    4. Test Adapter Sprinkle Control 0.2.x mit neuen Funktionen
    • Dirk Peter
      Dirk Peter @SaschaS last edited by Dirk Peter
      @saschas
      maxIrrigation = 8mm
      maximale Bodenfeuchtigkeit nach der Bewässerung in (mm)
      triggersIrrigation = 4mm
      Einschaltpunkt (Bodenfeuchtigkeit) des Bewässerungsventils in % x maxIrrigation [8mm * 50% = 4mm]
      wateringTime = 60min
      Bewässerungszeit in min
      MfG Dirk Peter
        gyle last edited by gyle
        ich habe 3 Ventile - davon habe ich Nr. 1 & 3 per option "autoOn" deaktiviert.
        Dennoch startet die Bewässerung mit einem dieser Ventile (Bewässerung Garage:3.STATE).
        Wo liegt das problem?
          "_id": "system.adapter.sprinklecontrol.0",
          "common": {
            "name": "sprinklecontrol",
            "version": "0.2.11",
            "title": "Sprinkle Control",
            "authors": [
              "Dirk Peter <dirk.peter@freenet.de>"
            "keywords": [
              "Sprinkle",
              "Irrigation",
              "Bewässerung",
              "Steuerung",
              "ioBroker"
            "docs": {
              "en": "docs/en/sprinklecontrol.md",
              "de": "docs/de/sprinklecontrol.md"
            "license": "MIT",
            "platform": "Javascript/Node.js",
            "main": "main.js",
            "icon": "sprinklecontrol.png",
            "enabled": true,
            "extIcon": "https://raw.githubusercontent.com/Dirk-Peter-md/ioBroker.sprinklecontrol/master/admin/sprinklecontrol.png",
            "readme": "https://github.com/Dirk-Peter-md/ioBroker.sprinklecontrol/blob/master/README.md",
            "loglevel": "info",
            "mode": "daemon",
            "type": "garden",
            "compact": true,
            "materialize": true,
            "messagebox": true,
            "stopBeforeUpdate": true,
            "connectionType": "local",
            "dataSource": "assumption",
            "dependencies": [
                "js-controller": ">=2.0.0"
            "installedFrom": "iobroker.sprinklecontrol@0.2.11",
            "installedVersion": "0.2.11",
            "host": "iobroker"
          "native": {
            "triggerControlVoltage": "",
            "maximumParallelValves": 1,
            "switchingDistance": 500,
            "triggerMainPump": "hm-rpc.1.SEQ0343973.4.STATE",
            "triggerMainPumpPower": 750,
            "cisternSettings": false,
            "triggerCisternPump": "",
            "triggerCisternPumpPower": 1800,
            "actualValueLevel": "30",
            "triggerMinCisternLevel": 25,
            "wateringStartTime": "livingTime",
            "timeShift": 0,
            "weekLiving": "21:10",
            "publicWeekend": true,
            "weekEndLiving": "23:00",
            "publicHolidays": true,
            "publicHolInstance": "feiertage.0",
            "latitude": "50.22116135719122",
            "longitude": "8.683589310246877",
            "notificationEnabled": false,
            "sensorOutsideTemperature": "",
            "sensorOutsideHumidity": "",
            "sensorWindSpeed": "",
            "sensorBrightness": "",
            "sensorRainfall": "",
            "weatherForecast": false,
            "weatherForInstance": "",
            "thresholdRain": 2,
            "notificationsType": "Telegram",
            "telegramInstance": "",
            "telegramUser": null,
            "telegramNoticeType": "longTelegramNotice",
            "telegramWaitToSend": 0,
            "telegramSilentNotice": false,
            "telegramOnlyError": false,
            "whatsappInstance": "",
            "whatsappNoticeType": "longWhatsappNotice",
            "whatsappWaitToSend": 0,
            "whatsappOnlyError": false,
            "pushoverInstance": "",
            "pushoverNoticeType": "longPushoverNotice",
            "pushoverWaitToSend": 0,
            "pushoverDeviceID": "",
            "pushoverSound": "",
            "pushoverSilentNotice": false,
            "pushoverOnlyError": false,
            "emailReceiver": "xxx@xxx.com",
            "emailSender": "xxx@xxx.com",
            "emailInstance": "",
            "emailNoticeType": "longEmailNotice",
            "emailWaitToSend": 0,
            "emailOnlyError": false,
            "events": [
                "enabled": true,
                "sprinkleName": "Bewässerung Garage:1.STATE",
                "name": "hm-rpc.1.SEQ0343973.1.STATE",
                "triggerID": "",
                "wateringTime": "20",
                "wateringAdd": "130",
                "wateringInterval": "0",
                "maxSoilMoistureIrrigation": "8",
                "maxSoilMoistureRainPct": "120",
                "triggersIrrigation": "50",
                "pipeFlow": "1100",
                "booster": false,
                "endIrrigation": true,
                "methodControlSM": "fixDay",
                "inGreenhouse": false,
                "triggerSM": "",
                "analogZPct": "0",
                "analogOHPct": "100",
                "startDay": "fixDay",
                "sun": true,
                "mon": true,
                "tue": true,
                "wed": true,
                "thur": true,
                "fri": true,
                "sat": true
                "enabled": true,
                "sprinkleName": "Rasen",
                "name": "hm-rpc.1.SEQ0343973.2.STATE",
                "triggerID": "",
                "wateringTime": "50",
                "pipeFlow": "370",
                "booster": false,
                "endIrrigation": false,
                "triggerSM": "",
                "analogZPct": "0",
                "sun": true,
                "mon": true,
                "tue": true,
                "wed": true,
                "thur": true,
                "fri": true,
                "sat": true
                "enabled": true,
                "sprinkleName": "Bewässerung Garage:3.STATE",
                "name": "hm-rpc.1.SEQ0343973.3.STATE",
                "triggerID": "",
                "pipeFlow": "700",
                "booster": false,
                "triggerSM": "",
                "analogZPct": "0",
                "sun": true,
                "mon": true,
                "tue": true,
                "wed": true,
                "thur": true,
                "fri": true,
                "sat": true
        Dirk Peter 1 Reply Last reply Reply Quote 0
        • Dirk Peter
          Dirk Peter @gyle last edited by
          @gyle
          Hallo, das ist ein Fehler im Adapter! Wenn man die Konfiguration speichert, so wird autoOn nicht neu ausgelesen. Am besten du deaktivierst die Bewässerungskreise direkt in der Konfiguration. Ich ändere es in der nächsten Version.
          Danke für die Info, Dirk Peter
          G 2 Replies Last reply Reply Quote 0
            gyle @Dirk Peter last edited by
            @dirk-peter super danke dir!
              Hat man denn die Möglichkeit die einzelnen Sprinkler zu resetten?
              Bin ja noch am Experimentieren. Wenn ich acutalSoilMoisture im Expertenmodus schreibe, dann wird bei der nächsten Berechnung wieder der alte Wert errechnet. Ich würde gerne gezielt den acutalSoilMoisture vorgeben können.
                dirkhe Developer @SaschaS last edited by
                @saschas adapter stoppen, wert ändern und wieder starten
                • Z
                  Zeptran @Dirk Peter last edited by
                  @dirk-peter
                  ich habe das ganze entsprechend deiner Anleitung umgestellt.
                  Funktioniert soweit super bis auf ein kleines Problem.
                  Bei jedem Regen Tag wird der Tages Unterschied wieder überschrieben und laufen wieder parallel.
                  Hast du hierfür noch einen Tipp für mich, wie ich das manuelle Umstellen umgehen kann?
                  MfG
                  Paul
                    SaschaS @dirkhe last edited by SaschaS
                    @dirkhe dann war das wohl mein Fehler, dass ich den Adapter zuvor nicht gestoppt habe. Werde ich direkt mal probieren.
                    Edit: Funktioniert! Danke
                    • Dirk Peter
                      Dirk Peter @Zeptran last edited by
                      @zeptran
                      lad dir mal die Version von GitHub zum Testen herunter. Hier ist ein Taster zum weiterschalten der Tage integriert und bei Regen sollten jetzt alle Kreise verschoben werden und nicht nur der aktive. Die Verschiebung der Kreise sollte also bestehen bleiben!
                      Das Laden von GitHub kann unter npm 6 bis zu 30 min dauern!
                      MfG Dirk Peter
                        @dirk-peter hast du schon eine Idee, wann du den fehler beheben willst?
                        • Dirk Peter
                          @gyle
                          Auf GitHub ist er schon behoben. Ich veröffentliche die Adapter nach dem ich sie auf adapter-check.iobroker.in getestet habe. Dieser funktioniert aber momentan nicht. Eine issue habe ich schon eröffnet, aber keine Antwort bis jetzt erhalten.
                          MfG Dirk Peter
                            bimmi last edited by
                            Ich habe eine Umfrage gestartet für eine Erweiterung dieses Adapters um eine automatische Düngereinspritzung.
                            Falls Interesse besteht:
                            https://forum.iobroker.net/topic/56717/sprinklecontrol-adapter-automatisches-düngen-umfrage
                            Gruß Christoph
                              @dirk-peter Kannst du mir/uns kurz schildern, wie sich die Werte aus dem Log zusammensetzen: 6.9 mm [ 0.08 (4.880000000000001) <= 4 ]
                              6.9mm müsste der Wert der Wettervorhersage aus rainToday sein. Die restlichen sind mir unbekannt.
                              Ich frage, da korrekterweise der Kreis "Rasen_Oben" ausgesetzt wurde, der nächste Kreis "Rasen_Küche" aber nicht.
                              2022-09-03 03:00:00.064  - info: sprinklecontrol.0 (30064) Rasen_Oben: Start verschoben, da Regenvorhersage für Heute 6.9 mm [ 0.08 (4.880000000000001) <= 4 ]
                              2022-09-03 03:00:00.158  - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 started with pid 27732
                              2022-09-03 03:00:00.178  - info: javascript.0 (10340) script.js.SprinkleControl.SprinkleControl_Hilfsfunktion: SprinkleControl startet Bewässerung Rasen_Küche
                              2022-09-03 03:00:00.221  - info: sprinklecontrol.0 (30064) Set (calculation) ID: Rasen_Küche, value: true, duration: 59:24
                              • Dirk Peter
                                @saschas sagte in Test Adapter Sprinkle Control 0.2.x mit neuen Funktionen:
                                Hallo, hier die Werte und ihre Bedeutung:
                                • 6,9 mm
                                • 0,08 => .actualSoilMoisture unter Objekte lag bei 1% (unterste Grenze) 8 x 1% = 0,08
                                • 4.880000000000001 => 0,08 + 6,9 - Schwellwert für Regenvorhersage aus der Konfiguration, bei dir wahrscheinlich 2,1
                                • 4 => In deiner Konfiguration steht wahrscheinlich unter maximale Bodenfeuchtigkeit nach der Bewässerung = 8 und der Einschaltpunkt (Bodenfeuchtigkeit) des Bewässerungsventile in % = 50%. Daraus resultiert der Einschaltpunkt 8 x 50% = 4
                                MfG Dirk Peter
                                  sigi234 Forum Testing Most Active @Dirk Peter last edited by sigi234
                                  @dirk-peter
                                  bekomme immer diesen Warn:
                                  sprinklecontrol.0
                                  2023-02-20 08:55:29.609	warn	The bistable sensor 0_userdata.0.Bewaesserungssensor.Feuchte_Sensor_6 in Ventil_6 does not deliver correct values!
                                  sprinklecontrol.0
                                  2023-02-20 08:55:28.292	warn	The bistable sensor 0_userdata.0.Bewaesserungssensor.Feuchte_Sensor_5 in Ventil_5 does not deliver correct values!
                                  sprinklecontrol.0
                                  2023-02-20 08:55:27.090	warn	The bistable sensor 0_userdata.0.Bewaesserungssensor.Feuchte_Sensor_4 in Ventil_4 does not deliver correct values!
                                  sprinklecontrol.0
                                  2023-02-20 08:55:25.929	warn	The bistable sensor 0_userdata.0.Bewaesserungssensor.Feuchte_Sensor_3 in Ventil_3 does not deliver correct values!
                                  sprinklecontrol.0
                                  2023-02-20 08:55:24.764	warn	The bistable sensor 0_userdata.0.Bewaesserungssensor.Feuchte_Sensor_2 in Ventil_2 does not deliver correct values!
                                  sprinklecontrol.0
                                  2023-02-20 08:55:23.456	warn	The bistable sensor 0_userdata.0.Bewaesserungssensor.Feuchte_Sensor_1 in Ventil_1 does not deliver correct values!
                                    "common": {
                                      "name": "Feuchte_Sensor_1",
                                      "desc": "Manuell erzeugt",
                                      "role": "state",
                                      "type": "number",
                                      "read": true,
                                      "write": true,
                                      "def": 0
                                    "type": "state",
                                    "user": "system.user.admin",
                                    "ts": 1654759418133,
                                    "_id": "0_userdata.0.Bewaesserungssensor.Feuchte_Sensor_1",
                                    "acl": {
                                      "object": 1636,
                                      "state": 1636,
                                      "owner": "system.user.admin",
                                  • Dirk Peter
                                    Dirk Peter @sigi234 last edited by
                                    @sigi234 sagte in Test Adapter Sprinkle Control 0.2.x mit neuen Funktionen:
                                    Hallo Sigi,
                                    wie die Meldung sagt, wird ein Signal von einem bistabilen Sensor erwartet. Also true oder false!
                                    Dein Feuchtesensor liefert aber einen Wert vom Typ "type": "number"! Daher die Fehlermeldung.
                                    Die Frage ist jetzt, was für einen Sensor verwendest du Bistabil (type "boolean", true/false) oder Analog (type "number", Wertebereich entsprechend der Bodenfeuchte).
                                    MfG Dirk Peter
                                      @dirk-peter
                                      Aha, das ist ein Dummy DP!
                                      • Dirk Peter
                                        Hallo, was meinst du mit Dummy DP? Welche Werte bzw. Datentype liefert denn dein Bodenfeuchte-Sensor.
                                        MfG Dirk Peter
                                          @dirk-peter sagte in Test Adapter Sprinkle Control 0.2.x mit neuen Funktionen:
                                          MfG Dirk Peter
                                          Ich habe keinen Garten und alle DP sind nur Virtuelle DPs , zur Erstellung einer VIS.
                                          • Dirk Peter
                                            @sigi234 Verstehe! Dir eine schöne Woche Dirk Peter
                                            31.7k
                                            79.9k
                                            bodenfeuchte-sensoren gartenbewässerung sprinkle control wetterabhängig
                                            41
                                            295
                                            38148
