    4. Kann keine Adapter aktualisieren
      Frank_y @grrfield last edited by Frank_y
      @grrfield sagte in Kann keine Adapter aktualisieren:
      Bei mir lassen sich auch keine Adapter mehr aktualisieren - weder über die Weboberfläche noch über die Kommandozeile:
      rock64@rock64:/opt/iobroker$ iobroker update
      Used repository: stable
      Adapter    "admin"        : 5.3.8    , installed 5.3.8
      Adapter    "alexa2"       : 3.11.2   , installed 3.11.2
      Adapter    "backitup"     : 2.4.9    , installed 2.4.9
      Adapter    "cloud"        : 4.1.1    , installed 4.1.1
      Adapter    "daswetter"    : 3.1.2    , installed 3.1.2
      Adapter    "denon"        : 1.13.4   , installed 1.13.4
      Adapter    "devices"      : 1.0.12   , installed 1.0.12
      Adapter    "discovery"    : 3.0.5    , installed 3.0.3  [Updatable]
      Adapter    "fahrplan"     : 1.2.0    , installed 1.2.0
      Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
      Adapter    "flot"         : 1.11.0   , installed 1.11.0
      Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
      Adapter    "harmony"      : 1.2.2    , installed 1.2.2
      Adapter    "history"      : 2.1.7    , installed 1.11.1 [Updatable]
      Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
      Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
      Adapter    "ical"         : 1.13.1   , installed 1.12.1 [Updatable]
      Adapter    "info"         : 1.9.19   , installed 1.9.19
      Adapter    "iot"          : 1.11.8   , installed 1.11.4 [Updatable]
      Adapter    "javascript"   : 5.7.0    , installed 5.7.0
      Adapter    "mobile"       : 1.0.1    , installed 1.0.1
      Adapter    "nina"         : 0.0.25   , installed 0.0.25
      Adapter    "node-red"     : 3.3.1    , installed 3.3.1
      Adapter    "pi-hole"      : 1.3.4    , installed 1.3.4
      Adapter    "ping"         : 1.5.3    , installed 1.5.3
      Adapter    "radar2"       : 2.0.3    , installed 2.0.3
      Adapter    "rest-api"     : 1.0.0    , installed 1.0.0
      Adapter    "roomba"       : 1.1.4    , installed 1.1.4
      Adapter    "samsung"      : 0.5.8    , installed 0.5.8
      Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
      Adapter    "synology"     : 2.1.9    , installed 2.1.7  [Updatable]
      Adapter    "telegram"     : 1.13.0   , installed 1.13.0
      Adapter    "unifi"        : 0.5.10   , installed 0.5.10
      Adapter    "vis"          : 1.4.15   , installed 1.4.15
      Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
      Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
      rock64@rock64:/opt/iobroker$ iobroker upgrade
      This upgrade of "synology" will introduce the following changes:
      -> 2.1.9:
      Try to prevent account locks when using 2FA on restarts of the NAS
      -> 2.1.8:
      slow down reconnects to the DSM
      Would you like to upgrade synology from @2.1.7 to @2.1.9 now? [(y)es, (n)o]: y
      Update synology from @2.1.7 to @2.1.9
      NPM version: 8.11.0
      Installing iobroker.synology@2.1.9... (System call)
      host.rock64 Cannot install iobroker.synology@2.1.9: 128
      Bisher hatte ich nie Probleme beim Aktualisieren. Ich habe schon den iobroker-Fixer laufen lassen. Was kann ich noch tun?
      js-controller 4.0.23
      nodejs v16.16.0
      npm 8.11.0
      Bei mir das selbe Problem mit den stabel-Updates folgender Adapter:
      -discovery devices 3.0.3 ->3.0.5
      -History 1.11.1 ->2.1.7
      -iCal 1.12.1 ->1.13.1
      -influxDB 2.6.3 ->3.1.7
      -IoT assistants 1.11.4 ->1.11.8
      Der Worx-Adapter 1.5.5 -> 1.6.6 ließ sich ohne Fehler updaten
      nodejs sowohl bei v16.15.1 und v16.16.0
      node v16.15.1 bzw. v16.16.0
      npm 8.11.0
      habe auch iob fix noch einmal laufen lassen.
      Beispielhaft hier für History-Update:
      XXXXX@iobrokerVM:~$ iobroker upgrade history  --debug
      This upgrade of "history" will at least introduce the following changes:
      -> 2.1.7:
      Allow to remove a configuration value for "round" in config again
      -> 2.1.6:
      When not count is provided for aggregate "none" or "onchange" then the limit (de                                                fault 2000) is used as count to define the number of data to return.
      -> 2.1.5:
      Ignore errors from forked process after response was sent for GetHistory
      -> 2.1.4:
      Make sure debug log is active according to the settings
      -> 2.1.3:
      Huge performance optimizations for GetHistory calls
      -> 2.1.2:
      Fix crash case reported by Sentry
      -> 2.1.1:
      BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING C                                                HANGES!
      Would you like to upgrade history from @1.11.1 to @2.1.7 now? [(y)es, (n)o]: y
      Update history from @1.11.1 to @2.1.7
      NPM version: 8.11.0
      Installing iobroker.history@2.1.7... (System call)
      npm ERR! code ENOTEMPTY
      npm ERR! syscall rename
      npm ERR! path /opt/iobroker/node_modules/abab
      npm ERR! dest /opt/iobroker/node_modules/.abab-bvmibCm3
      npm ERR! errno -39
      npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/abab' -> '/opt/iobroker/node_modules/.abab-bvmibCm3'
      npm ERR!     /home/iobroker/.npm/_logs/2022-07-22T08_56_29_851Z-debug-0.log
      host.iobrokerVM Cannot install iobroker.history@2.1.7: 217
        Thomas Braun Most Active @Frank_y last edited by
        @frank_y sagte in Kann keine Adapter aktualisieren:
        Dann das gleiche auch für dich:
        Upgrade mit --debug Option laufen lassen.
          Frank_y @Thomas Braun last edited by
          hier für iot-Update:
          XXXXX@iobrokerVM:~$ iobroker upgrade iot --debug
          This upgrade of "iot" will introduce the following changes:
          -> 1.11.8:
          Update dependencies to allow better automatic rebuild
          -> 1.11.7:
          Tried to correct URL key creation for Google home
          -> 1.11.5:
          Alisa: update for binary-sensor "motion" and "contact"
          Would you like to upgrade iot from @1.11.4 to @1.11.8 now? [(y)es, (n)o]: y
          Update iot from @1.11.4 to @1.11.8
          NPM version: 8.11.0
          Installing iobroker.iot@1.11.8... (System call)
          npm ERR! path /opt/iobroker/node_modules/abbrev
          npm ERR! dest /opt/iobroker/node_modules/.abbrev-5eNud0FY
          npm ERR! errno -39
          npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/abbrev' -> '/opt/iobroker/node_modules/.abbrev-5eNud0FY'
          npm ERR!     /home/iobroker/.npm/_logs/2022-07-22T09_00_22_561Z-debug-0.log
          host.iobrokerVM Cannot install iobroker.iot@1.11.8: 217
            Alle Verzeichnisse die so ausgespuckt werden löschen.
            Beispiel:
            rm -rf /opt/iobroker/node_modules/.abab-bvmibCm3
            Solange bis alle angemeckerten Verzeichnisse weg sind.
            • grrfield
              grrfield @Thomas Braun last edited by
              @thomas-braun sagte in Kann keine Adapter aktualisieren:
              ioBroker.radar-trap
              Vielen Dank für die schnelle Antwort!
              Deinstallier den mal temporär für die Upgrades.
              Ich habe den Adapter über die Weboberfläche deinstalliert, er ist da auch nicht mehr zu sehen. Nach
              iob update
              iobroker upgrade synology --debug
              bekomme ich wieder dieselbe Debug-Ausgabe wie vorher, d. h. es wird immer noch versucht, auf ssh://git@github.com/Steiger04/ioBroker.radar-trap.git zuzugreifen.
              Hattest du die git-basierten Adapter vor dem nodejs16 Update nicht rausgeworfen?
              Nein, ich bin eigentlich genau nach der Anleitung [How-to] Node.js ioBroker richtig updaten-2021/22 Edition](https://forum.iobroker.net/topic/44566/how-to-node-js-iobroker-richtig-updaten-2021-22-edition?page=1) vorgegangen, und da habe ich nichts gelesen, daß die Git-Adapter vorher entfernt werden müssen. Hätte ich das tun müssen?
                Thomas Braun Most Active @grrfield last edited by
                @grrfield
                Bei Updates wo es größere Versionssprünge bei npm gibt (zb Node.js 14->16 updated npm von 6.x auf 8.x) kann es sehr hilfreich sein wenn man schaut ob Adapter die von GitHub installiert wurden inzwischen in der gleichen version auf auf npm liegen und dann ggf von dort nochmals installieren oder updaten. Im Admin werden Adapter die per GitHub installiert wurden gesondert mit einem GitHub Symbol angezeigt. Das hilft auch im Vorfeld Probleme zu vermeiden.
                Das ist die Passage, die für dich relevant gewesen wäre.
                grrfield 1 Reply Last reply Reply Quote 1
                • grrfield
                  Oh, das hatte ich nicht so aufgefaßt, da einige Adapter (radar-trap) noch nicht auf npm sind. Das nächste Mal bin ich dann klüger.
                  Wie kann ich denn den Fehler, daß immer bei der Installation neuer Adapter immer noch nach den git-Adaptern gesucht wird, loswerden?
                    @grrfield
                    Schau wo der im tree liegt:
                    cd /opt/iobroker
                    npm ls iobroker.radar-trap
                    • nbrgit
                      nbrgit last edited by
                      ich versuche gerade diverse Adapter zu aktualisieren, leider ohne Erfolg.
                      Kurzer Ausschnitt was bei der "Update-Kachel" erscheint :
                      Dependencies:
                      js-controller (>=3.3.22): 4.0.23
                      node (>=12.0.0): 16.16.0
                      Der Button "Aktualisieren" ist ausgeblendet.
                      Ich weiß nicht so richtig weiter, denn wenn ich das richtig lese, sind alle Voraussetzungen erfüllt aber ein Update ist nicht möglich.
                      Kann mir jemand helfen?
                      LG
                      haselchen Thomas Braun 2 Replies Last reply Reply Quote 0
                      • haselchen
                        haselchen Most Active @nbrgit last edited by haselchen
                        @nbrgit
                        6 Zeilen unter Dir ist das gleiche Problem.
                        Warum nutzt du nicht den Thread?
                        @Negalein
                        @Homoran
                        Bitte zusammenführen
                        https://forum.iobroker.net/topic/55518/kann-keine-adapter-aktualisieren
                          Thomas Braun Most Active @nbrgit last edited by
                          @nbrgit
                          Was kommt vom System auf diese Befehle in der Kommandozeile zurück?
                          iobroker update -i
                          sudo ln -s /usr/bin/node /usr/bin/nodejs
                          uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                          cd /opt/iobroker
                          npm ls | grep -E 'github|ERR'
                          • grrfield
                            Vielen Dank! Ich hatte in der Zwischenzeit weiter nach einem Eintrag mit "radar-trap" gesucht und habe dann in der Datei /opt/iobroker/package.json eine Zeile
                             "iobroker.radar-trap": "github:Steiger04/ioBroker.radar-trap#59772746bcfedabc4482b47115ca8584a1381bd5",
                            gefunden und diese gelöscht (vorher eine Kopie der Datei erstellt).
                            Jetzt bekomme ich diese Fehlermeldung nicht mehr, sondern bin einen Schritt weiter und bekomme die Meldungen, die auch frank_y hat. Ich bin nun dabei, die Verzeichnisse, die als Meldungen ausgegeben werden, zu löschen. Könnte man auch einfach alle versteckten Verzeichnisse unter /opt/iobroker/node_modules löschen, also
                            rm -rf /opt/iobroker/node_modules/.*
                            Für mich das so aus, als ob das nur Sicherheitskopien sind, die vor einer Installation neu erstellt werden.
                              @grrfield
                              Vorsicht! Da liegt auch ein Verzeichnis .bin drin, das würde ich nicht unbedingt löschen.
                              grrfield 1 Reply Last reply Reply Quote 0
                              • grrfield
                                @thomas-braun Und der Rest?
                                  @grrfield
                                  Probier es aus...
                                  Ich kann/konnte es bei mir nicht nachstellen, ich hab keine Meldungen zu solchen Verzeichnissen bekommen, in meinem Dateipfad sind auch keine zu finden.
                                    Beispiel:
                                    Ich musste ca. 20 Verzeichnisse händisch löschen!
                                    Jetzt wird folgender Fehler ausgeworfen:
                                    XXXXXXX@iobrokerVM:/opt$ iobroker upgrade history  --debug
                                    node:internal/modules/cjs/loader:936
                                      throw err;
                                    Error: Cannot find module 'at-least-node'
                                    Require stack:
                                    - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/mkdirs/m        ake-dir.js
                                    - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/mkdirs/i        ndex.js
                                    - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/copy-syn        c/copy-sync.js
                                    - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/copy-syn        c/index.js
                                    - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/index.js
                                    - /opt/iobroker/node_modules/@alcalzone/pak/build/lib/package-managers/npm/ind        ex.js
                                    - /opt/iobroker/node_modules/@alcalzone/pak/build/lib/pak.js
                                    - /opt/iobroker/node_modules/@alcalzone/pak/build/index.js
                                    - /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.j        s
                                    - /opt/iobroker/node_modules/@iobroker/js-controller-common/index.js
                                    - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
                                    - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
                                        at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:        15)
                                        at Function.Module._load (node:internal/modules/cjs/loader:778:27)
                                        at Module.require (node:internal/modules/cjs/loader:1005:19)
                                        at require (node:internal/modules/cjs/helpers:102:18)
                                        at Object.<anonymous> (/opt/iobroker/node_modules/@alcalzone/pak/node_modu        les/fs-extra/lib/mkdirs/make-dir.js:9:21)
                                        at Module._compile (node:internal/modules/cjs/loader:1105:14)
                                        at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10        )
                                        at Module.load (node:internal/modules/cjs/loader:981:32)
                                        at Function.Module._load (node:internal/modules/cjs/loader:822:12)
                                        at Module.require (node:internal/modules/cjs/loader:1005:19) {
                                      code: 'MODULE_NOT_FOUND',
                                      requireStack: [
                                        '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/mkdir        s/make-dir.js',
                                        '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/mkdir        s/index.js',
                                        '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/copy-        sync/copy-sync.js',
                                        '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/copy-        sync/index.js',
                                        '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/index        .js',
                                        '/opt/iobroker/node_modules/@alcalzone/pak/build/lib/package-managers/npm/        index.js',
                                        '/opt/iobroker/node_modules/@alcalzone/pak/build/lib/pak.js',
                                        '/opt/iobroker/node_modules/@alcalzone/pak/build/index.js',
                                        '/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tool        s.js',
                                        '/opt/iobroker/node_modules/@iobroker/js-controller-common/index.js',
                                        '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
                                        '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                    Sieht nicht gut aus, oder?
                                      @frank_y
                                      iobroker stop
                                      cd /opt/iobroker
                                      sudo -H -u iobroker npm install iobroker.js-controller
                                        jetzt werden wieder Verzeichnisse angemeckert:
                                        npm ERR! path /opt/iobroker/node_modules/aws4
                                        npm ERR! dest /opt/iobroker/node_modules/.aws4-3BmHzpIi
                                        npm ERR! errno -39
                                        npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/aws4' -> '/opt/iobroker/node_modules/.aws4-3BmHzpIi'
                                        npm ERR!     /home/iobroker/.npm/_logs/2022-07-22T14_18_20_594Z-debug-0.log
                                        ich lösche mal weiter: rm -rf /opt/iobroker/node_modules/.aws4-3BmHzpIi
                                          Frank_y @Frank_y last edited by
                                          @frank_y
                                          es sind wieder mehrere Verzeichnisse....bisher 6...sehr mühsam
                                          Woran liegt das denn. Es lief ja alles?
                                            Ich weiß es nicht. Wenn man sich im Netz umschaut passiert das überwiegend bei Aktionen im npm tree die mit root-Rechten und/oder global durchgeführt wurden. Kann auch geraume Zeit her sein, da schlummern dann halt immer Zeitbomben.
                                            Als ich auf npm8 gewechselt bin hatte ich solche Probleme jedenfalls nicht.
                                            75
                                            8460
