    4. Kein Update mehr möglich mit Node.js 16
    • tobasium
      tobasium @Thomas Braun last edited by
      @thomas-braun also was mir noch auffällt ich komme mit npm prune auch nicht weiter gefühlt soll ich 100 Ordner umbennen. Ich verzweifel da echt dran:
      root@iobroker:/opt/iobroker# npm ls | grep -E 'github.com|ERR'
      sudo: unable to resolve host iobroker: Name or service not known
      npm ERR! code ELSPROBLEMS
      npm ERR! extraneous: @types/caseless@0.12.2 /opt/iobroker/node_modules/@types/caseless
      npm ERR! extraneous: @types/request@2.48.8 /opt/iobroker/node_modules/@types/request
      npm ERR! extraneous: @types/tough-cookie@4.0.2 /opt/iobroker/node_modules/@types/tough-cookie
      npm ERR! extraneous: coffee-compiler@0.3.2 /opt/iobroker/node_modules/coffee-compiler
      npm ERR! extraneous: coffee-script@1.12.7 /opt/iobroker/node_modules/coffee-script
      npm ERR! extraneous: error-ex@ /opt/iobroker/node_modules/error-ex
      npm ERR! invalid: iobroker.js-controller@4.0.23 /opt/iobroker/node_modules/iobroker.js-controller
      npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
      npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors
      npm ERR! extraneous: utile@ /opt/iobroker/node_modules/utile
      npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
      npm ERR! extraneous: vm2@3.9.10 /opt/iobroker/node_modules/vm2
      npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
      npm ERR!     /opt/iobroker/.npm/_logs/2022-07-11T08_37_11_257Z-debug-0.log
        Thomas Braun Most Active @tobasium last edited by
        @tobasium sagte in Kein Update mehr möglich mit Node.js 16:
        Nicht umbenennen, löschen.
        tobasium 1 Reply Last reply Reply Quote 0
        • tobasium
          tobasium @Thomas Braun last edited by tobasium
          @thomas-braun gibts da eine Möglichkeit schneller alle Ordner rauszufinden oder wirklich jedesmal npm prune ausführen
          root@iobroker:/opt/iobroker# npm prune
          npm ERR! code ENOTEMPTY
          npm ERR! syscall rename
          npm ERR! path /opt/iobroker/node_modules/coffee-compiler
          npm ERR! dest /opt/iobroker/node_modules/.coffee-compiler-H6FiAEHY
          npm ERR! errno -39
          npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/coffee-compiler' -> '/opt/iobroker/node_modules/.coffee-compiler-H6FiAEHY'
          npm ERR!     /opt/iobroker/.npm/_logs/2022-07-11T08_39_21_493Z-debug-0.log
            Thomas Braun Most Active @tobasium last edited by Thomas Braun
            @tobasium
            Mit prune findest du die zu löschenden Verzeichnisse soweit ich weiß nicht.
            Edith:
            rm -rf /opt/iobroker/node_modules/.coffee-compiler-H6FiAEHY
            • tobasium
              @thomas-braun ja das geht aber nicht gut. Verzeichnis ist weg aber jetzt kommt der hier. lösche ich jetzt ist der io tot
              npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
              npm ERR! dest /opt/iobroker/node_modules/.iobroker.js-controller-7Q8bmsba
              npm ERR! errno -39
              npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.js-controller' -> '/opt/iobroker/node_modules/.iobroker.js-controller-7Q8bmsba'
              npm ERR!     /opt/iobroker/.npm/_logs/2022-07-11T08_42_43_262Z-debug-0.log
                @tobasium
                Den iobroker solltest du während dessen auch stoppen.
                • tobasium
                  @thomas-braun ja ich bin im maintenace on, das passt doch auch oder?
                    @tobasium
                    Was ist maintenance on?
                    • tobasium
                      @thomas-braun naja ist ja ein buanet docker über maintenance on wird iobroker beendet.
                      • Glasfaser
                        Glasfaser @tobasium last edited by Glasfaser
                        Kenne ich gerade auch nicht was du damit meinst
                        Einfach , den ioBroker stoppen :
                        pkill -u iobroker
                        • tobasium
                          tobasium @Glasfaser last edited by
                          @glasfaser jo hab ich das macht der befehl auch
                          • tobasium
                            Also ich geh jetzt alle fehler bei npm prune durch das wird erstmal dauern. Melde mich wen ich durch bin.
                            • tobasium
                              tobasium last edited by Negalein
                              @Glasfaser @thomas-braun
                              so also npm prune läuft jetzt durch, keine Fehler mehr:
                              changed 8 packages in 2m
                              129 packages are looking for funding
                              run npm fund for details
                              npm ERR!     /opt/iobroker/.npm/_logs/2022-07-11T09_12_05_196Z-debug-0.log
                              Updates / Downgrades laufen noch nicht:
                              $ iobroker upgrade milight-smart-light@1.2.1 --debug
                              Update milight-smart-light from @1.2.2 to @1.2.1
                              NPM version: 8.11.0
                              Installing iobroker.milight-smart-light@1.2.1... (System call)
                              npm ERR! code ENOTEMPTYnpm ERR! syscall renamenpm ERR! path /opt/iobroker/node_modules/iobroker.milight-smart-lightnpm ERR! dest /opt/iobroker/node_modules/.iobroker.milight-smart-light-RTE0VXzonpm ERR! errno -39npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.milight-smart-light' -> '/opt/iobroker/node_modules/.iobroker.milight-smart-light-RTE0VXzo'npm ERR! A complete log of this run can be found in:npm ERR! /opt/iobroker/.npm/_logs/2022-07-11T09_09_18_542Z-debug-0.log
                              host.iobroker Cannot install iobroker.milight-smart-light@1.2.1: 217
                              ERROR: Process exited with code 25
                                Weiter die Verzeichnisse mit den kryptischen Endungen löschen...
                                • Glasfaser
                                  Deinstalliere den js-controller mal und dann neu installieren .
                                  inkl.
                                  Lösch die Datei /opt/iobroler/package-lock.json
                                  • tobasium
                                    @glasfaser wie deinstalliere ich den? da steh ich auf dem schlauch
                                    Glasfaser Thomas Braun 2 Replies Last reply Reply Quote 0
                                    • Glasfaser
                                      @tobasium
                                      iob del js-controller
                                        @tobasium
                                        Ich würde den erstmal drüber klatschen.
                                        iobroker stoppen.
                                        cd /opt/iobroker
                                        npm install iobroker.js-controller
                                        • tobasium
                                          tobasium @Thomas Braun last edited by Negalein
                                          @thomas-braun hab ich gemacht
                                          downgrade geht aber immer noch nicht:
                                          NPM version: 8.11.0Installing iobroker.milight-smart-light@1.2.1... (System call)
                                          npm ERR! code ENOTEMPTYnpm ERR! syscall renamenpm ERR! path /opt/iobroker/node_modules/iobroker.milight-smart-lightnpm ERR! dest /opt/iobroker/node_modules/.iobroker.milight-smart-light-RTE0VXzonpm ERR! errno -39npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.milight-smart-light' -> '/opt/iobroker/node_modules/.iobroker.milight-smart-light-RTE0VXzo'npm ERR! A complete log of this run can be found in:npm ERR! /opt/iobroker/.npm/_logs/2022-07-11T09_26_39_068Z-debug-0.log
                                          Mod-Edit: Code in </> Code-Tag gepackt!
                                          • Glasfaser
                                            @tobasium
                                            immer weiter Löschen ,
                                            hat er auch schon oben geschrieben
                                            @thomas-braun sagte in Kein Update mehr möglich mit Node.js 16:
                                            node js
                                            16
                                            335
                                            38979
