    4. Adapterupdate schlägt fehl > Version dennoch hochgezogen
    • MichMein
      MichMein last edited by
      nun muss ich mich auch mal melden, auch wenn die Themen schon zahlreich vorhanden sind.
      Ich habe ein Updatedes Admin von 6.2.3 auf 6.2.4 machen wollen und folgendes hat sich ereignet:
      Update über die Konsole angestoßen mit folgendem Ergebnis,
      pi@ioBroker:/opt/iobroker $ iobroker upgrade --debug
      This upgrade of "admin" will introduce the following changes:
      -> 6.2.4:
      Corrected yahka settings
      Would you like to upgrade admin from @6.2.3 to @6.2.4 now? [(y)es, (n)o]: y
      Update admin from @6.2.3 to @6.2.4
      host.ioBroker Adapter "system.adapter.admin.0" is stopped.
      NPM version: 8.11.0
      Installing iobroker.admin@6.2.4... (System call)
      npm WARN skipping integrity check for git dependency ssh://git@github.com/MiGoller/ioBroker.xplora.git
      npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
      npm WARN deprecated har-validator@5.1.5: this library is no longer supported
      npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
      npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
      npm WARN deprecated multer@1.4.4: Multer 1.x is affected by CVE-2022-24434. This is fixed in v1.4.4-lts.1 which drops support for versions of Node.js before 6. Please upgrade to at least Node.js 6 and version 1.4.4-lts.1 of Multer. If you need support for older versions of Node.js, we are open to accepting patches that would fix the CVE on the main 1.x release line, whilst maintaining compatibility with Node.js 0.10.
      npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
      npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
      npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
      npm WARN deprecated uuid@3.3.2: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
      npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
      npm WARN deprecated axios@0.27.0: Formdata complete broken, incorrect build size
      npm ERR! code ENOTEMPTY
      npm ERR! syscall rename
      npm ERR! path /opt/iobroker/node_modules/node-red-node-email/node_modules/encoding-japanese/src
      npm ERR! dest /opt/iobroker/node_modules/.node-red-node-email-1lk8B7Gi/node_modules/encoding-japanese/src
      npm ERR! errno -39
      npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/node-red-node-email/node_modules/encoding-japanese/src' -> '/opt/iobroker/node_modules/.node-red-node-email-1lk8B7Gi/node_modules/encoding-japanese/src'
      npm ERR!     /home/iobroker/.npm/_logs/2022-07-22T17_42_27_099Z-debug-0.log
      host.ioBroker Cannot install iobroker.admin@6.2.4: 217
      Dann den Admin Adapter per Hand gestartet da er nicht lief und entdeckt das im Admin V6.2.4 steht,
      Und hier noch die Ausgaben der Konsole zu den Instanzen und Adaptern,
      pi@ioBroker:/opt/iobroker $ iobroker list instances
      + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.alias-manager.0          : alias-manager         : ioBroker                                 -  enabled
      + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
      + system.adapter.device-reminder.0        : device-reminder       : ioBroker                                 -  enabled
      + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
        system.adapter.echarts.0                : echarts               : ioBroker                                 - disabled
      + system.adapter.email.0                  : email                 : ioBroker                                 -  enabled
      + system.adapter.fb-checkpresence.0       : fb-checkpresence      : ioBroker                                 -  enabled
        system.adapter.feiertage.0              : feiertage             : ioBroker                                 -  enabled
      + system.adapter.go-e.0                   : go-e                  : ioBroker                                 -  enabled
      + system.adapter.heatingcontrol.0         : heatingcontrol        : ioBroker                                 -  enabled
      + system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
      + system.adapter.info.0                   : info                  : ioBroker                                 -  enabled
      + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
        system.adapter.linkeddevices.0          : linkeddevices         : ioBroker                                 - disabled
      + system.adapter.linux-control.0          : linux-control         : ioBroker                                 -  enabled
        system.adapter.minuvis.0                : minuvis               : ioBroker                                 - disabled
      + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1885, bind: 0.0.0.0
      + system.adapter.net-tools.0              : net-tools             : ioBroker                                 -  enabled
      + system.adapter.node-red.0               : node-red              : ioBroker                                 -  enabled, port: 1880, bind: 0.0.0.0
        system.adapter.openweathermap.0         : openweathermap        : ioBroker                                 -  enabled
      + system.adapter.rpi2.0                   : rpi2                  : ioBroker                                 -  enabled
      + system.adapter.sayit.0                  : sayit                 : ioBroker                                 -  enabled, port: 0
        system.adapter.scenes.0                 : scenes                : ioBroker                                 - disabled
        system.adapter.schoolfree.0             : schoolfree            : ioBroker                                 -  enabled
      + system.adapter.shuttercontrol.0         : shuttercontrol        : ioBroker                                 -  enabled
        system.adapter.shuttercontrol.1         : shuttercontrol        : ioBroker                                 - disabled
        system.adapter.shuttercontrol.2         : shuttercontrol        : ioBroker                                 - disabled
        system.adapter.smartcontrol.0           : smartcontrol          : ioBroker                                 - disabled
      + system.adapter.smartmeter.0             : smartmeter            : ioBroker                                 -  enabled
      + system.adapter.sonoff.0                 : sonoff                : ioBroker                                 -  enabled, port: 1884, bind: 0.0.0.0
      + system.adapter.sonos.0                  : sonos                 : ioBroker                                 -  enabled
      + system.adapter.sony-bravia.0            : sony-bravia           : ioBroker                                 -  enabled
      + system.adapter.sony-bravia.1            : sony-bravia           : ioBroker                                 -  enabled
      + system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 -  enabled
      + system.adapter.synology.0               : synology              : ioBroker                                 -  enabled, port: 5001
        system.adapter.vis.0                    : vis                   : ioBroker                                 - disabled
      + system.adapter.vw-connect.0             : vw-connect            : ioBroker                                 -  enabled
      + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.zigbee.0                 : zigbee                : ioBroker                                 -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_CC2538_USB_CDC-if00
      + instance is alive
      pi@ioBroker:/opt/iobroker $ iobroker list adapters
      system.adapter.admin                   : admin          - v6.2.3
      system.adapter.alias-manager           : alias-manager  - v1.2.6
      system.adapter.backitup                : backitup       - v2.4.10
      system.adapter.device-reminder         : device-reminder - v1.2.9
      system.adapter.discovery               : discovery      - v3.0.5
      system.adapter.echarts                 : echarts        - v1.0.12
      system.adapter.email                   : email          - v1.1.3
      system.adapter.fb-checkpresence        : fb-checkpresence - v1.1.19
      system.adapter.feiertage               : feiertage      - v1.1.0
      system.adapter.go-e                    : go-e           - v1.0.23
      system.adapter.heatingcontrol          : heatingcontrol - v2.9.1
      system.adapter.influxdb                : influxdb       - v3.1.7
      system.adapter.info                    : info           - v1.9.19
      system.adapter.javascript              : javascript     - v6.0.0
      system.adapter.linkeddevices           : linkeddevices  - v1.5.5
      system.adapter.linux-control           : linux-control  - v1.1.5
      system.adapter.minuvis                 : minuvis        - v2.3.0
      system.adapter.mqtt                    : mqtt           - v4.0.7
      system.adapter.net-tools               : net-tools      - v0.2.0
      system.adapter.node-red                : node-red       - v3.3.1
      system.adapter.openweathermap          : openweathermap - v0.3.0
      system.adapter.rpi2                    : rpi2           - v1.3.2
      system.adapter.sayit                   : sayit          - v1.12.6
      system.adapter.scenes                  : scenes         - v2.3.9
      system.adapter.schoolfree              : schoolfree     - v1.0.1
      system.adapter.shuttercontrol          : shuttercontrol - v1.4.14
      system.adapter.simple-api              : simple-api     - v2.7.0
      system.adapter.smartcontrol            : smartcontrol   - v1.2.1
      system.adapter.smartmeter              : smartmeter     - v3.3.4
      system.adapter.socketio                : socketio       - v6.1.8
      system.adapter.sonoff                  : sonoff         - v2.5.1
      system.adapter.sonos                   : sonos          - v2.2.3
      system.adapter.sony-bravia             : sony-bravia    - v1.0.9
      system.adapter.sourceanalytix          : sourceanalytix - v0.4.14
      system.adapter.synology                : synology       - v2.1.9
      system.adapter.vis                     : vis            - v1.4.15
      system.adapter.vw-connect              : vw-connect     - v0.0.51
      system.adapter.web                     : web            - v5.2.4
      system.adapter.ws                      : ws             - v2.1.3
      system.adapter.zigbee                  : zigbee         - v1.7.5
      Das macht irgendwie nen ganz schön verrückten Eindruck.
      pi@ioBroker:/opt/iobroker $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
      /usr/bin/nodejs
      v16.16.0
      /usr/bin/node
      v16.16.0
      /usr/bin/npm
      8.11.0
      nodejs:
        Installed: 16.16.0-deb-1nodesource1
        Candidate: 16.16.0-deb-1nodesource1
        Version table:
       *** 16.16.0-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
              100 /var/lib/dpkg/status
           10.24.0~dfsg-1~deb10u1 500
      Es muss doch irgendwie ne Lösung geben die Probleme seit den NodeJS Updates in den Griff zu bekommen. Ich habe ehrlicher Weise keine Lust ständig irgendwelche Verzeichnisse zu löschen nur damit sie wieder erstellt werden oder gar mein ganzes System neu aufzusetzen.
      Schönes Wochenende
      Qix- created this issue in visionmedia/debug
      closed ReDos Vulnerability Regression Visibility Notice #797
      mikeal created this issue in request/request
      open Request’s Past, Present and Future #3142
      MichMein Glasfaser 2 Replies Last reply Reply Quote 0
      • MichMein
        MichMein @MichMein last edited by
        @michmein
        Hier noch ein kleines Update aus der Konsole (es wurde nichts geändert, ich habe es nur im ersten Post vergessen),
        All adapters are up to date
        • Glasfaser
          Glasfaser @MichMein last edited by Glasfaser
          @michmein sagte in Adapterupdate schlägt fehl > Version dennoch hochgezogen:
          Nicht Böse sein ....aber :
          wenn man sich wie du im Beta -Zweig aufhält , kann es schon sein das es so zu diesem kommen kann .
          Da muß man schon sein System kennen bzw. auch mal was einstecken das sowas kommen kann .
          MichMein 1 Reply Last reply Reply Quote 1
          • MichMein
            MichMein @Glasfaser last edited by MichMein
            @glasfaser sagte in Adapterupdate schlägt fehl > Version dennoch hochgezogen:
            Danke für die Blumen, dessen bin ich mir durchaus bewusst und auch nicht böse. Diese Aussagen lassen sich sehr häufig hier im Forum lesen.
            Kann ich deiner Aussage denn entnehmen bzw. würdest du diese so umformulieren?
            "Wenn du NICHT im Beta-Zweig unterwegs gewesen wärst, dann wären diese Fehler NICHT aufgetaucht"?
            Ich danke dir.
