backitup kein Backup von iobroker
@glasfaser said in backitup kein Backup von iobroker:
ps auxww|grep io
pi@raspberrypi:/opt/iobroker/iobroker-data/backup-objects $ ps auxww|grep io root 13 0.0 0.0 0 0 ? S 17:12 0:00 [migration/0] root 16 0.0 0.0 0 0 ? S 17:12 0:00 [migration/1] root 21 0.0 0.0 0 0 ? S 17:12 0:00 [migration/2] root 26 0.0 0.0 0 0 ? S 17:12 0:00 [migration/3] root 62 0.0 0.0 0 0 ? I< 17:12 0:00 [blkcg_punt_bio] root 66 0.0 0.0 0 0 ? I< 17:12 0:00 [rpciod] root 68 0.0 0.0 0 0 ? I< 17:12 0:00 [xprtiod] root 71 0.0 0.0 0 0 ? I< 17:12 0:00 [nfsiod] root 80 0.0 0.0 0 0 ? I< 17:12 0:00 [DWC Notificatio] message+ 439 0.0 0.0 8204 4168 ? Ss 17:12 0:00 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only grafana 1053 0.2 0.9 963292 80424 ? Ssl 17:12 0:15 /usr/sbin/grafana-server --config=/etc/grafana/grafana.ini --pidfile=/run/grafana/grafana-server.pid --packaging=deb cfg:default.paths.logs=/var/log/grafana cfg:default.paths.data=/var/lib/grafana cfg:default.paths.plugins=/var/lib/grafana/plugins cfg:default.paths.provisioning=/etc/grafana/provisioning iobroker 1057 11.4 5.1 523620 414836 ? Ssl 17:12 11:45 iobroker.js-controller iobroker 1162 0.5 1.2 208788 100684 ? Sl 17:12 0:32 io.admin.0 root 1177 0.0 0.0 33204 7576 ? Sl 17:13 0:00 lightdm --session-child 14 23 iobroker 1178 0.3 0.9 187712 72936 ? Sl 17:13 0:21 io.history.0 iobroker 1202 2.8 4.0 437120 331376 ? Sl 17:13 2:57 io.javascript.0 pi 1220 0.0 0.1 377272 10772 ? S<sl 17:13 0:00 /usr/bin/pulseaudio --daemonize=no --log-target=journal pi 1222 0.0 0.0 7780 3764 ? Ss 17:13 0:04 /usr/bin/dbus-daemon --session --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only pi 1223 0.0 0.0 19636 4816 ? S<l 17:13 0:00 /usr/bin/pipewire-media-session pi 1232 0.0 0.1 52404 12988 ? Ssl 17:13 0:00 /usr/bin/lxsession -s LXDE-pi -e LXDE -w openbox-lxde-pi pi 1276 0.0 0.0 4616 280 ? Ss 17:13 0:00 /usr/bin/ssh-agent x-session-manager iobroker 1443 0.2 0.8 182492 70532 ? Sl 17:13 0:12 io.node-red.0 pi 1509 0.0 0.0 32516 5740 ? Sl 17:13 0:00 /usr/libexec/at-spi2-registryd --use-gnome-session iobroker 1632 0.1 0.7 184772 62236 ? Sl 17:13 0:11 io.pushover.0 iobroker 1885 1.4 1.9 282648 161704 ? Sl 17:13 1:29 node-red iobroker 1915 0.5 0.9 194012 76516 ? Sl 17:13 0:30 io.sql.0 iobroker 1921 0.6 0.9 192340 80516 ? Sl 17:13 0:41 io.hm-rega.0 iobroker 1943 0.4 0.9 190352 74596 ? Sl 17:13 0:24 io.hm-rpc.1 iobroker 2011 0.2 0.8 185832 65300 ? Sl 17:13 0:13 io.hm-rpc.2 iobroker 2019 0.2 0.8 183600 70404 ? Sl 17:13 0:16 io.hm-rpc.3 iobroker 2047 0.2 0.7 186016 64528 ? Sl 17:13 0:14 io.hm-rpc.4 iobroker 2059 0.4 0.8 183176 64992 ? Sl 17:13 0:30 io.rpi2.0 iobroker 2074 0.6 0.9 194384 77736 ? Sl 17:13 0:41 io.alexa2.0 iobroker 2125 0.6 0.9 194840 78496 ? Sl 17:13 0:41 io.alexa2.1 iobroker 2155 0.4 0.9 189288 75824 ? Sl 17:13 0:26 io.hm-rpc.5 iobroker 2170 0.1 0.7 182976 60936 ? Sl 17:14 0:12 io.discovery.0 iobroker 2185 0.3 0.9 194168 78604 ? Sl 17:14 0:22 io.tankerkoenig.0 iobroker 2215 0.2 0.8 187656 67528 ? Sl 17:14 0:14 io.web.0 iobroker 2245 0.2 0.9 191564 75052 ? Sl 17:14 0:18 io.info.0 iobroker 2264 0.5 1.1 206104 90728 ? Sl 17:14 0:32 io.ring.0 iobroker 2279 0.2 0.7 182356 59360 ? Sl 17:14 0:12 io.ble.0 iobroker 2336 0.3 0.8 190412 70568 ? Sl 17:14 0:23 io.fb-checkpresence.0 iobroker 2346 0.5 0.5 123852 42112 ? Sl 17:14 0:30 /usr/bin/node /opt/iobroker/node_modules/iobroker.ble/build/scanProcess -s fe95 iobroker 2390 0.2 0.9 187008 73052 ? Sl 17:14 0:12 io.backitup.0 iobroker 2419 0.2 0.8 185560 65764 ? Sl 17:14 0:15 io.trashschedule.0 iobroker 2555 0.2 0.8 185012 67852 ? Sl 17:14 0:12 io.backitup.1 iobroker 11577 7.8 0.8 185304 72492 ? Sl 18:55 0:03 io.smartgarden.0 pi 11649 0.0 0.0 3536 1780 pts/0 S+ 18:55 0:00 grep --color=auto io pi@raspberrypi:/opt/iobroker/iobroker-data/backup-objects $ -
@neuling-mit-großem-interesse sagte in backitup kein Backup von iobroker:
.ring.0
.ble.0 -
ls -lah /opt/iobroker/iobroker-data -
@glasfaser
ja -
ja über w-lan verbunden -
pi@raspberrypi:/opt/iobroker/iobroker-data/backup-objects $ ls -lah /opt/iobroker/iobroker-data insgesamt 91M drwxrwxr-x+ 10 iobroker iobroker 4,0K 11. Jul 18:12 . drwxrwxr-x+ 8 iobroker iobroker 4,0K 11. Jul 16:01 .. drwxrwxr-x+ 2 iobroker iobroker 4,0K 13. Jun 18:56 backitup drwxrwxr-x+ 2 iobroker iobroker 4,0K 11. Jul 13:10 backup-objects drwxrwxr-x+ 32 iobroker iobroker 4,0K 11. Jul 16:17 files -rw-rwxr--+ 1 iobroker iobroker 6,5K 11. Jul 15:16 iobroker.json drwxrwxr-x+ 4 iobroker iobroker 4,0K 11. Jul 00:34 node-red -rw-rwxr--+ 1 iobroker iobroker 3 11. Jul 17:12 notifications.json -rw-rw-r--+ 1 iobroker iobroker 14M 11. Jul 19:03 objects.jsonl drwxrwxr-x+ 2 iobroker iobroker 4,0K 11. Jul 19:03 objects.jsonl.lock drwxrwxr-x+ 2 iobroker iobroker 4,0K 20. Jun 18:49 sqlite -rw-rw-r--+ 1 iobroker iobroker 78M 11. Jul 19:03 states.jsonl drwxrwxr-x+ 2 iobroker iobroker 4,0K 11. Jul 19:03 states.jsonl.lock drwxrwxr-x+ 4 iobroker iobroker 4,0K 14. Jun 17:33 tuya_0 pi@raspberrypi:/opt/iobroker/iobroker-data/backup-objects $ -
Hast du eigentlich schonmal deine Pi ... komplett neu gestartet und danach mal ein Backup versucht !?
@glasfaser 78M an states.
mit ring und ble sind beide Verdächtigen an Bord -
Ich dachte er hat schon auf deinen Hinweis dazu geantwortet ...
Habe ich überlesen .... -
Für mich als anfänger ist es einfacher um an die speicherorte und dateipfade zu kommen... das eigentliche Problem hat nichts mit dem Monitor zu tun.
io.backitup.1
Warum hast du 2 instanzen !?
Zeige mal
iobroker list instances -
Mit dem Monitor nicht. Aber vielleicht mit dem ganzen DesktopEnvironment das da mitrumpelt und das ganze komplexer, unsicherer und ressourcenhungriger macht.
pi@raspberrypi:~ $ iobroker list instances + system.adapter.admin.0 : admin : raspberrypi - enabled, compact disabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.alexa2.0 : alexa2 : raspberrypi - enabled, compact disabled + system.adapter.alexa2.1 : alexa2 : raspberrypi - enabled, compact disabled + system.adapter.backitup.0 : backitup : raspberrypi - enabled, compact disabled + system.adapter.backitup.1 : backitup : raspberrypi - enabled, compact disabled + system.adapter.ble.0 : ble : raspberrypi - enabled system.adapter.daswetter.0 : daswetter : raspberrypi - enabled, compact disabled + system.adapter.discovery.0 : discovery : raspberrypi - enabled, compact disabled + system.adapter.fb-checkpresence.0 : fb-checkpresence : raspberrypi - enabled, compact disabled system.adapter.flot.0 : flot : raspberrypi - enabled + system.adapter.history.0 : history : raspberrypi - enabled, compact disabled + system.adapter.hm-rega.0 : hm-rega : raspberrypi - enabled, compact disabled + system.adapter.hm-rpc.1 : hm-rpc : raspberrypi - enabled, compact disabled, port: 0 + system.adapter.hm-rpc.2 : hm-rpc : raspberrypi - enabled, compact disabled, port: 0 + system.adapter.hm-rpc.3 : hm-rpc : raspberrypi - enabled, compact disabled, port: 0 + system.adapter.hm-rpc.4 : hm-rpc : raspberrypi - enabled, compact disabled, port: 0 + system.adapter.hm-rpc.5 : hm-rpc : raspberrypi - enabled, compact disabled, port: 0 system.adapter.ical.0 : ical : raspberrypi - enabled, compact disabled + system.adapter.info.0 : info : raspberrypi - enabled, compact disabled + system.adapter.javascript.0 : javascript : raspberrypi - enabled, compact disabled + system.adapter.node-red.0 : node-red : raspberrypi - enabled, compact disabled, port: 1880, bind: 192.168.178.73 + system.adapter.pushover.0 : pushover : raspberrypi - enabled, compact disabled + system.adapter.ring.0 : ring : raspberrypi - enabled, compact disabled + system.adapter.rpi2.0 : rpi2 : raspberrypi - enabled + system.adapter.smartgarden.0 : smartgarden : raspberrypi - enabled, compact disabled + system.adapter.sql.0 : sql : raspberrypi - enabled, compact disabled, port: 3306 + system.adapter.tankerkoenig.0 : tankerkoenig : raspberrypi - enabled, compact disabled + system.adapter.trashschedule.0 : trashschedule : raspberrypi - enabled, compact disabled system.adapter.vis.0 : vis : raspberrypi - enabled, compact disabled + system.adapter.web.0 : web : raspberrypi - enabled, compact disabled, port: 8082, bind: 0.0.0.0, run as: admin + instance is alive pi@raspberrypi:~ $ -
wie gesagt wenn node js 3x instaliert ist dann geht backup....
in der konsole wird etwas von speicher erwähnt....[ERROR] [iobroker] - <--- Last few GCs ---> [32392:0x4fbafc8] 23688 ms: Mark-sweep (reduce) 586.4 (593.5) -> 586.4 (590.5) MB, 114.8 / 0.0 ms (+ 0.0 ms in 0 steps since start of marking, biggest step 0.0 ms, walltime since start of marking 2269 ms) (average mu = 0.970, current mu = 0.951) last [32392:0x4fbafc8] 23765 ms: Mark-sweep (reduce) 586.4 (590.5) -> 586.4 (589.8) MB, 77.4 / 0.0 ms (average mu = 0.951, current mu = 0.001) last resort GC in old space requested [ERROR] [iobroker] - <--- JS stacktrace ---> -
Der 'Kompakt'-Modus. Da kann man beim Speicher ein paar MB einsparen. Hat aber soweit ich weiß an anderer Stelle wieder Stolperfallen, wenn der aktiv ist.
Bei mir ist der auch aus. -
sorry ...js-controller 4.0 dann fehler
js-controller 3.0 dann geht es mit dem backup -
Ich weiß .... du wirst gerade mit Fragen zugeschüttet .
Aber oben sind noch welche offen !!!
@thomas-braun said in backitup kein Backup von iobroker:
Bei mir ist der auch aus.Hatte ich auch schon versucht....
