Das passt nicht , zu 16 soll 8 ... sein !!!
          • tobasium
            @glasfaser
            ja ich bin gestern nochmal auf die 6 gegangen. Da nur so die Adpter updates liefen. Bin jetzt wieder auf 8
            root@iobroker:/opt/iobroker# iobroker upgrade js-controller@4.0.23
            Cannot update js-controller using this command. Please use "iobroker upgrade self" instead!
            root@iobroker:/opt/iobroker# npm ls | grep -E 'github.com|ERR'
            npm ERR! code ELSPROBLEMS
            npm ERR! extraneous: error-ex@ /opt/iobroker/node_modules/error-ex
            npm ERR! extraneous: utile@ /opt/iobroker/node_modules/utile
            npm ERR! extraneous: zigbee-herdsman-converters@ /opt/iobroker/node_modules/zigbee-herdsman-converters
            npm ERR! extraneous: zigbee-herdsman@ /opt/iobroker/node_modules/zigbee-herdsman
            npm ERR!     /opt/iobroker/.npm/_logs/2022-07-11T06_51_44_458Z-debug-0.log
            • Glasfaser
              Mit NPM 8 auf NPM 6 zu Nodejs 18 Spielt man nicht bzw. die passen nicht zusammen !
              Nodejs 14 mit NPM 6 passt nur zusammen
              pkill -u iobroker
              iobroker upgrade
              dann Container neu starten
              • tobasium
                @glasfaser hab ich gemacht.
                npm ERR!     /opt/iobroker/.npm/_logs/2022-07-11T07_23_35_248Z-debug-0.log
                Thomas Braun Glasfaser 2 Replies Last reply Reply Quote 0
                  Thomas Braun Most Active @tobasium last edited by Thomas Braun
                  @tobasium
                  Lösch die Datei /opt/iobroler/package-lock.json
                  Backup haben zahlt sich aus.
                  • Glasfaser
                    Was ist mit Nodejs / NPM , hast du es jetzt geändert und auch aktualisiert .!
                    • tobasium
                      @glasfaser
                      root@iobroker:/opt/iobroker# uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                      x86_64
                      /usr/bin/nodejs
                      /usr/bin/node
                      /usr/bin/npm
                      v16.16.0
                      v16.16.0
                      8.13.2
                      root
                      /opt/iobroker
                      nodejs:
                        Version table:
                      • Glasfaser
                        Glasfaser @tobasium last edited by Glasfaser
                        v16.16.0
                        8.13.2
                        Er hat immer mit NPM gespielt , bin gerade unterwegs , kannst du bitte nachschauen ... ich meine die 16.16.0 ist nicht aktuell.
                        EDIT
                        8.13.2 ist doch falsch
                          Thomas Braun Most Active @Glasfaser last edited by
                          @glasfaser
                          Container und dann noch von Hand in den Paketen rumpfuschen ist genau meine bevorzugte Konstellation ...
                          • tobasium
                            tobasium @Thomas Braun last edited by
                            @thomas-braun hab ich gemacht, habe auch ein backup
                              @tobasium
                              iobroker restart
                              gemacht?
                              tobasium 2 Replies Last reply Reply Quote 0
                              • tobasium
                                tobasium @Thomas Braun last edited by tobasium
                                @thomas-braun ich hab jetzt den ganzen container neu gestartet
                                • tobasium
                                  @thomas-braun also was mir noch auffällt ich komme mit npm prune auch nicht weiter gefühlt soll ich 100 Ordner umbennen. Ich verzweifel da echt dran:
                                  npm ERR! extraneous: @types/caseless@0.12.2 /opt/iobroker/node_modules/@types/caseless
                                  npm ERR! extraneous: @types/request@2.48.8 /opt/iobroker/node_modules/@types/request
                                  npm ERR! extraneous: @types/tough-cookie@4.0.2 /opt/iobroker/node_modules/@types/tough-cookie
                                  npm ERR! extraneous: coffee-compiler@0.3.2 /opt/iobroker/node_modules/coffee-compiler
                                  npm ERR! extraneous: coffee-script@1.12.7 /opt/iobroker/node_modules/coffee-script
                                  npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
                                  npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors
                                  npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
                                  npm ERR! extraneous: vm2@3.9.10 /opt/iobroker/node_modules/vm2
                                  npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
                                  npm ERR!     /opt/iobroker/.npm/_logs/2022-07-11T08_37_11_257Z-debug-0.log
                                    Nicht umbenennen, löschen.
                                    • tobasium
                                      @thomas-braun gibts da eine Möglichkeit schneller alle Ordner rauszufinden oder wirklich jedesmal npm prune ausführen
                                      root@iobroker:/opt/iobroker# npm prune
                                      npm ERR! code ENOTEMPTY
                                      npm ERR! syscall rename
                                      npm ERR! path /opt/iobroker/node_modules/coffee-compiler
                                      npm ERR! dest /opt/iobroker/node_modules/.coffee-compiler-H6FiAEHY
                                      npm ERR! errno -39
                                      npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/coffee-compiler' -> '/opt/iobroker/node_modules/.coffee-compiler-H6FiAEHY'
                                      npm ERR!     /opt/iobroker/.npm/_logs/2022-07-11T08_39_21_493Z-debug-0.log
                                        @tobasium
                                        Mit prune findest du die zu löschenden Verzeichnisse soweit ich weiß nicht.
                                        Edith:
                                        rm -rf /opt/iobroker/node_modules/.coffee-compiler-H6FiAEHY
                                        • tobasium
                                          @thomas-braun ja das geht aber nicht gut. Verzeichnis ist weg aber jetzt kommt der hier. lösche ich jetzt ist der io tot
                                          npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
                                          npm ERR! dest /opt/iobroker/node_modules/.iobroker.js-controller-7Q8bmsba
                                          npm ERR! errno -39
                                          npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.js-controller' -> '/opt/iobroker/node_modules/.iobroker.js-controller-7Q8bmsba'
                                          npm ERR!     /opt/iobroker/.npm/_logs/2022-07-11T08_42_43_262Z-debug-0.log
                                            @tobasium
                                            Den iobroker solltest du während dessen auch stoppen.
                                            node js
                                            16
                                            335
                                            38916
