    5. Lange Ladezeit vom iobroker
      Thomas Braun Most Active @Spidermike last edited by
      @spidermike
      Bitte das puTTY-Fenster aufziehen, damit da nicht diese Spalten in den Zeilen sind. Danke.
        Spidermike @Thomas Braun last edited by
        [So Jul 17 11:03:17 2022] Booting Linux on physical CPU 0x0
        [So Jul 17 11:03:17 2022] Linux version 5.10.92-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1514 SMP Mon Jan 17 17:38:03 GMT 2022
        [So Jul 17 11:03:17 2022] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
        [So Jul 17 11:03:17 2022] CPU: div instructions available: patching division code
        [So Jul 17 11:03:17 2022] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
        [So Jul 17 11:03:17 2022] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.4
        [So Jul 17 11:03:17 2022] random: fast init done
        [So Jul 17 11:03:17 2022] Memory policy: Data cache writealloc
        [So Jul 17 11:03:17 2022] Reserved memory: created CMA memory pool at 0x000000001ac00000, size 320 MiB
        [So Jul 17 11:03:17 2022] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
        [So Jul 17 11:03:17 2022] Zone ranges:
        [So Jul 17 11:03:17 2022]   DMA      [mem 0x0000000000000000-0x000000002fffffff]
        [So Jul 17 11:03:17 2022]   Normal   empty
        [So Jul 17 11:03:17 2022]   HighMem  [mem 0x0000000030000000-0x00000001ffffffff]
        [So Jul 17 11:03:17 2022] Movable zone start for each node
        [So Jul 17 11:03:17 2022] Early memory node ranges
        [So Jul 17 11:03:17 2022]   node   0: [mem 0x0000000000000000-0x000000003b2fffff]
        [So Jul 17 11:03:17 2022]   node   0: [mem 0x0000000040000000-0x00000000fbffffff]
        [So Jul 17 11:03:17 2022]   node   0: [mem 0x0000000100000000-0x00000001ffffffff]
        [So Jul 17 11:03:17 2022] Initmem setup node 0 [mem 0x0000000000000000-0x00000001ffffffff]
        [So Jul 17 11:03:17 2022] On node 0 totalpages: 2061056
        [So Jul 17 11:03:17 2022]   DMA zone: 1728 pages used for memmap
        [So Jul 17 11:03:17 2022]   DMA zone: 0 pages reserved
        [So Jul 17 11:03:17 2022]   DMA zone: 196608 pages, LIFO batch:63
        [So Jul 17 11:03:17 2022]   HighMem zone: 1864448 pages, LIFO batch:63
        [So Jul 17 11:03:17 2022] percpu: Embedded 20 pages/cpu s50828 r8192 d22900 u81920
        [So Jul 17 11:03:17 2022] pcpu-alloc: s50828 r8192 d22900 u81920 alloc=20*4096
        [So Jul 17 11:03:17 2022] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
        [So Jul 17 11:03:17 2022] Built 1 zonelists, mobility grouping on.  Total pages: 2059328
        [So Jul 17 11:03:17 2022] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:FD:BB:CC vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 console=ttyS0,115200 root=PARTUUID=1045efe5-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
        [So Jul 17 11:03:17 2022] Kernel parameter elevator= does not have any effect anymore.
                                  Please use sysfs to set IO scheduler for individual devices.
        [So Jul 17 11:03:17 2022] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
        [So Jul 17 11:03:17 2022] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
        [So Jul 17 11:03:17 2022] mem auto-init: stack:off, heap alloc:off, heap free:off
        [So Jul 17 11:03:17 2022] software IO TLB: mapped [mem 0x0000000012400000-0x0000000016400000] (64MB)
        [So Jul 17 11:03:17 2022] Memory: 7757552K/8244224K available (10240K kernel code, 1366K rwdata, 3196K rodata, 2048K init, 882K bss, 158992K reserved, 327680K cma-reserved, 7457792K highmem)
        [So Jul 17 11:03:17 2022] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
        [So Jul 17 11:03:17 2022] ftrace: allocating 34360 entries in 101 pages
        [So Jul 17 11:03:17 2022] ftrace: allocated 101 pages with 4 groups
        [So Jul 17 11:03:17 2022] rcu: Hierarchical RCU implementation.
        [So Jul 17 11:03:17 2022]       Rude variant of Tasks RCU enabled.
        [So Jul 17 11:03:17 2022]       Tracing variant of Tasks RCU enabled.
        [So Jul 17 11:03:17 2022] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
        [So Jul 17 11:03:17 2022] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
        [So Jul 17 11:03:17 2022] GIC: Using split EOI/Deactivate mode
        [So Jul 17 11:03:17 2022] irq_brcmstb_l2: registered L2 intc (/soc/interrupt-controller@7ef00100, parent irq: 25)
        [So Jul 17 11:03:17 2022] random: get_random_bytes called from start_kernel+0x3c8/0x59c with crng_init=1
        [So Jul 17 11:03:17 2022] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
        [So Jul 17 11:03:17 2022] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
        [So Jul 17 11:03:17 2022] bcm2835: system timer (irq = 26)
        [So Jul 17 11:03:17 2022] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
        [So Jul 17 11:03:17 2022] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
        [So Jul 17 11:03:17 2022] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
        [So Jul 17 11:03:17 2022] Switching to timer-based delay loop, resolution 18ns
        [So Jul 17 11:03:17 2022] Console: colour dummy device 80x30
        [So Jul 17 11:03:17 2022] printk: console [tty1] enabled
        [So Jul 17 11:03:17 2022] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
        [So Jul 17 11:03:17 2022] pid_max: default: 32768 minimum: 301
        [So Jul 17 11:03:17 2022] LSM: Security Framework initializing
        [So Jul 17 11:03:17 2022] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
        [So Jul 17 11:03:17 2022] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
        [So Jul 17 11:03:17 2022] cgroup: Disabling memory control group subsystem
        [So Jul 17 11:03:17 2022] CPU: Testing write buffer coherency: ok
        [So Jul 17 11:03:17 2022] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
        [So Jul 17 11:03:17 2022] Setting up static identity map for 0x200000 - 0x20003c
        [So Jul 17 11:03:17 2022] rcu: Hierarchical SRCU implementation.
        [So Jul 17 11:03:17 2022] smp: Bringing up secondary CPUs ...
        [So Jul 17 11:03:17 2022] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
        [So Jul 17 11:03:17 2022] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
        [So Jul 17 11:03:17 2022] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
        [So Jul 17 11:03:17 2022] smp: Brought up 1 node, 4 CPUs
        [So Jul 17 11:03:17 2022] SMP: Total of 4 processors activated (432.00 BogoMIPS).
        [So Jul 17 11:03:17 2022] CPU: All CPU(s) started in HYP mode.
        [So Jul 17 11:03:17 2022] CPU: Virtualization extensions available.
        [So Jul 17 11:03:17 2022] devtmpfs: initialized
        [So Jul 17 11:03:17 2022] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
        [So Jul 17 11:03:17 2022] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
        [So Jul 17 11:03:17 2022] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
        [So Jul 17 11:03:17 2022] pinctrl core: initialized pinctrl subsystem
        [So Jul 17 11:03:17 2022] NET: Registered protocol family 16
        [So Jul 17 11:03:17 2022] DMA: preallocated 1024 KiB pool for atomic coherent allocations
        [So Jul 17 11:03:17 2022] audit: initializing netlink subsys (disabled)
        [So Jul 17 11:03:17 2022] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
        [So Jul 17 11:03:17 2022] thermal_sys: Registered thermal governor 'step_wise'
        [So Jul 17 11:03:17 2022] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
        [So Jul 17 11:03:17 2022] hw-breakpoint: maximum watchpoint size is 8 bytes.
        [So Jul 17 11:03:17 2022] Serial: AMBA PL011 UART driver
        [So Jul 17 11:03:17 2022] bcm2835-mbox fe00b880.mailbox: mailbox enabled
        [So Jul 17 11:03:17 2022] raspberrypi-firmware soc:firmware: Attached to firmware from 2022-01-20T13:56:48, variant start
        [So Jul 17 11:03:17 2022] raspberrypi-firmware soc:firmware: Firmware hash is bd88f66f8952d34e4e0613a85c7a6d3da49e13e2
        [So Jul 17 11:03:17 2022] Kprobes globally optimized
        [So Jul 17 11:03:17 2022] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
        [So Jul 17 11:03:17 2022] vgaarb: loaded
        [So Jul 17 11:03:17 2022] SCSI subsystem initialized
        [So Jul 17 11:03:17 2022] usbcore: registered new interface driver usbfs
        [So Jul 17 11:03:17 2022] usbcore: registered new interface driver hub
        [So Jul 17 11:03:17 2022] usbcore: registered new device driver usb
        [So Jul 17 11:03:17 2022] usb_phy_generic phy: supply vcc not found, using dummy regulator
        [So Jul 17 11:03:17 2022] clocksource: Switched to clocksource arch_sys_counter
        [So Jul 17 11:03:18 2022] VFS: Disk quotas dquot_6.6.0
        [So Jul 17 11:03:18 2022] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
        [So Jul 17 11:03:18 2022] FS-Cache: Loaded
        [So Jul 17 11:03:18 2022] CacheFiles: Loaded
        [So Jul 17 11:03:18 2022] NET: Registered protocol family 2
        [So Jul 17 11:03:18 2022] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
        [So Jul 17 11:03:18 2022] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
        [So Jul 17 11:03:18 2022] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
        [So Jul 17 11:03:18 2022] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
        [So Jul 17 11:03:18 2022] TCP: Hash tables configured (established 8192 bind 8192)
        [So Jul 17 11:03:18 2022] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
        [So Jul 17 11:03:18 2022] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
        [So Jul 17 11:03:18 2022] NET: Registered protocol family 1
        [So Jul 17 11:03:18 2022] RPC: Registered named UNIX socket transport module.
        [So Jul 17 11:03:18 2022] RPC: Registered udp transport module.
        [So Jul 17 11:03:18 2022] RPC: Registered tcp transport module.
        [So Jul 17 11:03:18 2022] RPC: Registered tcp NFSv4.1 backchannel transport module.
        [So Jul 17 11:03:18 2022] PCI: CLS 0 bytes, default 64
        [So Jul 17 11:03:18 2022] Initialise system trusted keyrings
        [So Jul 17 11:03:18 2022] workingset: timestamp_bits=14 max_order=21 bucket_order=7
        [So Jul 17 11:03:18 2022] zbud: loaded
        [So Jul 17 11:03:18 2022] FS-Cache: Netfs 'nfs' registered for caching
        [So Jul 17 11:03:18 2022] NFS: Registering the id_resolver key type
        [So Jul 17 11:03:18 2022] Key type id_resolver registered
        [So Jul 17 11:03:18 2022] Key type id_legacy registered
        [So Jul 17 11:03:18 2022] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
        [So Jul 17 11:03:18 2022] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
        [So Jul 17 11:03:18 2022] Key type asymmetric registered
        [So Jul 17 11:03:18 2022] Asymmetric key parser 'x509' registered
        [So Jul 17 11:03:18 2022] bounce: pool size: 64 pages
        [So Jul 17 11:03:18 2022] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
        [So Jul 17 11:03:18 2022] io scheduler mq-deadline registered
        [So Jul 17 11:03:18 2022] io scheduler kyber registered
        [So Jul 17 11:03:18 2022] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
        [So Jul 17 11:03:18 2022] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
        [So Jul 17 11:03:18 2022] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0x00c0000000
        [So Jul 17 11:03:18 2022] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000
        [So Jul 17 11:03:18 2022] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
        [So Jul 17 11:03:18 2022] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
        [So Jul 17 11:03:18 2022] pci_bus 0000:00: root bus resource [bus 00-ff]
        [So Jul 17 11:03:18 2022] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
        [So Jul 17 11:03:18 2022] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
        [So Jul 17 11:03:18 2022] pci 0000:00:00.0: PME# supported from D0 D3hot
        [So Jul 17 11:03:18 2022] PCI: bus0: Fast back to back transfers disabled
        [So Jul 17 11:03:18 2022] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
        [So Jul 17 11:03:18 2022] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
        [So Jul 17 11:03:18 2022] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
        [So Jul 17 11:03:18 2022] pci 0000:01:00.0: PME# supported from D0 D3hot
        [So Jul 17 11:03:18 2022] PCI: bus1: Fast back to back transfers disabled
        [So Jul 17 11:03:18 2022] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
        [So Jul 17 11:03:18 2022] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
        [So Jul 17 11:03:18 2022] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
        [So Jul 17 11:03:18 2022] pci 0000:00:00.0: PCI bridge to [bus 01]
        [So Jul 17 11:03:18 2022] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
        [So Jul 17 11:03:18 2022] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
        [So Jul 17 11:03:18 2022] pcieport 0000:00:00.0: PME: Signaling with IRQ 83
        [So Jul 17 11:03:18 2022] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
        [So Jul 17 11:03:18 2022] bcm2835-aux-uart fe215040.serial: there is not valid maps for state default
        [So Jul 17 11:03:18 2022] iproc-rng200 fe104000.rng: hwrng registered
        [So Jul 17 11:03:18 2022] vc-mem: phys_addr:0x00000000 mem_base=0x3eb00000 mem_size:0x3ff00000(1023 MiB)
        [So Jul 17 11:03:18 2022] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
        [So Jul 17 11:03:18 2022] brd: module loaded
        [So Jul 17 11:03:18 2022] loop: module loaded
        [So Jul 17 11:03:18 2022] Loading iSCSI transport class v2.0-870.
        [So Jul 17 11:03:18 2022] libphy: Fixed MDIO Bus: probed
        [So Jul 17 11:03:18 2022] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
        [So Jul 17 11:03:18 2022] libphy: bcmgenet MII bus: probed
        [So Jul 17 11:03:18 2022] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
        [So Jul 17 11:03:18 2022] usbcore: registered new interface driver r8152
        [So Jul 17 11:03:18 2022] usbcore: registered new interface driver lan78xx
        [So Jul 17 11:03:18 2022] usbcore: registered new interface driver smsc95xx
        [So Jul 17 11:03:18 2022] xhci_hcd 0000:01:00.0: xHCI Host Controller
        [So Jul 17 11:03:18 2022] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
        [So Jul 17 11:03:18 2022] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x00000e0000000890
        [So Jul 17 11:03:18 2022] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
        [So Jul 17 11:03:18 2022] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
        [So Jul 17 11:03:18 2022] usb usb1: Product: xHCI Host Controller
        [So Jul 17 11:03:18 2022] usb usb1: Manufacturer: Linux 5.10.92-v7l+ xhci-hcd
        [So Jul 17 11:03:18 2022] usb usb1: SerialNumber: 0000:01:00.0
        [So Jul 17 11:03:18 2022] hub 1-0:1.0: USB hub found
        [So Jul 17 11:03:18 2022] hub 1-0:1.0: 1 port detected
        [So Jul 17 11:03:18 2022] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
        [So Jul 17 11:03:18 2022] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
        [So Jul 17 11:03:18 2022] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
        [So Jul 17 11:03:18 2022] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
        [So Jul 17 11:03:18 2022] usb usb2: Product: xHCI Host Controller
        [So Jul 17 11:03:18 2022] usb usb2: Manufacturer: Linux 5.10.92-v7l+ xhci-hcd
        [So Jul 17 11:03:18 2022] usb usb2: SerialNumber: 0000:01:00.0
        [So Jul 17 11:03:18 2022] hub 2-0:1.0: USB hub found
        [So Jul 17 11:03:18 2022] hub 2-0:1.0: 4 ports detected
        [So Jul 17 11:03:18 2022] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
        [So Jul 17 11:03:18 2022] dwc_otg: FIQ enabled
        [So Jul 17 11:03:18 2022] dwc_otg: NAK holdoff enabled
        [So Jul 17 11:03:18 2022] dwc_otg: FIQ split-transaction FSM enabled
        [So Jul 17 11:03:18 2022] Module dwc_common_port init
        [So Jul 17 11:03:18 2022] usbcore: registered new interface driver uas
        [So Jul 17 11:03:18 2022] usbcore: registered new interface driver usb-storage
        [So Jul 17 11:03:18 2022] mousedev: PS/2 mouse device common for all mice
        [So Jul 17 11:03:18 2022] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
        [So Jul 17 11:03:18 2022] sdhci: Secure Digital Host Controller Interface driver
        [So Jul 17 11:03:18 2022] sdhci: Copyright(c) Pierre Ossman
        [So Jul 17 11:03:18 2022] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
        [So Jul 17 11:03:18 2022] sdhci-pltfm: SDHCI platform and OF driver helper
        [So Jul 17 11:03:18 2022] ledtrig-cpu: registered to indicate activity on CPUs
        [So Jul 17 11:03:18 2022] hid: raw HID events driver (C) Jiri Kosina
        [So Jul 17 11:03:18 2022] usbcore: registered new interface driver usbhid
        [So Jul 17 11:03:18 2022] usbhid: USB HID core driver
        [So Jul 17 11:03:18 2022] Initializing XFRM netlink socket
        [So Jul 17 11:03:18 2022] NET: Registered protocol family 17
        [So Jul 17 11:03:18 2022] Key type dns_resolver registered
        [So Jul 17 11:03:18 2022] Registering SWP/SWPB emulation handler
        [So Jul 17 11:03:18 2022] registered taskstats version 1
        [So Jul 17 11:03:18 2022] Loading compiled-in X.509 certificates
        [So Jul 17 11:03:18 2022] Key type ._fscrypt registered
        [So Jul 17 11:03:18 2022] Key type .fscrypt registered
        [So Jul 17 11:03:18 2022] Key type fscrypt-provisioning registered
        [So Jul 17 11:03:18 2022] uart-pl011 fe201000.serial: there is not valid maps for state default
        [So Jul 17 11:03:18 2022] uart-pl011 fe201000.serial: cts_event_workaround enabled
        [So Jul 17 11:03:18 2022] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 38, base_baud = 0) is a PL011 rev2
        [So Jul 17 11:03:18 2022] printk: console [ttyS0] disabled
        [So Jul 17 11:03:18 2022] fe215040.serial: ttyS0 at MMIO 0xfe215040 (irq = 39, base_baud = 62500000) is a 16550
        [So Jul 17 11:03:19 2022] printk: console [ttyS0] enabled
        [So Jul 17 11:03:19 2022] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
        [So Jul 17 11:03:19 2022] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
        [So Jul 17 11:03:19 2022] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
        [So Jul 17 11:03:19 2022] of_cfs_init
        [So Jul 17 11:03:19 2022] of_cfs_init: OK
        [So Jul 17 11:03:19 2022] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
        [So Jul 17 11:03:19 2022] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
        [So Jul 17 11:03:19 2022] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
        [So Jul 17 11:03:19 2022] Waiting for root device PARTUUID=1045efe5-02...
        [So Jul 17 11:03:19 2022] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
        [So Jul 17 11:03:20 2022] usb 1-1: new high-speed USB device number 2 using xhci_hcd
        [So Jul 17 11:03:20 2022] mmc1: new high speed SDIO card at address 0001
        [So Jul 17 11:03:20 2022] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
        [So Jul 17 11:03:20 2022] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
        [So Jul 17 11:03:20 2022] usb 1-1: Product: USB2.0 Hub
        [So Jul 17 11:03:20 2022] hub 1-1:1.0: USB hub found
        [So Jul 17 11:03:20 2022] hub 1-1:1.0: 4 ports detected
        [So Jul 17 11:03:20 2022] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
        [So Jul 17 11:03:20 2022] usb 2-1: New USB device found, idVendor=0781, idProduct=55a3, bcdDevice= 1.00
        [So Jul 17 11:03:20 2022] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
        [So Jul 17 11:03:20 2022] usb 2-1: Product:  SanDisk 3.2Gen1
        [So Jul 17 11:03:20 2022] usb 2-1: Manufacturer:  USB
        [So Jul 17 11:03:20 2022] usb 2-1: SerialNumber: 01017c2086c5f43ce99946245926287f82ddc05644aebdc46473d8f554c3aa6bf25c00000000000000000000ca572d07001c4c00a3558107bdab5cc6
        [So Jul 17 11:03:20 2022] usb-storage 2-1:1.0: USB Mass Storage device detected
        [So Jul 17 11:03:20 2022] scsi host0: usb-storage 2-1:1.0
        [So Jul 17 11:03:20 2022] usb 2-2: new SuperSpeed Gen 1 USB device number 3 using xhci_hcd
        [So Jul 17 11:03:20 2022] usb 2-2: New USB device found, idVendor=174c, idProduct=1156, bcdDevice= 1.00
        [So Jul 17 11:03:20 2022] usb 2-2: New USB device strings: Mfr=2, Product=3, SerialNumber=1
        [So Jul 17 11:03:20 2022] usb 2-2: Product: Forty
        [So Jul 17 11:03:20 2022] usb 2-2: Manufacturer: Argon
        [So Jul 17 11:03:20 2022] usb 2-2: SerialNumber: 0000000000E4
        [So Jul 17 11:03:20 2022] scsi host1: uas
        [So Jul 17 11:03:20 2022] scsi 1:0:0:0: Direct-Access     Argon    Forty            0    PQ: 0 ANSI: 6
        [So Jul 17 11:03:20 2022] sd 1:0:0:0: [sda] 250069680 512-byte logical blocks: (128 GB/119 GiB)
        [So Jul 17 11:03:20 2022] sd 1:0:0:0: [sda] Write Protect is off
        [So Jul 17 11:03:20 2022] sd 1:0:0:0: [sda] Mode Sense: 43 00 00 00
        [So Jul 17 11:03:20 2022] sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
        [So Jul 17 11:03:20 2022] sd 1:0:0:0: [sda] Optimal transfer size 33553920 bytes
        [So Jul 17 11:03:20 2022] usb 1-1.4: new full-speed USB device number 3 using xhci_hcd
        [So Jul 17 11:03:20 2022]  sda: sda1 sda2
        [So Jul 17 11:03:20 2022] sd 1:0:0:0: [sda] Attached SCSI disk
        [So Jul 17 11:03:20 2022] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
        [So Jul 17 11:03:20 2022] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
        [So Jul 17 11:03:20 2022] devtmpfs: mounted
        [So Jul 17 11:03:20 2022] Freeing unused kernel memory: 2048K
        [So Jul 17 11:03:20 2022] Run /sbin/init as init process
        [So Jul 17 11:03:20 2022]   with arguments:
        [So Jul 17 11:03:20 2022]     /sbin/init
        [So Jul 17 11:03:20 2022]   with environment:
        [So Jul 17 11:03:20 2022]     HOME=/
        [So Jul 17 11:03:20 2022]     TERM=linux
        [So Jul 17 11:03:20 2022] usb 1-1.4: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
        [So Jul 17 11:03:20 2022] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
        [So Jul 17 11:03:20 2022] usb 1-1.4: Product: ConBee II
        [So Jul 17 11:03:20 2022] usb 1-1.4: Manufacturer: dresden elektronik ingenieurtechnik GmbH
        [So Jul 17 11:03:20 2022] usb 1-1.4: SerialNumber: DE2414409
        [So Jul 17 11:03:21 2022] systemd[1]: System time before build time, advancing clock.
        [So Jul 17 11:03:21 2022] NET: Registered protocol family 10
        [So Jul 17 11:03:21 2022] Segment Routing with IPv6
        [So Jul 17 11:03:21 2022] systemd[1]: systemd 247.3-6+rpi1 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
        [So Jul 17 11:03:21 2022] systemd[1]: Detected architecture arm.
        [So Jul 17 11:03:21 2022] systemd[1]: Set hostname to <raspberrypi4-iobroker>.
        [So Jul 17 11:03:21 2022] scsi 0:0:0:0: Direct-Access      USB      SanDisk 3.2Gen1 1.00 PQ: 0 ANSI: 6
        [So Jul 17 11:03:21 2022] sd 0:0:0:0: [sdb] 60088320 512-byte logical blocks: (30.8 GB/28.7 GiB)
        [So Jul 17 11:03:21 2022] sd 0:0:0:0: [sdb] Write Protect is off
        [So Jul 17 11:03:21 2022] sd 0:0:0:0: [sdb] Mode Sense: 43 00 00 00
        [So Jul 17 11:03:21 2022] sd 0:0:0:0: [sdb] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
        [So Jul 17 11:03:21 2022]  sdb: sdb1
        [So Jul 17 11:03:21 2022] sd 0:0:0:0: [sdb] Attached SCSI removable disk
        [So Jul 17 11:03:22 2022] systemd[1]: Queued start job for default target Graphical Interface.
        [So Jul 17 11:03:22 2022] random: systemd: uninitialized urandom read (16 bytes read)
        [So Jul 17 11:03:22 2022] systemd[1]: Created slice system-getty.slice.
        [So Jul 17 11:03:22 2022] systemd[1]: Created slice system-modprobe.slice.
        [So Jul 17 11:03:22 2022] systemd[1]: Created slice system-serial\x2dgetty.slice.
        [So Jul 17 11:03:22 2022] systemd[1]: Created slice system-systemd\x2dfsck.slice.
        [So Jul 17 11:03:22 2022] systemd[1]: Created slice User and Session Slice.
        [So Jul 17 11:03:22 2022] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
        [So Jul 17 11:03:22 2022] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
        [So Jul 17 11:03:22 2022] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
        [So Jul 17 11:03:22 2022] systemd[1]: Reached target Local Encrypted Volumes.
        [So Jul 17 11:03:22 2022] systemd[1]: Reached target Paths.
        [So Jul 17 11:03:22 2022] systemd[1]: Reached target Slices.
        [So Jul 17 11:03:22 2022] systemd[1]: Reached target Swap.
        [So Jul 17 11:03:22 2022] systemd[1]: Listening on Syslog Socket.
        [So Jul 17 11:03:22 2022] systemd[1]: Listening on fsck to fsckd communication Socket.
        [So Jul 17 11:03:22 2022] systemd[1]: Listening on initctl Compatibility Named Pipe.
        [So Jul 17 11:03:22 2022] systemd[1]: Listening on Journal Audit Socket.
        [So Jul 17 11:03:22 2022] systemd[1]: Listening on Journal Socket (/dev/log).
        [So Jul 17 11:03:22 2022] systemd[1]: Listening on Journal Socket.
        [So Jul 17 11:03:22 2022] systemd[1]: Listening on udev Control Socket.
        [So Jul 17 11:03:22 2022] systemd[1]: Listening on udev Kernel Socket.
        [So Jul 17 11:03:22 2022] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
        [So Jul 17 11:03:22 2022] systemd[1]: Mounting POSIX Message Queue File System...
        [So Jul 17 11:03:22 2022] systemd[1]: Mounting RPC Pipe File System...
        [So Jul 17 11:03:22 2022] systemd[1]: Mounting Kernel Debug File System...
        [So Jul 17 11:03:23 2022] systemd[1]: Mounting Kernel Trace File System...
        [So Jul 17 11:03:23 2022] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
        [So Jul 17 11:03:23 2022] systemd[1]: Starting Restore / save the current clock...
        [So Jul 17 11:03:23 2022] systemd[1]: Starting Set the console keyboard layout...
        [So Jul 17 11:03:23 2022] systemd[1]: Starting Create list of static device nodes for the current kernel...
        [So Jul 17 11:03:23 2022] systemd[1]: Starting Load Kernel Module configfs...
        [So Jul 17 11:03:23 2022] systemd[1]: Starting Load Kernel Module drm...
        [So Jul 17 11:03:23 2022] systemd[1]: Starting Load Kernel Module fuse...
        [So Jul 17 11:03:23 2022] fuse: init (API version 7.32)
        [So Jul 17 11:03:23 2022] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
        [So Jul 17 11:03:23 2022] systemd[1]: Starting File System Check on Root Device...
        [So Jul 17 11:03:23 2022] systemd[1]: Starting Journal Service...
        [So Jul 17 11:03:23 2022] systemd[1]: Starting Load Kernel Modules...
        [So Jul 17 11:03:23 2022] systemd[1]: Starting Coldplug All udev Devices...
        [So Jul 17 11:03:23 2022] systemd[1]: Mounted POSIX Message Queue File System.
        [So Jul 17 11:03:23 2022] systemd[1]: Mounted RPC Pipe File System.
        [So Jul 17 11:03:23 2022] systemd[1]: Mounted Kernel Debug File System.
        [So Jul 17 11:03:23 2022] systemd[1]: Mounted Kernel Trace File System.
        [So Jul 17 11:03:23 2022] i2c /dev entries driver
        [So Jul 17 11:03:23 2022] systemd[1]: Finished Restore / save the current clock.
        [So Jul 17 11:03:23 2022] systemd[1]: Finished Set the console keyboard layout.
        [So Jul 17 11:03:23 2022] systemd[1]: Finished Create list of static device nodes for the current kernel.
        [So Jul 17 11:03:23 2022] systemd[1]: modprobe@configfs.service: Succeeded.
        [So Jul 17 11:03:23 2022] systemd[1]: Finished Load Kernel Module configfs.
        [So Jul 17 11:03:23 2022] systemd[1]: modprobe@drm.service: Succeeded.
        [So Jul 17 11:03:23 2022] systemd[1]: Finished Load Kernel Module drm.
        [So Jul 17 11:03:23 2022] systemd[1]: modprobe@fuse.service: Succeeded.
        [So Jul 17 11:03:23 2022] systemd[1]: Finished Load Kernel Module fuse.
        [So Jul 17 11:03:23 2022] systemd[1]: Finished Load Kernel Modules.
        [So Jul 17 11:03:23 2022] systemd[1]: Mounting FUSE Control File System...
        [So Jul 17 11:03:23 2022] systemd[1]: Mounting Kernel Configuration File System...
        [So Jul 17 11:03:23 2022] systemd[1]: Started File System Check Daemon to report status.
        [So Jul 17 11:03:23 2022] systemd[1]: Starting Apply Kernel Variables...
        [So Jul 17 11:03:23 2022] systemd[1]: Mounted FUSE Control File System.
        [So Jul 17 11:03:23 2022] systemd[1]: Mounted Kernel Configuration File System.
        [So Jul 17 11:03:23 2022] systemd[1]: Finished File System Check on Root Device.
        [So Jul 17 11:03:23 2022] systemd[1]: Started Journal Service.
        [So Jul 17 11:03:24 2022] EXT4-fs (sda2): re-mounted. Opts: (null)
        [So Jul 17 11:03:24 2022] systemd-journald[145]: Received client request to flush runtime journal.
        [So Jul 17 11:03:24 2022] systemd-journald[145]: File /var/log/journal/ceda8666c83a44189d7d8b22875c3095/system.journal corrupted or uncleanly shut down, renaming and replacing.
        [So Jul 17 11:03:25 2022] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
        [So Jul 17 11:03:25 2022] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
        [So Jul 17 11:03:25 2022] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
        [So Jul 17 11:03:25 2022] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
        [So Jul 17 11:03:25 2022] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
        [So Jul 17 11:03:25 2022] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
        [So Jul 17 11:03:25 2022] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
        [So Jul 17 11:03:25 2022] [vc_sm_connected_init]: start
        [So Jul 17 11:03:25 2022] [vc_sm_connected_init]: installed successfully
        [So Jul 17 11:03:25 2022] mc: Linux media interface: v0.10
        [So Jul 17 11:03:25 2022] bcm2835_audio bcm2835_audio: card created with 8 channels
        [So Jul 17 11:03:25 2022] videodev: Linux video capture interface: v2.00
        [So Jul 17 11:03:25 2022] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
        [So Jul 17 11:03:25 2022] sd 1:0:0:0: Attached scsi generic sg0 type 0
        [So Jul 17 11:03:25 2022] sd 0:0:0:0: Attached scsi generic sg1 type 0
        [So Jul 17 11:03:25 2022] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
        [So Jul 17 11:03:25 2022] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
        [So Jul 17 11:03:25 2022] brcmstb-i2c fef04500.i2c:  @97500hz registered in polling mode
        [So Jul 17 11:03:25 2022] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
        [So Jul 17 11:03:25 2022] brcmstb-i2c fef09500.i2c:  @97500hz registered in polling mode
        [So Jul 17 11:03:25 2022] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
        [So Jul 17 11:03:25 2022] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
        [So Jul 17 11:03:25 2022] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
        [So Jul 17 11:03:25 2022] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
        [So Jul 17 11:03:25 2022] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
        [So Jul 17 11:03:25 2022] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
        [So Jul 17 11:03:25 2022] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
        [So Jul 17 11:03:25 2022] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
        [So Jul 17 11:03:25 2022] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
        [So Jul 17 11:03:25 2022] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
        [So Jul 17 11:03:25 2022] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
        [So Jul 17 11:03:25 2022] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
        [So Jul 17 11:03:25 2022] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
        [So Jul 17 11:03:25 2022] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
        [So Jul 17 11:03:25 2022] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
        [So Jul 17 11:03:25 2022] cdc_acm 1-1.4:1.0: ttyACM0: USB ACM device
        [So Jul 17 11:03:25 2022] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
        [So Jul 17 11:03:25 2022] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
        [So Jul 17 11:03:25 2022] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
        [So Jul 17 11:03:25 2022] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
        [So Jul 17 11:03:25 2022] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
        [So Jul 17 11:03:25 2022] usbcore: registered new interface driver cdc_acm
        [So Jul 17 11:03:25 2022] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
        [So Jul 17 11:03:25 2022] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
        [So Jul 17 11:03:25 2022] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
        [So Jul 17 11:03:25 2022] Registered IR keymap rc-cec
        [So Jul 17 11:03:25 2022] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0
        [So Jul 17 11:03:25 2022] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input0
        [So Jul 17 11:03:25 2022] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input1
        [So Jul 17 11:03:25 2022] cfg80211: Loading compiled-in X.509 certificates for regulatory database
        [So Jul 17 11:03:25 2022] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 1
        [So Jul 17 11:03:25 2022] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
        [So Jul 17 11:03:25 2022] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
        [So Jul 17 11:03:25 2022] brcmfmac: F1 signature read @0x18000000=0x15264345
        [So Jul 17 11:03:25 2022] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
        [So Jul 17 11:03:25 2022] usbcore: registered new interface driver brcmfmac
        [So Jul 17 11:03:25 2022] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input2
        [So Jul 17 11:03:26 2022] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
        [So Jul 17 11:03:26 2022] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Nov  1 2021 00:37:25 version 7.45.241 (1a2f2fa CY) FWID 01-703fd60
        [So Jul 17 11:03:26 2022] random: crng init done
        [So Jul 17 11:03:26 2022] random: 7 urandom warning(s) missed due to ratelimiting
        [So Jul 17 11:03:26 2022] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
        [So Jul 17 11:03:26 2022] Registered IR keymap rc-cec
        [So Jul 17 11:03:26 2022] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0
        [So Jul 17 11:03:26 2022] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input3
        [So Jul 17 11:03:26 2022] vc4-drm gpu: bound fef00700.hdmi (ops vc4_hdmi_ops [vc4])
        [So Jul 17 11:03:26 2022] rc rc1: vc4 as /devices/platform/soc/fef05700.hdmi/rc/rc1
        [So Jul 17 11:03:26 2022] input: vc4 as /devices/platform/soc/fef05700.hdmi/rc/rc1/input4
        [So Jul 17 11:03:26 2022] vc4-drm gpu: bound fef05700.hdmi (ops vc4_hdmi_ops [vc4])
        [So Jul 17 11:03:26 2022] vc4-drm gpu: bound fe004000.txp (ops vc4_txp_ops [vc4])
        [So Jul 17 11:03:26 2022] vc4-drm gpu: bound fe206000.pixelvalve (ops vc4_crtc_ops [vc4])
        [So Jul 17 11:03:26 2022] vc4-drm gpu: bound fe207000.pixelvalve (ops vc4_crtc_ops [vc4])
        [So Jul 17 11:03:26 2022] vc4-drm gpu: bound fe20a000.pixelvalve (ops vc4_crtc_ops [vc4])
        [So Jul 17 11:03:26 2022] vc4-drm gpu: bound fe216000.pixelvalve (ops vc4_crtc_ops [vc4])
        [So Jul 17 11:03:26 2022] vc4-drm gpu: bound fec12000.pixelvalve (ops vc4_crtc_ops [vc4])
        [So Jul 17 11:03:26 2022] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 0
        [So Jul 17 11:03:26 2022] vc4-drm gpu: [drm] Cannot find any crtc or sizes
        [So Jul 17 11:03:28 2022] FAT-fs (sdb1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
        [So Jul 17 11:03:29 2022] uart-pl011 fe201000.serial: no DMA platform data
        [So Jul 17 11:03:29 2022] 8021q: 802.1Q VLAN Support v1.8
        [So Jul 17 11:03:29 2022] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
        [So Jul 17 11:03:30 2022] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
        [So Jul 17 11:03:30 2022] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
        [So Jul 17 11:03:30 2022] bcmgenet fd580000.ethernet eth0: Link is Down
        [So Jul 17 11:03:35 2022] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
        [So Jul 17 11:03:35 2022] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
        [So Jul 17 11:03:35 2022] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
        [So Jul 17 11:03:36 2022] Bluetooth: Core ver 2.22
        [So Jul 17 11:03:36 2022] NET: Registered protocol family 31
        [So Jul 17 11:03:36 2022] Bluetooth: HCI device and connection manager initialized
        [So Jul 17 11:03:36 2022] Bluetooth: HCI socket layer initialized
        [So Jul 17 11:03:36 2022] Bluetooth: L2CAP socket layer initialized
        [So Jul 17 11:03:36 2022] Bluetooth: SCO socket layer initialized
        [So Jul 17 11:03:36 2022] Bluetooth: HCI UART driver ver 2.3
        [So Jul 17 11:03:36 2022] Bluetooth: HCI UART protocol H4 registered
        [So Jul 17 11:03:36 2022] Bluetooth: HCI UART protocol Three-wire (H5) registered
        [So Jul 17 11:03:36 2022] Bluetooth: HCI UART protocol Broadcom registered
        [So Jul 17 11:03:36 2022] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
        [So Jul 17 11:03:36 2022] Bluetooth: BNEP filters: protocol multicast
        [So Jul 17 11:03:36 2022] Bluetooth: BNEP socket layer initialized
        [So Jul 17 11:03:36 2022] NET: Registered protocol family 38
        [So Jul 17 11:03:36 2022] cryptd: max_cpu_qlen set to 1000
        [So Jul 17 11:03:38 2022] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
        [So Jul 17 11:03:50 2022] cam-dummy-reg: disabling
        [So Jul 17 11:03:50 2022] cam1-reg: disabling
          @spidermike sagte in Lange Ladezeit vom iobroker:
          Bis auf
          soweit nichts auffälliges.
            @thomas-braun sagte in Lange Ladezeit vom iobroker:
            Bis auf
            was muss ich da jetzt machen ?
              @spidermike
              Von Extern (von deinem Windwos aus?) die Partition prüfen.
              Ich weiß aber nicht was es da in der Fenster-Welt für gute Tools gibt.
                @spidermike
                Ist das die SSD?
                  @spidermike
                  Das ist die erste Partition auf dem zweiten Datenträger (sdb1).
                  Vermutlich die SSD dann.
                    oje was mache ich da jetzt.
                    Alles nochmal neu aufsetzen?
                      Spidermike @Thomas Braun last edited by Spidermike
                      habe jetzt mal google gefragt und das herausbekommen
                      pi@raspberrypi4-iobroker:~ $ sudo fsck /dev/sdb
                      fsck from util-linux 2.36.1
                      e2fsck 1.46.2 (28-Feb-2021)
                      /dev/sdb is in use.
                      e2fsck: Cannot continue, aborting.
                        @spidermike
                        Du kannst keinen fschck auf eingehängten Partitionen durchführen.
                        Die boot-Partition im laufenden Betrieb auszuhängen ist aber hohe Kunst.
                        Deswegen ja mein Rat, das von extern auszuführen.
                          @spidermike
                          das heist die SSD ausbauen und an meinen Laptop direkt verbinden ?
                            Oder einfach nur die Gehäusebrücke entfernen und die SSD per USB-Kabel an den Laptop.
                            S paul53 2 Replies Last reply Reply Quote 0
                              ok das war auch mein 1. Gedanke.
                              Aber erkennt mein Laptop eigentlich eine Linux SSD?
                              Habe noch was anderes Gefunden was sagst Du dazu und kannst mir das kurz erklären.
                              pi@raspberrypi4-iobroker:~ $ sudo fsck /dev/sda1
                              fsck.fat 4.2 (2021-01-31)
                              There are differences between boot sector and its backup.
                              This is mostly harmless. Differences: (offset:original/backup)
                                65:01/00
                              1) Copy original to backup
                              2) Copy backup to original
                              3) No action
                              [123?q]? 3
                              Dirty bit is set. Fs was not properly unmounted and some data may be corrupt.
                              1) Remove dirty bit
                              2) No action
                              [12?q]? 2
                              /dev/sda1: 295 files, 98874/516190 clusters
                                Die boot-Partition ist FAT-formatiert, die sieht dein Windows und kann da Operationen mit dem Dateisystem unternehmen. Die zweite Partition mit (vermutich) EXT4 als Dateitsystem ist nicht ohne weiters von Windows aus sichtbar. Aber es wurde ja die FAT-Partition als 'komisch' erkannt.
                                  ok dann werde ich das mal machen, melde mich wenn ich was erreicht habe
                                    paul53 @Thomas Braun last edited by
                                    @thomas-braun sagte: SSD per USB-Kabel an den Laptop.
                                    sdb ist nicht die 128 GB SSD.
                                    Thomas Braun S 3 Replies Last reply Reply Quote 0
                                      Thomas Braun Most Active @paul53 last edited by
                                      Oh, gut aufgepasst, da habe ich gepennt.
                                      Das dürfte dann eine SD-Karte sein, denke ich.
                                      Ich hatte vorausgesetzt das komplett von der SSD gebootet wird.
                                        Ich habe aber eigentlich keine SD Card mehr drin?????
                                        Thomas Braun paul53 2 Replies Last reply Reply Quote 0
                                          @spidermike
                                          Dann wird die SSD nicht vollständig genutzt.
                                            Spidermike @paul53 last edited by
                                            ich hatte damals alles auf SSD umgestellt
                                            13490
