    4. Alexa2 Adapter 3.13/3.14/3.15/3.16/3.17 (Beta)
    • DJMarc75
      DJMarc75 @neolight last edited by
      @neolight bitte komplett mit ein und ausgabe in codetags posten. Bildschnippsel helfen wenig.
      • N
        neolight @Thomas Braun last edited by
        @thomas-braun said in Alexa2 Adapter 3.13/3.14/3.15/3.16/3.17 (Beta):
        @neolight
        Bitte vollständig und in CodeTags.
        @djmarc75 said in Alexa2 Adapter 3.13/3.14/3.15/3.16/3.17 (Beta):
        Sorry, da bin ich überfragt. Geht wie?
          Homoran Global Moderator Administrators @neolight last edited by
          @neolight https://forum.iobroker.net/topic/51555/hinweise-für-gute-forenbeiträge/1
          • N
            Linux iobroker 5.10.17-v7l+ #1403 SMP Mon Feb 22 11:33:35 GMT 2021 armv7l
            The programs included with the Debian GNU/Linux system are free software;
            the exact distribution terms for each program are described in the
            individual files in /usr/share/doc/*/copyright.
            Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
            permitted by applicable law.
            Last login: Thu Jul 14 19:01:51 2022 from 192.168.178.21
            pi@iobroker:~ $ iobroker update
            Used repository: stable
            Adapter    "admin"        : 5.3.8    , installed 5.3.8
            Adapter    "alexa2"       : 3.11.2   , installed 3.17.4
            Adapter    "backitup"     : 2.4.9    , installed 2.4.9
            Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
            Adapter    "cloud"        : 4.1.1    , installed 4.1.1
            Adapter    "device-reminder": 1.2.9  , installed 1.2.9
            Adapter    "devices"      : 1.0.12   , installed 1.0.12
            Adapter    "discovery"    : 3.0.3    , installed 3.0.3
            Adapter    "fritzdect"    : 2.2.3    , installed 2.2.3
            Adapter    "ham"          : 4.0.2    , installed 4.0.2
            Adapter    "history"      : 1.11.1   , installed 1.11.1
            Adapter    "influxdb"     : 2.6.3    , installed 2.6.3
            Adapter    "info"         : 1.9.19   , installed 1.9.19
            Adapter    "iot"          : 1.11.4   , installed 1.11.4
            Adapter    "javascript"   : 5.7.0    , installed 5.7.0
            Adapter    "mihome"       : 1.4.0    , installed 1.4.0
            Adapter    "mihome-vacuum": 3.4.2    , installed 3.4.2
            Adapter    "ping"         : 1.5.3    , installed 1.5.3
            Adapter    "shelly"       : 5.3.2    , installed 5.3.2
            Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
            Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
            Adapter    "vis"          : 1.4.15   , installed 1.4.15
            Adapter    "whatsapp-cmb" : 0.2.2    , installed 0.2.2
            Adapter    "wled"         : 0.6.7    , installed 0.6.7
            Adapter    "worx"         : 1.6.6    , installed 1.6.6
            Adapter    "yeelight-2"   : 1.1.2    , installed 1.1.2
            pi@iobroker:~ $ iobroker update -i
            pi@iobroker:~ $ iobroker upgrade alexa2 --debug
            Adapter "alexa2"         is up to date.
            pi@iobroker:~ $ Linux iobroker 5.10.17-v7l+ #1403 SMP Mon Feb 22 11:33:35 GMT 2021 armv7l
            Adapter    "mihome"       : 1.4.0    , installed 1-bash: Linux: command not found
            .4.0
            pi@iobroker:~ $
            • Dr. Bakterius
              Dr. Bakterius Most Active @neolight last edited by
              @neolight Klar, du bist im stable-Zweig und nicht in beta. Lass es einfach so und warte bis der Adapter als stabil eingestuft und freigegeben wird. Dann siehst du auch wenn er zum Updaten bereit ist.
              • N
                neolight @Dr. Bakterius last edited by
                @dr-bakterius
                Ah, okay. Hab ich jetzt auch gesehen.
                Macht es Sinn, auf Beta zu gehen? Wenn ja, wie?
                • Negalein
                  @apollon77
                  bin gerade auf 3.17.5 gegangen.
                  Trotz Intervalle von >60, bekomm ich Meldungen, dass die zu klein sind.
                  alexa2.0
                  2022-07-14 19:26:24.670	info	Alexa-Push-Connection (macDms = true) established. Disable Polling
                  alexa2.0
                  2022-07-14 19:26:21.109	info	Update SmartHome Devices Interval is too low, set to 322s
                  alexa2.0
                  2022-07-14 19:26:20.871	info	starting. Version 3.17.5 in /opt/iobroker/node_modules/iobroker.alexa2, node: v16.15.1, js-controller: 4.0.23
                  alexa2.0
                  2022-07-14 19:26:16.620	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  alexa2.0
                  2022-07-14 19:26:16.619	info	terminating
                  alexa2.0
                  2022-07-14 19:26:16.618	info	Got terminate signal TERMINATE_YOURSELF
                  alexa2.0
                  2022-07-14 19:26:02.354	info	Subscribing to states...
                  alexa2.0
                  2022-07-14 19:25:29.227	info	Alexa-Push-Connection (macDms = true) established. Disable Polling
                  alexa2.0
                  2022-07-14 19:25:25.601	info	Update SmartHome Devices Interval is too low, set to 356s
                  alexa2.0
                  2022-07-14 19:25:25.381	info	starting. Version 3.17.5 in /opt/iobroker/node_modules/iobroker.alexa2, node: v16.15.1, js-controller: 4.0.23
                  • ESP8266
                    ESP8266 @Negalein last edited by ESP8266
                    @negalein , 300 sec oder > sollten es sein.
                    • Negalein
                      Negalein Global Moderator @ESP8266 last edited by
                      @esp8266 sagte in Alexa2 Adapter 3.13/3.14/3.15/3.16/3.17 (Beta):
                      Danke, dann ist es hier etwas missverständlich beschrieben.
                      ESP8266 apollon77 2 Replies Last reply Reply Quote 0
                      • ESP8266
                        @negalein sagte in Alexa2 Adapter 3.13/3.14/3.15/3.16/3.17 (Beta):
                        @apollon77 sagte in Alexa2 Adapter 3.13/3.14/3.15/3.16/3.17 (Beta):
                        Eine 3.17.5 wird bald kommen. Diese setzt das minimum für das Smart-Home-Query-Interval auf 5 Minuten und optimiert noch eine Weitere Sache, um weiter zu unterstützen das die Requests weniger werden. Wer Smart Home Devices synchronisiert und ein Intervall != 0 nutzt bitte installieren
                          apollon77 @Negalein last edited by
                          @negalein ja da hab ich wohl vergessen den Text anzupassen ;-( kommt in nächste Version. 5 min ist das aktuelle - wenn man Smart devices braucht!! Sonst aus lasse
                          Yoda padrino 2 Replies Last reply Reply Quote 1
                          • Yoda
                            Yoda @apollon77 last edited by
                            @apollon77
                            seit Heute habe ich in meiner Adapterversion 3.11.2 ebenfalls keine Hardware mehr unter Smart Home Device.
                            Da scheint Amazon ja wieder was dolles gemacht zu haben 😞
                            Ich Nutze 15 Alexa Steckdosen die ich so Aktuell nicht mehr steuern kann.
                            Der Alexa Skill wurde von mir einmal Deaktiviert und neu mit Iobroker verbunden.
                            Adapter Neustart und Geräte suche, alles vergebens.
                            Ich habe grade von neuen Adapter Versionen gelesen,
                            so wie ich verstehe gibt es aber noch keine Lösung oder?
                            Dr. Bakterius apollon77 2 Replies Last reply Reply Quote 0
                            • Dr. Bakterius
                              @neolight sagte in Alexa2 Adapter 3.13/3.14/3.15/3.16/3.17 (Beta):
                              Wenn du nicht weißt wie das geht, lass es lieber bleiben. Beta-Versionen können noch Fehler enthalten (wie man aktuell gesehen hat) und wenn du dir dann nicht zu helfen weißt, hast du ein Problem.
                              • Dr. Bakterius
                                Dr. Bakterius Most Active @Yoda last edited by Dr. Bakterius
                                @yoda sagte in Alexa2 Adapter 3.13/3.14/3.15/3.16/3.17 (Beta):
                                Geht mir auch so. Da kann man wohl nur abwarten und hoffen das Amazon die Sperre bald wieder aufhebt... (siehe auch https://forum.iobroker.net/topic/56347/alexa2-smarthome-geräte-aktuell-pot-ohne-funktion)
                                  apollon77 @Yoda last edited by apollon77
                                  naja der Ehrlichkeit halber habe ICH was tolles gemacht ... Amazon hat erst einmal nur reagiert um Ihre Systeme und Kunden (und Skill Betreiber) zu schützen ... Der Ehrlichkeit halber ... ich hätte nichts anderes getan wenn es mein System gewesen wäre.
                                  Also der geht leider voll auf meine Kappe und kann nicht genug Sorry dafür sagen ... Und ja jetzt hoffen das die User die noch auf einer der Kaputten Versionen sind schnellstmöglich updaten damit es wieder besser wird für alle.
                                  Yoda 1 Reply Last reply Reply Quote 3
                                  • Yoda
                                    @apollon77 Danke für die Info!
                                    Schon mal gut zu wissen das es kein User / Lokales Problem ist.
                                    Ich stehe aber grade auf der Leitung, was meinst du mit:
                                    "Und ja jetzt hoffen das die User die noch auf einer der Kaputten Versionen sind schnellstmöglich updaten damit es wieder besser wird für alle"
                                    Sollten die betroffenen User doch ein Adapterupdate auf Version .... machen?
                                      @yoda die User die eine beta Version aus dem Versionsbereich 3.14.0 bis einschließlich 3.17.3 haben müssen schnellstens auf 3.17.4 oder höher oder zurück auf eine Version kleiner 3.14 … darum geht es. Nur der genannte Versionsbereich ist „böse“ und verursacht die zu vielen calls an die Amazon Systeme. Je weniger User mit diesen buggy Versionen „spammen“ umso mehr sollte es für alle anderen wieder gehen.
                                      DJMarc75 1 Reply Last reply Reply Quote 1
                                      • DJMarc75
                                        DJMarc75 @apollon77 last edited by DJMarc75
                                        @apollon77 kurze Zwischenfrage: empfiehlt es sich die SHD-Abfrage in der 3.17.5 zu aktivieren bevor Amazon da wieder "besänftigt" ist oder lieber paar Tage warten ?
                                          apollon77 @DJMarc75 last edited by apollon77
                                          @djmarc75 die 5 Minuten in der 3.17.5 sind mit Amazon so abgesprochen und wird Vorauss alles gehen … wenn mal die „Spammer“ weg sind.
                                          Edit: die User die da beim interval etwas >0 stehen haben sind nicht das Problem. Der Bug passiert wenn man als interval 0 (= deaktiviert .. was default ist) stehen hat … dann macht er leider doch requests und sehr viele 😞
                                          ESP8266 1 Reply Last reply Reply Quote 1
                                          • ESP8266
                                            ESP8266 @apollon77 last edited by
                                            @apollon77 , jetzt bin ich ein wenig confused. Ich habe die 3.17.4 drauf und den Interval auf 0.
                                            Also macht er jetzt requests oder nicht? Ich brauche das normal nicht....
                                            apollon77 D 2 Replies Last reply Reply Quote 0
                                            391
                                            57230
