    4. Anfrage Tahoma/Somfy IO Adapter
      Willi-Wunder last edited by Willi-Wunder
      @Excodibur
      PN hat nicht geklappt, hab keine Adresse gefunden........Hab aber gerade wieder den Fehler im Log, vielleicht reicht das auch schon, ansonsten kann ich dir gerne die anderen Dateien noch schicken.
      tahoma.0
      	2022-07-02 01:09:48.188	info	eventRegisterID = 221bef9d-1c57-4d26-8ba3-005b34dxxxxx
      tahoma.0
      	2022-07-02 01:09:46.343	info	Using stored bearer token 6263c4b71f21561xxxxx
      tahoma.0
      	2022-07-02 01:09:46.340	info	Adapter will connect to Tahoma Box via local API.
      tahoma.0
      	2022-07-02 01:09:46.337	info	Configured polling interval: 500000
      tahoma.0
      	2022-07-02 01:09:46.336	info	[START] Starting adapter tahoma v0.7.2.3
      tahoma.0
      	2022-07-02 01:09:46.300	info	starting. Version 0.7.2 (non-npm: Excodibur/ioBroker.tahoma) in /opt/iobroker/node_modules/iobroker.tahoma, node: v12.22.12, js-controller: 4.0.23
      host.raspberrypi
      	2022-07-02 01:09:44.086	info	instance system.adapter.tahoma.0 started with pid 27807
      host.raspberrypi
      	2022-07-02 01:09:13.866	info	Restart adapter system.adapter.tahoma.0 because enabled
      host.raspberrypi
      	2022-07-02 01:09:13.864	error	instance system.adapter.tahoma.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      tahoma.0
      	2022-07-02 01:09:13.254	error	The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
      tahoma.0
      	2022-07-02 01:09:13.254	error	Error: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position! at validateSetStateObjectArgument (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5669:23) at Adapter.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5752:21) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.tahoma/lib/tahoma.js:1317:36) at processImmediate (internal/timers.js:463:21)
      tahoma.0
      	2022-07-02 01:09:13.253	error	unhandled promise rejection: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
      tahoma.0
      	2022-07-02 01:09:13.252	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      tahoma.0
      	2022-07-02 01:09:13.250	error	The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
      tahoma.0
      	2022-07-02 01:09:13.249	error	Error: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position! at validateSetStateObjectArgument (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5669:23) at Adapter.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5752:21) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.tahoma/lib/tahoma.js:1317:36) at processImmediate (internal/timers.js:463:21)
      tahoma.0
      	2022-07-02 01:09:13.248	error	unhandled promise rejection: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
      tahoma.0
      	2022-07-02 01:09:13.247	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      tahoma.0
      	2022-07-02 01:09:13.242	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      tahoma.0
      	2022-07-02 01:09:13.240	info	terminating
      tahoma.0
      	2022-07-02 01:09:13.236	error	The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
      tahoma.0
      	2022-07-02 01:09:13.236	error	Error: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position! at validateSetStateObjectArgument (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5669:23) at Adapter.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5752:21) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.tahoma/lib/tahoma.js:1317:36) at processImmediate (internal/timers.js:463:21)
      tahoma.0
      	2022-07-02 01:09:13.234	error	unhandled promise rejection: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
      tahoma.0
      	2022-07-02 01:09:13.233	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      tahoma.0
      	2022-07-02 01:09:13.227	error	The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
      tahoma.0
      	2022-07-02 01:09:13.226	error	Error: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position! at validateSetStateObjectArgument (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5669:23) at Adapter.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5752:21) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.tahoma/lib/tahoma.js:1317:36) at processImmediate (internal/timers.js:463:21)
      tahoma.0
      	2022-07-02 01:09:13.220	error	unhandled promise rejection: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
      tahoma.0
      	2022-07-02 01:09:13.219	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      tahoma.0
      	2022-07-02 01:00:53.155	info	eventRegisterID = 90020fb6-eea8-4b6d-a51c-c8870f5xxxxxx
      tahoma.0
      	2022-07-02 01:00:51.366	info	Using stored bearer token 6263c4b71f21561xxxxx
      tahoma.0
      	2022-07-02 01:00:51.363	info	Adapter will connect to Tahoma Box via local API.
      tahoma.0
      	2022-07-02 01:00:51.360	info	Configured polling interval: 500000
      tahoma.0
      	2022-07-02 01:00:51.359	info	[START] Starting adapter tahoma v0.7.2.3
      tahoma.0
      	2022-07-02 01:00:51.323	info	starting. Version 0.7.2 (non-npm: Excodibur/ioBroker.tahoma) in /opt/iobroker/node_modules/iobroker.tahoma, node: v12.22.12, js-controller: 4.0.23
      host.raspberrypi
      	2022-07-02 01:00:49.003	info	instance system.adapter.tahoma.0 started with pid 27411
      host.raspberrypi
      	2022-07-02 01:00:18.879	info	Restart adapter system.adapter.tahoma.0 because enabled
      host.raspberrypi
      	2022-07-02 01:00:18.878	error	instance system.adapter.tahoma.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      tahoma.0
      	2022-07-02 01:00:18.224	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      tahoma.0
      	2022-07-02 01:00:18.223	info	terminating
      tahoma.0
      	2022-07-02 01:00:18.221	error	The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, smart_protect, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
      tahoma.0
      	2022-07-02 01:00:18.221	error	Error: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, smart_protect, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position! at validateSetStateObjectArgument (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5669:23) at Adapter.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5752:21) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.tahoma/lib/tahoma.js:1317:36) at processImmediate (internal/timers.js:463:21)
      tahoma.0
      	2022-07-02 01:00:18.220	error	unhandled promise rejection: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, smart_protect, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
      tahoma.0
      	2022-07-02 01:00:18.220	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      tahoma.0
      	2022-07-02 01:00:18.219	error	The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, smart_protect, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
      tahoma.0
      	2022-07-02 01:00:18.219	error	Error: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, smart_protect, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position! at validateSetStateObjectArgument (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5669:23) at Adapter.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5752:21) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.tahoma/lib/tahoma.js:1317:36) at processImmediate (internal/timers.js:463:21)
      tahoma.0
      	2022-07-02 01:00:18.218	error	unhandled promise rejection: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, smart_protect, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
      tahoma.0
      	2022-07-02 01:00:18.218	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      tahoma.0
      	2022-07-02 01:00:18.216	error	The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
      tahoma.0
      	2022-07-02 01:00:18.215	error	Error: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position! at validateSetStateObjectArgument (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5669:23) at Adapter.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5752:21) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.tahoma/lib/tahoma.js:1317:36) at processImmediate (internal/timers.js:463:21)
      tahoma.0
      	2022-07-02 01:00:18.209	error	unhandled promise rejection: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
      tahoma.0
      	2022-07-02 01:00:18.209	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      tahoma.0
      	2022-07-02 00:35:18.102	info	eventRegisterID = 29eff3c1-fe48-4ff3-81ba-a7927f1xxxxx
      tahoma.0
      	2022-07-02 00:35:16.296	info	Using stored bearer token 6263c4b71f21561xxxxx
      tahoma.0
      	2022-07-02 00:35:16.293	info	Adapter will connect to Tahoma Box via local API.
      tahoma.0
      	2022-07-02 00:35:16.290	info	Configured polling interval: 500000
      tahoma.0
      	2022-07-02 00:35:16.289	info	[START] Starting adapter tahoma v0.7.2.3
      tahoma.0
      	2022-07-02 00:35:16.253	info	starting. Version 0.7.2 (non-npm: Excodibur/ioBroker.tahoma) in /opt/iobroker/node_modules/iobroker.tahoma, node: v12.22.12, js-controller: 4.0.23
      host.raspberrypi
      	2022-07-02 00:35:14.066	info	instance system.adapter.tahoma.0 started with pid 26211
      host.raspberrypi
      	2022-07-02 00:34:43.957	info	Restart adapter system.adapter.tahoma.0 because enabled
      host.raspberrypi
      	2022-07-02 00:34:43.956	error	instance system.adapter.tahoma.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      tahoma.0
      	2022-07-02 00:34:43.306	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      tahoma.0
      	2022-07-02 00:34:43.305	info	terminating
      tahoma.0
      	2022-07-02 00:34:43.303	error	The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, smart_protect, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
      tahoma.0
      	2022-07-02 00:34:43.302	error	Error: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, smart_protect, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position! at validateSetStateObjectArgument (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5669:23) at Adapter.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5752:21) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.tahoma/lib/tahoma.js:1317:36) at processImmediate (internal/timers.js:463:21)
      tahoma.0
      	2022-07-02 00:34:43.302	error	unhandled promise rejection: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, smart_protect, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
      tahoma.0
      	2022-07-02 00:34:43.301	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      tahoma.0
      	2022-07-02 00:34:43.301	error	The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, smart_protect, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
      tahoma.0
      	2022-07-02 00:34:43.300	error	Error: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, smart_protect, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position! at validateSetStateObjectArgument (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5669:23) at Adapter.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5752:21) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.tahoma/lib/tahoma.js:1317:36) at processImmediate (internal/timers.js:463:21)
      tahoma.0
      	2022-07-02 00:34:43.300	error	unhandled promise rejection: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, smart_protect, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
      tahoma.0
      	2022-07-02 00:34:43.299	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      tahoma.0
      	2022-07-02 00:34:43.298	error	The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, smart_protect, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
      tahoma.0
      	2022-07-02 00:34:43.297	error	Error: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, smart_protect, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position! at validateSetStateObjectArgument (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5669:23) at Adapter.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5752:21) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.tahoma/lib/tahoma.js:1317:36) at processImmediate (internal/timers.js:463:21)
      tahoma.0
      	2022-07-02 00:34:43.294	error	unhandled promise rejection: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, smart_protect, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
      tahoma.0
      	2022-07-02 00:34:43.294	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      Gruß Willi
        memme last edited by memme
        Wenn ich den bei meinem Rolladen den command.down auf True stelle, fährt der Rolladen runter. Er stellt sich dann aber nicht wieder auf false, wenn er runtergefahren ist.
        Nun kann ich auch keinen anderen Rolladen mehr fahren, sondern muss die adapter instanz neu starten. Dann kann ich wieder einmal fahren.
        Wenn ich nach dem runterfahren den down wert wieder auf false stelle geht es wieder mit dem hochfahren. Dann muss ich up wieder auf false stellen. Das geht dann ein paar mal, dann gar nicht mehr und ich muss die instanz wieder neustarten.....
        Gibt es eine Anleitung um die Rolläden als button in Jarvis hinzuzufügen?
        note: Nutze tahoma switch, adapter auf 0.7.2
        Excodibur 1 Reply Last reply Reply Quote 0
        • Excodibur
          Excodibur Developer @memme last edited by
          @memme Ja, das ist einer der komplizierteren Bugs mit der lokalen API. Hängt mit https://github.com/Excodibur/ioBroker.tahoma/issues/149 zusammen, nur leider bin ich noch nicht dazu gekommen.
          NilsReinecke created this issue in Excodibur/ioBroker.tahoma
          closed Failed getting execution state on local api #149
          M T 2 Replies Last reply Reply Quote 0
            Wie macht ihr es denn, wenn ihr einen Repeater braucht? Der IO Somfy Repeater kostet ja mehr als die Switch. Kann man die Connexoon in die Switch einlernen und dann auch mit dem Adapter steuern? Denn die Connexoon als single wird ja nicht vom adapter unterstützt.
            Und gibt es eine Jarvis Anleitung?
              mike2712 last edited by
              ich habe auch noch mal einen neuen Versuch mit der neueren Version vorgenommen, aber irgendwie komme ich nicht weiter, wie schaltet man eigentlich um, auf lokal und umgekehrt?
              Hier der Log, mir sagt das alles nicht viel:
              -2989-5271.local, request path: setup/gateways with payload:{}
              tahoma.0
              2022-07-08 09:22:50.248	debug	GET request on https://gateway-xxxxx-xxxxx-xxxxx.local:8443/enduser-mobile-web/1/enduserAPI/setup/gateways with payload:{}
              tahoma.0
              2022-07-08 09:22:50.247	debug	Update gateway status for id undefined
              tahoma.0
              2022-07-08 09:22:20.245	warn	error during request: Error: getaddrinfo EAI_AGAIN gateway-xxxxx-xxxxx-xxxxx.local, request path: setup/gateways with payload:{}
              tahoma.0
              2022-07-08 09:22:10.227	debug	GET request on https://gateway-xxxxx-xxxxx-xxxxx.local:8443/enduser-mobile-web/1/enduserAPI/setup/gateways with payload:{}
              tahoma.0
              2022-07-08 09:22:10.226	debug	Update gateway status for id undefined
              tahoma.0
              2022-07-08 09:21:40.224	warn	error during request: Error: getaddrinfo EAI_AGAIN gateway-xxxxx-xxxxx-xxxxx.local, request path: setup/gateways with payload:{}
              tahoma.0
              2022-07-08 09:21:30.304	warn	{"error":{"errno":-3001,"code":"EAI_AGAIN","syscall":"getaddrinfo","hostname":"gateway-xxxxx-xxxxx-xxxxx.local"}}
              tahoma.0
              2022-07-08 09:21:30.304	warn	setup failed!
              tahoma.0
              2022-07-08 09:21:30.303	warn	error during request: Error: getaddrinfo EAI_AGAIN gateway-xxxxx-xxxxx-xxxxx.local, request path: setup with payload:{}
              tahoma.0
              2022-07-08 09:21:30.204	debug	GET request on https://gateway-xxxxx-xxxx-xxxx.local:8443/enduser-mobile-web/1/enduserAPI/setup/gateways with payload:{}
              tahoma.0
              2022-07-08 09:21:30.203	debug	Update gateway status for id undefined
              • Excodibur
                Excodibur Developer @mike2712 last edited by
                @mike2712 Wenn du ab Version 0.7.2 die Gateway PIN aus der Konfiguration nimmst, verbindet sich der Adapter statt mit der lokalen API wieder mit Tahomalink (online).
                Dein Fehler getaddrinfo EAI_AGAIN deutet darauf hin, das bei dir die lokale Namensauflösung nicht funktioniert, d.h. der Adapter findet zu dem Namen kein Gerät im lokalen Netz. Eine Lösung wäre in deinem Router zu schauen, welche IP zu der Domain (gateway-xxxxx-xxxxx-xxxxx.local) gehört und die auf dem System wo dein Adapter läuft direkt mit der IP in die lokale hosts Datei einzutragen und dann den Adapter neu zu starten.
                  mike2712 @Excodibur last edited by
                  @excodibur
                  danke für den Tipp.
                  Adapter:
                  Fritz Box:
                  An welcher Stelle muss ich jetzt die 172.16.20.61 eintragen, das verstehe ich nicht?
                    wusa @mike2712 last edited by
                    @mike2712
                    Wenn ich das richtig sehe, dann ist bei dir Tahoma im selben Netz wie "alles" andere auch?
                    Hast du schon mal mDNS aktiviert?
                    Funktioniert es damit?
                      mike2712 @wusa last edited by
                      @wusa
                      ja mDNS das habe ich aktiviert.
                      Es ist aber nicht alles im selben Netz. Der iOBroker ist 172.16.20.30,. Alles im selben Netz ist unmöglich, dafür sind es zu viele Geräte, das ist in bestimmten Gruppen aufgeteilt, es ist alles im 172.16.xx.xx.
                      Das es nicht gefunden wird klingt etwas plausibel, aber ich weiß nicht an welcher Stelle ich den "IP in die lokale hosts Datei " eintragen muss.
                      • Excodibur
                        @mike2712 mDNS funktioniert bei mir zu Hause im von einer Fritzbox verwalteten Netz z.B. nicht, deswegen habe ich das immer aus.
                        Die IP-Adresse musst du bei dem von mir vorgeschlagenen Workaround in die hosts-Datei deines Betriebssystems (inkl. Hostname) eintragen. Läuft ioBroker auf Linux, normalerweise unter /etc/hosts, bei Windows meistens C:\Windows\System32\drivers\etc\hosts. Dort dann einen Eintrag in folgendem Format hinzufügen:
                        172.16.20.61  gateway-xxxxx-xxxxx-xxxxx.local gateway-xxxxx-xxxxx-xxxxx
                        xxxx ist natürlich deine individuelle Gateway-ID
                        M 2 Replies Last reply Reply Quote 1
                          mike2712 @Excodibur last edited by mike2712
                          @excodibur
                          danke, bei mir läuft es im Docker Container, vielleicht noch jemand hier der sich damit etwas auskennt?
                          Habe einiges probiert, aber hab es nicht hinbekommen.
                          TCP 172.16.22.35:9999 Error: connect EHOSTUNREACH 172.16.22.35:9999
                              at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1159:16) {
                            errno: -113,
                            code: 'EHOSTUNREACH',
                            syscall: 'connect',
                            address: '172.16.22.35',
                            port: 9999
                          172.16.20.61 gateway-2006-2989-5271.loacal gateway-xxxx-xxxx-xxxx
                            errno: -113,
                            syscall: 'connect',
                            port: 9999
                          # list
                          /bin/sh: 1: list: not found
                          # dir
                          backups  homematic_2022_01_11-01_30_12_2.59.7_backupiobroker.tar.sbk  INSTALLER_INFO.txt  iob  iobroker  iobroker.bak  iobroker-data  log  node_modules  package.json  package-lock.json  @Recently-Snapshot  @Recycle  reinstall.js
                          # cd iob
                          /bin/sh: 3: cd: can't cd to iob
                          # cd iobroker
                          /bin/sh: 4: cd: can't cd to iobroker
                          # iobroker
                          iobroker [command]
                          Commands:
                            iobroker setup                                               Setup ioBroker
                            iobroker start [all|<adapter>.<instance>]                    Starts the js-controller or a specified adapter instance
                            iobroker stop [<adapter>.<instance>]                         stops the js-controller or a specified adapter instance
                            iobroker restart [<adapter>.<instance>]                      Restarts js-controller or a specified adapter instance  [aliases: r]
                            iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
                            iobroker info                                                Shows the host info
                            iobroker logs [<adapter>]                                    Monitor log
                            iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
                            iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
                            iobroker rebuild [<module>]                                  Rebuild all native modules or path
                            iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
                            iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
                            iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
                            iobroker update [<repositoryUrl>]                            Update repository and list adapters
                            iobroker upgrade                                             Upgrade management
                            iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
                            iobroker object                                              Object management  [aliases: o]
                            iobroker state                                               State management  [aliases: s]
                            iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
                            iobroker list <type> [<filter>]                              List all entries, like objects
                            iobroker chmod <mode> <file>                                 Change file rights
                            iobroker chown <user> <group> <file>                         Change file ownership
                            iobroker touch <file>                                        Touch file
                            iobroker rm <file>                                           Remove file
                            iobroker file                                                File management
                            iobroker user                                                User commands
                            iobroker group                                               group management
                            iobroker host <hostname>                                     Set host to given hostname
                            iobroker set <adapter>.<instance>                            Change settings of adapter config
                            iobroker license <license.file or license.text>              Update license by given file
                            iobroker cert                                                Certificate management
                            iobroker clean <yes>                                         Clears all objects and states
                            iobroker backup                                              Create backup
                            iobroker restore <backup name or path>                       Restore a specified backup
                            iobroker validate <backup name or path>                      Validate a specified backup
                            iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
                            iobroker repo [<name>]                                       Show repo information
                            iobroker uuid                                                Show uuid of the installation  [aliases: id]
                            iobroker unsetup                                             Reset license, installation secret and language
                            iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
                            iobroker multihost                                           Multihost management
                            iobroker compact                                             compact group management
                            iobroker plugin                                              Plugin management
                            iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
                          Options:
                            --help  Show help  [boolean]
                          # 172.16.20.61 gateway-xxxx-xxxx-xxxx.loacal gateway-xxxx-xxxx-xxxx
                          /bin/sh: 6: 172.16.20.61: not found
                          • Excodibur
                            @mike2712 Das hinter deinem Gateway-Namen ".loacal" statt ".local" steht, ist seltsam.
                            Bei Docker gäbe es zwei Möglichkeiten:
                            • Du verwendest beim Deployment --add-host (https://docs.docker.com/engine/reference/commandline/run/#add-entries-to-container-hosts-file---add-host) und fügst das IP-Hostname-Mapping hinzu. Bei docker-compose wäre das Der extra_hosts Abschnitt.
                            • Du zwingst deinen Container via --network=host (https://docs.docker.com/network/host/) das Netzwerk des Host-Systems direkt mit zu nutzen, dann wird sicher auch die hosts-Datei deines Betriebssystems bei der Namensauflösung verwendet. Damit hebst du aber auch einen Teil der Docker Container-Isolierung auf, was nicht so optimal ist. Daher würde ich immer eher zu Option 1 raten.
                              wusa last edited by
                              @mike2712
                              Wäre es nicht erstmal Sinnvoll, die Tahoma Box in das selbe Netz zu hängen und zu schauen, ob es dort ohne Probleme funktioniert?
                              Erst dann würde ich vielleicht weiter machen oder ggf. sogar in dem Netz hängen lassen.
                                @Excodibur Vielen Dank für Deine Hilfe, nachdem ich alles nochmals durchgelesen habe ist mit das mit mDNS aufgefallen, das hatte ich aktiviert, nach dem deaktivieren ging es.
                                @wusa das ist eine gute Idee, dabei habe ich festgestellt das sie schon im selben Netz hängen, das hatte ich früher schon mal versuchsweise getestet.
                                Dann habe ich mich mit dem Tipp von Excodibur weiter versucht durchzukämpfen, leider habe ich das mit dem zufügen der Adresse nicht hinbekommen, danach habe ich alles nochmals gelesen.
                                Seltsam war das der Adapter komplett grün ist, aber dennoch die Fehler ausgeben hatte.
                                Eine kleine Frage, mit welchem Datenpunkt steuert Ihr die Position? Es funktionieren komischerweise alle 3 gelb markierten.
                                Ich kann alles steuern, aber die Rückmeldungen, wenn ich aus der Handy App steuere, kommen die neuen Positionen offensichtlich nicht in ioBorker an.
                                  mike2712 @mike2712 last edited by
                                  Mit der Aktualisierung liegt wohl am Abrufintervall, das hatte mir damals die Somfy Hotline gesagt, weil das Konto immer gesperrt war, was war der default Eintrag noch? Leider vergessen.
                                    TobFe last edited by
                                    Guten Tag in die Runde. Ich kann leider auf die Frage, ob man eine Connexoon io mit dem Adapter verbinden kann keine Antwort finden. Der Adapter möchte Zugangsdaten für das ältere Web-System TaHoma Link haben, die ich nicht habe, weil ich leider nur eine Connexoon io Box besitze. Gibt es hierfür auch eine Lösung?
                                    Ich danke für eine Rückmeldung und hoffe auf eine Lösung.
                                      puls200 @TobFe last edited by
                                      @tobfe : also bei meinem Adapter muss ich nur die Zugangsdaten eingeben, um meine Connexoon zu verbinden.
                                        TobFe @puls200 last edited by
                                        @puls200 Danke. Ich hatte einen Zahledreher 😉
                                        Allerdings bin ich nun zwar verbunden, aber in den Objekten finde ich meine angelegten Produkte nicht (Jaloussie, Lamellendach,...) Woran liegt das?
                                          @tobfe Nen bisserl warten? Oder ein Neustart?
                                            SaschaS last edited by
                                            Über die Suchfunktion habe ich in dem Thread nichts passendes gefunden.
                                            Wir versetzen einzelne Rollläden gerne mal mit dem Wandschalter in den "Manuellen Modus". Bleibt man in der "Somfy-Welt" kann man den Rollladen (in der App, tahomalink.com) zwar hoch und runter fahren, definierte Szenarien und Zeitabläufe werden aber ausgesetzt. Das ist auch richtig so.
                                            Gibt es mit dem Adapter auch die Möglichkeit den Sperrzustand abzufragen? Ich habe bislang noch keine Logik entdeckt, wann ein Befehl aus ioBroker tatsächlich durchgeführt wird und wann er abgelehnt wird.
                                            Im nachstehenden Beispiel war sowohl "Raffstore (Nachbar)" als auch "Wohnz klein" und "Wohnz gross" auf den manuellen Modus gestellt, dennoch ist "Raffstore (Nachbar)" hochgefahren.
                                            605
                                            157540
