    4. Test Adapter EnOcean v0.7.x
      Sepp @Jey Cee last edited by Sepp
      @jey-cee hab von eltako die Firmware bekommen, habs auch geschafft mit dem FAM-USB ein Aktor einzuschalten, aber leider scheint er wohl keine Telegramme vom Aktor zu empfangen ( relais on oder Signalqualität), hier noch ein Auszug vom debug log:
      enocean.0
      	2022-07-08 21:25:02.718	debug	Radio sub telegram received.
      enocean.0
      	2022-07-08 21:25:02.717	debug	550007120362f650ffb17b063003ffffffff3d008dbb004030073d301d4030
      enocean.0
      	2022-07-08 21:25:01.695	debug	Packet type 2 received: {"code":"OK"}
      enocean.0
      	2022-07-08 21:25:01.694	debug	55000100026500
      enocean.0
      	2022-07-08 21:25:01.677	debug	Sent data: 55000a0701eba501000008ffaa77800000ffb17b06ff005d
      enocean.0
      	2022-07-08 21:25:01.626	debug	state ffb17b06.CMD changed: 0 (ack = false) state: {"val":0,"ack":false,"ts":1657308301620,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1657308301620}
      enocean.0
      	2022-07-08 21:24:54.879	debug	Radio sub telegram received.
      enocean.0
      	2022-07-08 21:24:54.878	debug	55000a1203f3a5870900090590e5940003ffffffff4d006f17004d00074d001f4d00
      enocean.0
      	2022-07-08 21:24:51.440	debug	Radio sub telegram received.
      enocean.0
      	2022-07-08 21:24:51.439	debug	55000a1203f3a50056600fffb17b463003ffffffff3d0061a8004030033d30184030
      enocean.0
      	2022-07-08 21:24:48.608	debug	Radio sub telegram received.
      enocean.0
      	2022-07-08 21:24:48.607	debug	55000a1203f3a50056600f050b58030003ffffffff5200569b0052000652001f5200
      enocean.0
      	2022-07-08 21:23:13.392	debug	Radio sub telegram received.
      enocean.0
      	2022-07-08 21:23:13.391	debug	55000a1203f3a5880900090590e5940003ffffffff4d00e2a7004d00074d001f4d00
      enocean.0
      	2022-07-08 21:22:01.823	debug	Radio sub telegram received.
      enocean.0
      	2022-07-08 21:22:01.820	debug	5500070f03dcf670ffb17b063002ffffffff4000cb18004030194030
      enocean.0
      	2022-07-08 21:21:59.180	debug	Packet type 2 received: {"code":"OK"}
      enocean.0
      	2022-07-08 21:21:59.179	debug	55000100026500
      enocean.0
      	2022-07-08 21:21:59.167	debug	Sent data: 55000a0701eba501000009ffaa77800000ffb17b06ff00c9
      enocean.0
      	2022-07-08 21:21:59.111	debug	state ffb17b06.CMD changed: 1 (ack = false) state: {"val":1,"ack":false,"ts":1657308119099,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1657308119099}
      Dies ist der log vom ein- und ausschalten eines F4SR14-led
      • Jey Cee
        Jey Cee Developer @IOSD last edited by
        @iosd muss ich mir anschauen wo das her kommt, dann sollte ich dir sagen können was das Problem ist.
        • Jey Cee
          Jey Cee Developer @Sepp last edited by
          @sepp die Firmware gibt einen Telegram Typ aus der noch nicht Implentiert ist. Den hab ich bisher noch nie bekommen.
          Der gibt Zusätzliche informationen über das Empfangene Telegram mit, aber ich wüsste nicht für was man die in ioBroker benutzen kann.
          Sobald ich Zeit hab Bau ich den ein. Kann aber August werden weil ich in einer Woche in den Urlaub fahr.
            Sepp last edited by
            @jey-cee alles klar, wenn das dann funktioniert wäre weltklasse 🙂
            • Jey Cee
              @iosd Es sieht für mich so aus als wird hier ein Telegram falsch Interpretiert. Ich brauch das Vollständige Log im debug, bitte diesmal in Code Tags packen. Ohne ist es Anstrengend zu lesen.
              • I
                IOSD @Jey Cee last edited by
                @jey-cee hier der Debug Log, da ich das nirgends einstellen kann. der FGW14 USB sendet ja mit 57600 Baud. Das ist aber vermutlich korrekt. Ich habe es nur nirgends nochmal einstellen können.
                2022-07-09 11:28:15.216 - debug: enocean.0 (592) Redis Objects: Use Redis connection: 127.0.0.1:9001
                2022-07-09 11:28:15.261 - debug: enocean.0 (592) Objects client ready ... initialize now
                2022-07-09 11:28:15.264 - debug: enocean.0 (592) Objects create System PubSub Client
                2022-07-09 11:28:15.266 - debug: enocean.0 (592) Objects create User PubSub Client
                2022-07-09 11:28:15.289 - debug: enocean.0 (592) Objects client initialize lua scripts
                2022-07-09 11:28:15.298 - debug: enocean.0 (592) Objects connected to redis: 127.0.0.1:9001
                2022-07-09 11:28:15.328 - debug: enocean.0 (592) Redis States: Use Redis connection: 127.0.0.1:9000
                2022-07-09 11:28:15.356 - debug: enocean.0 (592) States create System PubSub Client
                2022-07-09 11:28:15.358 - debug: enocean.0 (592) States create User PubSub Client
                2022-07-09 11:28:15.371 - debug: enocean.0 (592) States connected to redis: 127.0.0.1:9000
                2022-07-09 11:28:15.563 - info: enocean.0 (592) starting. Version 0.7.0 (non-npm: Jey-Cee/ioBroker.enocean#df6980753d3beeadce3db596c2f0809372c55415) in /opt/iobroker/node_modules/iobroker.enocean, node: v16.16.0, js-controller: 4.0.23
                2022-07-09 11:28:33.137 - debug: enocean.0 (592) 55008b020a36055000000000000019302900010000
                2022-07-09 11:28:33.148 - debug: enocean.0 (592) ERP2 protocol radio telegram received.
                2022-07-09 11:28:33.198 - debug: enocean.0 (592) 55008b020a3605500000000000001a302a000100b4
                2022-07-09 11:28:33.202 - debug: enocean.0 (592) ERP2 protocol radio telegram received.
                2022-07-09 11:28:51.419 - debug: enocean.0 (592) 55008b020a3605500000000000001a302a000100b4
                2022-07-09 11:28:51.423 - debug: enocean.0 (592) ERP2 protocol radio telegram received.
                2022-07-09 11:28:52.970 - debug: enocean.0 (592) 55008b020a36055000000000000019302900010000
                2022-07-09 11:28:52.975 - debug: enocean.0 (592) ERP2 protocol radio telegram received.
                2022-07-09 11:28:59.432 - debug: enocean.0 (592) 550003020af6000100ac
                2022-07-09 11:28:59.438 - debug: enocean.0 (592) ERP2 protocol radio telegram received.
                2022-07-09 11:28:59.443 - error: enocean.0 (592) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                2022-07-09 11:28:59.444 - error: enocean.0 (592) unhandled promise rejection: The id is empty! Please provide a valid id.
                2022-07-09 11:28:59.452 - error: enocean.0 (592) Error: The id is empty! Please provide a valid id.
                at Utils.validateId (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/utils.js:114:19)
                at Enocean.getObject (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:2332:23)
                at /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2116:16
                at new Promise ()
                at Enocean.getObjectAsync (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2115:16)
                at handleType10.main (/opt/iobroker/node_modules/iobroker.enocean/lib/tools/Packet_handler.js:395:34)
                at new handleType10 (/opt/iobroker/node_modules/iobroker.enocean/lib/tools/Packet_handler.js:390:8)
                at Enocean.parseMessage (/opt/iobroker/node_modules/iobroker.enocean/main.js:613:24)
                2022-07-09 11:28:59.453 - error: enocean.0 (592) The id is empty! Please provide a valid id.
                2022-07-09 11:28:59.463 - info: enocean.0 (592) cleaned everything up...
                2022-07-09 11:28:59.465 - info: enocean.0 (592) terminating
                2022-07-09 11:28:59.467 - warn: enocean.0 (592) Terminated (UNCAUGHT_EXCEPTION): Without reason
                2022-07-09 11:28:59.475 - info: enocean.0 (592) The serial port was closed.
                2022-07-09 11:29:00.020 - error: host.iobroker instance system.adapter.enocean.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                2022-07-09 11:29:00.022 - info: host.iobroker Restart adapter system.adapter.enocean.0 because enabled
                • Jey Cee
                  @iosd bitte von Github neu installieren. Das Telegram was den Absturz verursacht ist Unvollständig, es wird jetzt einfach ignoriert.
                  Bitte beobachte ob Statusänderungen für ein bestimmtes Gerät nicht in ioBroker ankommen.
                  • I
                    IOSD last edited by
                    @jey-cee Danke das hat es gelöst. Verbindung ist jetzt da und Geräte werden erkannt. Ob was an Telegrammen fehlt muss ich noch schauen...
                      Denis1988 last edited by
                      vielen Dank erstmal für die tolle Arbeit!!!
                      Wollte den Enocean Adapter heute auch mal mit meinem TCM310 Stick ans Laufen bringen, aber irgendwie bekomm ich den Adapter nicht auf grün.
                      Mein Iobroker läuft über Proxmox in einer VM und parallel betreibe ich noch einen Zigbee USB-Dongle. Stick ist in der VM durchgereicht und ich bekomme folgendes im Logg angezeigt:
                      Ansonsten sieht die Einstellung wie folgt aus:
                      Kann mir jemand eventuell weiterhelfen?
                      Vielen Dank und liebe Grüße
                      Denis
                      • Jey Cee
                        @denis1988 du musst den Stick schon Auswählen. Da ist nichts ausgewählt und laut log ist alles in Ordnung.
                          Denis1988 @Jey Cee last edited by
                          @jey-cee oh stimmt sorry 🙂
                          jetzt bekomme ich allerdings folgenden Fehler
                          • Jey Cee
                            Jey Cee Developer @Denis1988 last edited by
                            @denis1988 Falscher Port ausgewählt, nimm den mit EnOcean im Namen.
                                @jey-cee da erscheint leider nur das bei mir 2105fd01-84db-41c4-bd02-d712e11b32e8-image.png
                                  @jey-cee jetzt hab ich es danke nochmal für deine schnelle Hilfe 🙂
                                  • wendy2702
                                    habe mir zum Testen den Hoppe eFenstergriff ConnectHome und einen Enocean USB Stick besorgt.
                                    Aus Unwissenheit den Griff beim ersten mal mit falscher ID angelernt. Wie kann ich den wieder löschen?
                                    Aktuell jetzt zwei Griffe drin wobei halt einer die Falsche ID hat.
                                    Der DP Window tilt bleibt immer auf "false", ist das normal ?
                                    EDIT: OK, der kann kein tilted anzeigen. Gerade bei Hoppe gefunden.
                                    • Jey Cee
                                      Jey Cee Developer @wendy2702 last edited by
                                      @wendy2702 sagte in Test Adapter EnOcean v0.7.x:
                                      Einfach die Objekte löschen.
                                      Gut zu wissen.
                                      wendy2702 1 Reply Last reply Reply Quote 1
                                      • wendy2702
                                        wendy2702 @Jey Cee last edited by wendy2702
                                        @jey-cee Hi,
                                        gerade wurde mein Ersatz Drehgriff geliefert welcher laut Hoppe Anleitung und Broschüre alle drei Stellungen (Offen, Gekippt, Geschlossen) übermitteln soll.
                                        Hoppe Toulon 0737/FR-409 Secusignal
                                        In den Objekten wechselt er aber nur zwischen open und tilted. Closed sehe ich nie.
                                        Drehgriff zeigt nach unten --> eigentlich geschlossen:
                                        Drehgriff zeigt nach links --> offen:
                                        Drehgriff zeigt nach oben --> gekippt:
                                        Drehgriff zeigt nach rechts --> offen:
                                        Drehgriff wieder unten --> sollte geschlossen sein:
                                        Das Debug log dazu sieht so aus, denke aber das hilft dir nicht viel
                                        2022-08-01 09:08:09.227  - debug: enocean.0 (2186136) 55000707017af6d0fedfa4fe2000ffffffff4900
                                        2022-08-01 09:08:09.231  - debug: enocean.0 (2186136) Message for ID fedfa4fe has been received. It was repeated 0 times.
                                        2022-08-01 09:10:29.027  - debug: enocean.0 (2186136) 55000707017af6c0fedfa4fe2000ffffffff4a00
                                        2022-08-01 09:10:29.030  - debug: enocean.0 (2186136) Message for ID fedfa4fe has been received. It was repeated 0 times.
                                        2022-08-01 09:11:21.845  - debug: enocean.0 (2186136) 55000707017af6d0fedfa4fe2000ffffffff4a00
                                        2022-08-01 09:11:21.848  - debug: enocean.0 (2186136) Message for ID fedfa4fe has been received. It was repeated 0 times.
                                        2022-08-01 09:12:22.769  - debug: enocean.0 (2186136) 55000707017af6c0fedfa4fe2000ffffffff4f00
                                        2022-08-01 09:12:22.775  - debug: enocean.0 (2186136) Message for ID fedfa4fe has been received. It was repeated 0 times.
                                        2022-08-01 09:13:22.621  - debug: enocean.0 (2186136) 55000707017af6d0fedfa4fe2000ffffffff4a00
                                        2022-08-01 09:13:22.624  - debug: enocean.0 (2186136) Message for ID fedfa4fe has been received. It was repeated 0 times.
                                        Hier noch das log vom Adpaterstart mit der Info zum USB Adapter:
                                        info: enocean.0 (2193870) {"BaseID":"ff92c880","Frequency":"868.3 Mhz","Protocol":"ERP1","AppVersion":"2.15.0.0","ApiVersion":"2.6.9.0","ChipID":"051f2591","ChipVersion":"454f0103","AppDescription":"GATEWAYCTRL"}
                                        Habe den als Gerät Hoppe Secusignal zugefügt.
                                        Ist das jetzt ein Fehler vom Griff, habe ich was falsch gemacht oder liegt es am Adapter?
                                        Kann ich noch weitere Infos liefern?
                                        • Jey Cee
                                          Sieht aus als wäre das vom Griff, laut den Telegrammen wird Geschlossen nie übermittelt.
                                          Das kann aber auch daran liegen wie du den Griff bedienst. Das drehen des Griffs sollte flüssig sein.
                                          Wenn sich das Fenster schwer schließen lässt könnte es sein das der Schwung nicht ausreicht um die nötige Energie auf zu bringen damit das Telegram gesendet wird.
                                          In dem Fall wäre es ratsam die Mechanik zu Schmieren und bei bedarf das Fenster neu einstellen (lassen).
                                          • wendy2702
                                            @jey-cee Der Griff liegt noch vor mir. Am Fenster kann es nicht liegen.
                                            Habe den auch schon so oft gedreht und zumindest jedesmal einen Eintrag im Log bekommen, die Objekte werden dann auch immer mit Zeitstempel aktualisiert.
                                            Lediglich den "Closed" Status bekomme ich nie zu sehen.
                                            31.7k
                                            79.8k
                                            eltako fgw14-usb enocean adapter
                                            7567
