    3. Einsteigerfragen
    4. Zigbee Netzwerk Aufbau
    • Hot-Air-Balloon
      Hot-Air-Balloon @Thomas Braun last edited by
      Danke !
      Jetzt sieht es so aus:
        Thomas Braun Most Active @Hot-Air-Balloon last edited by
        @hot-air-balloon
        Bitte keine Screenshots aus der Konsole.
        Als Text (in CodeTags eingebettet) hier rein kopieren.
        5c424217-50fa-4d46-b362-b4381e24bdda-image.png ```
        code_text
        Hot-Air-Balloon 1 Reply Last reply Reply Quote 0
        • Hot-Air-Balloon
          Verstanden
          host.ioBroker
          	2022-07-13 12:02:12.568	info	Restart adapter system.adapter.zigbee.0 because enabled
          host.ioBroker
          	2022-07-13 12:02:12.568	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          host.ioBroker
          	2022-07-13 12:02:12.568	error	Caught by controller[1]: at processImmediate (node:internal/timers:466:21)
          host.ioBroker
          	2022-07-13 12:02:12.568	error	Caught by controller[1]: at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:322:37)
          host.ioBroker
          	2022-07-13 12:02:12.568	error	Caught by controller[1]: at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5824:34)
          host.ioBroker
          	2022-07-13 12:02:12.567	error	Caught by controller[1]: at Zigbee.emit (node:domain:475:12)
          host.ioBroker
          	2022-07-13 12:02:12.567	error	Caught by controller[1]: at Zigbee.emit (node:events:539:35)
          host.ioBroker
          	2022-07-13 12:02:12.567	error	Caught by controller[1]: at Commands.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:76:30)
          host.ioBroker
          	2022-07-13 12:02:12.567	error	Caught by controller[1]: at Commands.getChannels (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:455:52)
          host.ioBroker
          	2022-07-13 12:02:12.567	error	Caught by controller[1]: at ZigbeeController.getChannelsEnergy (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:935:54)
          host.ioBroker
          	2022-07-13 12:02:12.567	error	Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'waitFor')
          host.ioBroker
          	2022-07-13 12:02:12.566	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
          zigbee.0
          	2022-07-13 12:02:11.947	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
          zigbee.0
          	2022-07-13 12:02:11.945	info	terminating
          zigbee.0
          	2022-07-13 12:02:11.465	info	Zigbee: disabling joining new devices.
          zigbee.0
          	2022-07-13 12:02:11.444	info	cleaned everything up...
          zigbee.0
          	2022-07-13 12:02:11.411	error	Cannot read properties of undefined (reading 'waitFor')
          zigbee.0
          	2022-07-13 12:02:11.410	error	TypeError: Cannot read properties of undefined (reading 'waitFor') at ZigbeeController.getChannelsEnergy (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:935:54) at Commands.getChannels (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:455:52) at Commands.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:76:30) at Zigbee.emit (node:events:539:35) at Zigbee.emit (node:domain:475:12) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5824:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:322:37) at processImmediate (node:internal/timers:466:21)
          zigbee.0
          	2022-07-13 12:02:11.255	error	unhandled promise rejection: Cannot read properties of undefined (reading 'waitFor')
          zigbee.0
          	2022-07-13 12:02:11.255	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          Die Meldung bekomme ich jetzt, wenn ich nach einem Netzwerk scanne.
            @hot-air-balloon
            Du hast gesehen, dass node und npm noch im falschen Pfad ist und das korrigiert?
            • Hot-Air-Balloon
              @thomas-braun Ehrlich gesagt nicht. Wie gesagt, ich bin auf dem Gebiet hier ein blutiger Anfänger.
              Schade, dass das install bash das nicht direkt sauber konfiguriert.
                Thomas Braun Most Active @Hot-Air-Balloon last edited by Thomas Braun
                @hot-air-balloon
                Macht es. Aber es kann natürlich die über einen anderen Installationsweg ins System gebügelte Installation nicht rauskratzen. Das mußte du schon selber wieder reparieren.
                • Hot-Air-Balloon
                  Hot-Air-Balloon @Thomas Braun last edited by Hot-Air-Balloon
                  Also meine ioBroker Installation sah wie folgt aus:
                  Raspberry OS auf die SD Karte schreiben und den PI damit starten. Pi Updaten und dann die ioBroker Install bash ausführen. Mehr habe ich nicht gemacht, alles was auf dem Pi läuft ist entweder teil der standard Installation oder kommt von der ioBroker Installation.
                  Was ist deine Empfehlung, wie ziehe ich das grade ? Wie gesagt ich habe mich noch nie mit node beschäftigt und was ich bislang im Internet gefunden habe, schien ja alles falsch zu sein. Dein Anleitung zeigt leider keine saubere Deinstallation, dann wäre ich danach noch mal von vorne angefangen.
                  sudo apt-get purge -y nodejs
                  Ich habs mal so entfernt und deine Anleitung gefolgt, trotzdem landet die installation im local Ordner und nicht im bin
                    @hot-air-balloon sagte in Zigbee Netzwerk Aufbau:
                    sudo npm install -g n
                    ausgeführt und dann:
                    sudo n stable
                    Das ist NICHT Teil der Standardinstallation, das hast du weiß der Geier woher. Das steht in keinem unserer HowTos zu nodeJS drin.
                    Da kommen aber die Installationen in /use/local/bin her. Also bitte nicht behaupten, man habe eine Standardinstallation.
                    Wie man die los wird steht auch in meinem How to drin. Im zweiten Teil, falls du bis dort nicht gelesen hast.
                    • Hot-Air-Balloon
                      @thomas-braun said in Zigbee Netzwerk Aufbau:
                      sudo n stable
                      Also .... ich habe mein ioBroker wie in dem posting gerade beschrieben installiert. Darauf bezog sich die Aussage mit der Standard Installation. Nach deiner Aussage:
                      @hot-air-balloon
                      Sehr lange dauert das, weil du vermutlich nicht die aktuell empfohlene nodejs/npm Versionen installiert hast. Mit nodejs16 sollte das schneller gehen.
                      habe ich die von dir gerade geqoteten Befehle ausgeführt. Davor war aber schon ein Node 14 installiert... lange rede... was kann ich also machen und kann mir dabei einer helfen?
                        @hot-air-balloon
                        Wie schon gesagt: Es steht alles in meinem How to drin.
                        • Hot-Air-Balloon
                          Danke, ich denke ich habe es hinbekommen:
                          pi@ioBroker:~ $ uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                          aarch64
                          /usr/bin/nodejs
                          /usr/bin/node
                          /usr/bin/npm
                          v16.16.0
                          v16.16.0
                          8.11.0
                          pi
                          /home/pi
                          Hit:1 http://deb.debian.org/debian bullseye InRelease
                          Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                          Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                          Hit:4 http://phoscon.de/apt/deconz bullseye InRelease
                          Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease
                          Hit:6 https://deb.nodesource.com/node_16.x bullseye InRelease
                          Reading package lists... Done
                          Building dependency tree... Done
                          All packages are up to date.
                          nodejs:
                            Installed: 16.16.0-deb-1nodesource1
                            Candidate: 16.16.0-deb-1nodesource1
                            Version table:
                           *** 16.16.0-deb-1nodesource1 500
                                  500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
                                  100 /var/lib/dpkg/status
                               12.22.12~dfsg-1~deb11u1 500
                                  500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                               12.22.5~dfsg-2~11u1 500
                                  500 http://deb.debian.org/debian bullseye/main arm64 Packages
                          Also Jetzt zuerst den normalen Zigbee Adapter installieren, dann den von GIT ?
                            gu kannst den direkt von git nehmen
                            • Hot-Air-Balloon
                              Hot-Air-Balloon @arteck last edited by
                              @arteck Danke, das habe ich jetzt gemacht, der bringt aber keine Instanz und auch kein Eintrag im Menü mit.
                              $ iobroker url ioBroker/ioBroker.zigbee --host ioBroker
                              install ioBroker/ioBroker.zigbee
                              NPM version: 8.11.0
                              Installing ioBroker/ioBroker.zigbee... (System call)
                              added 44 packages in 31s60 packages are looking for funding run `npm fund` for details
                              upload [311] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/adapter-settings.js adapter-settings.js application/javascript
                              upload [300] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Bitron_AV201021A.png img/Bitron_AV201021A.png image/png
                              upload [250] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/bitron_motion.png img/bitron_motion.png image/png
                              upload [200] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/hive.png img/hive.png image/png
                              upload [150] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/lh_32Zb.png img/lh_32Zb.png image/png
                              upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_amaze.png img/philips_amaze.png image/png
                              upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_ambiance.png img/philips_hue_ambiance.png image/png
                              upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_e27_ambiance.png img/philips_hue_e27_ambiance.png image/png
                              upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_ltc021.png img/philips_hue_ltc021.png image/png
                              upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/plug.png img/plug.png image/png
                              upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/sensor_philipshue.png img/sensor_philipshue.png image/png
                              upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/smartthings_motion.png img/smartthings_motion.png image/png
                              upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ts0203.png img/ts0203.png image/png
                              upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/tuya_tyzs1l.png img/tuya_tyzs1l.png image/png
                              upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/unavailable.png img/unavailable.png image/png
                              upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/unknown.png img/unknown.png image/png
                              upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/wemo.png img/wemo.png image/png
                              upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/xiaomi_plug_eu.png img/xiaomi_plug_eu.png image/png
                              upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/xiaomi_wireless_switch.png img/xiaomi_wireless_switch.png image/png
                              upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_e27.png img/zbt_e27.png image/png
                              upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_e27_rgbw.png img/zbt_e27_rgbw.png image/png
                              upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_led_panel.png img/zbt_led_panel.png image/png
                              upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_smart_switch.png img/zbt_smart_switch.png image/png
                              upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zemismart_sw2.png img/zemismart_sw2.png image/png
                              upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/index.html index.html text/html
                              upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/index_m.html index_m.html text/html
                              upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/moment.min.js moment.min.js application/javascript
                              upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/shuffle.min.js shuffle.min.js application/javascript
                              upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/tab_m.html tab_m.html text/html
                              upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/vis-network.min.css vis-network.min.css text/css
                              upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/vis-network.min.js vis-network.min.js application/javascript
                              upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/words.js words.js application/javascript
                              upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/zigbee.png zigbee.png image/png
                              upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/zigbee.svg zigbee.svg image/svg+xml
                              Process exited with code 0
                              arteck Thomas Braun 2 Replies Last reply Reply Quote 0
                                arteck Developer Most Active @Hot-Air-Balloon last edited by
                                @hot-air-balloon die insanz musst du selber hinzufügen
                                  Machen git-Installationen nie, die Instanz muss händisch hinzugefügt werden.
                                    arteck Developer Most Active @Thomas Braun last edited by arteck
                                    @thomas-braun sagte in Zigbee Netzwerk Aufbau:
                                    jaja... kam ja von mir. also alles gut..ist ja ne Ausnahme
                                    Thomas Braun Hot-Air-Balloon 2 Replies Last reply Reply Quote 0
                                      Thomas Braun Most Active @arteck last edited by
                                      @arteck sagte in Zigbee Netzwerk Aufbau:
                                      Hab ich gesehen, ich meinter aber das Hinzufügen einer Instanz. Das muss der geneigte git-user halt selber machen.
                                      • Hot-Air-Balloon
                                        @arteck Bevor ich jetzt wieder was ausführe, von dem ich keine Ahnung habe aber meine es hört sich gut an..
                                        cd /opt/iobroker
                                        sudo iobroker stop
                                        sudo iobroker add Zigbee
                                        sudo iobroker start
                                        Ist das so richtig ?
                                          @hot-air-balloon
                                          Nein, NIE NIE NIE NIEMALS iobroker mit sudo anpacken. NIE.
                                          Instanz z. B. über die GUI:
                                          • Hot-Air-Balloon
                                            @thomas-braun Wo finde ich denn das ? Ich habe trotz suchen in allen Bereichen die Option zum hinzufügen von Instanzen nicht gefunden.
                                            Nur halt auf dem Adapter, wenn eine instanz schon installiert ist.
                                            7546
