backitup kein Backup von iobroker
So?.... Neuling halt...
login as: pi pi@192.168.178.73's password: Linux raspberrypi 5.15.32-v7l+ #1538 SMP Thu Mar 31 19:39:41 BST 2022 armv7l The programs included with the Debian GNU/Linux system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*/copyright. Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. Last login: Mon Jul 11 05:03:41 2022 from 192.168.178.32 pi@raspberrypi:~ $ iobroker update -i Used repository: stable Adapter "admin" : 5.3.8 , installed 5.3.8 Adapter "alexa2" : 3.11.2 , installed 3.11.2 Adapter "backitup" : 2.4.9 , installed 2.4.9 Adapter "ble" : 0.12.0 , installed 0.12.0 Adapter "daswetter" : 3.1.2 , installed 3.1.2 Adapter "discovery" : 3.0.3 , installed 3.0.3 Adapter "fb-checkpresence": 1.1.14, installed 1.1.14 Adapter "flot" : 1.11.0 , installed 1.11.0 Adapter "history" : 1.11.1 , installed 1.11.1 Adapter "hm-rega" : 3.0.40 , installed 3.0.40 Adapter "hm-rpc" : 1.15.12 , installed 1.15.12 Adapter "ical" : 1.12.1 , installed 1.12.1 Adapter "info" : 1.9.19 , installed 1.9.19 Adapter "javascript" : 5.7.0 , installed 5.7.0 Controller "js-controller": 4.0.23 , installed 4.0.23 Adapter "luftdaten" : 2.2.4 , installed 2.2.4 Adapter "node-red" : 3.3.1 , installed 3.3.1 Adapter "pushover" : 2.1.0 , installed 2.1.0 Adapter "ring" : 3.0.4 , installed 3.0.4 Adapter "rpi2" : 1.3.2 , installed 1.3.2 Adapter "simple-api" : 2.7.0 , installed 2.7.0 Adapter "smartgarden" : 2.0.0 , installed 2.0.0 Adapter "socketio" : 4.2.0 , installed 4.2.0 Adapter "sql" : 1.16.2 , installed 1.16.2 Adapter "tankerkoenig" : 2.1.1 , installed 2.1.1 Adapter "trashschedule": 2.0.2 , installed 2.0.2 Adapter "tuya" : 3.6.15 , installed 3.6.15 Adapter "vis" : 1.4.15 , installed 1.4.15 Adapter "web" : 4.3.0 , installed 4.3.0 Adapter "ws" : 1.3.0 , installed 1.3.0 pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs pi@raspberrypi:~ $ uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs armv7l /usr/bin/nodejs /usr/bin/node /usr/bin/npm v16.16.0 v16.16.0 8.11.0 pi /home/pi OK:1 http://archive.raspberrypi.org/debian bullseye InRelease OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease OK:3 https://repos.influxdata.com/debian bullseye InRelease OK:4 https://deb.nodesource.com/node_16.x bullseye InRelease OK:5 https://packages.grafana.com/enterprise/deb stable InRelease Holen:6 https://download.sublimetext.com apt/stable/ InRelease [2.536 B] Es wurden 2.536 B in 2 s geholt (1.412 B/s). Paketlisten werden gelesen... Fertig Abh▒ngigkeitsbaum wird aufgebaut... Fertig Statusinformationen werden eingelesen... Fertig Alle Pakete sind aktuell. nodejs: Installiert: 16.16.0-deb-1nodesource1 Installationskandidat: 16.16.0-deb-1nodesource1 Versionstabelle: *** 16.16.0-deb-1nodesource1 500 500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages 100 /var/lib/dpkg/status 12.22.12~dfsg-1~deb11u1 500 500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages pi@raspberrypi:~ $ sudo iobroker restart pi@raspberrypi:~ $ sudo iobroker start pi@raspberrypi:~ $ -
Was ist sublimetext? Was issen das?
Und iobroker NEVER NEVER NEVER EVER mit sudo anpacken. Nie!iobroker stop iobroker fix iobroker start free -ht --mega -
@thomas-braun said in backitup kein Backup von iobroker:
free -ht --mega
login as: pi pi@192.168.178.73's password: Linux raspberrypi 5.15.32-v7l+ #1538 SMP Thu Mar 31 19:39:41 BST 2022 armv7l The programs included with the Debian GNU/Linux system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*/copyright. Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. Last login: Mon Jul 11 13:04:15 2022 from 192.168.178.32 pi@raspberrypi:~ $ iobroker stop pi@raspberrypi:~ $ iobroker fix library: loaded Library version=2022-06-15 ========================================================================== Welcome to the ioBroker installation fixer! Script version: 2022-06-03 You might need to enter your password a couple of times. ========================================================================== ========================================================================== Installing prerequisites (1/3) ========================================================================== Holen:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15,0 kB] OK:2 http://archive.raspberrypi.org/debian bullseye InRelease OK:3 https://repos.influxdata.com/debian bullseye InRelease OK:4 https://packages.grafana.com/enterprise/deb stable InRelease OK:5 https://deb.nodesource.com/node_16.x bullseye InRelease Holen:6 https://download.sublimetext.com apt/stable/ InRelease [2.536 B] Es wurden 17,5 kB in 2 s geholt (10,7 kB/s). Paketlisten werden gelesen... Fertig Installed gcc-c++ ========================================================================== Checking ioBroker user and directory permissions (2/3) ========================================================================== Created /etc/sudoers.d/iobroker Fixing directory permissions... ========================================================================== Checking autostart (3/3) ========================================================================== Enabling autostart... Autostart enabled! ========================================================================== Your installation was fixed successfully Run iobroker start to start ioBroker again! ========================================================================== pi@raspberrypi:~ $ iobroker start pi@raspberrypi:~ $ free -ht --mega gesamt benutzt frei gemns. Puffer/Cache verf▒gbar Speicher: 7,9G 1,1G 3,9G 102M 2,9G 6,5G Swap: 1,0G 0B 1,0G Gesamt: 8,9G 1,1G 5,0G pi@raspberrypi:~ $ free -ht --mega gesamt benutzt frei gemns. Puffer/Cache verf▒gbar Speicher: 7,9G 2,2G 2,7G 102M 2,9G 5,6G Swap: 1,0G 0B 1,0G Gesamt: 8,9G 2,2G 3,8G pi@raspberrypi:~ $Ohne Erfolg
[Started iobroker ... [DEBUG] [iobroker] - host.raspberrypi 11574 states saved [DEBUG] [iobroker] - host.raspberrypi 13365 objects saved [ERROR] [iobroker] - <--- Last few GCs ---> [20040:0x402ffc8] 24847 ms: Mark-sweep (reduce) 586.3 (594.7) -> 586.3 (589.9) MB, 132.8 / 0.0 ms (+ 0.0 ms in 0 steps since start of marking, biggest step 0.0 ms, walltime since start of marking 2249 ms) (average mu = 0.964, current mu = 0.942) last [20040:0x402ffc8] 24932 ms: Mark-sweep (reduce) 586.3 (589.9) -> 586.2 (589.9) MB, 84.6 / 0.0 ms (average mu = 0.945, current mu = 0.001) last resort GC in old space requested [ERROR] [iobroker] - <--- JS stacktrace ---> [ERROR] [iobroker] - FATAL ERROR: CALL_AND_RETRY_LAST Allocation failed - JavaScript heap out of memory [DEBUG] [iobroker] - done [DEBUG] [mysql] - MySql-Backup started ... [DEBUG] [mysql] - MySql File deleted! [DEBUG] [mysql] - MySql-Backup for is finish [DEBUG] [mysql] - done [DEBUG] [historyDB] - compress from historyDB started ... [DEBUG] [historyDB] - Backup created: /opt/iobroker/backups/historyDB_2022_07_11-13_40_18_backupiobroker.tar.gz [DEBUG] [historyDB] - done [DEBUG] [grafana] - Start Grafana Backup ... [DEBUG] [grafana] - Created grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp" [DEBUG] [grafana] - Created dashboard directory [DEBUG] [grafana] - Created dashboards_manually_restore directory [DEBUG] [grafana] - Created datasource directory [DEBUG] [grafana] - start Grafana request ... [DEBUG] [grafana] - Grafana is available ... Status: 200 [DEBUG] [grafana] - found Dashboard: duty-gate [DEBUG] [grafana] - found Dashboard: lux [DEBUG] [grafana] - found Dashboard: tomaten-bodentemperatur [DEBUG] [grafana] - found Dashboard: anwesenheit [DEBUG] [grafana] - found Dashboard: radieschen-lux [DEBUG] [grafana] - found Dashboard: pool [DEBUG] [grafana] - found Dashboard: tomaten [DEBUG] [grafana] - start Grafana backup compress ... [DEBUG] [grafana] - Backup created: /opt/iobroker/backups/grafana_2022_07_11-13_40_19_backupiobroker.tar.gz [DEBUG] [grafana] - Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp" [DEBUG] [grafana] - Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted [DEBUG] [grafana] - done [DEBUG] [javascripts] - Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts" [DEBUG] [javascripts] - found Script: Raspberry_Temperaturüberwachung [DEBUG] [javascripts] - found Script: Müll [DEBUG] [javascripts] - Try deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts" [DEBUG] [javascripts] - Javascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted [DEBUG] [javascripts] - Backup created: /opt/iobroker/backups/javascripts_2022_07_11-13_40_25_backupiobroker.tar.gz [DEBUG] [javascripts] - done [DEBUG] [cifs] - used copy path: /media/usbstick [DEBUG] [cifs] - Copy iobroker_2022_07_11-13_39_50_backupiobroker.tar.gz... [ERROR] [cifs] - Error: ENOENT: no such file or directory, open '/opt/iobroker/backups/iobroker_2022_07_11-13_39_50_backupiobroker.tar.gz' [DEBUG] [cifs] - Copy mysql_2022_07_11-13_40_15_backupiobroker.tar.gz... [DEBUG] [cifs] - Copy historyDB_2022_07_11-13_40_18_backupiobroker.tar.gz... [DEBUG] [cifs] - Copy grafana_2022_07_11-13_40_19_backupiobroker.tar.gz... [DEBUG] [cifs] - Copy javascripts_2022_07_11-13_40_25_backupiobroker.tar.gz... [DEBUG] [cifs] - done [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors. [DEBUG] [clean] - done [DEBUG] [historyHTML] - new history html values created [DEBUG] [historyHTML] - done [DEBUG] [historyJSON] - new history json values created [DEBUG] [historyJSON] - done [EXIT] 0](link url) -
Während Backitup ausgeführt wird
pi@raspberrypi:~ $ free -ht --mega gesamt benutzt frei gemns. Puffer/Cache verf▒gbar Speicher: 7,9G 2,2G 2,7G 102M 2,9G 5,7G Swap: 1,0G 0B 1,0G Gesamt: 8,9G 2,2G 3,8G pi@raspberrypi:~ $ free -ht --mega gesamt benutzt frei gemns. Puffer/Cache verf▒gbar Speicher: 7,9G 2,3G 2,6G 102M 2,9G 5,5G Swap: 1,0G 0B 1,0G Gesamt: 8,9G 2,3G 3,7G pi@raspberrypi:~ $ free -ht --mega gesamt benutzt frei gemns. Puffer/Cache verf▒gbar Speicher: 7,9G 2,4G 2,6G 102M 2,9G 5,5G Swap: 1,0G 0B 1,0G Gesamt: 8,9G 2,4G 3,6G pi@raspberrypi:~ $ free -ht --mega gesamt benutzt frei gemns. Puffer/Cache verf▒gbar Speicher: 7,9G 2,4G 2,6G 102M 2,9G 5,5G Swap: 1,0G 0B 1,0G Gesamt: 8,9G 2,4G 3,6G pi@raspberrypi:~ $ free -ht --mega gesamt benutzt frei gemns. Puffer/Cache verf▒gbar Speicher: 7,9G 2,6G 2,4G 102M 2,9G 5,3G Swap: 1,0G 0B 1,0G Gesamt: 8,9G 2,6G 3,4G pi@raspberrypi:~ $ free -ht --mega gesamt benutzt frei gemns. Puffer/Cache verf▒gbar Speicher: 7,9G 2,7G 2,2G 102M 2,9G 5,1G Swap: 1,0G 0B 1,0G Gesamt: 8,9G 2,7G 3,3G pi@raspberrypi:~ $ free -ht --mega gesamt benutzt frei gemns. Puffer/Cache verf▒gbar Speicher: 7,9G 2,8G 2,5G 102M 2,7G 5,1G Swap: 1,0G 0B 1,0G Gesamt: 8,9G 2,8G 3,5G pi@raspberrypi:~ $ free -ht --mega gesamt benutzt frei gemns. Puffer/Cache verf▒gbar Speicher: 7,9G 2,6G 2,6G 102M 2,7G 5,3G Swap: 1,0G 0B 1,0G Gesamt: 8,9G 2,6G 3,7G pi@raspberrypi:~ $ free -ht --mega gesamt benutzt frei gemns. Puffer/Cache verf▒gbar Speicher: 7,9G 2,6G 2,6G 102M 2,7G 5,2G Swap: 1,0G 0B 1,0G Gesamt: 8,9G 2,6G 3,6G pi@raspberrypi:~ $ free -ht --mega gesamt benutzt frei gemns. Puffer/Cache verf▒gbar Speicher: 7,9G 2,7G 2,5G 102M 2,7G 5,2G Swap: 1,0G 0B 1,0G Gesamt: 8,9G 2,7G 3,5G pi@raspberrypi:~ $ free -ht --mega gesamt benutzt frei gemns. Puffer/Cache verf▒gbar Speicher: 7,9G 2,8G 2,4G 102M 2,7G 5,0G Swap: 1,0G 0B 1,0G Gesamt: 8,9G 2,8G 3,4G pi@raspberrypi:~ $ free -ht --mega gesamt benutzt frei gemns. Puffer/Cache verf▒gbar Speicher: 7,9G 3,0G 2,3G 102M 2,7G 4,9G Swap: 1,0G 0B 1,0G Gesamt: 8,9G 3,0G 3,3G pi@raspberrypi:~ $ free -ht --mega gesamt benutzt frei gemns. Puffer/Cache verf▒gbar Speicher: 7,9G 3,0G 2,2G 102M 2,7G 4,9G Swap: 1,0G 0B 1,0G Gesamt: 8,9G 3,0G 3,2G pi@raspberrypi:~ $ free -ht --mega gesamt benutzt frei gemns. Puffer/Cache verf▒gbar Speicher: 7,9G 3,3G 1,9G 102M 2,7G 4,6G Swap: 1,0G 0B 1,0G Gesamt: 8,9G 3,3G 3,0G pi@raspberrypi:~ $ free -ht --mega gesamt benutzt frei gemns. Puffer/Cache verf▒gbar Speicher: 7,9G 3,5G 1,7G 102M 2,7G 4,3G Swap: 1,0G 0B 1,0G Gesamt: 8,9G 3,5G 2,7G pi@raspberrypi:~ $ free -ht --mega gesamt benutzt frei gemns. Puffer/Cache verf▒gbar Speicher: 7,9G 3,6G 1,6G 102M 2,7G 4,3G Swap: 1,0G 0B 1,0G Gesamt: 8,9G 3,6G 2,7G pi@raspberrypi:~ $ free -ht --mega gesamt benutzt frei gemns. Puffer/Cache verf▒gbar Speicher: 7,9G 3,8G 1,4G 102M 2,7G 4,1G Swap: 1,0G 0B 1,0G Gesamt: 8,9G 3,8G 2,4G pi@raspberrypi:~ $ free -ht --mega gesamt benutzt frei gemns. Puffer/Cache verf▒gbar Speicher: 7,9G 3,1G 1,9G 102M 2,9G 4,8G Swap: 1,0G 0B 1,0G Gesamt: 8,9G 3,1G 2,9G pi@raspberrypi:~ $ free -ht --mega gesamt benutzt frei gemns. Puffer/Cache verf▒gbar Speicher: 7,9G 3,3G 1,7G 102M 2,9G 4,6G Swap: 1,0G 0B 1,0G Gesamt: 8,9G 3,3G 2,7G pi@raspberrypi:~ $ free -ht --mega gesamt benutzt frei gemns. Puffer/Cache verf▒gbar Speicher: 7,9G 3,3G 1,7G 102M 2,9G 4,6G Swap: 1,0G 0B 1,0G Gesamt: 8,9G 3,3G 2,7G pi@raspberrypi:~ $ -
@neuling-mit-großem-interesse sagte in backitup kein Backup von iobroker:
Ohne Erfolg
Was?
bitte alles zeigen!
Man weiß ja gar nicht wer da gerade was tut -
Hallo!
Was meinst du mit alles zeigen?
Wie mein Benutzername schon sagt... absoluter Neuling.... Welche Informationen werden benötigt? -
Auf die Frage hin was ist sublimetext.... Ich hatte einen texteditor instalieren wollen und dieser landete beim falschen benutzer... ist deinstaliert....
Danach habe ich die obigen Schritte wiederholt...
pi@raspberrypi:~ $ iobroker stop pi@raspberrypi:~ $ iobroker fix library: loaded Library version=2022-06-15 ========================================================================== Welcome to the ioBroker installation fixer! Script version: 2022-06-03 You might need to enter your password a couple of times. ========================================================================== ========================================================================== Installing prerequisites (1/3) ========================================================================== OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease OK:2 http://archive.raspberrypi.org/debian bullseye InRelease OK:3 https://repos.influxdata.com/debian bullseye InRelease OK:4 https://deb.nodesource.com/node_16.x bullseye InRelease OK:5 https://packages.grafana.com/enterprise/deb stable InRelease Paketlisten werden gelesen... Fertig Installed gcc-c++ ========================================================================== Checking ioBroker user and directory permissions (2/3) ========================================================================== Created /etc/sudoers.d/iobroker Fixing directory permissions... ========================================================================== Checking autostart (3/3) ========================================================================== Enabling autostart... Autostart enabled! ========================================================================== Your installation was fixed successfully Run iobroker start to start ioBroker again! ========================================================================== pi@raspberrypi:~ $ iobroker start pi@raspberrypi:~ $ free -ht --mega gesamt benutzt frei gemns. Puffer/Cache verf▒gbar Speicher: 7,9G 901M 5,1G 59M 1,9G 6,7G Swap: 1,0G 0B 1,0G Gesamt: 8,9G 901M 6,1G pi@raspberrypi:~ $ free -ht --mega gesamt benutzt frei gemns. Puffer/Cache verf▒gbar Speicher: 7,9G 1,6G 4,4G 59M 1,9G 6,0G Swap: 1,0G 0B 1,0G Gesamt: 8,9G 1,6G 5,4G pi@raspberrypi:~ $jetzt ist der texteditor nicht mehr teil des fixes...
dann habe ich eine neu instanz von Backitup erstellt in der dann nur iobroker gesichert werden soll....
alles ausser iobroker selber geht.
Started iobroker ... [DEBUG] [iobroker] - host.raspberrypi 11599 states saved [DEBUG] [iobroker] - host.raspberrypi 13397 objects saved [ERROR] [iobroker] - <--- Last few GCs ---> [32392:0x4fbafc8] 23688 ms: Mark-sweep (reduce) 586.4 (593.5) -> 586.4 (590.5) MB, 114.8 / 0.0 ms (+ 0.0 ms in 0 steps since start of marking, biggest step 0.0 ms, walltime since start of marking 2269 ms) (average mu = 0.970, current mu = 0.951) last [32392:0x4fbafc8] 23765 ms: Mark-sweep (reduce) 586.4 (590.5) -> 586.4 (589.8) MB, 77.4 / 0.0 ms (average mu = 0.951, current mu = 0.001) last resort GC in old space requested [ERROR] [iobroker] - <--- JS stacktrace ---> [ERROR] [iobroker] - FATAL ERROR: CALL_AND_RETRY_LAST Allocation failed - JavaScript heap out of memory [DEBUG] [iobroker] - done [DEBUG] [clean] - done [DEBUG] [historyHTML] - new history html values created [DEBUG] [historyHTML] - done [DEBUG] [historyJSON] - new history json values created [DEBUG] [historyJSON] - done [EXIT] 0 -
Warum fragst du in einem neuen Thread !?
https://forum.iobroker.net/topic/56255/node-js-16x-und-alte-12x-gleichzeitigdas ist doch der Screenshot von ganz oben von dir und betrifft doch diesen Thread
@neuling-mit-großem-interesse sagte in Node.js 16x und alte 12x gleichzeitig?:
ok Danke
Ich bin auf der Suche nach möglichen Fehlern weshalb mein Backup nicht erstellt wird.Zeige mal :
du -hs /opt/iobroker/iobroker-data/files/* -
@glasfaser
Ich suche noch nach dem Fehler....Und da ich die node-js auch aktualisiert hatte dachte ich mir auch danach zu schauen bzw. zu Fragen...pi@raspberrypi:/opt/iobroker $ du -hs /opt/iobroker/iobroker-data/files/* 8,0K /opt/iobroker/iobroker-data/files/0_userdata.0 252K /opt/iobroker/iobroker-data/files/admin.admin 1,2M /opt/iobroker/iobroker-data/files/alexa2.admin 420K /opt/iobroker/iobroker-data/files/backitup.admin 732K /opt/iobroker/iobroker-data/files/ble.admin 4,9M /opt/iobroker/iobroker-data/files/daswetter.admin 472K /opt/iobroker/iobroker-data/files/discovery.admin 908K /opt/iobroker/iobroker-data/files/fb-checkpresence.admin 1,4M /opt/iobroker/iobroker-data/files/flot 12K /opt/iobroker/iobroker-data/files/flot.admin 180K /opt/iobroker/iobroker-data/files/history.admin 64K /opt/iobroker/iobroker-data/files/hm-rega 160K /opt/iobroker/iobroker-data/files/hm-rega.admin 2,5M /opt/iobroker/iobroker-data/files/hm-rpc.admin 84K /opt/iobroker/iobroker-data/files/ical.admin 2,7M /opt/iobroker/iobroker-data/files/info.admin 32M /opt/iobroker/iobroker-data/files/javascript.admin 188K /opt/iobroker/iobroker-data/files/node-red.admin 104K /opt/iobroker/iobroker-data/files/pushover.admin 48K /opt/iobroker/iobroker-data/files/ring.admin 48K /opt/iobroker/iobroker-data/files/rpi2.admin 76K /opt/iobroker/iobroker-data/files/smartgarden.admin 224K /opt/iobroker/iobroker-data/files/sql.admin 68K /opt/iobroker/iobroker-data/files/tankerkoenig.admin 188K /opt/iobroker/iobroker-data/files/trashschedule.admin 7,0M /opt/iobroker/iobroker-data/files/vis 488K /opt/iobroker/iobroker-data/files/vis.0 52K /opt/iobroker/iobroker-data/files/vis.admin 7,9M /opt/iobroker/iobroker-data/files/web 5,7M /opt/iobroker/iobroker-data/files/web.admin pi@raspberrypi:/opt/iobroker $ -
Ordnergröße 1,8 GB
Ja das ist mir klar ...
Du bekommst doch schon hier im Thread Hilfe .das wäre genauso , als würdest du nach Spanien fliegen und dort nach deinem Problem suchen ... aber dort sind andere User .... und das ganze fängt von neuen an.
So bleibt dein ( Problem ) erstmal für alle an einem Ort !
@glasfaser
ok -
Ich sehe gerade das in dem Unterordner backup-objects alleine 600MB Dateien sind.
states und objects.jsonl.gz
vom 09.07.2022 bis heute -
Wie groß sind die?
Hier sind die äußerst übersichtlich kompakt.ncdu 1.15.1 ~ Use the arrow keys to navigate, press ? for help --- /opt/iobroker/iobroker-data/backup-objects ------------------------------------------------------------------------------------------------------------- /.. 4.0 MiB [##########] 2022-07-11_15-38_objects.jsonl.gz 4.0 MiB [##########] 2022-07-11_13-38_objects.jsonl.gz 4.0 MiB [##########] 2022-07-11_17-38_objects.jsonl.gz 4.0 MiB [######### ] 2022-07-11_09-38_objects.jsonl.gz 4.0 MiB [######### ] 2022-07-11_05-38_objects.jsonl.gz 4.0 MiB [######### ] 2022-07-11_11-38_objects.jsonl.gz 4.0 MiB [######### ] 2022-07-11_01-38_objects.jsonl.gz 4.0 MiB [######### ] 2022-07-11_07-38_objects.jsonl.gz 4.0 MiB [######### ] 2022-07-11_03-38_objects.jsonl.gz 4.0 MiB [######### ] 2022-07-10_21-38_objects.jsonl.gz 4.0 MiB [######### ] 2022-07-10_19-38_objects.jsonl.gz 4.0 MiB [######### ] 2022-07-09_21-04_objects.jsonl.gz 4.0 MiB [######### ] 2022-07-10_01-04_objects.jsonl.gz 4.0 MiB [######### ] 2022-07-09_23-04_objects.jsonl.gz 4.0 MiB [######### ] 2022-07-10_03-04_objects.jsonl.gz 4.0 MiB [######### ] 2022-07-10_07-04_objects.jsonl.gz 4.0 MiB [######### ] 2022-07-10_09-04_objects.jsonl.gz 4.0 MiB [######### ] 2022-07-10_05-04_objects.jsonl.gz 4.0 MiB [######### ] 2022-07-10_12-53_objects.jsonl.gz 4.0 MiB [######### ] 2022-07-10_14-53_objects.jsonl.gz 4.0 MiB [######### ] 2022-07-10_16-53_objects.jsonl.gz 3.9 MiB [######### ] 2022-07-10_23-38_objects.jsonl.gz 3.9 MiB [######### ] 2022-07-09_17-04_objects.jsonl.gz 3.9 MiB [######### ] 2022-07-09_19-04_objects.jsonl.gz 348.0 KiB [ ] 2022-07-10_09-04_states.jsonl.gz 348.0 KiB [ ] 2022-07-11_17-38_states.jsonl.gz 344.0 KiB [ ] 2022-07-10_03-04_states.jsonl.gz 344.0 KiB [ ] 2022-07-10_21-38_states.jsonl.gz 344.0 KiB [ ] 2022-07-10_19-38_states.jsonl.gz 344.0 KiB [ ] 2022-07-11_03-38_states.jsonl.gz 344.0 KiB [ ] 2022-07-10_16-53_states.jsonl.gz 344.0 KiB [ ] 2022-07-10_12-53_states.jsonl.gz 344.0 KiB [ ] 2022-07-10_14-53_states.jsonl.gz 344.0 KiB [ ] 2022-07-11_15-38_states.jsonl.gz 344.0 KiB [ ] 2022-07-10_07-04_states.jsonl.gz 344.0 KiB [ ] 2022-07-09_23-04_states.jsonl.gz -
@glasfaser said in backitup kein Backup von iobroker:
iobroker setup custom
pi@raspberrypi:/opt/iobroker/iobroker-data/backup-objects $ iobroker setup custom Current configuration: - Objects database: - Type: jsonl - Host/Unix Socket: 127.0.0.1 - Port: 9001 - States database: - Type: jsonl - Host/Unix Socket: 127.0.0.1 - Port: 9000 - Data Directory: ../../iobroker-data/ Type of objects DB [(j)sonl, (f)ile, (r)edis, ...], default [jsonl]: -
dieses Fenster? -
Hier läuft das auf 0.0.0.0. , nicht auf localhost
Current configuration: - Objects database: - Type: jsonl - Host/Unix Socket: 0.0.0.0 - Port: 9001 - States database: - Type: jsonl - Host/Unix Socket: 0.0.0.0 - Port: 9000 - Data Directory: ../../iobroker-data/ -
pi@raspberrypi:/opt/iobroker/iobroker-data/backup-objects $ ls -l insgesamt 622444 -rw-rwxr--+ 1 iobroker iobroker 2354586 9. Jul 04:29 2022-07-09_04-29_objects.jsonl.gz -rw-rwxr--+ 1 iobroker iobroker 26002233 9. Jul 04:29 2022-07-09_04-29_states.jsonl.gz -rw-rwxr--+ 1 iobroker iobroker 2354600 9. Jul 06:29 2022-07-09_06-29_objects.jsonl.gz -rw-rwxr--+ 1 iobroker iobroker 26001930 9. Jul 06:30 2022-07-09_06-29_states.jsonl.gz -rw-rwxr--+ 1 iobroker iobroker 2354574 9. Jul 08:29 2022-07-09_08-29_objects.jsonl.gz -rw-rwxr--+ 1 iobroker iobroker 26001812 9. Jul 08:29 2022-07-09_08-29_states.jsonl.gz -rw-rwxr--+ 1 iobroker iobroker 2354588 9. Jul 10:29 2022-07-09_10-29_objects.jsonl.gz -rw-rwxr--+ 1 iobroker iobroker 26001885 9. Jul 10:29 2022-07-09_10-29_states.jsonl.gz -rw-rwxr--+ 1 iobroker iobroker 2354693 9. Jul 12:29 2022-07-09_12-29_objects.jsonl.gz -rw-rwxr--+ 1 iobroker iobroker 26001719 9. Jul 12:30 2022-07-09_12-29_states.jsonl.gz -rw-rwxr--+ 1 iobroker iobroker 2357008 9. Jul 14:29 2022-07-09_14-29_objects.jsonl.gz -rw-rwxr--+ 1 iobroker iobroker 26001491 9. Jul 14:30 2022-07-09_14-29_states.jsonl.gz -rw-rwxr--+ 1 iobroker iobroker 2357011 9. Jul 16:29 2022-07-09_16-29_objects.jsonl.gz -rw-rwxr--+ 1 iobroker iobroker 26001920 9. Jul 16:30 2022-07-09_16-29_states.jsonl.gz -rw-rwxr--+ 1 iobroker iobroker 2358936 9. Jul 21:40 2022-07-09_21-40_objects.jsonl.gz -rw-rwxr--+ 1 iobroker iobroker 26002780 9. Jul 21:40 2022-07-09_21-40_states.jsonl.gz -rw-rwxr--+ 1 iobroker iobroker 2359193 9. Jul 23:40 2022-07-09_23-40_objects.jsonl.gz -rw-rwxr--+ 1 iobroker iobroker 26002528 9. Jul 23:41 2022-07-09_23-40_states.jsonl.gz -rw-rwxr--+ 1 iobroker iobroker 2360125 10. Jul 01:40 2022-07-10_01-40_objects.jsonl.gz -rw-rwxr--+ 1 iobroker iobroker 26002230 10. Jul 01:40 2022-07-10_01-40_states.jsonl.gz -rw-rwxr--+ 1 iobroker iobroker 2360239 10. Jul 03:40 2022-07-10_03-40_objects.jsonl.gz -rw-rwxr--+ 1 iobroker iobroker 24769257 10. Jul 03:41 2022-07-10_03-40_states.jsonl.gz -rw-rwxr--+ 1 iobroker iobroker 2362730 10. Jul 05:40 2022-07-10_05-40_objects.jsonl.gz -rw-rwxr--+ 1 iobroker iobroker 22743471 10. Jul 05:40 2022-07-10_05-40_states.jsonl.gz -rw-rwxr--+ 1 iobroker iobroker 2363056 10. Jul 07:40 2022-07-10_07-40_objects.jsonl.gz -rw-rwxr--+ 1 iobroker iobroker 22743526 10. Jul 07:41 2022-07-10_07-40_states.jsonl.gz -rw-rwxr--+ 1 iobroker iobroker 2363063 10. Jul 09:40 2022-07-10_09-40_objects.jsonl.gz -rw-rwxr--+ 1 iobroker iobroker 22744250 10. Jul 09:40 2022-07-10_09-40_states.jsonl.gz -rw-rwxr--+ 1 iobroker iobroker 2363058 10. Jul 11:40 2022-07-10_11-40_objects.jsonl.gz -rw-rwxr--+ 1 iobroker iobroker 22745078 10. Jul 11:40 2022-07-10_11-40_states.jsonl.gz -rw-rwxr--+ 1 iobroker iobroker 2363384 10. Jul 13:40 2022-07-10_13-40_objects.jsonl.gz -rw-rwxr--+ 1 iobroker iobroker 22744725 10. Jul 13:40 2022-07-10_13-40_states.jsonl.gz -rw-rwxr--+ 1 iobroker iobroker 2363967 10. Jul 17:21 2022-07-10_17-21_objects.jsonl.gz -rw-rwxr--+ 1 iobroker iobroker 22760736 10. Jul 17:22 2022-07-10_17-21_states.jsonl.gz -rw-rwxr--+ 1 iobroker iobroker 2369971 10. Jul 19:54 2022-07-10_19-54_objects.jsonl.gz -rw-rwxr--+ 1 iobroker iobroker 22764209 10. Jul 19:55 2022-07-10_19-54_states.jsonl.gz -rw-rwxr--+ 1 iobroker iobroker 2369837 11. Jul 01:16 2022-07-11_01-16_objects.jsonl.gz -rw-rwxr--+ 1 iobroker iobroker 22752844 11. Jul 01:17 2022-07-11_01-16_states.jsonl.gz -rw-rwxr--+ 1 iobroker iobroker 2372027 11. Jul 03:40 2022-07-11_03-40_objects.jsonl.gz -rw-rwxr--+ 1 iobroker iobroker 22753286 11. Jul 03:40 2022-07-11_03-40_states.jsonl.gz -rw-rwxr--+ 1 iobroker iobroker 2368272 11. Jul 07:09 2022-07-11_07-09_objects.jsonl.gz -rw-rwxr--+ 1 iobroker iobroker 22765515 11. Jul 07:10 2022-07-11_07-09_states.jsonl.gz -rw-rwxr--+ 1 iobroker iobroker 2368266 11. Jul 09:09 2022-07-11_09-09_objects.jsonl.gz -rw-rwxr--+ 1 iobroker iobroker 22765469 11. Jul 09:10 2022-07-11_09-09_states.jsonl.gz -rw-rwxr--+ 1 iobroker iobroker 2368260 11. Jul 11:09 2022-07-11_11-09_objects.jsonl.gz -rw-rwxr--+ 1 iobroker iobroker 22765283 11. Jul 11:10 2022-07-11_11-09_states.jsonl.gz -rw-rwxr--+ 1 iobroker iobroker 2370627 11. Jul 13:09 2022-07-11_13-09_objects.jsonl.gz -rw-rwxr--+ 1 iobroker iobroker 22765295 11. Jul 13:10 2022-07-11_13-09_states.jsonl.gz pi@raspberrypi:/opt/iobroker/iobroker-data/backup-objects $
