    3. Entwicklung
    4. Anfrage AirConWithMe (IntesisHome) Klimasteuerung Adapter
      Thomas Braun Most Active @ah966 last edited by
      @ah966 sagte in Anfrage AirConWithMe (IntesisHome) Klimasteuerung Adapter:
      aber dann kam ein Fehler.
      Geheimer Fehler?
        ah966 @Thomas Braun last edited by
        @thomas-braun Sorry, natürlich nicht:
        $ ./iobroker url "https://github.com/weggetor/ioBroker.airconwithme" --debug
        Info: Can not get current GitHub commit, we remember master branch only. Status: 422 (No commit found for SHA: master)
        install https://github.com/weggetor/ioBroker.airconwithme/tarball/master
        NPM version: 6.14.6
        npm install https://github.com/weggetor/ioBroker.airconwithme/tarball/master --loglevel error --prefix "/opt/iobroker" (System call)
        npm
        ERR!
         code E404
        npm
        ERR!
        404 Not Found - GET https://codeload.github.com/weggetor/ioBroker.airconwithme/legacy.tar.gz/masternpm ERR! 404 npm ERR! 404  'https://github.com/weggetor/ioBroker.airconwithme/tarball/master' is not in the npm registry.npm ERR! 404 Your package name is not valid, because npm ERR! 404  1. name can only contain URL-friendly charactersnpm ERR! 404  2. name can no longer contain capital lettersnpm ERR! 404 npm ERR! 404 Note that you can also install from anpm ERR! 404 tarball, folder, http url, or git url.
        npm
        ERR! A complete log of this run can be found in:npm
        ERR!     /home/iobroker/.npm/_logs/2021-07-13T11_53_16_373Z-debug.log
        ERROR: host.linuxvm Cannot install https://github.com/weggetor/ioBroker.airconwithme/tarball/master: 1
        ERROR: process exited with code 25
        Viele Grüße,
        Andreas
          Thomas Braun Most Active @ah966 last edited by Thomas Braun
          @ah966
          [Edit:]
          $ iobroker url https://github.com/weggetor/ioBroker.airconwithme --host chet
          install weggetor/ioBroker.airconwithme#fb30a6c160eb3975888bb26f38f3787019150c72
          NPM version: 7.18.1
          npm install weggetor/ioBroker.airconwithme#fb30a6c160eb3975888bb26f38f3787019150c72 --loglevel error --prefix "/opt/iobroker" (System call)
          upload [4] airconwithme.admin /opt/iobroker/node_modules/iobroker.airconwithme/admin/words.js words.js application/javascript
          upload [3] airconwithme.admin /opt/iobroker/node_modules/iobroker.airconwithme/admin/style.css style.css text/css
          upload [2] airconwithme.admin /opt/iobroker/node_modules/iobroker.airconwithme/admin/index_m.html index_m.html text/html
          upload [1] airconwithme.admin /opt/iobroker/node_modules/iobroker.airconwithme/admin/airconwithme.png airconwithme.png image/png
          upload [0] airconwithme.admin /opt/iobroker/node_modules/iobroker.airconwithme/admin/admin.d.ts admin.d.ts video/mp2t
          Process exited with code 0
          Hier funktioniert es.
          Link einfach in das entsperchende Feld kopieren, fertig.
            Rand @ah966 last edited by
            @ah966
            WIr haben seit gestern eine Anlage von Mitsubishi HI und ich will die eigentlich auch aus der Cloud raushalten...
            Dann nicht den offiziellen WiFi Adapter verwenden... wenn der keine Internet Verbindung hat blinkt die ganze Zeit ein rotes "Verbindungsprobleme"-Licht...
            Hatte die Hoffnung das es nach einmaligen konfigurieren aus geht - aber entweder nein, oder habe es noch nicht gefunden.
            Wenn ich meine nicht teuer bezahlt hätte würde ich sie in die Tonne treten. Proprietärer künstlich limitierter Schei**.
              @thomas-braun Hat jetzt geklappt, habe es auf einer anderen Instanz probiert - da lief es problemlos durch.
              Auf der alten Instanz mit NPM 6.14.6 und NodeJS 12.18 hatte es nicht funktioniert.
              Erfolgreich war es bei der Instanz mit NPM 6.14.13 und NodeJS 14.17.
              Adapter läuft und die Anlage konnte ich in VIS auch schon abbilden.
              Danke!
              Viele Grüße,
              Andreas
                sonic0190 @coyote last edited by sonic0190
                @coyote said in Anfrage AirConWithMe (IntesisHome) Klimasteuerung Adapter:
                @ThatsIT das kann ich dir leider nicht sagen, warum die nicht angelegt werden. So gut kenne ich mich mit dem Arduino Programm und MQTT nicht aus. Bin mir nicht sicher ob das überhaupt funktioniert
                Guten Tag, ist zwar schon ein etwas älteres Thema, aber ich wollte jetzt auch mit der Arduino IDE
                https://github.com/knolleary/pubsubclient
                https://github.com/absalom-muc/MHI-AC-Ctrl
                auf den Wemos D1 mini flashen.
                Kann mir jemand verraten wie ich das in diesem Fall konkret mache?
                verstehe nicht ganz wie ich die beiden Sachen miteinander verbinde und dann flashen kann 😞
                steht ja leider auch nicht auf github wie der pubsubclient geflasht wird.
                wie ich sehe haben es aber schon einige von euch geschafft. Wäre für ne kurze Beschreibung oder Links dankbar, vielleicht hab ich ja was übersehen.
                edit:
                so wie es aussieht muss man, vorausgesetzt der Wemos 8266 D1 ist unter "Boardverwalter" installiert, in der Arduino Software unter
                "Werkzeuge" -> "Bibliotheken verwalten"
                einfach den pubsubclient 2.7.0 (und ggf. Onewire / DallasTemperature ) installieren und kann dann über den umbenannten "src" Ordner (in MHI-AC-Ctrl) "MHI-AC-Ctrl.ino" Arduino starten und nach anpassen der support.h "Sketch" ->"Hochladen".
                Danach wurden im iObroker in Mqtt Objekte auch schon der Ordner MHI-AC-Ctrl angelegt.
                Sollte also funktionieren. Genaues weiß ich dann erst nachdem die Platine fertig ist und an die AC angeschlossen.
                Momentan Fehlercode -4
                edit2:
                Alles klar habs angeschlossen, läuft alles wie es soll. Top!
                • coyote
                  coyote Most Active @sonic0190 last edited by
                  @sonic0190
                  Genau. Nach deinem EDIT zu Folge hast du es jetzt soweit erstmal hinbekommen. Dann warte mal ab, bis die Platine fertig ist.
                  • leika241265
                    leika241265 @Rababersaft last edited by
                    @rababersaft
                    Ich habe mir eine Mitsubishi Multisplit Anlage gegönnt und per IOBroker verbunden und suche nach einigen Scripten .
                    So wie du schon beschrieben hast:
                    -Tag Nacht Bewertung nach Uhrzeit (Nachtabsenkung)
                    -Sommer Winter Bewertung (Heizen Kühlen) nach Mittelwert der nächsten 3 Tage
                    -Aus bei Fensteröffnung länger als x Minuten
                    Kannst du mir diese zur Verfügung stellen.
                    Danke schonmal für deine Hilfe.
                      warhammer73 @leika241265 last edited by
                      @leika241265
                      Kannst Du kurz beschreiben wie Du die Anlage mit dem IOBroker verheiratet hast?
                      Also welche Hardware, welche Software...
                      Danke!
                      leika241265 1 Reply Last reply Reply Quote 0
                      • leika241265
                        leika241265 @warhammer73 last edited by
                        @warhammer73
                        jedes Gerät hat ein AirConWithMe modul bzw einen IntesisHome zugang.
                        Im IoBroker per "AirConWithMe" adapter.
                        Das ist soweit auch OK und ich sehe alle Geräte und alle settings.
                        Nun versuche einige Beispiele zum programmieren.
                          @leika241265
                          Danke.
                          Wo hast Du AirConWithMe her?
                          So wie ich das verstanden habe muss das beim Fachmann bestellt und eingebaut werden?
                          Bin irgendwie gerade etwas Lost mit irgendwelchen Eigenbauplatinen, WLAN Version von Mitsubishi, AirConWithMe...
                          Danke!
                          • leika241265
                            @warhammer73
                            das wurde mir so angeboten und war im gesamten Paket der Anlage enthalten. Da hatte ich aber noch nicht in dem Forum recherchiert, das es eine billige Möglichkeit gibt. Egal, soweit läuft die Anlage und bin nun dabei zu recherchieren wie ich die Anlage am besten steuere.
                              Fox1985 last edited by
                              Guten Morgen,
                              ich würde gerne meine Mitsubishi Heavy per MHI AC CTRL via MQTT und Web UI steuern.
                              habe auch schon alle Bauteile, leider bekomme ich das Image warum auch immer nicht geflasht.
                              Kann mir einer aus dem Forum eine flashbare .bin erstellen?
                              Noch eine weitere Frage. Stimmt es, dass bei MHI AC CTRL nicht immer das Web UI dabei ist?
                              Vielen Dank und viele Grüße
                                claus1968 @Fox1985 last edited by
                                @fox1985
                                Hier mal meine fw mit aktiviertem Mitsubishi
                                tasmota.bin
                                  Fox1985 @claus1968 last edited by
                                  @claus1968
                                  Hi Claus, vielen Dank für deinen Tipp,
                                  Kannst du damit eine Mitsubishi Havy steueren, oder hast du eine Mitsubishi Electric?
                                  Was kannst du denn mit deiner Konfiguration alles einstellen?
                                    @fox1985 said in Anfrage AirConWithMe (IntesisHome) Klimasteuerung Adapter:
                                    Mitsubishi Electric
                                    Ich habe eine Mitsubishi Electric, welche heute in Betrieb gegangen ist.
                                    Ich bin noch am Ausprobieren ...
                                      mirko3107 @claus1968 last edited by
                                      Ich habe in meiner SRK 35 ZS-W nun auch diesen Intesis-Adapter montiert, funktioniert einwandfrei.
                                      Leider funktioniert damit keine Timerfunktion mehr, die man per IR-Fernbedienung einstellt, somit ist der WAF schonmal
                                      gegen 0 gefallen.
                                      Hat schon jemand eine Art Script am laufen für ein Wochenprogramm? Oder wenigstens einen Sleep-Timer?
                                      Mirko
                                        Christian 2 @coyote last edited by
                                        @coyote
                                        ich stehe vor dem gleichen Problem wie sonic0190 damals, komme aber nicht weiter.
                                        Die Platine ist fertig verlötet, jedoch weiß ich nicht, was ich wie installieren muss.
                                        Gibt es dazu irgendwo eine verständliche anleitung bzw. kannst du mir sagen, was ich wo machen muss?
                                        Vielen Dank!
                                        Christian
                                        • coyote
                                          coyote Most Active @Christian 2 last edited by
                                          @christian-2 na wo hängst du denn genau? sonic0190 hatte es doch schon recht gut erklärt.
                                            Christian 2 @coyote last edited by Christian 2
                                            ich bekomme beim upload folgende Fehlermeldung:
                                            tal esptool.py error occurred: Cannot configure port, something went wrong. Original message: PermissionError(13, 'Ein an das System angeschlossenes Ger�t funktioniert nicht.', None, 31)
                                            vielen Dank schonmal!
                                            102
                                            21026
