    4. Test Adapter fb-checkpresence v1.1.x
    • afuerhoff
      afuerhoff Developer @Garfonso last edited by afuerhoff
      @Garfonso
      Hallo, er wird selber wieder neu starten. Ist in der nächsten Version drin.
      • Diginix
        Diginix @afuerhoff last edited by Diginix
        @afuerhoff Konnte heute die GIT Version testen.
        devicelist:
            "List":
                "Item": [
                    "Index": "67",
                    "IPAddress": "192.168.179.5",
                    "MACAddress": "08:C5:E1:52:4F:05",
                    "Active": "1",
                    "HostName": "Samsung-S9",
                    "InterfaceType": "802.11",
                    "X_AVM-DE_Port": "0",
                    "X_AVM-DE_Speed": "0",
                    "X_AVM-DE_UpdateAvailable": "0",
                    "X_AVM-DE_UpdateSuccessful": "unknown",
                    "X_AVM-DE_InfoURL": "",
                    "X_AVM-DE_Model": "",
                    "X_AVM-DE_URL": "",
                    "X_AVM-DE_Guest": "1",
                    "X_AVM-DE_VPN": "0",
                    "X_AVM-DE_WANAccess": "granted",
                    "X_AVM-DE_Disallow": "0"
                    "Index": "112",
                    "MACAddress": "48:51:B7:17:9F:17",
                    "Active": "1",
                    "HostName": "deichnb0190",
                    "X_AVM-DE_URL": "",
        devicelist2:
            "status": "new",
            "dp": "fb-devices.Samsung-S9",
            "hn": "Samsung-S9",
            "hnOrg": "Samsung-S9",
            "mac": "5A:96:B1:65:45:72",
            "ip": "192.168.2.120",
            "active": false,
            "data":
                "Index": "66",
                "IPAddress": "192.168.2.120",
                "MACAddress": "5A:96:B1:65:45:72",
                "Active": "0",
                "InterfaceType": "",
                "X_AVM-DE_URL": "",
                "X_AVM-DE_Guest": "0",
            "interfaceType": "",
            "speed": 0,
            "guest": false
            "status": "new",
            "hn": "Samsung-S9",
            "mac": "08:C5:E1:52:4F:05",
            "ip": "192.168.179.5",
            "active": true,
            "data":
                "Index": "67",
                "Active": "1",
                "X_AVM-DE_URL": "",
            "interfaceType": "802.11",
            "speed": 0,
            "guest": true
            "status": "new",
            "dp": "fb-devices.deichnb0190",
            "hn": "deichnb0190",
            "hnOrg": "deichnb0190",
            "mac": "48:51:B7:17:9F:17",
            "active": true,
            "data":
                "Index": "112",
                "Active": "1",
                "X_AVM-DE_URL": "",
            "speed": 0,
            "guest": true
            "status": "unchanged",
            "active": true,
            "data":
                "Index": "112",
                "Active": "1",
                "X_AVM-DE_URL": "",
            "speed": 0,
            "guest": true
        Samsung-S9 ist sonst nie im GästeWLAN, aber für den Test immer als weiteres Gerät und tauch immer nur einmal in den Objekten auf. deichnb0190 ist weiterhin immer zwei mal in den Objekten.
        Bin gespannt ob devicelist2 Aufschluss gibt.
        afuerhoff 1 Reply Last reply Reply Quote 0
        • afuerhoff
          afuerhoff Developer last edited by
          die Version 1.1.18 ist in Kürze im Latest.
          Änderungen:
          • Neuer Datenpunkt für VPN bei den FB-Devices
          • Restart des Adapter wenn ein Cycle Error auftritt
          • afuerhoff
            afuerhoff Developer @Diginix last edited by
            @diginix sagte in Test Adapter fb-checkpresence v1.1.x:
            Hallo, ich habe eine neue Version auf Github hochgeladen. Bitte testen, ob das Guest Problem behoben ist.
            Diginix 2 Replies Last reply Reply Quote 1
            • Diginix
              @afuerhoff 1.1.18 von git installiert. Morgen wird das Gastnetz wieder verwendet, dann kann ich testen.
              • Diginix
                @afuerhoff Mit der letzten Git Version sind die doppelte Gastnetz Geräte verschwunden.
                Hast du nun einfach alles doppelte auf unique gefiltert oder die echte Ursache gefunden? 😉
                • afuerhoff
                  @diginix
                  Ich vergleich die Liste der aus der Fritzbox ausgelesenen Devices mit der Liste der angelegten Datenpunkte und generiere daraus eine neue Liste. Neue Devices werden daraus dann z.B angelegt.
                  In der Funktion hatte ich einen Fehler, den ich aber nicht selbst nachstellen konnte. Das muss bei dir eine ganz spezielle Konstellation im Netzwerk gewesen sein. Der Fehler ist schon seit etlichen Versionen drin und keinem aufgefallen.
                  Danke für Deine Tests🙂
                  • afuerhoff
                    die Version 1.1.19 ist in Kürze im Latest.
                    Änderungen:
                    • Fehler doppelte Guest Devices behoben
                    • afuerhoff
                      Hallo, auf Github ist eine Testversion hochgeladen. Mit der kann man die Presence Prüfung manuell anstoßen. Wenn die Funktion aus einem Script gesendet wurde, ist jeder weitere Versuch für 10s gesperrt. Falls erfolgreich, dann kommt true zurück. Wenn gesperrt dann false.
                      Viel Spaß beim Testen. Bin gespannt auf euer Feedback.
                      sendTo('fb-checkpresence.0', 'triggerPresence', {}
                      , function (result) {
                      log(result, 'info');
                        gammler2003 last edited by
                        heute wollte ich die Familienmitglieder ändern. Ich klicke auf "Familienmitglied hinzufügen", das neue Fenster öffnet sich aber es wird nichts angezeigt und ich kann nichts suchen. Ich meine in der Vergangenheit wurden direkt die bekannten Geräte der Fritzbox angezeigt. Auch nach einer Eingabe ändern sich nichts.
                        Mache ich etwas falsch oder ist dieser Fehler bekannt? Falls es sich um einen Fehler handelt, gibt es Ideen wie ich dieses behebe.
                        Vielen Dank vorab für eure Hilfe.
                        afuerhoff Thomas Braun 2 Replies Last reply Reply Quote 0
                        • afuerhoff
                          afuerhoff Developer @gammler2003 last edited by
                          @gammler2003
                          der Adapter lief aber zu dem Zeitpunkt korrekt?
                          Adapter neu gestartet und nachdem grün nochmal versucht?
                            Thomas Braun Most Active @gammler2003 last edited by
                            @gammler2003
                            Welche Version beim Admin? Für Version 6.2.x gibt es ein Issue. Man kann einige Einstellungen in den Adaptern nicht ändern und speichern.
                              gammler2003 @Thomas Braun last edited by
                              @thomas-braun 5.3.8
                              @afuerhoff Adapter lief super und war grün. Neustart (Adapter, ioBroker) hat nichts gebracht. Habe ihn dann komplett deinstalliert und wieder installiert und nun funktioniert es wieder.
                              Vielen Dank euch beiden!
                                earl80 last edited by earl80
                                Hallo, ich habe gestern wegen VPN Wireguard von der 7490 auf die Fritzbox 7590 (5 GHz WIFI) mit der Laborsoftware 7.39 gewechselt. Seither habe ich das Problem, dass ich im Mesh (also im Mesh Repeater Netzwerk mit 2,4 GHz-Band) nicht mehr als presence - egal ob mit MAC, IP, oder Name - angezeigt werde. Wenn ich in der Fritzbox u. nicht im Repeater eingebucht bin, funktioniert es... Bei der 7490 hatte ich solche Probleme noch nicht. Sind Probleme mit der FW u. der 7590 bekannt? Oder liegt es vll. am WiFi Band, da die 7590 5Ghz hat, der Repeater aber nur 2,4Ghz, oder was könnte das Problem sein?
                                • afuerhoff
                                  afuerhoff Developer @earl80 last edited by
                                  @earl80
                                  Sind die Mesh Repeater richtig angemeldet an der Fritzbox?
                                  E 2 Replies Last reply Reply Quote 0
                                    earl80 @afuerhoff last edited by
                                    @afuerhoff Ich denke ja.
                                    Ich habe heute auch den neuen Repeater Fritz 1200 bekommen und eingebunden, weil ich dachte/hoffte, dass es an den unterschiedlichen WLAN Frequenzen liegt. Aber im Mesh werde ich leider nicht als Presence angezeigt...
                                      earl80 @afuerhoff last edited by earl80
                                      @afuerhoff Mir ist gerade aufgefallen, dass mit dem neuen Repeater die Anzahl der Geräte bei Family Members stimmt. So passt es also nur bei den eigentlichen Namen nicht. Jetzt kann ich die Skripte anpassen, kurios ist es dennoch...
                                      • afuerhoff
                                        Hallo, mir ist gerade aufgefallen, dass beim Drücken des Buttons "Familienmitglieder hinzufügen" die in der Tabelle vorhandenen Familienmitglieder nicht korrekt in der Dialogbox angehakt werden. Dies passiert in Abhängigkeit der Einstellung MAC, IP oder Hostname.
                                        Ebenfalls gibt es wohl ein Problem, dass die Dialogbox nicht korrekt angezeigt werden soll.
                                        Es taucht dort ein doppelter Header auf.
                                        Kann das einer von euch nachvollziehen?
                                        Danke im Voraus für Rückmeldungen.
                                        ? Phantomkommander 2 Replies Last reply Reply Quote 0
                                          A Former User @afuerhoff last edited by
                                          @afuerhoff ja ist bei mir auch:
                                          • Phantomkommander
                                            Phantomkommander @afuerhoff last edited by Phantomkommander
                                            @afuerhoff also bei mir ist alles bestens, keine Anzeigefehler oder so.
                                            Version 1.1.19
                                            avm fb-checkpresence fritzbox tr-064
                                            88
                                            947
                                            260810
