    4. Alexa2 Adapter 3.13/3.14/3.15/3.16/3.17 (Beta)
    • Diginix
      Diginix last edited by Diginix
      @apollon77 Und mir ist die 3.17.1 eben nach einer Sprachausgabe mittels announcement auf allen Echos mit diesen Meldungen abgestürzt:
      2022-07-12 16:55:01.488 - warn: alexa2.0 (649312) Exception: TypeError: value.replace(...).replaceAll is not a function
      2022-07-12 16:55:01.493 - error: alexa2.0 (649312) uncaught exception: value.replace(...).replaceAll is not a function
      2022-07-12 16:55:01.494 - error: alexa2.0 (649312) TypeError: value.replace(...).replaceAll is not a function
          at /opt/iobroker/node_modules/iobroker.alexa2/main.js:2220:98
          at Array.forEach (<anonymous>)
          at /opt/iobroker/node_modules/iobroker.alexa2/main.js:2216:67
          at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.alexa2/main.js:2211:65)
          at processImmediate (internal/timers.js:466:21)
      2022-07-12 16:55:01.494 - error: alexa2.0 (649312) value.replace(...).replaceAll is not a function
      2022-07-12 16:55:01.512 - info: alexa2.0 (649312) terminating
      2022-07-12 16:55:01.513 - warn: alexa2.0 (649312) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2022-07-12 16:55:02.080 - error: host.iobroker Caught by controller[0]: TypeError: value.replace(...).replaceAll is not a function
      2022-07-12 16:55:02.083 - error: host.iobroker Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.alexa2/main.js:2220:98
      2022-07-12 16:55:02.083 - error: host.iobroker Caught by controller[0]:     at Array.forEach (<anonymous>)
      2022-07-12 16:55:02.083 - error: host.iobroker Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.alexa2/main.js:2216:67
      2022-07-12 16:55:02.083 - error: host.iobroker Caught by controller[0]:     at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.alexa2/main.js:2211:65)
      2022-07-12 16:55:02.083 - error: host.iobroker Caught by controller[0]:     at processImmediate (internal/timers.js:466:21)
      2022-07-12 16:55:02.084 - error: host.iobroker instance system.adapter.alexa2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2022-07-12 16:55:33.964 - info: alexa2.0 (652182) starting. Version 3.17.1 in /opt/iobroker/node_modules/iobroker.alexa2, node: v14.20.0, js-controller: 4.0.23
      2022-07-12 16:55:34.205 - info: alexa2.0 (652182) Update History Interval is too low, set to 112s
      2022-07-12 16:55:34.206 - info: alexa2.0 (652182) Update Device State Interval is too low, set to 112s
      2022-07-12 16:55:39.181 - info: alexa2.0 (652182) Alexa-Push-Connection (macDms = true) established. Disable Polling
      2022-07-12 16:56:37.755 - info: alexa2.0 (652182) Subscribing to states...
      announcement funktioniert auch nicht mehr, weder mit "volume;text" noch mit nur "text". Dabei stürzt die Instanz immer ab. Die 3.17.2 ist aber auch unbrauchbar durch die loopenden Logmeldungen zu falschen Datentypen. 😉
      Also erstmal zurück zur 3.17.0.
      • Palm_Maniac
        Palm_Maniac @apollon77 last edited by
        @apollon77 sagte in Alexa2 Adapter 3.13/3.14/3.15/3.16/3.17 (Beta):
        Dann mach das doch mal 🙂 Der Entwickler freut sich
        Stimmt, da hast du recht, das hätte ich gleich machen sollen. 🙂
        • Palm_Maniac
          @palm_maniac sagte in Alexa2 Adapter 3.13/3.14/3.15/3.16/3.17 (Beta):
          Außerdem habe ich wohl den Auslöser für das Eigenleben des Lichts gefunden. Mir ist aufgefallen, dass das Treppenlicht 2mal unter Smart-Devices auftauchte mit allen Datenpunkten für RGB Beleuchtung. Das hätte so aber nicht sein dürfen, denn ich hatte dieses Licht garnicht per IOT-Adapter an Alexa übergeben. Also habe ich mir nochmal die Konfig in WLED angeschaut und gesehen, dass dort die Alexa-Unterstützung aktiviert war. Problem erkannt, Problem gebannt.
          Warum es plötzlich was tut wenn nichts gesteuert wird ist dennoch strange
          Ja, zumal diese Datenpunkte in keinem Skript Verwendung finden.
            apollon77 @Diginix last edited by
            @diginix Den hab ich auf Sentry gesehen. Fix kommt heute abend
              apollon77 @sigi234 last edited by
              @sigi234 Hab schon ne vermutung. Fix heute abend
              Thomas Braun sigi234 2 Replies Last reply Reply Quote 0
                Thomas Braun Most Active @apollon77 last edited by
                @apollon77
                Das muss aber im Diff von
                alexa2.git#0fd8690ca77e16285030ebbcdbce49b4c56f99a8 ist wieder leise im Log.
                zum Release 3.17.2 zu finden sein.
                Die quasselt mich nämlich auch im Log zu:
                2022-07-12 18:15:30.770  - info: alexa2.0 (74962) State value to set for "alexa2.0.Smart-Home-Devices.4acc0e22-bfb9-4e3e-bdfe-bea4f3912910.connectivity-reason" has to be type "string" but received type "object"
                2022-07-12 18:15:30.771  - info: alexa2.0 (74962) State value to set for "alexa2.0.Smart-Home-Devices.d7d81c77-a50c-41cb-9c3a-0450992ae160.connectivity-reason" has to be type "string" but received type "object"
                2022-07-12 18:15:30.773  - info: alexa2.0 (74962) State value to set for "alexa2.0.Smart-Home-Devices.f3c8b652-2523-4cd9-b7da-2b125e973bb6.connectivity-reason" has to be type "string" but received type "object"
                2022-07-12 18:15:30.773  - info: alexa2.0 (74962) State value to set for "alexa2.0.Smart-Home-Devices.4e18554e-e6fe-4771-8f4e-12fc640761db.connectivity-reason" has to be type "string" but received type "object"
                2022-07-12 18:15:30.774  - info: alexa2.0 (74962) State value to set for "alexa2.0.Smart-Home-Devices.d359aeb1-03f5-4cde-9071-179a5924f7fa.connectivity-reason" has to be type "string" but received type "object"
                2022-07-12 18:15:30.775  - info: alexa2.0 (74962) State value to set for "alexa2.0.Smart-Home-Devices.0f9cec35-b064-4598-923d-963b29af18b8.connectivity-reason" has to be type "string" but received type "object"
                2022-07-12 18:15:30.776  - info: alexa2.0 (74962) State value to set for "alexa2.0.Smart-Home-Devices.7cd146f6-aac1-4b01-98e6-3167447f9e70.connectivity-reason" has to be type "string" but received type "object"
                2022-07-12 18:15:30.777  - info: alexa2.0 (74962) State value to set for "alexa2.0.Smart-Home-Devices.ca41d22b-884b-4be1-aa28-ced702d9f694.connectivity-reason" has to be type "string" but received type "object"
                2022-07-12 18:15:30.778  - info: alexa2.0 (74962) State value to set for "alexa2.0.Smart-Home-Devices.98257657-55fe-4a59-96ee-bcbb24ee9bc8.colorRgb" has to be type "string" but received type "object"
                2022-07-12 18:15:30.814  - info: alexa2.0 (74962) State value to set for "alexa2.0.Smart-Home-Devices.98257657-55fe-4a59-96ee-bcbb24ee9bc8.connectivity-reason" has to be type "string" but received type "object"
                2022-07-12 18:15:30.815  - info: alexa2.0 (74962) State value to set for "alexa2.0.Smart-Home-Devices.3c24ecd2-b792-4d5f-9c25-75d7cf57a574.connectivity-reason" has to be type "string" but received type "object"
                2022-07-12 18:15:30.816  - info: alexa2.0 (74962) State value to set for "alexa2.0.Smart-Home-Devices.fb3ea3ff-cbdf-423a-9186-11da242e2947.connectivity-reason" has to be type "string" but received type "object"
                2022-07-12 18:15:30.816  - info: alexa2.0 (74962) State value to set for "alexa2.0.Smart-Home-Devices.dff78664-0a39-4ee4-aa2b-a9a8e0d7ba31.connectivity-reason" has to be type "string" but received type "object"
                2022-07-12 18:15:30.817  - info: alexa2.0 (74962) State value to set for "alexa2.0.Smart-Home-Devices.8bc3f37a-58a8-4d46-82e8-4d84dd10121c.connectivity-reason" has to be type "string" but received type "object"
                2022-07-12 18:15:30.817  - info: alexa2.0 (74962) State value to set for "alexa2.0.Smart-Home-Devices.39be3920-5d21-4742-9453-25790bcc07f5.connectivity-reason" has to be type "string" but received type "object"
                2022-07-12 18:15:30.818  - info: alexa2.0 (74962) State value to set for "alexa2.0.Smart-Home-Devices.e134e20d-ae41-4394-b4c7-1504ae3e4831.connectivity-reason" has to be type "string" but received type "object"
                2022-07-12 18:15:30.818  - info: alexa2.0 (74962) State value to set for "alexa2.0.Smart-Home-Devices.10d02cfd-be52-46a6-84ed-fcaae8db99b7.colorRgb" has to be type "string" but received type "object"
                2022-07-12 18:15:30.819  - info: alexa2.0 (74962) State value to set for "alexa2.0.Smart-Home-Devices.10d02cfd-be52-46a6-84ed-fcaae8db99b7.connectivity-reason" has to be type "string" but received type "object"
                2022-07-12 18:15:30.820  - info: alexa2.0 (74962) State value to set for "alexa2.0.Smart-Home-Devices.5144a434-eee6-42db-a91b-3b5df7b712e5.connectivity-reason" has to be type "string" but received type "object"
                2022-07-12 18:15:30.820  - info: alexa2.0 (74962) State value to set for "alexa2.0.Smart-Home-Devices.3a8fa5bf-7037-4806-aecf-fea3af6070a4.connectivity-reason" has to be type "string" but received type "object"
                2022-07-12 18:15:30.821  - info: alexa2.0 (74962) State value to set for "alexa2.0.Smart-Home-Devices.c77e7be4-86da-4595-8223-5ceb6b50254b.connectivity-reason" has to be type "string" but received type "object"
                2022-07-12 18:15:30.821  - info: alexa2.0 (74962) State value to set for "alexa2.0.Smart-Home-Devices.4967049f-b2b6-42a5-a0fc-825172dad02a.connectivity-reason" has to be type "string" but received type "object"
                2022-07-12 18:15:30.822  - info: alexa2.0 (74962) State value to set for "alexa2.0.Smart-Home-Devices.e7ea8a09-6582-480b-a6a6-935cbbe3275e.connectivity-reason" has to be type "string" but received type "object"
                2022-07-12 18:15:30.823  - info: alexa2.0 (74962) State value to set for "alexa2.0.Smart-Home-Devices.81de86f1-23b0-49f6-b5d0-402c197dcba0.connectivity-reason" has to be type "string" but received type "object"
                2022-07-12 18:15:30.823  - info: alexa2.0 (74962) State value to set for "alexa2.0.Smart-Home-Devices.6c714265-c3e0-450a-b7e0-5acf25326e57.connectivity-reason" has to be type "string" but received type "object"
                2022-07-12 18:15:30.824  - info: alexa2.0 (74962) State value to set for "alexa2.0.Smart-Home-Devices.48f3f6f6-a74c-4daa-97a3-32766f03e5b1.connectivity-reason" has to be type "string" but received type "object"
                2022-07-12 18:15:30.824  - info: alexa2.0 (74962) State value to set for "alexa2.0.Smart-Home-Devices.141b1d14-9591-4d28-bd03-698cd0cfd970.batteryLevel" has to be type "number" but received type "object"
                2022-07-12 18:15:30.825  - info: alexa2.0 (74962) State value to set for "alexa2.0.Smart-Home-Devices.141b1d14-9591-4d28-bd03-698cd0cfd970.connectivity-reason" has to be type "string" but received type "object"
                2022-07-12 18:15:30.825  - info: alexa2.0 (74962) State value to set for "alexa2.0.Smart-Home-Devices.60099b70-c2d2-46b7-b14d-77acc53e04f9.connectivity-reason" has to be type "string" but received type "object"
                2022-07-12 18:15:30.827  - info: alexa2.0 (74962) State value to set for "alexa2.0.Smart-Home-Devices.a3ab3c77-6751-458f-a7d5-0871e996c700.connectivity-reason" has to be type "string" but received type "object"
                2022-07-12 18:15:30.828  - info: alexa2.0 (74962) State value to set for "alexa2.0.Smart-Home-Devices.5d479e97-6965-4780-98d1-5438ccbc2371.colorRgb" has to be type "string" but received type "object"
                2022-07-12 18:15:30.829  - info: alexa2.0 (74962) State value to set for "alexa2.0.Smart-Home-Devices.5d479e97-6965-4780-98d1-5438ccbc2371.connectivity-reason" has to be type "string" but received type "object"
                2022-07-12 18:15:30.829  - info: alexa2.0 (74962) State value to set for "alexa2.0.Smart-Home-Devices.30d44a62-ba23-4a51-a417-d4215f8e6336.connectivity-reason" has to be type "string" but received type "object"
                  Megawaldi @Thomas Braun last edited by
                  @apollon77
                  Hier das selbe Problem mit dem zugespamtem Log.
                    Thomas Braun Most Active @Megawaldi last edited by
                    @megawaldi Setz das LogLevel auf 'Warning / Hinweis'.
                      schon erledigt. Aber trotzdem Danke für den Tip. 😉
                        @megawaldi Danke für den #metoo-Beitrag. 😄
                          Wollte nur nicht da jemand denkt es liegt an dir Thomas...
                            @Diginix @sigi234 Version 3.17.3 mit Fix ist auf dem Weg
                              sigi234 Forum Testing Most Active @apollon77 last edited by
                              Log wieder Ok, Danke für den Fix. 👍
                                @sigi234 danke für die Bestätigung. Die Werte sind auch korrekt?! Vor allem bei den States die vorher angemeckert wurden?
                                  3.17.4 ist auf dem Weg mit einem weiteren Bugfix:
                                  Es war nicht möglich die Query Intervalle für Smart-Home Devices, generellen State und Configuration auf 0 zu setzen aka zu deaktivieren.
                                  • Diginix
                                    Diginix @apollon77 last edited by
                                    @apollon77 Aus der iob Facebook Gruppe:
                                      apollon77 last edited by apollon77
                                      Naja ich sags mal so ... es gab einen Bug ... Alle schnellstens auf die 3.17.4 updaten!!!
                                      Admin-Notify ist geschaltet um alle user daraf hinzuweisen. Im Forum ist auch ab gleich eine Headline
                                      • Diginix
                                        @apollon77 Der Facebook User ist aber auf 3.14.0.
                                          @diginix Ok, da hats wohl mein changelog zerbröselt ... ab 3.14 ist "böse". Fixe kommunikatoon
                                          MyzerAT 1 Reply Last reply Reply Quote 0
                                          • MyzerAT
                                            MyzerAT @apollon77 last edited by MyzerAT
                                            @apollon77
                                            habe seit heute selbiges problem, habe dann auf 3.17.4 update gemacht und seither bekomme ich keine smart home devices unter objekte mehr angezeigt
                                            habe schon alles durch an tipps was ich gefunden habe.
                                            Instanz komplett gelöscht
                                            iobrokeriot skill in der handy app de und wieder aktiviert
                                            mehrere neustarts
                                            391
                                            57397
