    3. Off Topic
    4. [done] pihole update. pfade stimmen nicht, proxmox update
      crunchip Forum Testing Most Active @Thomas Braun last edited by
      @thomas-braun meine sources.list mit pihole sieht so aus
      deb http://ftp.debian.org/debian bullseye main contrib
      deb http://ftp.debian.org/debian bullseye-updates main contrib
      deb http://security.debian.org bullseye-security main contrib
      • da_Woody
        da_Woody @Thomas Braun last edited by
        @thomas-braun thnx, anscheinend tippfehler meinereiner...
        gerade versucht nach @crunchip proxmox update. der nächste kack.
        root@Homeserver:~#  pve6to7 --full
        = CHECKING VERSION INFORMATION FOR PVE PACKAGES =
        Checking for package updates..
        WARN: updates for the following packages are available:
          pve-kernel-5.4, pve-kernel-5.4.195-1-pve, pve-kernel-helper
        Checking proxmox-ve package version..
        PASS: proxmox-ve package has version >= 6.4-1
        Checking running kernel version..
        PASS: expected running kernel '5.4.189-2-pve'.
        = CHECKING CLUSTER HEALTH/SETTINGS =
        SKIP: standalone node.
        = CHECKING HYPER-CONVERGED CEPH STATUS =
        SKIP: no hyper-converged ceph setup detected!
        = CHECKING CONFIGURED STORAGES =
        PASS: storage 'local' enabled and active.
        PASS: storage 'local-lvm' enabled and active.
        PASS: storage 'proxmoxbackup' enabled and active.
        = MISCELLANEOUS CHECKS =
        INFO: Checking common daemon services..
        PASS: systemd unit 'pveproxy.service' is in state 'active'
        PASS: systemd unit 'pvedaemon.service' is in state 'active'
        PASS: systemd unit 'pvestatd.service' is in state 'active'
        INFO: Checking for running guests..
        WARN: 4 running guest(s) detected - consider migrating or stopping them.
        INFO: Checking if the local node's hostname 'Homeserver' is resolvable..
        INFO: Checking if resolved IP is configured on local node..
        FAIL: Resolved node IP '192.168.1.35' not configured or active for 'Homeserver'
        INFO: Checking backup retention settings..
        PASS: no problems found.
        INFO: checking CIFS credential location..
        PASS: no CIFS credentials at outdated location found.
        INFO: Checking custom roles for pool permissions..
        INFO: Checking node and guest description/note legnth..
        PASS: All node config descriptions fit in the new limit of 64 KiB
        PASS: All guest config descriptions fit in the new limit of 8 KiB
        INFO: Checking container configs for deprecated lxc.cgroup entries
        PASS: No legacy 'lxc.cgroup' keys found.
        INFO: Checking storage content type configuration..
        INFO: Checking if the suite for the Debian security repository is correct..
        INFO: Make sure to change the suite of the Debian security repository from 'buster/updates' to 'bullseye-security' - in /etc/apt/sources.list:9
        SKIP: No containers on node detected.
        = SUMMARY =
        TOTAL:    20
        PASSED:   14
        SKIPPED:  3
        WARNINGS: 2
        FAILURES: 1
        ATTENTION: Please check the output for detailed information!
        Try to solve the problems one at a time and then run this checklist tool again.
        root@Homeserver:~#
        mich hat das schon länger gewundert, daß ich am server eine andere IP lese. dort seh ich am monitor https://192.168.1.35: 8006. der server hat aber 192.168.0.254:8006
        danke @Homoran fürs verschieben... 😉
          crunchip Forum Testing Most Active @da_Woody last edited by
          @da_woody sagte in pihole update. pfade stimmen nicht... proxmox update...:
          bist du damit mal "umgezogen" auf nen anderen Rechner?
          • da_Woody
            da_Woody @crunchip last edited by
            @crunchip nope. das ist noch immer der i5 von anfang an... 😵
            k, pihole hab ich mal erledigt mit deiner liste! 🙂
              crunchip Forum Testing Most Active @da_Woody last edited by crunchip
              @da_woody dann pass die IP an, unter
              /etc/issue
              danach sollte die Ausgabe auf deinem Bildschirm auch wieder stimmen
              bzw hast du zwei nics? zeig mal die Ausgabe von /etc/network/interfaces
              • da_Woody
                @crunchip sorry, musste mal weg. nachbar ist heute früh gestorben...
                # network interface settings; autogenerated
                # Please do NOT modify this file directly, unless you know what
                # you're doing.
                # If you want to manage parts of the network configuration manually,
                # please utilize the 'source' or 'source-directory' directives to do
                # so.
                # PVE will preserve these directives, but will NOT read its network
                # configuration from sourced files, so do not attempt to move any of
                # the PVE managed interfaces into external files!
                auto lo
                iface lo inet loopback
                iface eno1 inet manual
                auto vmbr0
                iface vmbr0 inet static
                        address 192.168.0.254/21
                        gateway 192.168.0.1
                        bridge-ports eno1
                        bridge-stp off
                        bridge-fd 0
                musste mich aber händisch dort hinhangeln... bei den anderen dingens bekomm ich
                root@Homeserver:/etc/network# /etc/network/interfaces
                -bash: /etc/network/interfaces: Permission denied
                root@Homeserver:/etc/network# /etc/issue
                -bash: /etc/issue: Permission denied
                  Hä warum, einfach auf dem Host eingeben
                  cat /etc/network/interfaces
                  Aber passt schon so, die IP ist die
                  192.168.0.254
                  Und das andere mit nano bearbeiten
                  nano /etc/issue
                  Und dort die richtige ip eintragen, das ändert dann die Eingabemaske wie oben in deinem Screen zu sehen.
                  Das muss man z.b. anpassen, bei einem Serverumzug, wenn eine neue IP vergeben wird, deshalb fragte ich.
                  Weshalb das bei dir allerdings nicht übereinstimmt, wundert mich.
                  Ps, oder hattest du nach dem Einrichten nachträglich die Ip geändert?
                  • da_Woody
                    @crunchip 😳 als linux nulpe...
                    cat war mir nicht bewusst. mit nano hab ich nach dem hinholpern das ja rauskopiert.
                    hüstel. die kiste hat mir damals ein "freund" eingerichtet. wie auch das LAN umgeschnitzt. alles was ich jetzt, teilweise kann, hab ich mir dann selbst beigebracht. klar, da wurde die IP auf 192.168.0.254 geändert. steht ja auch in der datei so drinnen. warum sich die kiste so meldet?
                    ich muss auch nach einem reboot jedesmal
                    ethtool -K eno1 gso off gro off tso off tx off rx off
                    eingeben. sonst gibts probleme. hab ich mal im proxmox forum gefunden. das seh ich nur auf dem überflüssigen monitor, der hal am homeserver angestoppelt ist.
                    btw: hab inzwischen auch die VM mit influx/grafana/tasmoadmin hoch gezogen... 🙂
                      Hast de es denn nu angepasst?
                      • da_Woody
                        @crunchip was soll ich anpassen? steht ja die richtige drinnen.
                        auto lo
                        auto vmbr0
                                gateway 192.168.0.1
                                bridge-ports eno1
                                bridge-stp off
                                bridge-fd 0
                        das ist ja mein problem, keine ahnung, wo die andere IP her kommt. 192.168.1.35 gibts in meinem router nicht.
                          @crunchip sagte in pihole update. pfade stimmen nicht... proxmox update...:
                          nano /etc/issue
                          Hab ich dir doch erklärt, beim einrichten, war es die
                          192.168.1.35, deshalb steht die auch in der Eingabemaske.
                          Wenn du nun die statische Ip änderst, bleibt die Anzeige unverändert, wie in deinem Fall, deshalb musst du /etc/issue manuell anpassen und dort die richtige eintragen.
                          • da_Woody
                            @crunchip hmpf. 2x jetzt nano /etc/issue geändert. nach nem neustart kommt wieder die 1.35
                            bin ich wirklich so dämlich? 🤕
                              @da_woody schnell mal nachgelesen, das ist nicht persistent, da muss ebenfalls /etc/hosts angepasst werden, sonst wir es immer wieder überschrieben.
                              da_Woody 2 Replies Last reply Reply Quote 1
                              • da_Woody
                                @crunchip thnx! schau ich mir nach der F1 an... 😉
                                  @da_woody bzw schau mal https://www.bachmann-lan.de/proxmox-login-banner-aendern/
                                  • da_Woody
                                    @crunchip werkstatt büro, F1, yellow flag... yeah, geklappt. 🙂
                                    PASS: Resolved node IP '192.168.0.254' configured and active on single interface.
                                    = SUMMARY =
                                    TOTAL:    20
                                    PASSED:   15
                                    SKIPPED:  3
                                    WARNINGS: 2
                                    FAILURES: 0
                                    root@Homeserver:~#
                                      @da_woody na also, dann steht dem upgrade ja nix mehr im Wege
                                      • da_Woody
                                        da_Woody @crunchip last edited by da_Woody
                                        @crunchip püh, mühsam nähert sich der eichhorn... 😉
                                        irgend nen schwachsinn muss ich doch verbrochen haben...
                                        denk mal, die unterste zeile wegklicken...
                                        ah, zeile 3 und 5...
                                        hmpf, geht nicht in proxmox...
                                        crunchip Meister Mopper 2 Replies Last reply Reply Quote 0
                                          ja den Haken entfernen bei enterprise list, die ober 4 müssen aktiv bleiben
                                          was zurück bleibt ist die Meldung
                                          weil du proxmox ja umsonst nutzt
                                          früher musste man das per shell erledigen, mittlerweile bequem per Gui
                                          • da_Woody
                                            @crunchip siehe letzte zeile. lässt sich nicht wegklicken... hrnz, mit doppelklick kommt deaktivieren. ich werd wirklich alt... 😄
                                            und das no subscription bekommt man temporär auch weg. irgendwo hab ich das mal gefunden. muss man nur nach jedem update neu machen. ob das mit 7.x auch noch funzt, k.a. ist aber egal.
                                            schankedön für die geduld und hilfe! 🤙
                                            pihole iobroker proxmox
                                            5083
