    4. Nach Nodejs Update kein Adapter mehr updatebar
      tilly @Thomas Braun last edited by
      nein der war die ganze Zeit aus, wollte den nur bis morgen wieder an machen wenn ich weiter mache.
        Thomas Braun Most Active @tilly last edited by Thomas Braun
        @tilly
        Beim iobroker Start werden Module neukompiliert.
        Ich vermute stark, da ist in der Vergangenheit mal mit sudo oder gar vollem root was installiert worden und jetzt ist da einiges verbogen.
        Edit: Gerade nochmal hochgescrollt... Du warst ja tatsächlich als root unterwegs. Würde meine Vermutung stützen.
          so habe iobroker gestoppt, alle Dateien mit kryptischen Endungen gelöscht und versucht alexa2 upzudaten.
          user@iobroker-ubuntu:/opt/iobroker$ iobroker upgrade alexa2 --debug
          This upgrade of "alexa2" will introduce the following changes:
          -> 3.18.6:
          Fix deviceStop sequence command
          -> 3.18.5:
          Fix crash case reported by Sentry
          Add image for Fire Cube
          -> 3.18.3:
          Fix doNotDisturb and doNotDisturb for All devices
          Update do not disturb status after set for all devices
          preserve a changed name for a "This device" device object
          -> 3.18.2:
          Enable commands again for Apps with type A2TF17PFR55MTB - will only work sometimes as it seems
          Would you like to upgrade alexa2 from @3.18.1 to @3.18.6 now? [(y)es, (n)o]: y
          Update alexa2 from @3.18.1 to @3.18.6
          NPM version: 8.11.0
          Installing iobroker.alexa2@3.18.6... (System call)
          npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
          npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now a built-in Node module. If you've depended on crypto, you should switch to the one that's built-in.
          npm WARN deprecated node-xmpp-tls-connect@1.0.1: this package is deprecated please use https://github.com/xmppjs/xmpp.js
          npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
          npm WARN deprecated har-validator@5.1.5: this library is no longer supported
          npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
          npm WARN deprecated node-xmpp-core@5.0.9: this package is deprecated please use https://github.com/xmppjs/xmpp.js
          npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
          npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
          npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
          npm WARN deprecated multer@1.4.4: Multer 1.x is affected by CVE-2022-24434. This is fixed in v1.4.4-lts.1 which drops support for versions of Node.js before 6. Please upgrade to at least Node.js 6 and version 1.4.4-lts.1 of Multer. If you need support for older versions of Node.js, we are open to accepting patches that would fix the CVE on the main 1.x release line, whilst maintaining compatibility with Node.js 0.10.
          npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
          npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
          npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
          npm WARN deprecated uuid@3.3.2: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
          npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
          npm WARN deprecated appium-logger@2.1.0: Moved into appium-support
          npm WARN deprecated node-xmpp-client@3.2.0: this package is deprecated please use https://www.npmjs.com/package/@xmpp/client
          npm WARN deprecated axios@0.27.0: Formdata complete broken, incorrect build size
          npm WARN deprecated core-js@1.2.7: core-js@<3.23.3 is no longer maintained and not recommended for usage due to the number of issues. Because of the V8 engine whims, feature detection in old core-js versions could cause a slowdown up to 100x even if nothing is polyfilled. Some versions have web compatibility issues. Please, upgrade your dependencies to the actual version of core-js.
          npm WARN deprecated core-js@2.6.12: core-js@<3.23.3 is no longer maintained and not recommended for usage due to the number of issues. Because of the V8 engine whims, feature detection in old core-js versions could cause a slowdown up to 100x even if nothing is polyfilled. Some versions have web compatibility issues. Please, upgrade your dependencies to the actual version of core-js.
          npm ERR! code 1
          npm ERR! path /opt/iobroker/node_modules/openzwave-shared
          npm ERR! command failed
          npm ERR! command sh -c node-gyp rebuild
          npm ERR! make: Entering directory '/opt/iobroker/node_modules/openzwave-shared/build'
          npm ERR!   CXX(target) Release/obj.target/openzwave_shared/src/callbacks.o
          npm ERR! openzwave_shared.target.mk:150: recipe for target 'Release/obj.target/openzwave_shared/src/callbacks.o' failed
          npm ERR! make: Leaving directory '/opt/iobroker/node_modules/openzwave-shared/build'
          npm ERR! gyp info it worked if it ends with ok
          npm ERR! gyp info using node-gyp@8.4.1
          npm ERR! gyp info using node@16.16.0 | linux | x64
          npm ERR! gyp info find Python using Python version 3.6.9 found at "/usr/bin/python3"
          npm ERR! gyp info spawn /usr/bin/python3
          npm ERR! gyp info spawn args [
          npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',
          npm ERR! gyp info spawn args   'binding.gyp',
          npm ERR! gyp info spawn args   '-f',
          npm ERR! gyp info spawn args   'make',
          npm ERR! gyp info spawn args   '-I',
          npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/openzwave-shared/build/config.gypi',
          npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/addon.gypi',
          npm ERR! gyp info spawn args   '/home/iobroker/.cache/node-gyp/16.16.0/include/node/common.gypi',
          npm ERR! gyp info spawn args   '-Dlibrary=shared_library',
          npm ERR! gyp info spawn args   '-Dvisibility=default',
          npm ERR! gyp info spawn args   '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/16.16.0',
          npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',
          npm ERR! gyp info spawn args   '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/16.16.0/<(target_arch)/node.lib',
          npm ERR! gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/openzwave-shared',
          npm ERR! gyp info spawn args   '-Dnode_engine=v8',
          npm ERR! gyp info spawn args   '--depth=.',
          npm ERR! gyp info spawn args   '--no-parallel',
          npm ERR! gyp info spawn args   '--generator-output',
          npm ERR! gyp info spawn args   'build',
          npm ERR! gyp info spawn args   '-Goutput_dir=.'
          npm ERR! gyp info spawn args ]
          npm ERR! gyp info spawn make
          npm ERR! gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
          npm ERR! In file included from /home/iobroker/.cache/node-gyp/16.16.0/include/node/v8.h:30:0,
          npm ERR!                  from ../src/openzwave.hpp:27,
          npm ERR!                  from ../src/callbacks.cc:18:
          npm ERR! /home/iobroker/.cache/node-gyp/16.16.0/include/node/v8-internal.h: In function ‘void v8::internal::PerformCastCheck(T*)’:
          npm ERR! /home/iobroker/.cache/node-gyp/16.16.0/include/node/v8-internal.h:492:38: error: ‘remove_cv_t’ is not a member of ‘std’
          npm ERR!              !std::is_same<Data, std::remove_cv_t<T>>::value>::Perform(data);
          npm ERR!                                       ^~~~~~~~~~~
          npm ERR! /home/iobroker/.cache/node-gyp/16.16.0/include/node/v8-internal.h:492:38: note: suggested alternative: ‘remove_cv’
          npm ERR!                                       remove_cv
          npm ERR!                                       remove_cv
          npm ERR! /home/iobroker/.cache/node-gyp/16.16.0/include/node/v8-internal.h:492:50: error: template argument 2 is invalid
          npm ERR!                                                   ^
          npm ERR! /home/iobroker/.cache/node-gyp/16.16.0/include/node/v8-internal.h:492:63: error: ‘::Perform’ has not been declared
          npm ERR!        ^~~~~~~
          npm ERR! /home/iobroker/.cache/node-gyp/16.16.0/include/node/v8-internal.h:492:63: note: suggested alternative: ‘perror’
          npm ERR!        ^~~~~~~
          npm ERR!        perror
          npm ERR! make: *** [Release/obj.target/openzwave_shared/src/callbacks.o] Error 1
          npm ERR! gyp ERR! build error
          npm ERR! gyp ERR! stack Error: `make` failed with exit code: 2
          npm ERR! gyp ERR! stack     at ChildProcess.onExit (/opt/iobroker/node_modules/node-gyp/lib/build.js:194:23)
          npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:527:28)
          npm ERR! gyp ERR! stack     at Process.ChildProcess._handle.onexit (node:internal/child_process:291:12)
          npm ERR! gyp ERR! System Linux 4.15.0-189-generic
          npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"
          npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/openzwave-shared
          npm ERR! gyp ERR! node -v v16.16.0
          npm ERR! gyp ERR! node-gyp -v v8.4.1
          npm ERR! gyp ERR! not ok
          npm ERR!     /home/iobroker/.npm/_logs/2022-07-22T08_24_18_272Z-debug-0.log
          upload [27] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/alexa.png alexa.png image/png
          upload [20] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot3.png icons/echo_dot3.png image/png
          upload [19] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot4.png icons/echo_dot4.png image/png
          upload [18] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_flex.png icons/echo_flex.png image/png
          upload [17] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_plus2.png icons/echo_plus2.png image/png
          upload [16] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show.png icons/echo_show.png image/png
          upload [15] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show2.png icons/echo_show2.png image/png
          upload [14] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show5.png icons/echo_show5.png image/png
          upload [13] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_studio.png icons/echo_studio.png image/png
          upload [12] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_sub.png icons/echo_sub.png image/png
          upload [11] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetab.png icons/firetab.png image/png
          upload [10] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetv.png icons/firetv.png image/png
          upload [9] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/microphone.png icons/microphone.png image/png
          upload [8] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/multiroom.png icons/multiroom.png image/png
          upload [7] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/raspi.png icons/raspi.png image/png
          upload [6] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/reverb.png icons/reverb.png image/png
          upload [5] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/sonos.png icons/sonos.png image/png
          upload [4] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/spot.png icons/spot.png image/png
          upload [3] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/index_m.html index_m.html text/html
          upload [2] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/info.png info.png image/png
          upload [1] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/warning.png warning.png image/png
          upload [0] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/words.js words.js application/javascript^[Sorry, try again.
          mikeal created this issue in request/request
          open Request’s Past, Present and Future #3142
          Qix- created this issue in visionmedia/debug
          closed ReDos Vulnerability Regression Visibility Notice #797
            @tilly
            Ist 'build-essential' installiert?
            apt policy build-essential
              @thomas-braun said in Nach Nodejs Update kein Adapter mehr updatebar:
              ja
              user@iobroker-ubuntu:/opt/iobroker$ apt policy build-essential
              build-essential:
                Installiert:           12.4ubuntu1
                Installationskandidat: 12.4ubuntu1
                Versionstabelle:
               *** 12.4ubuntu1 500
                      500 http://archive.ubuntu.com/ubuntu bionic/main amd64 Packages
                      100 /var/lib/dpkg/status
                @tilly
                Dann lösch den cache mal.
                  so?
                  sudo apt-get clean
                    @tilly
                    Nein, den npm cache
                    cd /opt/iobroker
                    sudo -u iobroker npm cache clear --force
                      user@iobroker-ubuntu:/opt/iobroker$ sudo -u iobroker npm cache clear --force
                      npm WARN logfile could not be created: Error: EACCES: permission denied, open '/home/user/.npm/_logs/2022-07-22T09_05_23_231Z-debug-0.log'
                      npm WARN using --force Recommended protections disabled.
                        @tilly
                        sudo -H -u iobroker npm cache clear --force
                          user@iobroker-ubuntu:/opt/iobroker$ sudo -H -u iobroker npm cache clear --force
                          und jetzt nochmal versuchen alexa2 upzudaten?
                            @tilly
                            Nein, der Show Stopper liegt bei openzwave-shared.
                            Das Modul bzw. den zugehörigen Adapter nochmal sauber installieren/rebuilden.
                              möchte jetzt iobroker nicht starten, daher würde ich den Adapter(wird nicht mehr benötigt) über die Konsole löschen.
                              So?
                              iobroker del openzwave-shared
                                @tilly
                                Ich vermute der kommt als Dependency aus einem Adapter. Ich würde den ganzen Adapter rauswerfen.
                                Schau wo openzwave-shared hängt:
                                cd /opt/iobroker
                                npm ls openzwave-shared
                                • mickym
                                  Ich hätte ja das ganze node-modules Verzeichnis gelöscht, inkl. package-lock.json und dann mit npm install neu aufbauen lassen. Wenn du eh eine Datensicherung hast, solltest du ja auch auf den Stand zurückkehren können. Bei mir hat diese Radikalkur jedenfalls geholfen, einen fehlerfreien Baum zu bekommen.
                                    der kommt vom zwave adapter. Den lösche ich dann mit: iobroker del zwave2?
                                    user@iobroker-ubuntu:/opt/iobroker$ npm ls openzwave-shared
                                    [sudo] password for user:
                                    iobroker.inst@2.0.2 /opt/iobroker
                                    └─┬ iobroker.zwave@2.0.1
                                      └── openzwave-shared@1.7.2
                                      tilly @mickym last edited by
                                      @mickym
                                      wie würde ich da vorgehen?
                                      mickym Thomas Braun 2 Replies Last reply Reply Quote 0
                                      • mickym
                                        mickym Most Active @tilly last edited by mickym
                                        @tilly sagte in Nach Nodejs Update kein Adapter mehr updatebar:
                                        @mickym
                                        also in das /opt/iobroker Verzeichnis wechseln.
                                        IOB stoppen natürlich:
                                        iob stop
                                        cd /opt/iobroker
                                        komplettes node_modules Verzeichnis löschen oder das Verzeichnis umbenennen
                                        sudo rm -rf node_modules
                                        bzw.
                                        sudo mv node_modules node_modules.bak
                                        etwaige package-lock.json löschen
                                        sudo rm package-lock.json
                                        Den cache sicherheitshalber noch leeren:
                                        npm cache clean --force
                                        Dann das node_modules neu aufbauen lassen:
                                        npm install
                                        Die ganzen Informationen über die Adapter und deren Abhängigkeiten stehen in der package.json.
                                        Eine datensicherung oder ein Image würde ich aber in jedem Fall machen, falls was nicht geht. Ist aber noch schneller, als das ganze System neu aufzubauen.
                                        zum Schluss in dem Verzeichnis /opt/iobroker noch den Befehl
                                        npm list
                                        und schauen, ob Du einen sauberen Baum hast. npm cache hast ja soweit ich sehe schon gelöscht.
                                        1 Reply Last reply Reply Quote 4
                                          @tilly
                                          iobroker del zwave
                                            zwave gelöscht und alexa2 erneut versucht zu installieren
                                            -> 3.18.6:
                                            -> 3.18.5:
                                            -> 3.18.3:
                                            -> 3.18.2:
                                            NPM version: 8.11.0
                                            npm ERR! code ENOTEMPTY
                                            npm ERR! syscall rename
                                            npm ERR! path /opt/iobroker/node_modules/node-red-node-email/node_modules/encoding-japanese/src
                                            npm ERR! dest /opt/iobroker/node_modules/.node-red-node-email-1lk8B7Gi/node_modules/encoding-japanese/src
                                            npm ERR! errno -39
                                            npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/node-red-node-email/node_modules/encoding-japanese/src' -> '/opt/iobroker/node_modules/.node-red-node-email-1lk8B7Gi/node_modules/encoding-japanese/src'
                                            npm ERR!     /home/iobroker/.npm/_logs/2022-07-22T11_15_10_431Z-debug-0.log
                                            host.iobroker-ubuntu Cannot install iobroker.alexa2@3.18.6: 217
                                            nodejs update adaper update
                                            7987
