    3. Off Topic
    4. Grafana stürzt mehrfach täglich ab
      TimoV @Thomas Braun last edited by TimoV
      @thomas-braun Upgrade lief jetzt. Momentan startet Grafana gar nicht mehr.
      pi@iobroker:~ $ dpkg -l '*grafana*'
      Desired=Unknown/Install/Remove/Purge/Hold
      | Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
      |/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
      ||/ Name           Version      Architecture Description
      un  grafana        <none>       <none>       (no description available)
      ii  grafana-rpi    7.4.3        armhf        Grafana
        Thomas Braun Most Active @TimoV last edited by Thomas Braun
        @timov sagte in Grafana stürzt mehrfach täglich ab:
        grafana-rpi
        sudo dpkg -P grafana-rpi
        Dann das grafana-Repo anlegen:
        sudo apt-get install -y apt-transport-https
        sudo apt-get install -y software-properties-common wget
        wget -q -O - https://packages.grafana.com/gpg.key | sudo apt-key add -
        echo "deb https://packages.grafana.com/oss/deb stable main" | sudo tee -a /etc/apt/sources.list.d/grafana.list
        sudo apt update
        sudo apt install grafana
        T crunchip 2 Replies Last reply Reply Quote 0
          @thomas-braun Vielen Dank!
          Grafana läuft jetzt erstmal wieder und ich werde beobachten, wie es sich verhält.
            @timov
            sudo apt update
            apt policy grafana
            sagt nun?
              pi@iobroker:~ $ sudo apt update
              Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
              Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
              Hit:3 https://deb.nodesource.com/node_14.x bullseye InRelease
              Hit:4 https://repos.influxdata.com/debian bullseye InRelease
              Hit:5 https://packages.grafana.com/oss/deb stable InRelease
              Reading package lists... Done
              Building dependency tree... Done
              All packages are up to date.
              pi@iobroker:~ $ apt policy grafana
              grafana:
                Installed: 9.0.3
                Candidate: 9.0.3
                Version table:
               *** 9.0.3 500
                      500 https://packages.grafana.com/oss/deb stable/main armhf Packages
                      100 /var/lib/dpkg/status
                   9.0.2 500
                   9.0.1 500
                   9.0.0 500
                   8.5.9 500
                   8.5.6 500
                   8.5.5 500
                   8.5.4 500
                   8.5.3 500
                   8.5.2 500
                   8.5.1 500
                   8.5.0 500
                   8.4.10 500
                   8.4.7 500
                   8.4.6 500
                   8.4.5 500
                   8.4.4 500
                   8.4.3 500
                   8.4.2 500
                   8.4.1 500
                   8.4.0 500
                   8.3.10 500
                   8.3.7 500
                   8.3.6 500
                   8.3.5 500
                   8.3.4 500
                   8.3.3 500
                   8.3.2 500
                   8.3.1 500
                   8.3.0 500
                   8.2.7 500
                   8.2.6 500
                   8.2.5 500
                   8.2.4 500
                   8.2.3 500
                   8.2.2 500
                   8.2.1 500
                   8.2.0 500
                   8.1.8 500
                   8.1.7 500
                   8.1.6 500
                   8.1.5 500
                   8.1.4 500
                   8.1.3 500
                   8.1.2 500
                   8.1.1 500
                   8.1.0 500
                   8.0.7 500
                   8.0.6 500
                   8.0.5 500
                   8.0.4 500
                   8.0.3 500
                   8.0.2 500
                   8.0.1 500
                   8.0.0 500
                   7.5.16 500
                   7.5.15 500
                   7.5.13 500
                   7.5.12 500
                   7.5.11 500
                   7.5.10 500
                   7.5.9 500
                   7.5.8 500
                   7.5.7 500
                   7.5.6 500
                   7.5.5 500
                   7.5.4 500
                   7.5.3 500
                   7.5.2 500
                   7.5.1 500
                   7.5.0 500
                   7.4.5 500
                   7.4.3 500
                   7.4.2 500
                   7.4.1 500
                   7.4.0 500
                   7.3.10 500
                   7.3.7 500
                   7.3.6 500
                   7.3.5 500
                   7.3.4 500
                   7.3.3 500
                   7.3.2 500
                   7.3.1 500
                   7.3.0 500
                   7.2.2 500
                   7.2.1 500
                   7.2.0 500
                   7.1.5 500
                   7.1.4 500
                   7.1.3 500
                   7.1.2 500
                   7.1.1 500
                   7.1.0 500
                   7.0.6 500
                   7.0.5 500
                   7.0.4 500
                   7.0.3 500
                   7.0.2 500
                   7.0.1 500
                   7.0.0 500
                   6.7.6 500
                   6.7.5 500
                   6.7.4 500
                   6.7.3 500
                   6.7.2 500
                   6.7.1 500
                   6.7.0 500
                   6.6.2 500
                   6.6.1 500
                   6.6.0 500
                   6.5.3 500
                   6.5.2 500
                   6.5.1 500
                   6.5.0 500
                   6.4.5 500
                   6.4.4 500
                   6.4.3 500
                   6.4.2 500
                   6.4.1 500
                   6.4.0 500
                   6.3.7 500
                   6.3.6 500
                   6.3.5 500
                   6.3.4 500
                   6.3.3 500
                   6.3.2 500
                   6.3.1 500
                   6.3.0 500
                   6.2.5 500
                   6.2.4 500
                   6.2.3 500
                   6.2.2 500
                   6.2.1 500
                   6.2.0 500
                   6.1.6 500
                   6.1.5 500
                   6.1.4 500
                   6.1.3 500
                   6.1.2 500
                   6.1.1 500
                   6.1.0 500
                   6.0.2 500
                   6.0.1 500
                   6.0.0 500
                   5.4.5 500
                   5.4.4 500
                   5.4.3 500
                   5.4.2 500
                   5.4.1 500
                   5.4.0 500
                   5.3.4 500
                   5.3.3 500
                   5.3.2 500
                   5.3.1 500
                   5.3.0 500
                   5.2.5 500
                   5.2.4 500
                   5.2.3 500
                   5.2.2 500
                   5.2.1 500
                   5.2.0 500
                @timov
                Ja, das schaut besser aus.
                Jetzt noch auf nodejs 16 hüpfen und du bist soweit 'auf Stand'.
                  crunchip Forum Testing Most Active @Thomas Braun last edited by
                  @thomas-braun sagte in Grafana stürzt mehrfach täglich ab:
                  -P
                  Blöde Frage, was bedeutet dies?
                    Thomas Braun Most Active @crunchip last edited by
                    @crunchip
                    Prune
                    Das kratzt auch die config aus dem System.
                    Glasfaser crunchip 2 Replies Last reply Reply Quote 1
                    • Glasfaser
                      Glasfaser @Thomas Braun last edited by
                      @crunchip
                      stimmt ... Sorry konnte ich mir nicht verkneifen 🙂
                        @thomas-braun hätt ich auch selbst drauf kommen können
                        Steh heut irgendwie bisserl neben mir
                        @glasfaser sagte in Grafana stürzt mehrfach täglich ab:
                        Hahaha😜
                          Thomas Braun Most Active @Glasfaser last edited by
                          @glasfaser
                          Zu warm...
                          Verstehe ich nicht.
                          794
