    4. [hofftl. gelöst]auch code 25 bei adapter installation
      Thomas Braun Most Active @liv-in-sky last edited by
      @liv-in-sky
      Für meinen Geschmack habe ich im Moment zu viele git-Installarionen drin, aber am Ende sollte es irgendwie so aussehen:
      Last login: Sat Jul 16 09:34:54 2022 from 100.75.198.95
      Wi-Fi is currently blocked by rfkill.
      Use raspi-config to set the country before use.
      echad@chet:~ $ cd /opt/iobroker/
      echad@chet:/opt/iobroker $ npm ls
      iobroker.inst@3.0.0 /opt/iobroker
      ├── iobroker.admin@6.2.1
      ├── iobroker.alexa2@3.17.5
      ├── iobroker.alias-manager@1.2.6
      ├── iobroker.backitup@2.4.10
      ├── iobroker.ble@0.13.0
      ├── iobroker.echarts@1.0.12
      ├── iobroker.followthesun@0.3.9
      ├── iobroker.govee@0.0.5 (git+ssh://git@github.com/nbuenger/ioBroker.govee.git#0d983c49135b87ac2f88f9d832a6d632c4889606)
      ├── iobroker.history@2.1.7
      ├── iobroker.ical@1.13.1
      ├── iobroker.info@1.9.19
      ├── iobroker.iot@1.11.8
      ├── iobroker.javascript@5.8.10
      ├── iobroker.js-controller@4.0.23
      ├── iobroker.midea@0.1.0 (git+ssh://git@github.com/TA2k/ioBroker.midea.git#28ab1b8076a91e8276146a51e0ee27b16a7b2994)
      ├── iobroker.mihome-vacuum@3.6.0
      ├── iobroker.mihome@1.4.0
      ├── iobroker.miio@0.0.13
      ├── iobroker.nina@0.0.25
      ├── iobroker.nuki-extended@2.6.5
      ├── iobroker.parcel@0.0.20 (git+ssh://git@github.com/TA2k/ioBroker.parcel.git#07490c41c69761db66e5f5023bc737fbb24ac9e2)
      ├── iobroker.pi-hole@1.3.4
      ├── iobroker.rpi2@1.3.2
      ├── iobroker.sainlogic@0.9.0
      ├── iobroker.samsung@0.5.11 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.samsung.git#70366ba038c0f5092731db63f09d16db8eb56e65)
      ├── iobroker.simple-api@2.7.0
      ├── iobroker.socketio@6.1.8
      ├── iobroker.switchbot-hub@0.1.2 (git+ssh://git@github.com/DrozmotiX/ioBroker.switchbot-hub.git#de8c1ad97edafedb16cbbb2c6dc14b032848df8e)
      ├── iobroker.tado@0.3.15
      ├── iobroker.tankerkoenig@2.1.1
      ├── iobroker.tr-064@4.2.16
      ├── iobroker.tradfri@3.1.3
      ├── iobroker.trashschedule@2.0.3
      ├── iobroker.web@5.2.4
      ├── iobroker.whatsapp-cmb@0.2.2
      ├── iobroker.ws@2.1.3
      └── iobroker.zigbee@1.7.5
        crunchip Forum Testing Most Active @liv-in-sky last edited by
        @liv-in-sky beim zurück kopieren vom iobroker backup ins /opt/iobroker/backups , darauf achten das es dem iobroker gehört und nicht root😉
        liv-in-sky 1 Reply Last reply Reply Quote 1
          liv-in-sky @crunchip last edited by
          @crunchip welche node version wird eigentlich installiert, wenn man den iobroker installiert
          @Homoran wollte mir den install befehl von der doku kopieren - kann keine seite in der doku öffnen ? weißt du warum ?
            @liv-in-sky sagte in auch code 25 bei adapter installation:
            Immer die gerade empfohlene. Also node16.
              crunchip Forum Testing Most Active last edited by crunchip
              geht mir genauso, muss oben rechts zwischen den Reitern hin und her klicken und wieder auf die Doku, irgendwann öffnet sich dann die Seite
              bzw im Reiter auf Blog und dann wieder auf Doku
              welche node version
              automatisch 16, daher ja die Vorgehensweise wie beschrieben
                @crunchip guter tipp - jetzt sehe ich es auch - das steht ja auch ...setup_8....
                noch 'ne frage - wegen zigbee - muss ich da etwas besonderes machen, damit das wieder funktioniert
                  @crunchip
                  und nodejs mit
                  sudo apt remove node*
                  deinstallieren
                    nein, Voraussetzung, das du zigbee per backitup sicherst und ja ebenfalls wieder zurück spielst wenn der iobroker selbst, fertig ist
                      @liv-in-sky hatte es mit den alten Befehlen
                      apt-get --purge remove node
                      apt-get --purge remove nodejs
                      apt-get autoremove
                      gemacht
                        @crunchip muss jetzt erstmal pause machen - werd vielleicht heute nachmittag das ganze probieren
                        danke erstmal - das war eine große hilfe für mich
                        crunchip 1 Reply Last reply Reply Quote 1
                          @liv-in-sky und nicht vergessen, vis vor dem backup zurück spielen zu installieren(hatte ich nämlich)
                          musste deshalb zuerst mit der Version auf 1.4.0 zurück und dann anschliessend wieder auf die aktuelle, siehe https://github.com/ioBroker/ioBroker.vis/issues/502
                          denjo1982 created this issue in ioBroker/ioBroker.vis
                          closed VIS lässt sich nicht installieren #502
                            Thomas Braun Most Active last edited by
                            @crunchip
                            und nodejs mit
                            deinstallieren
                            Ist bei sauberer Installation der Alt-Version nicht erforderlich.
                            Und bei unsauberer Installation wäre es damit auch nicht getan.
                            • mickym
                              Schon mal geschaut, ob in dem Verzeichnis so eine „alte“ package-lock.json Datei rumfliegt. Die mal wo anders hin verschieben und dann ggf. Zu löschen bewirkt Wunder.
                                crunchip Forum Testing Most Active @mickym last edited by
                                @mickym das hatte ich auch schon durch
                                  @Thomas-Braun , @crunchip
                                  das ist zum verzweifeln - habe nun alles ( 2mal ) mit der lösung von @crunchip aufgesetzt. also ein "jungfräuliches system"
                                  als erstes war das vis problem aufgefallen - konnte keine edits in der vis durchführen - kam immer "no connection". durch die umstellung auf ws im web-adapter scheint das wieder zu funktionieren
                                  nach dem restore tritt nun folgendes auf: ich konnte z.b. den alexa adapter starten und auch updaten !! auch andere adapter konnten upgedatet werden. am ende startete ich die javascript instanzen. dort wurden die zusätzlichen npm module teilweise nicht geladen z.b. mail-listener4 - die scripte damit funktioneren auch nicht mehr - ist aber nicht sooo tragisch. was aber heute ist: nach dem neustart des systems, kommen die fehler 25 wieder bei jedem update versuch ! die fehler sind diesmal:
                                  Would you like to upgrade parcel from @0.0.18 to @0.0.20 now? [(y)es, (n)o]: y
                                  Update parcel from @0.0.18 to @0.0.20
                                  NPM version: 8.11.0
                                  Installing iobroker.parcel@0.0.20... (System call)
                                  npm ERR! code ENOTEMPTY
                                  npm ERR! syscall rename
                                  npm ERR! path /opt/iobroker/node_modules/iobroker.javascript/node_modules/deep-equal
                                  npm ERR! dest /opt/iobroker/node_modules/iobroker.javascript/node_modules/.deep-equal-DAyqMSDk
                                  npm ERR! errno -39
                                  npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript/node_modules/deep-equal' -> '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.deep-equal-DAyqMSDk'
                                  npm ERR!     /home/iobroker/.npm/_logs/2022-07-17T05_15_42_864Z-debug-0.log
                                  host.iobroker59 Cannot install iobroker.parcel@0.0.20: 217
                                  also jetzt sind die fehler wohl mit den zusätzlichen npm modulen unter der javascript instanz zu finden
                                    liv-in-sky last edited by liv-in-sky
                                    @AlCalzone
                                    ich schreibe dich an, weil du vielleicht eine idee haben könntest - ich habe im ordner /opt/iobroker/node_modules/iobroker.javascript/node_modules ein "npm ls" durchgeführt - da kommt ein fehler - siehe post vorher.
                                    der output von npm ls ist dieser und dort wirst du erwähnt beim ersten error:
                                    npm ls
                                    iobroker.javascript@5.7.0 /opt/iobroker/node_modules/iobroker.javascript
                                    ├── UNMET DEPENDENCY @alcalzone/release-script-plugin-iobroker@^3.5.9
                                    ├── UNMET DEPENDENCY @alcalzone/release-script-plugin-license@^3.5.9
                                    ├── UNMET DEPENDENCY @alcalzone/release-script@^3.5.9
                                    ├── @iobroker/adapter-core@2.6.0
                                    ├── @types/iobroker@4.0.4
                                    ├── @types/node@16.11.45
                                    ├── @types/request@2.48.8
                                    ├── UNMET DEPENDENCY alcalzone-shared@^4.0.1
                                    ├── available-typed-arrays@1.0.5 extraneous
                                    ├── axios@0.27.2
                                    ├── basic-ftp@5.0.0
                                    ├── Buffer@0.0.0
                                    ├── UNMET DEPENDENCY chai@^4.3.6
                                    ├── cheerio@1.0.0-rc.12
                                    ├── coffee-compiler@0.3.2
                                    ├── coffee-script@1.12.7
                                    ├── csv-parse@5.3.0
                                    ├── UNMET DEPENDENCY del@^6.0.0
                                    ├── dewpoint@1.0.0
                                    ├── es-abstract@1.20.1 extraneous
                                    ├── es-get-iterator@1.1.2 extraneous
                                    ├── es-to-primitive@1.2.1 extraneous
                                    ├── UNMET DEPENDENCY eslint@^7.32.0
                                    ├── filereader@0.10.3
                                    ├── for-each@0.3.3 extraneous
                                    ├── formidable@2.0.1
                                    ├── fs@0.0.1-security
                                    ├── function.prototype.name@1.1.5 extraneous
                                    ├── functions-have-names@1.2.3 extraneous
                                    ├── get-symbol-description@1.0.0 extraneous
                                    ├── UNMET DEPENDENCY gulp-rename@^2.0.0
                                    ├── UNMET DEPENDENCY gulp-replace@^1.1.3
                                    ├── UNMET DEPENDENCY gulp@^4.0.2
                                    ├── has-bigints@1.0.2 extraneous
                                    ├── has-tostringtag@1.0.0 extraneous
                                    ├── https@1.0.0
                                    ├── internal-slot@1.0.3 extraneous
                                    ├── is-arguments@1.1.1 extraneous
                                    ├── is-bigint@1.0.4 extraneous
                                    ├── is-boolean-object@1.1.2 extraneous
                                    ├── is-callable@1.2.4 extraneous
                                    ├── is-date-object@1.0.5 extraneous
                                    ├── is-map@2.0.2 extraneous
                                    ├── is-negative-zero@2.0.2 extraneous
                                    ├── is-number-object@1.0.7 extraneous
                                    ├── is-regex@1.1.4 extraneous
                                    ├── is-set@2.0.2 extraneous
                                    ├── is-shared-array-buffer@1.0.2 extraneous
                                    ├── is-string@1.0.7 extraneous
                                    ├── is-symbol@1.0.4 extraneous
                                    ├── is-typed-array@1.1.9 extraneous
                                    ├── is-weakmap@2.0.1 extraneous
                                    ├── is-weakref@1.0.2 extraneous
                                    ├── is-weakset@2.0.2 extraneous
                                    ├── jsonata@1.8.6
                                    ├── jszip@3.10.0
                                    ├── mail-listener4@1.1.3
                                    ├── mail-listener6@2.0.3
                                    ├── UNMET DEPENDENCY mocha@^9.2.2
                                    ├── node-inspect@2.0.0
                                    ├── node-schedule@2.1.0
                                    ├── node-wol@0.1.1
                                    ├── num-words-de@1.0.4
                                    ├── object-inspect@1.12.2 extraneous
                                    ├── object-is@1.1.5 extraneous
                                    ├── object.assign@4.1.2 extraneous
                                    ├── pdfkit@0.13.0
                                    ├── regexp.prototype.flags@1.4.3 extraneous
                                    ├── request@2.88.2
                                    ├── rss-parser@3.12.0
                                    ├── semver@7.3.7
                                    ├── sftp-watcher@2.0.5
                                    ├── side-channel@1.0.4 extraneous
                                    ├── socket.io@4.5.1
                                    ├── ssh2shell@2.0.1
                                    ├── string.prototype.trimend@1.0.5 extraneous
                                    ├── string.prototype.trimstart@1.0.5 extraneous
                                    ├── suncalc2@1.8.1
                                    ├── UNMET DEPENDENCY timekeeper@^2.2.0
                                    ├── typescript@4.7.4
                                    ├── unbox-primitive@1.0.2 extraneous
                                    ├── utf8@3.0.0
                                    ├── virtual-tsc@0.6.2
                                    ├── vm2@3.9.10
                                    ├── wake_on_lan@1.0.0
                                    ├── which-boxed-primitive@1.0.2 extraneous
                                    ├── which-collection@1.0.1 extraneous
                                    ├── which-typed-array@1.1.8 extraneous
                                    ├── xml2js@0.4.23
                                    └── xml2json@0.12.0
                                    npm ERR! code ELSPROBLEMS
                                    npm ERR! missing: @alcalzone/release-script-plugin-iobroker@^3.5.9, required by iobroker.javascript@5.7.0
                                    npm ERR! missing: @alcalzone/release-script-plugin-license@^3.5.9, required by iobroker.javascript@5.7.0
                                    npm ERR! missing: @alcalzone/release-script@^3.5.9, required by iobroker.javascript@5.7.0
                                    npm ERR! missing: alcalzone-shared@^4.0.1, required by iobroker.javascript@5.7.0
                                    npm ERR! extraneous: available-typed-arrays@1.0.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/available-typed-arrays
                                    npm ERR! missing: chai@^4.3.6, required by iobroker.javascript@5.7.0
                                    npm ERR! missing: del@^6.0.0, required by iobroker.javascript@5.7.0
                                    npm ERR! extraneous: es-abstract@1.20.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/es-abstract
                                    npm ERR! extraneous: es-get-iterator@1.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/es-get-iterator
                                    npm ERR! extraneous: es-to-primitive@1.2.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/es-to-primitive
                                    npm ERR! missing: eslint@^7.32.0, required by iobroker.javascript@5.7.0
                                    npm ERR! extraneous: for-each@0.3.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/for-each
                                    npm ERR! extraneous: function.prototype.name@1.1.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/function.prototype.name
                                    npm ERR! extraneous: functions-have-names@1.2.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/functions-have-names
                                    npm ERR! extraneous: get-symbol-description@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/get-symbol-description
                                    npm ERR! missing: gulp-rename@^2.0.0, required by iobroker.javascript@5.7.0
                                    npm ERR! missing: gulp-replace@^1.1.3, required by iobroker.javascript@5.7.0
                                    npm ERR! missing: gulp@^4.0.2, required by iobroker.javascript@5.7.0
                                    npm ERR! extraneous: has-bigints@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-bigints
                                    npm ERR! extraneous: has-tostringtag@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-tostringtag
                                    npm ERR! extraneous: internal-slot@1.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/internal-slot
                                    npm ERR! extraneous: is-arguments@1.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-arguments
                                    npm ERR! extraneous: is-bigint@1.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-bigint
                                    npm ERR! extraneous: is-boolean-object@1.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-boolean-object
                                    npm ERR! extraneous: is-callable@1.2.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-callable
                                    npm ERR! extraneous: is-date-object@1.0.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-date-object
                                    npm ERR! extraneous: is-map@2.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-map
                                    npm ERR! extraneous: is-negative-zero@2.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-negative-zero
                                    npm ERR! extraneous: is-number-object@1.0.7 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-number-object
                                    npm ERR! extraneous: is-regex@1.1.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-regex
                                    npm ERR! extraneous: is-set@2.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-set
                                    npm ERR! extraneous: is-shared-array-buffer@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-shared-array-buffer
                                    npm ERR! extraneous: is-string@1.0.7 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-string
                                    npm ERR! extraneous: is-symbol@1.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-symbol
                                    npm ERR! extraneous: is-typed-array@1.1.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-typed-array
                                    npm ERR! extraneous: is-weakmap@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-weakmap
                                    npm ERR! extraneous: is-weakref@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-weakref
                                    npm ERR! extraneous: is-weakset@2.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-weakset
                                    npm ERR! missing: mocha@^9.2.2, required by iobroker.javascript@5.7.0
                                    npm ERR! extraneous: object-inspect@1.12.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-inspect
                                    npm ERR! extraneous: object-is@1.1.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-is
                                    npm ERR! extraneous: object.assign@4.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/object.assign
                                    npm ERR! extraneous: regexp.prototype.flags@1.4.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/regexp.prototype.flags
                                    npm ERR! extraneous: side-channel@1.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/side-channel
                                    npm ERR! extraneous: string.prototype.trimend@1.0.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/string.prototype.trimend
                                    npm ERR! extraneous: string.prototype.trimstart@1.0.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/string.prototype.trimstart
                                    npm ERR! missing: timekeeper@^2.2.0, required by iobroker.javascript@5.7.0
                                    npm ERR! extraneous: unbox-primitive@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/unbox-primitive
                                    npm ERR! extraneous: which-boxed-primitive@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/which-boxed-primitive
                                    npm ERR! extraneous: which-collection@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/which-collection
                                    npm ERR! extraneous: which-typed-array@1.1.8 /opt/iobroker/node_modules/iobroker.javascript/node_modules/which-typed-array
                                    npm ERR!     /home/iobroker/.npm/_logs/2022-07-17T05_32_18_106Z-debug-0.log
                                      apollon77 last edited by
                                      Wir wissen nicht warum npm diese Verzeichnisse nicht wegräumt. Das ist das main Thema. Und passiert auch nicht bei jedem
                                      Bzw immer.
                                      Für mich sieht das nach nem npm Bug aus.
                                        liv-in-sky @apollon77 last edited by
                                        @apollon77 @crunchip @Thomas-Braun @AlCalzone
                                        bin etwas weiter - habe diesmal wieder begonnen, diese angegebenen ordner zu löschen - zum glück waren es diesmal nur 5 oder 6 stück - jetzt konnte ich wieder adapter installieren und auch ein update ausführen
                                          liv-in-sky @apollon77 last edited by liv-in-sky
                                          @apollon77
                                          jetzt muss nur noch amazon die smart-geräte wieder für den adapter bereitstellen, dann sollte wieder alles soweit funktionieren 😞
                                            Ja da bibts aktuell Probleme
                                            Hatte ich auch bemerkt, da nachher ein Update fürn javascript Adapter kam, wurden die die beim update gebaut.
                                            Das kann eigentlich nicht sein, sehr seltsam
                                            code 25
                                            1787
