    3. Einsteigerfragen
    4. backitup kein Backup von iobroker
    • N
      Neuling mit großem Interesse @Glasfaser last edited by
      @glasfaser
      pi@raspberrypi:~ $ iobroker list instances
      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, compact disabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled, compact disabled
      + system.adapter.alexa2.1                 : alexa2                : raspberrypi                              -  enabled, compact disabled
      + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled, compact disabled
      + system.adapter.backitup.1               : backitup              : raspberrypi                              -  enabled, compact disabled
      + system.adapter.ble.0                    : ble                   : raspberrypi                              -  enabled
        system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled, compact disabled
      + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled, compact disabled
      + system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              -  enabled, compact disabled
        system.adapter.flot.0                   : flot                  : raspberrypi                              -  enabled
      + system.adapter.history.0                : history               : raspberrypi                              -  enabled, compact disabled
      + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled, compact disabled
      + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, compact disabled, port: 0
      + system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              -  enabled, compact disabled, port: 0
      + system.adapter.hm-rpc.3                 : hm-rpc                : raspberrypi                              -  enabled, compact disabled, port: 0
      + system.adapter.hm-rpc.4                 : hm-rpc                : raspberrypi                              -  enabled, compact disabled, port: 0
      + system.adapter.hm-rpc.5                 : hm-rpc                : raspberrypi                              -  enabled, compact disabled, port: 0
        system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled, compact disabled
      + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled, compact disabled
      + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled, compact disabled
      + system.adapter.node-red.0               : node-red              : raspberrypi                              -  enabled, compact disabled, port: 1880, bind: 192.168.178.73
      + system.adapter.pushover.0               : pushover              : raspberrypi                              -  enabled, compact disabled
      + system.adapter.ring.0                   : ring                  : raspberrypi                              -  enabled, compact disabled
      + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
      + system.adapter.smartgarden.0            : smartgarden           : raspberrypi                              -  enabled, compact disabled
      + system.adapter.sql.0                    : sql                   : raspberrypi                              -  enabled, compact disabled, port: 3306
      + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled, compact disabled
      + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled, compact disabled
        system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled, compact disabled
      + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, compact disabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      pi@raspberrypi:~ $
      • N
        Neuling mit großem Interesse @Thomas Braun last edited by
        wie gesagt wenn node js 3x instaliert ist dann geht backup....
        in der konsole wird etwas von speicher erwähnt....
        [ERROR] [iobroker] -
        <--- Last few GCs --->
        [32392:0x4fbafc8]    23688 ms: Mark-sweep (reduce) 586.4 (593.5) -> 586.4 (590.5) MB, 114.8 / 0.0 ms  (+ 0.0 ms in 0 steps since start of marking, biggest step 0.0 ms, walltime since start of marking 2269 ms) (average mu = 0.970, current mu = 0.951) last [32392:0x4fbafc8]    23765 ms: Mark-sweep (reduce) 586.4 (590.5) -> 586.4 (589.8) MB, 77.4 / 0.0 ms  (average mu = 0.951, current mu = 0.001) last resort GC in old space requested
        <--- JS stacktrace --->
        • Glasfaser
          Glasfaser @Neuling mit großem Interesse last edited by
          @Thomas-Braun
          compact disabled
          Was ist das , sagt mir gerade nichts
          Thomas Braun N 2 Replies Last reply Reply Quote 0
            Thomas Braun Most Active @Glasfaser last edited by
            @glasfaser
            Der 'Kompakt'-Modus. Da kann man beim Speicher ein paar MB einsparen. Hat aber soweit ich weiß an anderer Stelle wieder Stolperfallen, wenn der aktiv ist.
            Bei mir ist der auch aus.
            • N
              @glasfaser
              sorry ...js-controller 4.0 dann fehler
              js-controller 3.0 dann geht es mit dem backup
              • Glasfaser
                @neuling-mit-großem-interesse
                Ich weiß .... du wirst gerade mit Fragen zugeschüttet .
                Aber oben sind noch welche offen !!!
                • N
                  @thomas-braun said in backitup kein Backup von iobroker:
                  Hatte ich auch schon versucht....
                  • Glasfaser
                    Nee die von @Homoran
                    und von mir mit dem Neustart
                      Jedenfalls hast du ein Problem mit dem Speicher.
                      https://www.geeksforgeeks.org/mark-and-sweep-garbage-collection-algorithm/
                      Und da trägt ein fetter Desktop nicht gerade dazu bei da mehr Ressourcen zu haben.
                      • N
                        @glasfaser
                        habe ich dann übersehen...
                        kannst du die bitte erneut stellen
                        • N
                          Neuling mit großem Interesse @Neuling mit großem Interesse last edited by
                          sorry
                          2493
