    4. Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda
    • Glasfaser
      Glasfaser @Wszene last edited by
      @wszene sagte in Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda:
      Wie verwende ich das im Blockly
      Auf die schnelle ...
       <variables>
         <variable id="39{QeS!%5I-R0CSOhdN3">Orginal</variable>
         <variable id="g0x:2wAJ5]9.hwD]U+p^">Search</variable>
         <variable id="#sE`E5Cpz5|Qj%FOX88h">Replace</variable>
         <variable id="VrUUF1Ye5*=K^Kgrz=,J">Datenpunkt</variable>
         <variable id=":b?D+98VTpSSnwUnV,u^">NeuerText</variable>
       </variables>
       <block type="procedures_defcustomreturn" id=";:Q_:a@qkZdbJ+WIePv(" x="163" y="112">
         <mutation statements="false">
           <arg name="Orginal" varid="39{QeS!%5I-R0CSOhdN3"></arg>
           <arg name="Search" varid="g0x:2wAJ5]9.hwD]U+p^"></arg>
           <arg name="Replace" varid="#sE`E5Cpz5|Qj%FOX88h"></arg>
         </mutation>
         <field name="NAME">etwas tun</field>
         <field name="SCRIPT">bGV0IHRleHRfMSA9IE9yZ2luYWw7DQpsZXQgdGV4dF8yID0gU2VhcmNoOw0KbGV0IHRleHRfMyA9IFJlcGxhY2U7DQp0ZXh0XzEgPSB0ZXh0XzEucmVwbGFjZShTZWFyY2ggLCBSZXBsYWNlKTsNCnJldHVybiB0ZXh0XzE7</field>
       <block type="variables_set" id="p7Qg/BSlDhWX5LjndAz$" x="162" y="162">
         <field name="VAR" id="VrUUF1Ye5*=K^Kgrz=,J">Datenpunkt</field>
           <block type="text" id=",J(*lg~Ho5g9z2X[^og(">
             <field name="TEXT">Lisa Str 3333 , 45738 Pfaffenhof , Deutschland</field>
           <block type="variables_set" id="-*O?z(J*HV8uDzPf#r[y">
             <field name="VAR" id=":b?D+98VTpSSnwUnV,u^">NeuerText</field>
               <block type="procedures_callcustomreturn" id="ED,*L4dd}-3[N#7NjO^S">
                 <mutation name="etwas tun">
                   <arg name="Orginal"></arg>
                   <arg name="Search"></arg>
                   <arg name="Replace"></arg>
                 </mutation>
                 <value name="ARG0">
                   <block type="variables_get" id="(D2qo~+A#o}vL:%(*{#G">
                 <value name="ARG1">
                   <block type="text" id="3LXYsj,;|s@;0e~8ljRX">
                     <field name="TEXT">, Deutschland</field>
                 <value name="ARG2">
                   <block type="text" id="Wr|Gm@qo;FdI^pJl}CC*">
                     <field name="TEXT"></field>
               <block type="debug" id="3`r4|M1~CvH2x`0W,URe">
                 <value name="TEXT">
                   <shadow type="text" id="ZK!B:JU4dToV:8E0!_9e">
                   <block type="variables_get" id="4^rK!)W6DtDLTxnVqZt(">
      Wszene 1 Reply Last reply Reply Quote 1
      • Wszene
        Wszene @Glasfaser last edited by
        @glasfaser
        Sehr geil
        Vielen Dank das funktioniert perfekt
        • JB_Sullivan
          JB_Sullivan last edited by
          Kann es ggf. sein, das der IT Dienstleister für VW, Skoda & Audi die Anzahl der zulässigen Abfragen verändert hat?
          Ich bin heute morgen aufgestanden und wollte in der Handy App die Fahrzeug Daten sehen. Da wurde ich damit begrüßt, das ich die maximal Anzahl an Abfragen überschritten hätte und erst in 24 Stunden die App wieder nutzen kann.
          Da ich Nachts schlafe, werde ich wohl kaum die Abfragen überlastet haben ....... einzig die automatischen Abfragen des Adapters kämen dafür in Frage. Die stehen aber schon seit Jahr und Tag auf 5 Minuten bzw. 360 Minuten (erzwungen).
          Die Fehlermeldung im Log des Adapters sagt das gleiche ......
          Ist diesbezüglich etwas bekannt?
          vw-connect.0
          2022-07-12 08:13:34.574	error	failed set state targetTemperatureInKelvin
          vw-connect.0
          2022-07-12 08:13:34.573	error	{"errorCode":"NUMBER_OF_OPERATIONS_EXHAUSTED","message":"Too many requests sent to external repository. {Call VCF failed with error code {429}, message {The maximum amount of requests has been reached} and additional description {null}}"}
          vw-connect.0
          2022-07-12 08:13:34.572	error	429
            dispo112 last edited by
            Kann mir jemand verraten wo ich den Datenpunkt für den aktuellen Fahrzeugstandort finde? Mein ID3 hat die Softwareversion 3.0 und lässt sich über die App einwandfrei verfolgen.
            David G. T 2 Replies Last reply Reply Quote 0
            • David G.
              David G. @dispo112 last edited by David G.
              @dispo112
              Hab keinen ID. Bei mir liegen die GPS Daten aber unter
              vw-connect.0.xxxx.position
              Die Adresse unter
              vw-connect.0.xxxx.position.address
                tombox @dispo112 last edited by
                @dispo112 Ich bräuchte Zugang zu einem Account mit software 3.0 um zu sehen was die App macht
                • David G.
                  David G. last edited by
                  Hey,
                  hab das Connect noch nicht aktiviert.
                  Wollte man zu dem remote Datenpunkten "climatisation" und "Ventilation" eine Frage stellen.
                  Schalten die bei abgeschlossem und abgeschlossen Fahrzeug die Lüftung bzw Klimaanlage ein?
                    srkonus @tombox last edited by
                    @tombox Mein ID4 hat Version 3.0 - wenn ich dir helfen kann, melde dich.
                    • David G.
                      David G. @srkonus last edited by
                      @srkonus
                      Danke für das Angebot.
                      War denn meine Annahme zu den Datenpunkten richtig?
                        TT-Tom @David G. last edited by
                        @david-g sagte in Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda:
                        Verstehe die Frage nicht ganz. Aber du kannst mit den DP einschalten.
                        • David G.
                          David G. @TT-Tom last edited by David G.
                          @tt-tom
                          Bei mir scheint es nichts zu machen.
                          Hab bevor ich die Datenpunkte betätigt habe die Temperatur und duration eingestellt.
                          Auf alle Datenpunkte für "climatisation" und "Ventilation" hat das Auto nicht reagiert (auf- und abschließen klappt).
                          Sehe in der App aber aicu keine Temperatur zum einstellen.
                          Geht das dann nicht?
                          Ist ein Seat Tarraco aus 22.
                            @david-g
                            Kannst du denn über App beide Funktionen starten???
                            • David G.
                              @tt-tom
                              Nein, leider nicht....
                              Dachte, dass wäre was "inoffizielles".
                                @david-g na wir schummeln hier doch nicht 😉
                                • David G.
                                  @tt-tom
                                  Ziemlich doof kommuniziert vom Hersteller, welches Auto was unterstützt.
                                  In der Anleitung vom Tarraco steht es drinnen. Aber mit der Überschrift, dass dort alles was die Version 3 von cloud connect kann steht.
                                  Aber nicht, was das spezielle Auto kann.
                                    @david-g
                                    Ja die Anleitungen sind für Vollausstattung geschrieben und man muss selber sehen was verbaut bzw. bestellt wurde.
                                    • David G.
                                      @tt-tom
                                      Frage mich, was ich gebraucht hätte.
                                      Hab eigentlich alles außer der Standheißubg.
                                      T 1 Reply Last reply Reply Quote -1
                                        @david-g ja die standhzg die Automatik steuert dann auch die Lüftung. Ohne wird es nix
                                        • David G.
                                          @tt-tom
                                          Hab mich schon gefreut bei den Temperaturen im Moment.
                                          Die Lüftung könnte man ja ruihg so einschalten können.
                                            WRE4444 last edited by
                                            Hallo zusammen, seit einiger Zeit funktioniert der Adapter nicht mehr mit "Audi Etron" für meinen Audi Q4 Sportback. Er bleibt immer auf gelb und antwortet mit Fehler 403, Fehler bei Login. Die Änderung auf Adapter "Audi" bringt zwar ein grünes Zeichen, aber dann wird kein Fahrzeug erkannt.
                                            Die Einstellung wurde nicht verändert und hat schon funktioniert. Hat jemand das gleiche Problem, hat hier Audi was geändert. Die App im iPhone funktioniert. Wäre für einen Hinweis dankbar.
                                            81.1k
                                            audi id.3 myaudi seat skoda skoda connect volkswagen vw id we connect wecharge
                                            399
                                            3091
                                            1602115
