    5. Brauche Hilfe um ein json abzurufen und auszuwerten
      fastfoot @Homoran last edited by
      @Homoran sagte in Brauche Hilfe um ein json abzurufen und auszuwerten:
      Ja, so in der Art sieht es aus
      Probiere mal hinter die letzte geschweifte Klammer eckige Klammern zu setzen, das forciert das Erstellen eines Array. Er meldet aber trotzdem mehr als ein Element, das verstehe ich nicht 😞 Er liefert neben dem Objekt noch zweimal true
      [{'flight':'HUMMEL4 ','lat':50.900574,'lon':6.983445,'alt_baro':800}]
      aircraft[
          flight.$contains(/./) and
          lat >50.78 and
          lat < 51.08 and
          alt_baro < 900
          "flight":flight,
          "lat":lat,
          "lon":lon,
          "alt_baro":alt_baro
       <variables>
         <variable id="17xfL.e+0-6.cfxoIMob">json</variable>
         <variable id="j^BFzJQ/hdkEzTTe!.l_">expr</variable>
         <variable id=":s3D=Sg#cp3Ghx(ZTDdl">erg</variable>
         <variable id="C^O=/ydi(ot$dj2/M!HS">i</variable>
       </variables>
       <block type="variables_set" id="=Zan`!z6BJv/lt5yvcAk" x="88" y="13">
         <field name="VAR" id="17xfL.e+0-6.cfxoIMob">json</field>
           <block type="convert_json2object" id="E8Vj:2;B#0VMQjtiI7vF">
               <block type="text" id="N@UB[t{awydMGpb|}Ebx">
                 <field name="TEXT">{ "now" : 1603545549.7,   "messages" : 1678929,   "aircraft" : [     {"hex":"3c4d8f","flight":"ABR1540 ","alt_baro":34075,"ias":263,"mach":0.764,"mag_heading":54.8,"baro_rate":64,"geom_rate":32,"version":0,"nac_p":0,"sil":0,"sil_type":"unknown","mlat":[],"tisb":[],"messages":29,"seen":3.5,"rssi":-23.2},     {"hex":"3e3f1f","alt_baro":11075,"version":0,"nac_p":8,"sil":2,"sil_type":"unknown","mlat":[],"tisb":[],"messages":8,"seen":2.4,"rssi":-22.9},     {"hex":"3c56f3","flight":"EWG53N  ","alt_baro":18725,"alt_geom":19150,"gs":354.9,"ias":288,"tas":376,"mach":0.612,"track":221.7,"track_rate":0.06,"roll":-0.4,"mag_heading":223.1,"baro_rate":2048,"geom_rate":2016,"squawk":"4132","emergency":"none","category":"A3","nav_qnh":1012.8,"nav_altitude_mcp":24000,"lat":51.072507,"lon":6.167068,"nic":8,"rc":186,"seen_pos":38.8,"version":2,"nic_baro":1,"nac_p":9,"nac_v":1,"sil":3,"sil_type":"perhour","gva":2,"sda":2,"mlat":[],"tisb":[],"messages":148,"seen":3.8,"rssi":-23.1},     {"hex":"484160","flight":"KLM1631 ","alt_baro":41000,"alt_geom":41125,"gs":443.6,"ias":226,"tas":436,"mach":0.768,"track":159.7,"track_rate":-0.03,"roll":-0.4,"mag_heading":163.7,"baro_rate":64,"geom_rate":0,"squawk":"1000","category":"A0","nav_qnh":1013.2,"nav_altitude_mcp":41008,"lat":50.771453,"lon":6.746521,"nic":7,"rc":371,"seen_pos":3.4,"version":0,"nac_p":7,"nac_v":0,"sil":2,"sil_type":"unknown","mlat":[],"tisb":[],"messages":2832,"seen":2.6,"rssi":-20.3},     {"hex":"3ddc04","mlat":[],"tisb":[],"messages":52,"seen":101.5,"rssi":-19.9},     {"hex":"440395","flight":"EJU93MQ ","alt_baro":38000,"alt_geom":38425,"gs":414.3,"ias":242,"tas":432,"mach":0.764,"track":241.8,"track_rate":-0.03,"roll":0.4,"mag_heading":245.6,"baro_rate":0,"geom_rate":-32,"squawk":"1136","emergency":"none","category":"A3","nav_qnh":1013.6,"nav_altitude_mcp":38016,"lat":50.905655,"lon":7.165090,"nic":8,"rc":186,"seen_pos":1.2,"version":2,"nic_baro":1,"nac_p":9,"nac_v":1,"sil":3,"sil_type":"perhour","gva":2,"sda":2,"mlat":[],"tisb":[],"messages":653,"seen":0.5,"rssi":-20.2},     {"hex":"4070e2","version":2,"sil_type":"perhour","mlat":[],"tisb":[],"messages":219,"seen":64.5,"rssi":-23.4},     {"hex":"48548d","flight":"KLM73C  ","alt_baro":23600,"alt_geom":37350,"gs":451.2,"ias":233,"tas":414,"mach":0.724,"track":149.1,"track_rate":0.00,"roll":0.2,"mag_heading":149.9,"baro_rate":0,"geom_rate":-32,"squawk":"3177","emergency":"none","category":"A3","nav_qnh":1013.6,"nav_altitude_mcp":37024,"nav_altitude_fms":37008,"nav_modes":["autopilot","althold","tcas"],"lat":50.463464,"lon":7.402261,"nic":8,"rc":186,"seen_pos":45.5,"version":2,"nic_baro":1,"nac_p":10,"nac_v":2,"sil":3,"sil_type":"perhour","gva":2,"sda":2,"mlat":[],"tisb":[],"messages":3056,"seen":3.8,"rssi":-24.7},     {"hex":"aa9300","flight":"UAL2777 ","alt_baro":29825,"alt_geom":30275,"gs":475.0,"ias":321,"tas":488,"mach":0.828,"track":317.6,"roll":0.2,"mag_heading":314.3,"baro_rate":1408,"geom_rate":1376,"squawk":"0635","emergency":"none","category":"A5","nav_qnh":1012.8,"nav_altitude_mcp":34016,"nav_heading":314.3,"lat":50.999313,"lon":6.929255,"nic":8,"rc":186,"seen_pos":43.6,"version":2,"nic_baro":1,"nac_p":9,"nac_v":1,"sil":3,"sil_type":"perhour","gva":2,"sda":2,"mlat":[],"tisb":[],"messages":2082,"seen":1.5,"rssi":-22.9},     {"hex":"40697c","version":0,"sil_type":"unknown","mlat":[],"tisb":[],"messages":123,"seen":184.6,"rssi":-21.9},     {"hex":"3c0ca5","category":"A3","version":2,"sil_type":"perhour","mlat":[],"tisb":[],"messages":514,"seen":90.3,"rssi":-23.4},     {"hex":"3d11d6","mlat":[],"tisb":[],"messages":1345,"seen":165.9,"rssi":-23.0},     {"hex":"3ded08","mlat":[],"tisb":[],"messages":2819,"seen":171.5,"rssi":-22.5}   ] }</field>
           <block type="variables_set" id="k/n^+L}X+kdj)JFN?)pb">
               <block type="convert_json2object" id="X6ehI@w+w2WmkF4Ntt,(">
                   <block type="text" id="@Ax=.ZO~Aa^H+wAw4Bb!">
                     <field name="TEXT">{ "now" : 1603552640.8,   "messages" : 1850340,   "aircraft" : [     {"hex":"3df744","flight":"HUMMEL4 ","alt_baro":800,"alt_geom":900,"gs":133.7,"track":332.9,"baro_rate":-128,"squawk":"4426","emergency":"none","category":"A7","lat":50.900574,"lon":6.983445,"nic":9,"rc":75,"seen_pos":0.1,"version":2,"nic_baro":1,"nac_p":10,"nac_v":2,"sil":3,"sil_type":"perhour","gva":2,"sda":2,"mlat":[],"tisb":[],"messages":453,"seen":0.1,"rssi":-16.2},     {"hex":"3c66ea","flight":"DLH3U   ","alt_baro":21875,"alt_geom":22450,"gs":402.4,"ias":271,"tas":376,"mach":0.612,"track":94.7,"track_rate":0.00,"roll":-0.2,"mag_heading":94.6,"baro_rate":-1856,"geom_rate":-1856,"squawk":"5245","emergency":"none","category":"A3","nav_qnh":1012.8,"nav_altitude_mcp":11008,"lat":50.328555,"lon":7.004230,"nic":8,"rc":186,"seen_pos":14.4,"version":2,"nic_baro":1,"nac_p":9,"nac_v":1,"sil":3,"sil_type":"perhour","gva":2,"sda":2,"mlat":[],"tisb":[],"messages":351,"seen":12.8,"rssi":-22.1},     {"hex":"461e16","flight":"FIN3EF  ","alt_baro":40000,"alt_geom":40350,"gs":409.6,"ias":233,"tas":432,"mach":0.772,"track":226.7,"track_rate":0.00,"roll":0.0,"mag_heading":229.6,"baro_rate":64,"geom_rate":32,"squawk":"1000","category":"A3","nav_qnh":1013.6,"nav_altitude_mcp":40000,"nav_altitude_fms":40000,"nav_modes":["autopilot","vnav","tcas"],"lat":50.716599,"lon":7.030730,"nic":8,"rc":186,"seen_pos":2.0,"version":2,"nic_baro":1,"nac_p":10,"nac_v":2,"sil":3,"sil_type":"perhour","gva":2,"sda":2,"mlat":[],"tisb":[],"messages":2888,"seen":1.5,"rssi":-19.9},     {"hex":"4400d0","alt_baro":21825,"alt_geom":22300,"gs":401.2,"ias":284,"mach":0.632,"track":116.5,"mag_heading":104.2,"baro_rate":1984,"geom_rate":1984,"squawk":"5333","version":2,"nac_v":2,"sil_type":"perhour","mlat":[],"tisb":[],"messages":74,"seen":19.3,"rssi":-22.4},     {"hex":"ac45d5","alt_baro":14950,"alt_geom":15250,"gs":362.1,"ias":313,"tas":392,"mach":0.620,"track":238.0,"roll":-0.4,"mag_heading":235.7,"baro_rate":-2624,"geom_rate":-3072,"squawk":"7702","category":"A5","nav_qnh":1012.8,"nav_altitude_mcp":11008,"nav_heading":237.7,"lat":50.936016,"lon":6.497955,"nic":8,"rc":186,"seen_pos":48.4,"version":2,"nic_baro":1,"nac_p":9,"nac_v":1,"sil":3,"sil_type":"perhour","gva":2,"sda":2,"mlat":[],"tisb":[],"messages":711,"seen":42.3,"rssi":-21.2},     {"hex":"406a59","version":0,"sil_type":"unknown","mlat":[],"tisb":[],"messages":45,"seen":221.6,"rssi":-23.3},     {"hex":"4072c8","category":"A3","version":2,"sil_type":"perhour","mlat":[],"tisb":[],"messages":3337,"seen":71.3,"rssi":-22.5},     {"hex":"407797","flight":"EZY21DC ","alt_baro":38000,"alt_geom":38400,"gs":381.5,"ias":244,"tas":434,"mach":0.772,"track":289.8,"track_rate":0.03,"roll":-0.4,"mag_heading":286.2,"baro_rate":0,"geom_rate":-32,"squawk":"6604","category":"A3","nav_qnh":1013.6,"nav_altitude_mcp":38016,"nav_heading":0.0,"lat":51.126088,"lon":6.040497,"nic":8,"rc":186,"seen_pos":0.2,"version":2,"nic_baro":1,"nac_p":9,"nac_v":1,"sil":3,"sil_type":"perhour","mlat":[],"tisb":[],"messages":8064,"seen":0.2,"rssi":-20.7}   ] }</field>
               <block type="variables_set" id="v)o8[|Cl)9TMCZ?w57EJ">
                 <field name="VAR" id="j^BFzJQ/hdkEzTTe!.l_">expr</field>
                   <block type="text" id="${+RanyDz#59vb@V6dYO">
                     <field name="TEXT">aircraft[     lat &gt;50.78 and      lat &lt; 51.08 and      alt_baro &lt; 1000     ].{     "flight":flight,     "lat":lat,     "lon":lon,     "alt_baro":alt_baro  }[]</field>
                   <block type="variables_set" id="lhH4rQ~:glMfw._JOlPP">
                     <field name="VAR" id=":s3D=Sg#cp3Ghx(ZTDdl">erg</field>
                       <block type="convert_jsonata" id="Bbs|KtZ,ky,}7I(4UNjg">
                         <value name="EXPRESSION">
                           <shadow type="text" id="#II]/P^EG`5X%vq7p`JW">
                             <field name="TEXT">*</field>
                           <block type="variables_get" id=")J|PZuc2d!`ZYHpT`E;V">
                         <value name="TARGET">
                           <block type="variables_get" id="mRA`B%EA,A^9Ag+Po%ju">
                       <block type="controls_if" id="_YdP)#=i2B#A*bbt9(FJ">
                           <block type="variables_get" id="Ww@AV!LH.n^M@eb0a%{k">
                           <block type="debug" id=".5NIWaw#TszdX-_~e3Z$">
                             <value name="TEXT">
                               <shadow type="text" id="cW^.=02N.@Toj9XyG|.8">
                               <block type="variables_get" id="igi?fBev!HhzimQ]m5rv">
                               <block type="controls_forEach" id="!5,(BmoX)#tFNNW0nmd!">
                                 <field name="VAR" id="C^O=/ydi(ot$dj2/M!HS">i</field>
                                 <value name="LIST">
                                   <block type="variables_get" id="}~mt$C+aq,DQex(mJrCL">
                                 <statement name="DO">
                                   <block type="controls_if" id="[6n[w2Fe0n!~BKYCh~w#">
                                       <block type="variables_get" id="uDiKTPb.Oaf;Qrr.t;PY">
                                       <block type="debug" id=",yzRaj^wBGOm)FuXLE%~" inline="true" disabled="true">
                                         <value name="TEXT">
                                           <shadow type="text" id="7?iQ#CzTP0U+]T[-b=]L">
                                           <block type="variables_get" id="rE8-pu:p|-:2Dae0Qv,|">
                                           <block type="debug" id="%/D(|w$!p%VRD?LI:bHb" inline="true">
                                             <value name="TEXT">
                                               <shadow type="text" id="A%qyXK/pF4-P+4Sf@edo">
                                               <block type="get_attr" id="O;^U$CxOpO#O8}SUt6c7">
                                                 <value name="PATH">
                                                   <shadow type="text" id="2(aoz`T2Jfz.2TuDe|Iu">
                                                     <field name="TEXT">flight</field>
                                                 <value name="OBJECT">
                                                   <block type="variables_get" id="^u|[||1Uh=x;S.,^CB`m">
                                               <block type="debug" id="9}rn4L5TBOn!8d%8}E.w" inline="true">
                                                 <value name="TEXT">
                                                   <shadow type="text">
                                                   <block type="get_attr" id="n#F4D9:*.oV6?yfEj25E">
                                                     <value name="PATH">
                                                       <shadow type="text" id="LVq5v19VoKSm-UK)W@fO">
                                                         <field name="TEXT">lat</field>
                                                       <block type="variables_get" id="SP,FXso4|/L}DlxTu{O6">
                                                   <block type="debug" id=".bg8w!-4#3x..B@,NW(j" inline="true">
                                                     <value name="TEXT">
                                                       <block type="get_attr" id=":GzM=9^:2?r*M||slBBF">
                                                         <value name="PATH">
                                                           <shadow type="text" id="LRZyLEu){,I)g[V(dhMW">
                                                             <field name="TEXT">lon</field>
                                                           <block type="variables_get" id="/UraS|Fc?ctIvD-DAI]/">
                                                       <block type="debug" id=";UJZV:%dh/?f[U[BT.}G" inline="true">
                                                         <value name="TEXT">
                                                           <block type="get_attr" id="4B/VA^,2r?4/PYO*J`gr">
                                                             <value name="PATH">
                                                               <shadow type="text" id="`QF}d=G_9]6gU7/tt{gv">
        <field name="TEXT">alt_baro</field>
                                                               <block type="variables_get" id="zh|}0+2O0]C9p^Sq~p$T">
        Homoran Global Moderator Administrators @fastfoot last edited by Homoran
        @fastfoot bin da auch dran,
        wollte über length_of abfangen, klappt aber nicht.
        bei nur noch einem Flugzeug springt er nicht in den sonst_falls, bei mehr als einem läuft es richtig
        EDIT:
        läuft!
        habe das SONST_FALLS gegen ein SONST getauscht.
        Beim ersten Versuch damit hatte ich noch das falsch Objekt, nämlich i angegeben
          @fastfoot
          Euch beiden erst mal vielen Dank.
          Habe heute viel gelernt. Hoffentlich war das nicht zuviel und setzt sich noch 😉
          Habe jetzt nur noch ein Problem.
          Ich habe jetzt die erste Abfrage nach der Kennung weggelassen und wollte auch Flieger erfassen, deren Kennung ich nicht habe.
          Dieser Fall sollte abgefangen werden und mit "unbekannt" erstezt werden.
          Das klappt auch bei nur einem Flieger, bei mehreren Fliegern weitestgehend auch, jedoch wird IMMER zum Schluss ein weiterer Eintrag ohne jegliche Daten erstellt.
          Hier im Beispiel ist die Länge des Arrays 3, es gibt jedoch 4 Einträge.
          Die ersten 3 sind in Ordnung (im 3. lag keine Flugnummer vor und wurde korrekt mit "unbekannt" ersetzt)
          Wo kommt diese letzte Zeile noch her?
          Bevor ich sie mit unlauteren Mitteln abfange, was ohne weiteres gehen würde, würde ich es gerne verstehen.
          Außerdem hätte ich gerne i im debug angezeigt, bekomme bei 1-3 nur ein [object][object] und in der ominösen 4. Zeile ein true undefined
          ich dachte i wäre eine Zahl
            @Homoran sagte:
            Nein, das ist bei einer for-Schleife (Zählschleife) so, aber nicht bei for in Schleifen. Bei Arrays sollte man besser die Zählschleifen verwenden.
              paul53 @Homoran last edited by paul53
              @Homoran
              Ich würde die Zählschleife verwenden und innerhalb der Schleife filtern, wobei das erstes Filterkriterium das Vorhandensein von "lat", "lon" und "alt_baro" sein sollte:
                @paul53 sagte in Brauche Hilfe um ein json abzurufen und auszuwerten:
                so weit bin ich auch schon, wobei es mir nicht gelingt die Attribute korrekt zu bestimmen. Objekt 'i' geht ja jetzt nicht mehr
                Muss mir mal deine Vorgehensweise ansehen
                  @paul53 Hat was länger gedauert, waren grad keine Flieger unterwegs (muss mein System später mal hardwaretechnisch noch was aufrüsten).
                  Jetzt scheint es zu klappen!
                  War ich gar nicht so weit von entfernt, mir fehlte nur das eigenständige Zerlegen des JSON(-Arrays) in "Unter"-JSONs, was bisher die Schleifen gemacht hatte.
                  Das das ganze JSON jeweils wieder "nur" ein Element des Arrays war, und damit als i-tes Element aufgerufen werden konnte, hatte ich nicht auf dem Schirm.
                  Da habe ich ja heite Nacht noch einiges zu rekapitulieren
                    sooo, aktueller Stand:
                    gestern Abend bekam ich keinerlei Meldungen.
                    Vom Bett aus habe ich es dann mit dem Tablet noch geschafft einen debug einzubauen und stellte fest, dass die Geokoordinaten aus der javascript Instanz anscheinend vom Typ String waren.
                    Diese noch "schnell" in Zahl konvertiert und es lief.
                    Die Daten werden im Moment zur Kontrolle in einen Datenpunkt geschrieben und historisiert:
                    Dann hatte ich noch versucht den Erfassungsbereich weniger hardcoded zu machen und mit einer Variable schnell zu ändern, Im Moment bekam ich auch Maschinen, die aus einer anderen Richtung im Landeanflug waren (zum Testen ganz gut, auf Dauer aber nicht)
                    Hatte aber die Rechnung nicht mit Herrn Mercator gemacht, der Ausschnitt war nicht quadratisch 😉
                    Also empirisch noch einen Faktor eingebaut und es sah besser aus:
                    Ich werde wahrscheinlich diesen Faktor noch erhöhen, da die mich interessierende Flugroute fast genau von Ost nach West geht.
                    Jetzt kam der quälende Teil.
                    Ich wollte den Abstand des Fliegers zu meinem Haus berechnen.
                    Habe im Netz eine brauchbare Rechnung gefunden:
                    distance = sqrt(dx * dx + dy * dy)
                    mit distance: Entfernung in km
                    dx = 111.3 * cos(lat) * (lon1 - lon2)
                    lat = (lat1 + lat2) / 2 * 0.01745
                    dy = 111.3 * (lat1 - lat2)
                    lat1, lat2, lon1, lon2: Breite, Länge in Grad
                    Quelle: https://www.kompf.de/gps/distcalc.html
                    Das wollte ich aus Platzgründen in einer Funktion verstecken, woran ich mal wieder gescheitert bin.
                    Das Blockly sieht inzwischen gigantisch aus:
                    und das ist nur der obere Teil für mehrere Flieger, für einen Flieger kommt das selbe nochmal 😞
                    weitere geplante Dinge
                    • Der Abstand im Raum (zusätzlich noch ein Pythagoras zur Höhe)
                    • Arrays für jeweils einen Flug aufbauen, dort den dichtesten Abstand rausfinden
                    • diesen einen Datensatz in ein weiteres Array für alle Flüge übernehmen
                    • danach das temporäre Array wieder löschen
                    mal sehen wie weit ich komme, habe noch keine Möglichkeit gefunden eine Liste mit Namen des Fluges variabel zu erstellen
                      kaum getippt, kommt eine Ryanair rein:
                      die Einträge mit Abstand in km dazu:
                        So, nach einiger Zeit und Problemen nach einem piaware Update würde ich das Ganze noch etwas optimieren
                        ich bekomme während des Durchfluges durch das Beobachungsfensters mehrere Meldungen
                        ich bräuchte aber nur den Datensatz vom nahesten Ergebnis.
                        ich habe schon versucht jeden Satz als JSON zu bilden und dann in einer Liste das Minimum für Entfernung am Boden zu finden.
                        Das war nix 😞
                        gibt es da eine sinnvolle Vorgehensweise, so dass ich optimalerweise ein json pro Flug erhalte, das ich später in einem jsonlist widget oder Eventlis Widget als Liste darstellen kann?
                          @homoran sagte: jsonlist widget
                          Welche Daten soll die Liste enthalten?
                            @paul53 Danke schon mal!
                            im Prinzip, die die ich jetzt als String in den Datenpunkt schreibe.
                            sorry für den Screenshot, bin nur am Tablet
                              Ansatz, der noch nicht das Löschen von nicht mehr vorhandenen Flugzeugen aus der Tabelle enthält:
                              Inhalt der Funktion flugObjekt(kennung,_hoehe,abstand,entfernung,pos):
                              return {
                                  Kennung: kennung,
                                  Hoehe: _hoehe,
                                  Bodenabstand: abstand,
                                  Entfernung: entfernung,
                                  Position: pos
                                @paul53 DANKE!
                                Das muss ich jetzt erst mal ventilieren 🙂
                                Hab gerade mit Schrecken sogar zwei Flugzeuge zeitgleich im Sektor gehabt.. Ich dachte das wird schon nicht passieren.
                                Jetzt kreiste zusätzlich noch ein Polizeihubschrauber auf +/- 300m rum.
                                Aber solche Spezialfälle sind erst einmal unwichtig.
                                Werde deinen Ansatz mal testen
                                  Habe gerade noch eine Korrektur eingefügt: setze obj.
                                    Homoran Global Moderator Administrators @paul53 last edited by Homoran
                                    @paul53 ich hab es eben abgetippert und mir schon gedacht wo kommt die Liste her?
                                    Jetzt kommt prompt:
                                    18:43:00.020	error	javascript.0 (728) script.js.Fliegenklatsche_v3: TypeError: Cannot read property 'length' of undefined
                                    18:43:00.020	error	javascript.0 (728) at script.js.Fliegenklatsche_v3:66:23
                                    66:23 ist
                                    vorhanden = false;
                                        var j_end = Liste.length;
                                        var j_inc = 1;
                                        if (1 > j_end) {
                                          j_inc = -j_inc;
                                    (hier die 2. Zeile)
                                    EDIT:
                                    oder meinst du diese Liste ("Rest")
                                      @homoran sagte: wo kommt die Liste her?
                                      Erzeuge erst einmal eine leere Liste, damit der Datenpunkt mit einer JSON-Liste befüllt wird. Danach lese oben den Datenpunkt ein:
                                      @homoran sagte in Brauche Hilfe um ein json abzurufen und auszuwerten:
                                      Nein.
                                        Jetzt stehe ich ganz auf dem Schlauch!
                                        ich habe keinen DP mit einem JSON. Das war ja mein Problem.
                                          @homoran sagte: ich habe keinen DP mit einem JSON.
                                          Erstelle den Datenpunkt vom Typ "string" unter "0_userdata.0". Keinen Wert reinschreiben!
                                          Das Erzeugen der leeren Liste kann besser so erfolgen:
                                            Hab ich bereits gemacht.
                                            Allerdings für den DP in den nachher das Ergebnis soll.
                                            Ich brauche jetzt einen weiteren DP?
                                            Jetzt hab ich mir endlich angewöhnt mit Variablen statt DPs zu arbeiten, jetzt kommst du so 🙂
                                            Oder ab ich dich ganz falsch verstanden?
                                            2533
