    4. Test Adapter EnOcean v0.7.x
    • I
      IOSD @Jey Cee last edited by
      @jey-cee hier der Debug Log, da ich das nirgends einstellen kann. der FGW14 USB sendet ja mit 57600 Baud. Das ist aber vermutlich korrekt. Ich habe es nur nirgends nochmal einstellen können.
      2022-07-09 11:28:15.216 - debug: enocean.0 (592) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2022-07-09 11:28:15.261 - debug: enocean.0 (592) Objects client ready ... initialize now
      2022-07-09 11:28:15.264 - debug: enocean.0 (592) Objects create System PubSub Client
      2022-07-09 11:28:15.266 - debug: enocean.0 (592) Objects create User PubSub Client
      2022-07-09 11:28:15.289 - debug: enocean.0 (592) Objects client initialize lua scripts
      2022-07-09 11:28:15.298 - debug: enocean.0 (592) Objects connected to redis: 127.0.0.1:9001
      2022-07-09 11:28:15.328 - debug: enocean.0 (592) Redis States: Use Redis connection: 127.0.0.1:9000
      2022-07-09 11:28:15.356 - debug: enocean.0 (592) States create System PubSub Client
      2022-07-09 11:28:15.358 - debug: enocean.0 (592) States create User PubSub Client
      2022-07-09 11:28:15.371 - debug: enocean.0 (592) States connected to redis: 127.0.0.1:9000
      2022-07-09 11:28:15.563 - info: enocean.0 (592) starting. Version 0.7.0 (non-npm: Jey-Cee/ioBroker.enocean#df6980753d3beeadce3db596c2f0809372c55415) in /opt/iobroker/node_modules/iobroker.enocean, node: v16.16.0, js-controller: 4.0.23
      2022-07-09 11:28:33.137 - debug: enocean.0 (592) 55008b020a36055000000000000019302900010000
      2022-07-09 11:28:33.148 - debug: enocean.0 (592) ERP2 protocol radio telegram received.
      2022-07-09 11:28:33.198 - debug: enocean.0 (592) 55008b020a3605500000000000001a302a000100b4
      2022-07-09 11:28:33.202 - debug: enocean.0 (592) ERP2 protocol radio telegram received.
      2022-07-09 11:28:51.419 - debug: enocean.0 (592) 55008b020a3605500000000000001a302a000100b4
      2022-07-09 11:28:51.423 - debug: enocean.0 (592) ERP2 protocol radio telegram received.
      2022-07-09 11:28:52.970 - debug: enocean.0 (592) 55008b020a36055000000000000019302900010000
      2022-07-09 11:28:52.975 - debug: enocean.0 (592) ERP2 protocol radio telegram received.
      2022-07-09 11:28:59.432 - debug: enocean.0 (592) 550003020af6000100ac
      2022-07-09 11:28:59.438 - debug: enocean.0 (592) ERP2 protocol radio telegram received.
      2022-07-09 11:28:59.443 - error: enocean.0 (592) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2022-07-09 11:28:59.444 - error: enocean.0 (592) unhandled promise rejection: The id is empty! Please provide a valid id.
      2022-07-09 11:28:59.452 - error: enocean.0 (592) Error: The id is empty! Please provide a valid id.
      at Utils.validateId (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/utils.js:114:19)
      at Enocean.getObject (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:2332:23)
      at /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2116:16
      at new Promise ()
      at Enocean.getObjectAsync (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2115:16)
      at handleType10.main (/opt/iobroker/node_modules/iobroker.enocean/lib/tools/Packet_handler.js:395:34)
      at new handleType10 (/opt/iobroker/node_modules/iobroker.enocean/lib/tools/Packet_handler.js:390:8)
      at Enocean.parseMessage (/opt/iobroker/node_modules/iobroker.enocean/main.js:613:24)
      2022-07-09 11:28:59.453 - error: enocean.0 (592) The id is empty! Please provide a valid id.
      2022-07-09 11:28:59.463 - info: enocean.0 (592) cleaned everything up...
      2022-07-09 11:28:59.465 - info: enocean.0 (592) terminating
      2022-07-09 11:28:59.467 - warn: enocean.0 (592) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2022-07-09 11:28:59.475 - info: enocean.0 (592) The serial port was closed.
      2022-07-09 11:29:00.020 - error: host.iobroker instance system.adapter.enocean.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2022-07-09 11:29:00.022 - info: host.iobroker Restart adapter system.adapter.enocean.0 because enabled
      • Jey Cee
        Jey Cee Developer @IOSD last edited by
        @iosd bitte von Github neu installieren. Das Telegram was den Absturz verursacht ist Unvollständig, es wird jetzt einfach ignoriert.
        Bitte beobachte ob Statusänderungen für ein bestimmtes Gerät nicht in ioBroker ankommen.
        • I
          IOSD last edited by
          @jey-cee Danke das hat es gelöst. Verbindung ist jetzt da und Geräte werden erkannt. Ob was an Telegrammen fehlt muss ich noch schauen...
            Denis1988 last edited by
            vielen Dank erstmal für die tolle Arbeit!!!
            Wollte den Enocean Adapter heute auch mal mit meinem TCM310 Stick ans Laufen bringen, aber irgendwie bekomm ich den Adapter nicht auf grün.
            Mein Iobroker läuft über Proxmox in einer VM und parallel betreibe ich noch einen Zigbee USB-Dongle. Stick ist in der VM durchgereicht und ich bekomme folgendes im Logg angezeigt:
            Ansonsten sieht die Einstellung wie folgt aus:
            Kann mir jemand eventuell weiterhelfen?
            Vielen Dank und liebe Grüße
            Denis
            • Jey Cee
              @denis1988 du musst den Stick schon Auswählen. Da ist nichts ausgewählt und laut log ist alles in Ordnung.
                Denis1988 @Jey Cee last edited by
                @jey-cee oh stimmt sorry 🙂
                jetzt bekomme ich allerdings folgenden Fehler
                • Jey Cee
                  Jey Cee Developer @Denis1988 last edited by
                  @denis1988 Falscher Port ausgewählt, nimm den mit EnOcean im Namen.
                      @jey-cee da erscheint leider nur das bei mir 2105fd01-84db-41c4-bd02-d712e11b32e8-image.png
                        @jey-cee jetzt hab ich es danke nochmal für deine schnelle Hilfe 🙂
                        • wendy2702
                          habe mir zum Testen den Hoppe eFenstergriff ConnectHome und einen Enocean USB Stick besorgt.
                          Aus Unwissenheit den Griff beim ersten mal mit falscher ID angelernt. Wie kann ich den wieder löschen?
                          Aktuell jetzt zwei Griffe drin wobei halt einer die Falsche ID hat.
                          Der DP Window tilt bleibt immer auf "false", ist das normal ?
                          EDIT: OK, der kann kein tilted anzeigen. Gerade bei Hoppe gefunden.
                          • Jey Cee
                            Jey Cee Developer @wendy2702 last edited by
                            @wendy2702 sagte in Test Adapter EnOcean v0.7.x:
                            Einfach die Objekte löschen.
                            Gut zu wissen.
                            wendy2702 1 Reply Last reply Reply Quote 1
                            • wendy2702
                              wendy2702 @Jey Cee last edited by wendy2702
                              @jey-cee Hi,
                              gerade wurde mein Ersatz Drehgriff geliefert welcher laut Hoppe Anleitung und Broschüre alle drei Stellungen (Offen, Gekippt, Geschlossen) übermitteln soll.
                              Hoppe Toulon 0737/FR-409 Secusignal
                              In den Objekten wechselt er aber nur zwischen open und tilted. Closed sehe ich nie.
                              Drehgriff zeigt nach unten --> eigentlich geschlossen:
                              Drehgriff zeigt nach links --> offen:
                              Drehgriff zeigt nach oben --> gekippt:
                              Drehgriff zeigt nach rechts --> offen:
                              Drehgriff wieder unten --> sollte geschlossen sein:
                              Das Debug log dazu sieht so aus, denke aber das hilft dir nicht viel
                              2022-08-01 09:08:09.227  - debug: enocean.0 (2186136) 55000707017af6d0fedfa4fe2000ffffffff4900
                              2022-08-01 09:08:09.231  - debug: enocean.0 (2186136) Message for ID fedfa4fe has been received. It was repeated 0 times.
                              2022-08-01 09:10:29.027  - debug: enocean.0 (2186136) 55000707017af6c0fedfa4fe2000ffffffff4a00
                              2022-08-01 09:10:29.030  - debug: enocean.0 (2186136) Message for ID fedfa4fe has been received. It was repeated 0 times.
                              2022-08-01 09:11:21.845  - debug: enocean.0 (2186136) 55000707017af6d0fedfa4fe2000ffffffff4a00
                              2022-08-01 09:11:21.848  - debug: enocean.0 (2186136) Message for ID fedfa4fe has been received. It was repeated 0 times.
                              2022-08-01 09:12:22.769  - debug: enocean.0 (2186136) 55000707017af6c0fedfa4fe2000ffffffff4f00
                              2022-08-01 09:12:22.775  - debug: enocean.0 (2186136) Message for ID fedfa4fe has been received. It was repeated 0 times.
                              2022-08-01 09:13:22.621  - debug: enocean.0 (2186136) 55000707017af6d0fedfa4fe2000ffffffff4a00
                              2022-08-01 09:13:22.624  - debug: enocean.0 (2186136) Message for ID fedfa4fe has been received. It was repeated 0 times.
                              Hier noch das log vom Adpaterstart mit der Info zum USB Adapter:
                              info: enocean.0 (2193870) {"BaseID":"ff92c880","Frequency":"868.3 Mhz","Protocol":"ERP1","AppVersion":"2.15.0.0","ApiVersion":"2.6.9.0","ChipID":"051f2591","ChipVersion":"454f0103","AppDescription":"GATEWAYCTRL"}
                              Habe den als Gerät Hoppe Secusignal zugefügt.
                              Ist das jetzt ein Fehler vom Griff, habe ich was falsch gemacht oder liegt es am Adapter?
                              Kann ich noch weitere Infos liefern?
                              • Jey Cee
                                Sieht aus als wäre das vom Griff, laut den Telegrammen wird Geschlossen nie übermittelt.
                                Das kann aber auch daran liegen wie du den Griff bedienst. Das drehen des Griffs sollte flüssig sein.
                                Wenn sich das Fenster schwer schließen lässt könnte es sein das der Schwung nicht ausreicht um die nötige Energie auf zu bringen damit das Telegram gesendet wird.
                                In dem Fall wäre es ratsam die Mechanik zu Schmieren und bei bedarf das Fenster neu einstellen (lassen).
                                • wendy2702
                                  @jey-cee Der Griff liegt noch vor mir. Am Fenster kann es nicht liegen.
                                  Habe den auch schon so oft gedreht und zumindest jedesmal einen Eintrag im Log bekommen, die Objekte werden dann auch immer mit Zeitstempel aktualisiert.
                                  Lediglich den "Closed" Status bekomme ich nie zu sehen.
                                  • Jey Cee
                                    Dann montiere ihn mal und Teste es dann.
                                    • wendy2702
                                      @jey-cee Das hat leider nichts geändert.
                                      Hast du noch eine Idee?
                                      • Jey Cee
                                        Nein sonst fällt mir gerade nichts mehr ein.
                                        • wendy2702
                                          @jey-cee OK.
                                          Jetzt zeigt er es an. Habe ihn nach einem Hinweis im Netz mal 3-4 mal im Kreis gedreht und quasi alle möglichkeiten hintereinander durch geacktert. Dann das gleiche in die andere Richtung und plötzlich:
                                          Mal gucken wie lange das teure Teil funktioniert.
                                          JackDaniel 1 Reply Last reply Reply Quote 0
                                          • JackDaniel
                                            JackDaniel @wendy2702 last edited by
                                            bei mir 6 stk schon seit jahren sehr zuverlässig
                                            eltako fgw14-usb enocean adapter
                                            8027
