    4. Kann keine Adapter aktualisieren
      Thomas Braun Most Active @grrfield last edited by
      @grrfield sagte in Kann keine Adapter aktualisieren:
      ioBroker.radar-trap
      Deinstallier den mal temporär für die Upgrades.
      Hattest du die git-basierten Adapter vor dem nodejs16 Update nicht rausgeworfen?
      grrfield 1 Reply Last reply Reply Quote 1
        Frank_y @grrfield last edited by Frank_y
        Bei mir lassen sich auch keine Adapter mehr aktualisieren - weder über die Weboberfläche noch über die Kommandozeile:
        rock64@rock64:/opt/iobroker$ iobroker update
        Used repository: stable
        Adapter    "admin"        : 5.3.8    , installed 5.3.8
        Adapter    "alexa2"       : 3.11.2   , installed 3.11.2
        Adapter    "backitup"     : 2.4.9    , installed 2.4.9
        Adapter    "cloud"        : 4.1.1    , installed 4.1.1
        Adapter    "daswetter"    : 3.1.2    , installed 3.1.2
        Adapter    "denon"        : 1.13.4   , installed 1.13.4
        Adapter    "devices"      : 1.0.12   , installed 1.0.12
        Adapter    "discovery"    : 3.0.5    , installed 3.0.3  [Updatable]
        Adapter    "fahrplan"     : 1.2.0    , installed 1.2.0
        Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
        Adapter    "flot"         : 1.11.0   , installed 1.11.0
        Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
        Adapter    "harmony"      : 1.2.2    , installed 1.2.2
        Adapter    "history"      : 2.1.7    , installed 1.11.1 [Updatable]
        Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
        Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
        Adapter    "ical"         : 1.13.1   , installed 1.12.1 [Updatable]
        Adapter    "info"         : 1.9.19   , installed 1.9.19
        Adapter    "iot"          : 1.11.8   , installed 1.11.4 [Updatable]
        Adapter    "javascript"   : 5.7.0    , installed 5.7.0
        Adapter    "mobile"       : 1.0.1    , installed 1.0.1
        Adapter    "nina"         : 0.0.25   , installed 0.0.25
        Adapter    "node-red"     : 3.3.1    , installed 3.3.1
        Adapter    "pi-hole"      : 1.3.4    , installed 1.3.4
        Adapter    "ping"         : 1.5.3    , installed 1.5.3
        Adapter    "radar2"       : 2.0.3    , installed 2.0.3
        Adapter    "rest-api"     : 1.0.0    , installed 1.0.0
        Adapter    "roomba"       : 1.1.4    , installed 1.1.4
        Adapter    "samsung"      : 0.5.8    , installed 0.5.8
        Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
        Adapter    "synology"     : 2.1.9    , installed 2.1.7  [Updatable]
        Adapter    "telegram"     : 1.13.0   , installed 1.13.0
        Adapter    "unifi"        : 0.5.10   , installed 0.5.10
        Adapter    "vis"          : 1.4.15   , installed 1.4.15
        Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
        Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
        rock64@rock64:/opt/iobroker$ iobroker upgrade
        This upgrade of "synology" will introduce the following changes:
        -> 2.1.9:
        Try to prevent account locks when using 2FA on restarts of the NAS
        -> 2.1.8:
        slow down reconnects to the DSM
        Would you like to upgrade synology from @2.1.7 to @2.1.9 now? [(y)es, (n)o]: y
        Update synology from @2.1.7 to @2.1.9
        NPM version: 8.11.0
        Installing iobroker.synology@2.1.9... (System call)
        host.rock64 Cannot install iobroker.synology@2.1.9: 128
        Bisher hatte ich nie Probleme beim Aktualisieren. Ich habe schon den iobroker-Fixer laufen lassen. Was kann ich noch tun?
        js-controller 4.0.23
        nodejs v16.16.0
        npm 8.11.0
        Bei mir das selbe Problem mit den stabel-Updates folgender Adapter:
        -discovery devices 3.0.3 ->3.0.5
        -History 1.11.1 ->2.1.7
        -iCal 1.12.1 ->1.13.1
        -influxDB 2.6.3 ->3.1.7
        -IoT assistants 1.11.4 ->1.11.8
        Der Worx-Adapter 1.5.5 -> 1.6.6 ließ sich ohne Fehler updaten
        nodejs sowohl bei v16.15.1 und v16.16.0
        node v16.15.1 bzw. v16.16.0
        npm 8.11.0
        habe auch iob fix noch einmal laufen lassen.
        Beispielhaft hier für History-Update:
        XXXXX@iobrokerVM:~$ iobroker upgrade history  --debug
        This upgrade of "history" will at least introduce the following changes:
        -> 2.1.7:
        Allow to remove a configuration value for "round" in config again
        -> 2.1.6:
        When not count is provided for aggregate "none" or "onchange" then the limit (de                                                fault 2000) is used as count to define the number of data to return.
        -> 2.1.5:
        Ignore errors from forked process after response was sent for GetHistory
        -> 2.1.4:
        Make sure debug log is active according to the settings
        -> 2.1.3:
        Huge performance optimizations for GetHistory calls
        -> 2.1.2:
        Fix crash case reported by Sentry
        -> 2.1.1:
        BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING C                                                HANGES!
        Would you like to upgrade history from @1.11.1 to @2.1.7 now? [(y)es, (n)o]: y
        Update history from @1.11.1 to @2.1.7
        NPM version: 8.11.0
        Installing iobroker.history@2.1.7... (System call)
        npm ERR! code ENOTEMPTY
        npm ERR! syscall rename
        npm ERR! path /opt/iobroker/node_modules/abab
        npm ERR! dest /opt/iobroker/node_modules/.abab-bvmibCm3
        npm ERR! errno -39
        npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/abab' -> '/opt/iobroker/node_modules/.abab-bvmibCm3'
        npm ERR!     /home/iobroker/.npm/_logs/2022-07-22T08_56_29_851Z-debug-0.log
        host.iobrokerVM Cannot install iobroker.history@2.1.7: 217
          Thomas Braun Most Active @Frank_y last edited by
          @frank_y sagte in Kann keine Adapter aktualisieren:
          Dann das gleiche auch für dich:
          Upgrade mit --debug Option laufen lassen.
            Frank_y @Thomas Braun last edited by
            hier für iot-Update:
            XXXXX@iobrokerVM:~$ iobroker upgrade iot --debug
            This upgrade of "iot" will introduce the following changes:
            -> 1.11.8:
            Update dependencies to allow better automatic rebuild
            -> 1.11.7:
            Tried to correct URL key creation for Google home
            -> 1.11.5:
            Alisa: update for binary-sensor "motion" and "contact"
            Would you like to upgrade iot from @1.11.4 to @1.11.8 now? [(y)es, (n)o]: y
            Update iot from @1.11.4 to @1.11.8
            NPM version: 8.11.0
            Installing iobroker.iot@1.11.8... (System call)
            npm ERR! path /opt/iobroker/node_modules/abbrev
            npm ERR! dest /opt/iobroker/node_modules/.abbrev-5eNud0FY
            npm ERR! errno -39
            npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/abbrev' -> '/opt/iobroker/node_modules/.abbrev-5eNud0FY'
            npm ERR!     /home/iobroker/.npm/_logs/2022-07-22T09_00_22_561Z-debug-0.log
            host.iobrokerVM Cannot install iobroker.iot@1.11.8: 217
              Alle Verzeichnisse die so ausgespuckt werden löschen.
              Beispiel:
              rm -rf /opt/iobroker/node_modules/.abab-bvmibCm3
              Solange bis alle angemeckerten Verzeichnisse weg sind.
              • grrfield
                grrfield @Thomas Braun last edited by
                @thomas-braun sagte in Kann keine Adapter aktualisieren:
                ioBroker.radar-trap
                Vielen Dank für die schnelle Antwort!
                Ich habe den Adapter über die Weboberfläche deinstalliert, er ist da auch nicht mehr zu sehen. Nach
                iob update
                iobroker upgrade synology --debug
                bekomme ich wieder dieselbe Debug-Ausgabe wie vorher, d. h. es wird immer noch versucht, auf ssh://git@github.com/Steiger04/ioBroker.radar-trap.git zuzugreifen.
                Nein, ich bin eigentlich genau nach der Anleitung [How-to] Node.js ioBroker richtig updaten-2021/22 Edition](https://forum.iobroker.net/topic/44566/how-to-node-js-iobroker-richtig-updaten-2021-22-edition?page=1) vorgegangen, und da habe ich nichts gelesen, daß die Git-Adapter vorher entfernt werden müssen. Hätte ich das tun müssen?
                  @grrfield
                  Bei Updates wo es größere Versionssprünge bei npm gibt (zb Node.js 14->16 updated npm von 6.x auf 8.x) kann es sehr hilfreich sein wenn man schaut ob Adapter die von GitHub installiert wurden inzwischen in der gleichen version auf auf npm liegen und dann ggf von dort nochmals installieren oder updaten. Im Admin werden Adapter die per GitHub installiert wurden gesondert mit einem GitHub Symbol angezeigt. Das hilft auch im Vorfeld Probleme zu vermeiden.
                  Das ist die Passage, die für dich relevant gewesen wäre.
                  • grrfield
                    Oh, das hatte ich nicht so aufgefaßt, da einige Adapter (radar-trap) noch nicht auf npm sind. Das nächste Mal bin ich dann klüger.
                    Wie kann ich denn den Fehler, daß immer bei der Installation neuer Adapter immer noch nach den git-Adaptern gesucht wird, loswerden?
                      @grrfield
                      Schau wo der im tree liegt:
                      cd /opt/iobroker
                      npm ls iobroker.radar-trap
                      • nbrgit
                        nbrgit last edited by
                        ich versuche gerade diverse Adapter zu aktualisieren, leider ohne Erfolg.
                        Kurzer Ausschnitt was bei der "Update-Kachel" erscheint :
                        Dependencies:
                        js-controller (>=3.3.22): 4.0.23
                        node (>=12.0.0): 16.16.0
                        Der Button "Aktualisieren" ist ausgeblendet.
                        Ich weiß nicht so richtig weiter, denn wenn ich das richtig lese, sind alle Voraussetzungen erfüllt aber ein Update ist nicht möglich.
                        Kann mir jemand helfen?
                        LG
                        haselchen Thomas Braun 2 Replies Last reply Reply Quote 0
                        • haselchen
                          haselchen Most Active @nbrgit last edited by haselchen
                          @nbrgit
                          6 Zeilen unter Dir ist das gleiche Problem.
                          Warum nutzt du nicht den Thread?
                          @Negalein
                          @Homoran
                          Bitte zusammenführen
                          https://forum.iobroker.net/topic/55518/kann-keine-adapter-aktualisieren
                            Thomas Braun Most Active @nbrgit last edited by
                            @nbrgit
                            Was kommt vom System auf diese Befehle in der Kommandozeile zurück?
                            iobroker update -i
                            sudo ln -s /usr/bin/node /usr/bin/nodejs
                            uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                            cd /opt/iobroker
                            npm ls | grep -E 'github|ERR'
                            • grrfield
                              Vielen Dank! Ich hatte in der Zwischenzeit weiter nach einem Eintrag mit "radar-trap" gesucht und habe dann in der Datei /opt/iobroker/package.json eine Zeile
                               "iobroker.radar-trap": "github:Steiger04/ioBroker.radar-trap#59772746bcfedabc4482b47115ca8584a1381bd5",
                              gefunden und diese gelöscht (vorher eine Kopie der Datei erstellt).
                              Jetzt bekomme ich diese Fehlermeldung nicht mehr, sondern bin einen Schritt weiter und bekomme die Meldungen, die auch frank_y hat. Ich bin nun dabei, die Verzeichnisse, die als Meldungen ausgegeben werden, zu löschen. Könnte man auch einfach alle versteckten Verzeichnisse unter /opt/iobroker/node_modules löschen, also
                              rm -rf /opt/iobroker/node_modules/.*
                              Für mich das so aus, als ob das nur Sicherheitskopien sind, die vor einer Installation neu erstellt werden.
                                @grrfield
                                Vorsicht! Da liegt auch ein Verzeichnis .bin drin, das würde ich nicht unbedingt löschen.
                                grrfield 1 Reply Last reply Reply Quote 0
                                • grrfield
                                  @thomas-braun Und der Rest?
                                    @grrfield
                                    Probier es aus...
                                    Ich kann/konnte es bei mir nicht nachstellen, ich hab keine Meldungen zu solchen Verzeichnissen bekommen, in meinem Dateipfad sind auch keine zu finden.
                                      Beispiel:
                                      Ich musste ca. 20 Verzeichnisse händisch löschen!
                                      Jetzt wird folgender Fehler ausgeworfen:
                                      XXXXXXX@iobrokerVM:/opt$ iobroker upgrade history  --debug
                                      node:internal/modules/cjs/loader:936
                                        throw err;
                                      Error: Cannot find module 'at-least-node'
                                      Require stack:
                                      - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/mkdirs/m        ake-dir.js
                                      - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/mkdirs/i        ndex.js
                                      - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/copy-syn        c/copy-sync.js
                                      - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/copy-syn        c/index.js
                                      - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/index.js
                                      - /opt/iobroker/node_modules/@alcalzone/pak/build/lib/package-managers/npm/ind        ex.js
                                      - /opt/iobroker/node_modules/@alcalzone/pak/build/lib/pak.js
                                      - /opt/iobroker/node_modules/@alcalzone/pak/build/index.js
                                      - /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.j        s
                                      - /opt/iobroker/node_modules/@iobroker/js-controller-common/index.js
                                      - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
                                      - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
                                          at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:        15)
                                          at Function.Module._load (node:internal/modules/cjs/loader:778:27)
                                          at Module.require (node:internal/modules/cjs/loader:1005:19)
                                          at require (node:internal/modules/cjs/helpers:102:18)
                                          at Object.<anonymous> (/opt/iobroker/node_modules/@alcalzone/pak/node_modu        les/fs-extra/lib/mkdirs/make-dir.js:9:21)
                                          at Module._compile (node:internal/modules/cjs/loader:1105:14)
                                          at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10        )
                                          at Module.load (node:internal/modules/cjs/loader:981:32)
                                          at Function.Module._load (node:internal/modules/cjs/loader:822:12)
                                          at Module.require (node:internal/modules/cjs/loader:1005:19) {
                                        code: 'MODULE_NOT_FOUND',
                                        requireStack: [
                                          '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/mkdir        s/make-dir.js',
                                          '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/mkdir        s/index.js',
                                          '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/copy-        sync/copy-sync.js',
                                          '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/copy-        sync/index.js',
                                          '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/index        .js',
                                          '/opt/iobroker/node_modules/@alcalzone/pak/build/lib/package-managers/npm/        index.js',
                                          '/opt/iobroker/node_modules/@alcalzone/pak/build/lib/pak.js',
                                          '/opt/iobroker/node_modules/@alcalzone/pak/build/index.js',
                                          '/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tool        s.js',
                                          '/opt/iobroker/node_modules/@iobroker/js-controller-common/index.js',
                                          '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
                                          '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                      Sieht nicht gut aus, oder?
                                        @frank_y
                                        iobroker stop
                                        cd /opt/iobroker
                                        sudo -H -u iobroker npm install iobroker.js-controller
                                          jetzt werden wieder Verzeichnisse angemeckert:
                                          npm ERR! path /opt/iobroker/node_modules/aws4
                                          npm ERR! dest /opt/iobroker/node_modules/.aws4-3BmHzpIi
                                          npm ERR! errno -39
                                          npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/aws4' -> '/opt/iobroker/node_modules/.aws4-3BmHzpIi'
                                          npm ERR!     /home/iobroker/.npm/_logs/2022-07-22T14_18_20_594Z-debug-0.log
                                          ich lösche mal weiter: rm -rf /opt/iobroker/node_modules/.aws4-3BmHzpIi
                                            Frank_y @Frank_y last edited by
                                            @frank_y
                                            es sind wieder mehrere Verzeichnisse....bisher 6...sehr mühsam
                                            Woran liegt das denn. Es lief ja alles?
                                            75
                                            8460
