    4. Anfrage Tahoma/Somfy IO Adapter
      puls200 @blackeagle998 last edited by
      Yes!
      Jetzt geht wieder Alles dank v0.7.2...
      Vielen Dank an alle!
        Willi-Wunder @Excodibur last edited by
        @excodibur
        Log sollte gerade per PN raus sein. Hoffe es paßt so......
        Gruß Willi
          Willi-Wunder last edited by Willi-Wunder
          @Excodibur
          PN hat nicht geklappt, hab keine Adresse gefunden........Hab aber gerade wieder den Fehler im Log, vielleicht reicht das auch schon, ansonsten kann ich dir gerne die anderen Dateien noch schicken.
          tahoma.0
          	2022-07-02 01:09:48.188	info	eventRegisterID = 221bef9d-1c57-4d26-8ba3-005b34dxxxxx
          tahoma.0
          	2022-07-02 01:09:46.343	info	Using stored bearer token 6263c4b71f21561xxxxx
          tahoma.0
          	2022-07-02 01:09:46.340	info	Adapter will connect to Tahoma Box via local API.
          tahoma.0
          	2022-07-02 01:09:46.337	info	Configured polling interval: 500000
          tahoma.0
          	2022-07-02 01:09:46.336	info	[START] Starting adapter tahoma v0.7.2.3
          tahoma.0
          	2022-07-02 01:09:46.300	info	starting. Version 0.7.2 (non-npm: Excodibur/ioBroker.tahoma) in /opt/iobroker/node_modules/iobroker.tahoma, node: v12.22.12, js-controller: 4.0.23
          host.raspberrypi
          	2022-07-02 01:09:44.086	info	instance system.adapter.tahoma.0 started with pid 27807
          host.raspberrypi
          	2022-07-02 01:09:13.866	info	Restart adapter system.adapter.tahoma.0 because enabled
          host.raspberrypi
          	2022-07-02 01:09:13.864	error	instance system.adapter.tahoma.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          tahoma.0
          	2022-07-02 01:09:13.254	error	The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
          tahoma.0
          	2022-07-02 01:09:13.254	error	Error: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position! at validateSetStateObjectArgument (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5669:23) at Adapter.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5752:21) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.tahoma/lib/tahoma.js:1317:36) at processImmediate (internal/timers.js:463:21)
          tahoma.0
          	2022-07-02 01:09:13.253	error	unhandled promise rejection: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
          tahoma.0
          	2022-07-02 01:09:13.252	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          tahoma.0
          	2022-07-02 01:09:13.250	error	The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
          tahoma.0
          	2022-07-02 01:09:13.249	error	Error: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position! at validateSetStateObjectArgument (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5669:23) at Adapter.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5752:21) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.tahoma/lib/tahoma.js:1317:36) at processImmediate (internal/timers.js:463:21)
          tahoma.0
          	2022-07-02 01:09:13.248	error	unhandled promise rejection: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
          tahoma.0
          	2022-07-02 01:09:13.247	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          tahoma.0
          	2022-07-02 01:09:13.242	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
          tahoma.0
          	2022-07-02 01:09:13.240	info	terminating
          tahoma.0
          	2022-07-02 01:09:13.236	error	The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
          tahoma.0
          	2022-07-02 01:09:13.236	error	Error: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position! at validateSetStateObjectArgument (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5669:23) at Adapter.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5752:21) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.tahoma/lib/tahoma.js:1317:36) at processImmediate (internal/timers.js:463:21)
          tahoma.0
          	2022-07-02 01:09:13.234	error	unhandled promise rejection: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
          tahoma.0
          	2022-07-02 01:09:13.233	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          tahoma.0
          	2022-07-02 01:09:13.227	error	The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
          tahoma.0
          	2022-07-02 01:09:13.226	error	Error: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position! at validateSetStateObjectArgument (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5669:23) at Adapter.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5752:21) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.tahoma/lib/tahoma.js:1317:36) at processImmediate (internal/timers.js:463:21)
          tahoma.0
          	2022-07-02 01:09:13.220	error	unhandled promise rejection: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
          tahoma.0
          	2022-07-02 01:09:13.219	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          tahoma.0
          	2022-07-02 01:00:53.155	info	eventRegisterID = 90020fb6-eea8-4b6d-a51c-c8870f5xxxxxx
          tahoma.0
          	2022-07-02 01:00:51.366	info	Using stored bearer token 6263c4b71f21561xxxxx
          tahoma.0
          	2022-07-02 01:00:51.363	info	Adapter will connect to Tahoma Box via local API.
          tahoma.0
          	2022-07-02 01:00:51.360	info	Configured polling interval: 500000
          tahoma.0
          	2022-07-02 01:00:51.359	info	[START] Starting adapter tahoma v0.7.2.3
          tahoma.0
          	2022-07-02 01:00:51.323	info	starting. Version 0.7.2 (non-npm: Excodibur/ioBroker.tahoma) in /opt/iobroker/node_modules/iobroker.tahoma, node: v12.22.12, js-controller: 4.0.23
          host.raspberrypi
          	2022-07-02 01:00:49.003	info	instance system.adapter.tahoma.0 started with pid 27411
          host.raspberrypi
          	2022-07-02 01:00:18.879	info	Restart adapter system.adapter.tahoma.0 because enabled
          host.raspberrypi
          	2022-07-02 01:00:18.878	error	instance system.adapter.tahoma.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          tahoma.0
          	2022-07-02 01:00:18.224	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
          tahoma.0
          	2022-07-02 01:00:18.223	info	terminating
          tahoma.0
          	2022-07-02 01:00:18.221	error	The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, smart_protect, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
          tahoma.0
          	2022-07-02 01:00:18.221	error	Error: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, smart_protect, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position! at validateSetStateObjectArgument (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5669:23) at Adapter.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5752:21) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.tahoma/lib/tahoma.js:1317:36) at processImmediate (internal/timers.js:463:21)
          tahoma.0
          	2022-07-02 01:00:18.220	error	unhandled promise rejection: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, smart_protect, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
          tahoma.0
          	2022-07-02 01:00:18.220	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          tahoma.0
          	2022-07-02 01:00:18.219	error	The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, smart_protect, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
          tahoma.0
          	2022-07-02 01:00:18.219	error	Error: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, smart_protect, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position! at validateSetStateObjectArgument (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5669:23) at Adapter.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5752:21) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.tahoma/lib/tahoma.js:1317:36) at processImmediate (internal/timers.js:463:21)
          tahoma.0
          	2022-07-02 01:00:18.218	error	unhandled promise rejection: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, smart_protect, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
          tahoma.0
          	2022-07-02 01:00:18.218	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          tahoma.0
          	2022-07-02 01:00:18.216	error	The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
          tahoma.0
          	2022-07-02 01:00:18.215	error	Error: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position! at validateSetStateObjectArgument (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5669:23) at Adapter.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5752:21) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.tahoma/lib/tahoma.js:1317:36) at processImmediate (internal/timers.js:463:21)
          tahoma.0
          	2022-07-02 01:00:18.209	error	unhandled promise rejection: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
          tahoma.0
          	2022-07-02 01:00:18.209	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          tahoma.0
          	2022-07-02 00:35:18.102	info	eventRegisterID = 29eff3c1-fe48-4ff3-81ba-a7927f1xxxxx
          tahoma.0
          	2022-07-02 00:35:16.296	info	Using stored bearer token 6263c4b71f21561xxxxx
          tahoma.0
          	2022-07-02 00:35:16.293	info	Adapter will connect to Tahoma Box via local API.
          tahoma.0
          	2022-07-02 00:35:16.290	info	Configured polling interval: 500000
          tahoma.0
          	2022-07-02 00:35:16.289	info	[START] Starting adapter tahoma v0.7.2.3
          tahoma.0
          	2022-07-02 00:35:16.253	info	starting. Version 0.7.2 (non-npm: Excodibur/ioBroker.tahoma) in /opt/iobroker/node_modules/iobroker.tahoma, node: v12.22.12, js-controller: 4.0.23
          host.raspberrypi
          	2022-07-02 00:35:14.066	info	instance system.adapter.tahoma.0 started with pid 26211
          host.raspberrypi
          	2022-07-02 00:34:43.957	info	Restart adapter system.adapter.tahoma.0 because enabled
          host.raspberrypi
          	2022-07-02 00:34:43.956	error	instance system.adapter.tahoma.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          tahoma.0
          	2022-07-02 00:34:43.306	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
          tahoma.0
          	2022-07-02 00:34:43.305	info	terminating
          tahoma.0
          	2022-07-02 00:34:43.303	error	The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, smart_protect, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
          tahoma.0
          	2022-07-02 00:34:43.302	error	Error: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, smart_protect, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position! at validateSetStateObjectArgument (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5669:23) at Adapter.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5752:21) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.tahoma/lib/tahoma.js:1317:36) at processImmediate (internal/timers.js:463:21)
          tahoma.0
          	2022-07-02 00:34:43.302	error	unhandled promise rejection: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, smart_protect, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
          tahoma.0
          	2022-07-02 00:34:43.301	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          tahoma.0
          	2022-07-02 00:34:43.301	error	The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, smart_protect, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
          tahoma.0
          	2022-07-02 00:34:43.300	error	Error: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, smart_protect, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position! at validateSetStateObjectArgument (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5669:23) at Adapter.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5752:21) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.tahoma/lib/tahoma.js:1317:36) at processImmediate (internal/timers.js:463:21)
          tahoma.0
          	2022-07-02 00:34:43.300	error	unhandled promise rejection: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, smart_protect, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
          tahoma.0
          	2022-07-02 00:34:43.299	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          tahoma.0
          	2022-07-02 00:34:43.298	error	The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, smart_protect, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
          tahoma.0
          	2022-07-02 00:34:43.297	error	Error: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, smart_protect, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position! at validateSetStateObjectArgument (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5669:23) at Adapter.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5752:21) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.tahoma/lib/tahoma.js:1317:36) at processImmediate (internal/timers.js:463:21)
          tahoma.0
          	2022-07-02 00:34:43.294	error	unhandled promise rejection: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, smart_protect, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
          tahoma.0
          	2022-07-02 00:34:43.294	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          Gruß Willi
            memme last edited by memme
            Wenn ich den bei meinem Rolladen den command.down auf True stelle, fährt der Rolladen runter. Er stellt sich dann aber nicht wieder auf false, wenn er runtergefahren ist.
            Nun kann ich auch keinen anderen Rolladen mehr fahren, sondern muss die adapter instanz neu starten. Dann kann ich wieder einmal fahren.
            Wenn ich nach dem runterfahren den down wert wieder auf false stelle geht es wieder mit dem hochfahren. Dann muss ich up wieder auf false stellen. Das geht dann ein paar mal, dann gar nicht mehr und ich muss die instanz wieder neustarten.....
            Gibt es eine Anleitung um die Rolläden als button in Jarvis hinzuzufügen?
            note: Nutze tahoma switch, adapter auf 0.7.2
            Excodibur 1 Reply Last reply Reply Quote 0
            • Excodibur
              Excodibur Developer @memme last edited by
              @memme Ja, das ist einer der komplizierteren Bugs mit der lokalen API. Hängt mit https://github.com/Excodibur/ioBroker.tahoma/issues/149 zusammen, nur leider bin ich noch nicht dazu gekommen.
              NilsReinecke created this issue in Excodibur/ioBroker.tahoma
              closed Failed getting execution state on local api #149
              M T 2 Replies Last reply Reply Quote 0
                Wie macht ihr es denn, wenn ihr einen Repeater braucht? Der IO Somfy Repeater kostet ja mehr als die Switch. Kann man die Connexoon in die Switch einlernen und dann auch mit dem Adapter steuern? Denn die Connexoon als single wird ja nicht vom adapter unterstützt.
                Und gibt es eine Jarvis Anleitung?
                  mike2712 last edited by
                  ich habe auch noch mal einen neuen Versuch mit der neueren Version vorgenommen, aber irgendwie komme ich nicht weiter, wie schaltet man eigentlich um, auf lokal und umgekehrt?
                  Hier der Log, mir sagt das alles nicht viel:
                  -2989-5271.local, request path: setup/gateways with payload:{}
                  tahoma.0
                  2022-07-08 09:22:50.248	debug	GET request on https://gateway-xxxxx-xxxxx-xxxxx.local:8443/enduser-mobile-web/1/enduserAPI/setup/gateways with payload:{}
                  tahoma.0
                  2022-07-08 09:22:50.247	debug	Update gateway status for id undefined
                  tahoma.0
                  2022-07-08 09:22:20.245	warn	error during request: Error: getaddrinfo EAI_AGAIN gateway-xxxxx-xxxxx-xxxxx.local, request path: setup/gateways with payload:{}
                  tahoma.0
                  2022-07-08 09:22:10.227	debug	GET request on https://gateway-xxxxx-xxxxx-xxxxx.local:8443/enduser-mobile-web/1/enduserAPI/setup/gateways with payload:{}
                  tahoma.0
                  2022-07-08 09:22:10.226	debug	Update gateway status for id undefined
                  tahoma.0
                  2022-07-08 09:21:40.224	warn	error during request: Error: getaddrinfo EAI_AGAIN gateway-xxxxx-xxxxx-xxxxx.local, request path: setup/gateways with payload:{}
                  tahoma.0
                  2022-07-08 09:21:30.304	warn	{"error":{"errno":-3001,"code":"EAI_AGAIN","syscall":"getaddrinfo","hostname":"gateway-xxxxx-xxxxx-xxxxx.local"}}
                  tahoma.0
                  2022-07-08 09:21:30.304	warn	setup failed!
                  tahoma.0
                  2022-07-08 09:21:30.303	warn	error during request: Error: getaddrinfo EAI_AGAIN gateway-xxxxx-xxxxx-xxxxx.local, request path: setup with payload:{}
                  tahoma.0
                  2022-07-08 09:21:30.204	debug	GET request on https://gateway-xxxxx-xxxx-xxxx.local:8443/enduser-mobile-web/1/enduserAPI/setup/gateways with payload:{}
                  tahoma.0
                  2022-07-08 09:21:30.203	debug	Update gateway status for id undefined
                  • Excodibur
                    Excodibur Developer @mike2712 last edited by
                    @mike2712 Wenn du ab Version 0.7.2 die Gateway PIN aus der Konfiguration nimmst, verbindet sich der Adapter statt mit der lokalen API wieder mit Tahomalink (online).
                    Dein Fehler getaddrinfo EAI_AGAIN deutet darauf hin, das bei dir die lokale Namensauflösung nicht funktioniert, d.h. der Adapter findet zu dem Namen kein Gerät im lokalen Netz. Eine Lösung wäre in deinem Router zu schauen, welche IP zu der Domain (gateway-xxxxx-xxxxx-xxxxx.local) gehört und die auf dem System wo dein Adapter läuft direkt mit der IP in die lokale hosts Datei einzutragen und dann den Adapter neu zu starten.
                      mike2712 @Excodibur last edited by
                      @excodibur
                      danke für den Tipp.
                      Adapter:
                      Fritz Box:
                      An welcher Stelle muss ich jetzt die 172.16.20.61 eintragen, das verstehe ich nicht?
                        wusa @mike2712 last edited by
                        @mike2712
                        Wenn ich das richtig sehe, dann ist bei dir Tahoma im selben Netz wie "alles" andere auch?
                        Hast du schon mal mDNS aktiviert?
                        Funktioniert es damit?
                          mike2712 @wusa last edited by
                          @wusa
                          ja mDNS das habe ich aktiviert.
                          Es ist aber nicht alles im selben Netz. Der iOBroker ist 172.16.20.30,. Alles im selben Netz ist unmöglich, dafür sind es zu viele Geräte, das ist in bestimmten Gruppen aufgeteilt, es ist alles im 172.16.xx.xx.
                          Das es nicht gefunden wird klingt etwas plausibel, aber ich weiß nicht an welcher Stelle ich den "IP in die lokale hosts Datei " eintragen muss.
                          • Excodibur
                            @mike2712 mDNS funktioniert bei mir zu Hause im von einer Fritzbox verwalteten Netz z.B. nicht, deswegen habe ich das immer aus.
                            Die IP-Adresse musst du bei dem von mir vorgeschlagenen Workaround in die hosts-Datei deines Betriebssystems (inkl. Hostname) eintragen. Läuft ioBroker auf Linux, normalerweise unter /etc/hosts, bei Windows meistens C:\Windows\System32\drivers\etc\hosts. Dort dann einen Eintrag in folgendem Format hinzufügen:
                            172.16.20.61  gateway-xxxxx-xxxxx-xxxxx.local gateway-xxxxx-xxxxx-xxxxx
                            xxxx ist natürlich deine individuelle Gateway-ID
                            M 2 Replies Last reply Reply Quote 1
                              mike2712 @Excodibur last edited by mike2712
                              @excodibur
                              danke, bei mir läuft es im Docker Container, vielleicht noch jemand hier der sich damit etwas auskennt?
                              Habe einiges probiert, aber hab es nicht hinbekommen.
                              TCP 172.16.22.35:9999 Error: connect EHOSTUNREACH 172.16.22.35:9999
                                  at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1159:16) {
                                errno: -113,
                                code: 'EHOSTUNREACH',
                                syscall: 'connect',
                                address: '172.16.22.35',
                                port: 9999
                              172.16.20.61 gateway-2006-2989-5271.loacal gateway-xxxx-xxxx-xxxx
                                errno: -113,
                                syscall: 'connect',
                                port: 9999
                              # list
                              /bin/sh: 1: list: not found
                              # dir
                              backups  homematic_2022_01_11-01_30_12_2.59.7_backupiobroker.tar.sbk  INSTALLER_INFO.txt  iob  iobroker  iobroker.bak  iobroker-data  log  node_modules  package.json  package-lock.json  @Recently-Snapshot  @Recycle  reinstall.js
                              # cd iob
                              /bin/sh: 3: cd: can't cd to iob
                              # cd iobroker
                              /bin/sh: 4: cd: can't cd to iobroker
                              # iobroker
                              iobroker [command]
                              Commands:
                                iobroker setup                                               Setup ioBroker
                                iobroker start [all|<adapter>.<instance>]                    Starts the js-controller or a specified adapter instance
                                iobroker stop [<adapter>.<instance>]                         stops the js-controller or a specified adapter instance
                                iobroker restart [<adapter>.<instance>]                      Restarts js-controller or a specified adapter instance  [aliases: r]
                                iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
                                iobroker info                                                Shows the host info
                                iobroker logs [<adapter>]                                    Monitor log
                                iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
                                iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
                                iobroker rebuild [<module>]                                  Rebuild all native modules or path
                                iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
                                iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
                                iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
                                iobroker update [<repositoryUrl>]                            Update repository and list adapters
                                iobroker upgrade                                             Upgrade management
                                iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
                                iobroker object                                              Object management  [aliases: o]
                                iobroker state                                               State management  [aliases: s]
                                iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
                                iobroker list <type> [<filter>]                              List all entries, like objects
                                iobroker chmod <mode> <file>                                 Change file rights
                                iobroker chown <user> <group> <file>                         Change file ownership
                                iobroker touch <file>                                        Touch file
                                iobroker rm <file>                                           Remove file
                                iobroker file                                                File management
                                iobroker user                                                User commands
                                iobroker group                                               group management
                                iobroker host <hostname>                                     Set host to given hostname
                                iobroker set <adapter>.<instance>                            Change settings of adapter config
                                iobroker license <license.file or license.text>              Update license by given file
                                iobroker cert                                                Certificate management
                                iobroker clean <yes>                                         Clears all objects and states
                                iobroker backup                                              Create backup
                                iobroker restore <backup name or path>                       Restore a specified backup
                                iobroker validate <backup name or path>                      Validate a specified backup
                                iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
                                iobroker repo [<name>]                                       Show repo information
                                iobroker uuid                                                Show uuid of the installation  [aliases: id]
                                iobroker unsetup                                             Reset license, installation secret and language
                                iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
                                iobroker multihost                                           Multihost management
                                iobroker compact                                             compact group management
                                iobroker plugin                                              Plugin management
                                iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
                              Options:
                                --help  Show help  [boolean]
                              # 172.16.20.61 gateway-xxxx-xxxx-xxxx.loacal gateway-xxxx-xxxx-xxxx
                              /bin/sh: 6: 172.16.20.61: not found
                              • Excodibur
                                @mike2712 Das hinter deinem Gateway-Namen ".loacal" statt ".local" steht, ist seltsam.
                                Bei Docker gäbe es zwei Möglichkeiten:
                                • Du verwendest beim Deployment --add-host (https://docs.docker.com/engine/reference/commandline/run/#add-entries-to-container-hosts-file---add-host) und fügst das IP-Hostname-Mapping hinzu. Bei docker-compose wäre das Der extra_hosts Abschnitt.
                                • Du zwingst deinen Container via --network=host (https://docs.docker.com/network/host/) das Netzwerk des Host-Systems direkt mit zu nutzen, dann wird sicher auch die hosts-Datei deines Betriebssystems bei der Namensauflösung verwendet. Damit hebst du aber auch einen Teil der Docker Container-Isolierung auf, was nicht so optimal ist. Daher würde ich immer eher zu Option 1 raten.
                                  wusa last edited by
                                  @mike2712
                                  Wäre es nicht erstmal Sinnvoll, die Tahoma Box in das selbe Netz zu hängen und zu schauen, ob es dort ohne Probleme funktioniert?
                                  Erst dann würde ich vielleicht weiter machen oder ggf. sogar in dem Netz hängen lassen.
                                    @Excodibur Vielen Dank für Deine Hilfe, nachdem ich alles nochmals durchgelesen habe ist mit das mit mDNS aufgefallen, das hatte ich aktiviert, nach dem deaktivieren ging es.
                                    @wusa das ist eine gute Idee, dabei habe ich festgestellt das sie schon im selben Netz hängen, das hatte ich früher schon mal versuchsweise getestet.
                                    Dann habe ich mich mit dem Tipp von Excodibur weiter versucht durchzukämpfen, leider habe ich das mit dem zufügen der Adresse nicht hinbekommen, danach habe ich alles nochmals gelesen.
                                    Seltsam war das der Adapter komplett grün ist, aber dennoch die Fehler ausgeben hatte.
                                    Eine kleine Frage, mit welchem Datenpunkt steuert Ihr die Position? Es funktionieren komischerweise alle 3 gelb markierten.
                                    Ich kann alles steuern, aber die Rückmeldungen, wenn ich aus der Handy App steuere, kommen die neuen Positionen offensichtlich nicht in ioBorker an.
                                      mike2712 @mike2712 last edited by
                                      Mit der Aktualisierung liegt wohl am Abrufintervall, das hatte mir damals die Somfy Hotline gesagt, weil das Konto immer gesperrt war, was war der default Eintrag noch? Leider vergessen.
                                        TobFe last edited by
                                        Guten Tag in die Runde. Ich kann leider auf die Frage, ob man eine Connexoon io mit dem Adapter verbinden kann keine Antwort finden. Der Adapter möchte Zugangsdaten für das ältere Web-System TaHoma Link haben, die ich nicht habe, weil ich leider nur eine Connexoon io Box besitze. Gibt es hierfür auch eine Lösung?
                                        Ich danke für eine Rückmeldung und hoffe auf eine Lösung.
                                          puls200 @TobFe last edited by
                                          @tobfe : also bei meinem Adapter muss ich nur die Zugangsdaten eingeben, um meine Connexoon zu verbinden.
                                            TobFe @puls200 last edited by
                                            @puls200 Danke. Ich hatte einen Zahledreher 😉
                                            Allerdings bin ich nun zwar verbunden, aber in den Objekten finde ich meine angelegten Produkte nicht (Jaloussie, Lamellendach,...) Woran liegt das?
                                            605
                                            157532
