    4. Server Cannot start inMem-objects on port 9001
      apollon77 @Glasfaser last edited by
      @glasfaser oohh Danke ...!! Auf diese Idee war ich bei den doch "kleinen" Files nicht gekommen
      @Dieter_P Also wenn bei solchen "kleinen" Files hier Probleme mit der Lesegeschwindigkeit herrschen ... wie geht es denn so der SD Karte???
      Was sagt "dmesg"?
        Dieter_P @apollon77 last edited by
        @apollon77
        Dmesg gibt mir nichts sagendes raus, aber das heißt nichts ...
        pi@raspberrypi:~ $ dmesg
        [    0.000000] Booting Linux on physical CPU 0xf00
        [    0.000000] Linux version 5.10.103-v7+ (dom@buildbot) (arm-linux-gnueabihf-gc        c-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34)        #1529 SMP Tue Mar 8 12:21:37 GMT 2022
        [    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
        [    0.000000] CPU: div instructions available: patching division code
        [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instructio        n cache
        [    0.000000] OF: fdt: Machine model: Raspberry Pi 2 Model B Rev 1.1
        [    0.000000] random: fast init done
        [    0.000000] Memory policy: Data cache writealloc
        [    0.000000] Reserved memory: created CMA memory pool at 0x37400000, size 64 M        iB
        [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id share        d-dma-pool
        [    0.000000] Zone ranges:
        [    0.000000]   DMA      [mem 0x0000000000000000-0x000000003b3fffff]
        [    0.000000]   Normal   empty
        [    0.000000] Movable zone start for each node
        [    0.000000] Early memory node ranges
        [    0.000000]   node   0: [mem 0x0000000000000000-0x000000003b3fffff]
        [    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000003b3fffff]
        [    0.000000] On node 0 totalpages: 242688
        [    0.000000]   DMA zone: 2133 pages used for memmap
        [    0.000000]   DMA zone: 0 pages reserved
        [    0.000000]   DMA zone: 242688 pages, LIFO batch:63
        [    0.000000] percpu: Embedded 20 pages/cpu s50828 r8192 d22900 u81920
        [    0.000000] pcpu-alloc: s50828 r8192 d22900 u81920 alloc=20*4096
        [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
        [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 240555
        [    0.000000] Kernel command line: coherent_pool=1M snd_bcm2835.enable_compat_a        lsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 b        cm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  consol        e=ttyAMA0,115200 console=tty1 root=PARTUUID=a560571a-02 rootfstype=ext4 elevator        =deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
        [    0.000000] Kernel parameter elevator= does not have any effect anymore.
                       Please use sysfs to set IO scheduler for individual devices.
        [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes,        linear)
        [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, li        near)
        [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
        [    0.000000] Memory: 878812K/970752K available (10240K kernel code, 1312K rwda        ta, 2952K rodata, 1024K init, 862K bss, 26404K reserved, 65536K cma-reserved)
        [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
        [    0.000000] ftrace: allocating 32081 entries in 95 pages
        [    0.000000] ftrace: allocated 94 pages with 5 groups
        [    0.000000] rcu: Hierarchical RCU implementation.
        [    0.000000]  Rude variant of Tasks RCU enabled.
        [    0.000000]  Tracing variant of Tasks RCU enabled.
        [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jif        fies.
        [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
        [    0.000000] random: get_random_bytes called from start_kernel+0x3ac/0x580 wit        h crng_init=1
        [    0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
        [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles:        0x46d987e47, max_idle_ns: 440795202767 ns
        [    0.000011] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 43980        46511078ns
        [    0.000028] Switching to timer-based delay loop, resolution 52ns
        [    0.000379] Console: colour dummy device 80x30
        [    0.000477] printk: console [tty1] enabled
        [    0.000549] Calibrating delay loop (skipped), value calculated using timer fr        equency.. 38.40 BogoMIPS (lpj=192000)
        [    0.000588] pid_max: default: 32768 minimum: 301
        [    0.000868] LSM: Security Framework initializing
        [    0.001175] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linea        r)
        [    0.001214] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes,        linear)
        [    0.003088] cgroup: Disabling memory control group subsystem
        [    0.003465] CPU: Testing write buffer coherency: ok
        [    0.004177] CPU0: update cpu_capacity 1024
        [    0.004200] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
        [    0.005982] Setting up static identity map for 0x100000 - 0x10003c
        [    0.006249] rcu: Hierarchical SRCU implementation.
        [    0.007541] smp: Bringing up secondary CPUs ...
        [    0.009184] CPU1: update cpu_capacity 1024
        [    0.009198] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
        [    0.011182] CPU2: update cpu_capacity 1024
        [    0.011196] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
        [    0.012941] CPU3: update cpu_capacity 1024
        [    0.012953] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
        [    0.013183] smp: Brought up 1 node, 4 CPUs
        [    0.013212] SMP: Total of 4 processors activated (153.60 BogoMIPS).
        [    0.013226] CPU: All CPU(s) started in HYP mode.
        [    0.013240] CPU: Virtualization extensions available.
        [    0.014605] devtmpfs: initialized
        [    0.036137] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7        rev 5
        [    0.036520] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma        x_idle_ns: 19112604462750000 ns
        [    0.036563] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
        [    0.040621] pinctrl core: initialized pinctrl subsystem
        [    0.042317] NET: Registered protocol family 16
        [    0.047497] DMA: preallocated 1024 KiB pool for atomic coherent allocations
        [    0.054827] audit: initializing netlink subsys (disabled)
        [    0.055325] audit: type=2000 audit(0.050:1): state=initialized audit_enabled=        0 res=1
        [    0.056198] thermal_sys: Registered thermal governor 'step_wise'
        [    0.057468] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint        registers.
        [    0.057490] hw-breakpoint: maximum watchpoint size is 8 bytes.
        [    0.057887] Serial: AMBA PL011 UART driver
        [    0.078757] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
        [    0.090291] raspberrypi-firmware soc:firmware: Attached to firmware from 2021        -12-01T15:07:06, variant start
        [    0.100302] raspberrypi-firmware soc:firmware: Firmware hash is 71bd3109023a0        c8575585ba87cbb374d2eeb038f
        [    0.155584] Kprobes globally optimized
        [    0.163096] bcm2835-dma 3f007000.dma: DMA legacy API manager, dmachans=0x1
        [    0.166017] SCSI subsystem initialized
        [    0.166393] usbcore: registered new interface driver usbfs
        [    0.166486] usbcore: registered new interface driver hub
        [    0.166587] usbcore: registered new device driver usb
        [    0.169341] clocksource: Switched to clocksource arch_sys_counter
        [    1.921351] VFS: Disk quotas dquot_6.6.0
        [    1.921517] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
        [    1.921792] FS-Cache: Loaded
        [    1.922174] CacheFiles: Loaded
        [    1.937348] NET: Registered protocol family 2
        [    1.937703] IP idents hash table entries: 16384 (order: 5, 131072 bytes, line        ar)
        [    1.940954] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144        bytes, linear)
        [    1.941037] TCP established hash table entries: 8192 (order: 3, 32768 bytes,        linear)
        [    1.941163] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
        [    1.941361] TCP: Hash tables configured (established 8192 bind 8192)
        [    1.941620] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
        [    1.941704] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
        [    1.942069] NET: Registered protocol family 1
        [    1.943264] RPC: Registered named UNIX socket transport module.
        [    1.943285] RPC: Registered udp transport module.
        [    1.943301] RPC: Registered tcp transport module.
        [    1.943316] RPC: Registered tcp NFSv4.1 backchannel transport module.
        [    1.945472] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counter        s available
        [    1.950585] Initialise system trusted keyrings
        [    1.951022] workingset: timestamp_bits=14 max_order=18 bucket_order=4
        [    1.962988] zbud: loaded
        [    1.965836] FS-Cache: Netfs 'nfs' registered for caching
        [    1.967094] NFS: Registering the id_resolver key type
        [    1.967152] Key type id_resolver registered
        [    1.967169] Key type id_legacy registered
        [    1.967380] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
        [    1.967400] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering        ...
        [    1.969015] Key type asymmetric registered
        [    1.969036] Asymmetric key parser 'x509' registered
        [    1.969128] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2        49)
        [    1.969148] io scheduler mq-deadline registered
        [    1.969165] io scheduler kyber registered
        [    1.972615] bcm2708_fb soc:fb: FB found 1 display(s)
        [    1.981527] Console: switching to colour frame buffer device 82x26
        [    1.987088] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 656        x416
        [    1.994390] bcm2835-rng 3f104000.rng: hwrng registered
        [    1.994906] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000        000(1024 MiB)
        [    1.996118] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f2        00000
        [    2.014297] brd: module loaded
        [    2.031625] loop: module loaded
        [    2.033855] Loading iSCSI transport class v2.0-870.
        [    2.036515] usbcore: registered new interface driver lan78xx
        [    2.036609] usbcore: registered new interface driver smsc95xx
        [    2.036646] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
        [    2.765202] Core Release: 2.80a
        [    2.765226] Setting default values for core params
        [    2.765272] Finished setting default values for core params
        [    2.965776] Using Buffer DMA mode
        [    2.965794] Periodic Transfer Interrupt Enhancement - disabled
        [    2.965809] Multiprocessor Interrupt Enhancement - disabled
        [    2.965827] OTG VER PARAM: 0, OTG VER FLAG: 0
        [    2.965863] Dedicated Tx FIFOs mode
        [    2.966683] WARN::dwc_otg_hcd_init:1074: FIQ DMA bounce buffers: virt = b7514        000 dma = 0xf7514000 len=9024
        [    2.966726] FIQ FSM acceleration enabled for :
                       Non-periodic Split Transactions
                       Periodic Split Transactions
                       High-Speed Isochronous Endpoints
                       Interrupt/Control Split Transaction hack enabled
        [    2.966745] dwc_otg: Microframe scheduler enabled
        [    2.966851] WARN::hcd_init_fiq:457: FIQ on core 1
        [    2.966872] WARN::hcd_init_fiq:458: FIQ ASM at 807cb8b8 length 36
        [    2.966895] WARN::hcd_init_fiq:497: MPHI regs_base at bb810000
        [    2.966927] dwc_otg 3f980000.usb: DWC OTG Controller
        [    2.966982] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number        1
        [    2.967050] dwc_otg 3f980000.usb: irq 89, io mem 0x00000000
        [    2.967112] Init: Port Power? op_state=1
        [    2.967127] Init: Power Port (0)
        [    2.967662] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bc        dDevice= 5.10
        [    2.967685] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=        1
        [    2.967705] usb usb1: Product: DWC OTG Controller
        [    2.967724] usb usb1: Manufacturer: Linux 5.10.103-v7+ dwc_otg_hcd
        [    2.967742] usb usb1: SerialNumber: 3f980000.usb
        [    2.968865] hub 1-0:1.0: USB hub found
        [    2.968965] hub 1-0:1.0: 1 port detected
        [    2.970740] dwc_otg: FIQ enabled
        [    2.970759] dwc_otg: NAK holdoff enabled
        [    2.970774] dwc_otg: FIQ split-transaction FSM enabled
        [    2.970797] Module dwc_common_port init
        [    2.971265] usbcore: registered new interface driver usb-storage
        [    2.971675] mousedev: PS/2 mouse device common for all mice
        [    2.973300] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
        [    2.976005] sdhci: Secure Digital Host Controller Interface driver
        [    2.976027] sdhci: Copyright(c) Pierre Ossman
        [    2.976865] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
        [    2.977215] sdhci-pltfm: SDHCI platform and OF driver helper
        [    2.978450] ledtrig-cpu: registered to indicate activity on CPUs
        [    2.978937] hid: raw HID events driver (C) Jiri Kosina
        [    2.979156] usbcore: registered new interface driver usbhid
        [    2.979172] usbhid: USB HID core driver
        [    2.985931] Initializing XFRM netlink socket
        [    2.985995] NET: Registered protocol family 17
        [    2.986207] Key type dns_resolver registered
        [    2.986991] Registering SWP/SWPB emulation handler
        [    2.987208] registered taskstats version 1
        [    2.987251] Loading compiled-in X.509 certificates
        [    2.988502] Key type ._fscrypt registered
        [    2.988527] Key type .fscrypt registered
        [    2.988543] Key type fscrypt-provisioning registered
        [    3.003808] uart-pl011 3f201000.serial: cts_event_workaround enabled
        [    3.003952] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 114, base_baud        = 0) is a PL011 rev2
        [    3.004319] printk: console [ttyAMA0] enabled
        [    3.007413] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains drive        r
        [    3.010545] sdhost: log_buf @ (ptrval) (f7513000)
        [    3.059115] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
        [    3.063081] of_cfs_init
        [    3.063516] of_cfs_init: OK
        [    3.065068] Waiting for root device PARTUUID=a560571a-02...
        [    3.099579] Indeed it is in host mode hprt0 = 00021501
        [    3.192862] mmc0: host does not support reading read-only switch, assuming wr        ite-enable
        [    3.196368] mmc0: new high speed SDHC card at address aaaa
        [    3.197738] mmcblk0: mmc0:aaaa SE16G 14.8 GiB
        [    3.200877]  mmcblk0: p1 p2
        [    3.223717] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. O        pts: (null)
        [    3.223868] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [    3.224947] devtmpfs: mounted
        [    3.234729] Freeing unused kernel memory: 1024K
        [    3.259830] Run /sbin/init as init process
        [    3.259846]   with arguments:
        [    3.259861]     /sbin/init
        [    3.259889]     splash
        [    3.259903]   with environment:
        [    3.259916]     HOME=/
        [    3.259930]     TERM=linux
        [    3.309409] usb 1-1: new high-speed USB device number 2 using dwc_otg
        [    3.309667] Indeed it is in host mode hprt0 = 00001101
        [    3.550036] usb 1-1: New USB device found, idVendor=0424, idProduct=9514, bcd        Device= 2.00
        [    3.550070] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
        [    3.551267] hub 1-1:1.0: USB hub found
        [    3.551476] hub 1-1:1.0: 5 ports detected
        [    3.869438] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
        [    3.892639] systemd[1]: System time before build time, advancing clock.
        [    4.000015] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00, b        cdDevice= 2.00
        [    4.000052] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber        =0
        [    4.003306] smsc95xx v2.0.0
        [    4.037914] NET: Registered protocol family 10
        [    4.039933] Segment Routing with IPv6
        [    4.120340] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-        1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:c2:18:be
        [    4.143484] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SEL        INUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +        XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybr        id)
        [    4.145448] systemd[1]: Detected architecture arm.
        [    4.202443] systemd[1]: Set hostname to <raspberrypi>.
        [    4.229450] usb 1-1.4: new full-speed USB device number 4 using dwc_otg
        [    4.365851] usb 1-1.4: New USB device found, idVendor=10c4, idProduct=ea60, b        cdDevice= 1.00
        [    4.365893] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber        =3
        [    4.365915] usb 1-1.4: Product: CP2102N USB to UART Bridge Controller
        [    4.365934] usb 1-1.4: Manufacturer: Silicon Labs
        [    4.365954] usb 1-1.4: SerialNumber: 00b847ef8093eb118e34214f3d98b6d1
        [    4.527023] uart-pl011 3f201000.serial: no DMA platform data
        [    5.361818] random: systemd: uninitialized urandom read (16 bytes read)
        [    5.388310] random: systemd: uninitialized urandom read (16 bytes read)
        [    5.389603] systemd[1]: Set up automount Arbitrary Executable File Formats Fi        le System Automount Point.
        [    5.390174] random: systemd: uninitialized urandom read (16 bytes read)
        [    5.390292] systemd[1]: Reached target Swap.
        [    5.393436] systemd[1]: Created slice User and Session Slice.
        [    5.394821] systemd[1]: Listening on Journal Socket (/dev/log).
        [    5.396506] systemd[1]: Listening on Journal Audit Socket.
        [    5.397744] systemd[1]: Listening on Journal Socket.
        [    5.398904] systemd[1]: Condition check resulted in Huge Pages File System be        ing skipped.
        [    5.621499] i2c /dev entries driver
        [    6.354417] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
        [    6.508434] systemd-journald[117]: Received request to flush runtime journal        from PID 1
        [    7.389031] mc: Linux media interface: v0.10
        [    7.416572] vc_sm_cma: module is from the staging directory, the quality is u        nknown, you have been warned.
        [    7.420231] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
        [    7.420271] [vc_sm_connected_init]: start
        [    7.443996] [vc_sm_connected_init]: installed successfully
        [    7.452916] videodev: Linux video capture interface: v2.00
        [    7.503607] snd_bcm2835: module is from the staging directory, the quality is        unknown, you have been warned.
        [    7.525083] bcm2835_audio bcm2835_audio: card created with 8 channels
        [    7.532540] bcm2835_mmal_vchiq: module is from the staging directory, the qua        lity is unknown, you have been warned.
        [    7.534169] bcm2835_mmal_vchiq: module is from the staging directory, the qua        lity is unknown, you have been warned.
        [    7.535475] bcm2835_mmal_vchiq: module is from the staging directory, the qua        lity is unknown, you have been warned.
        [    7.541622] bcm2835_v4l2: module is from the staging directory, the quality i        s unknown, you have been warned.
        [    7.605403] bcm2835_isp: module is from the staging directory, the quality is        unknown, you have been warned.
        [    7.624902] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev        /video13
        [    7.625829] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /de        v/video14
        [    7.630793] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /de        v/video15
        [    7.637183] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/        video16
        [    7.637246] bcm2835-isp bcm2835-isp: Register output node 0 with media contro        ller
        [    7.637284] bcm2835-isp bcm2835-isp: Register capture node 1 with media contr        oller
        [    7.637316] bcm2835-isp bcm2835-isp: Register capture node 2 with media contr        oller
        [    7.637346] bcm2835-isp bcm2835-isp: Register capture node 3 with media contr        oller
        [    7.637698] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
        [    7.651075] bcm2835_codec: module is from the staging directory, the quality        is unknown, you have been warned.
        [    7.690077] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
        [    7.690200] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
        [    7.704296] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
        [    7.704394] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
        [    7.711239] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
        [    7.711342] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
        [    7.740003] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
        [    7.740087] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
        [    8.163484] usbcore: registered new interface driver usbserial_generic
        [    8.163618] usbserial: USB Serial support registered for generic
        [    8.177315] usbcore: registered new interface driver cp210x
        [    8.177464] usbserial: USB Serial support registered for cp210x
        [    8.177716] cp210x 1-1.4:1.0: cp210x converter detected
        [    8.187937] usb 1-1.4: cp210x converter now attached to ttyUSB0
        [   11.651879] random: crng init done
        [   11.651912] random: 7 urandom warning(s) missed due to ratelimiting
        [   11.844359] 8021q: 802.1Q VLAN Support v1.8
        [   12.079228] cfg80211: Loading compiled-in X.509 certificates for regulatory d        atabase
        [   12.196956] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
        [   12.210225] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:1        02396k SSFS
        [   12.482975] SMSC LAN8700 usb-001:003:01: attached PHY driver [SMSC LAN8700] (        mii_bus:phy_addr=usb-001:003:01, irq=POLL)
        [   12.483497] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
        [   12.501423] smsc95xx 1-1.1:1.0 eth0: Link is Down
        [   13.030561] wireguard: WireGuard 1.0.0 loaded. See www.wireguard.com for info        rmation.
        [   13.030599] wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld <Jason@zx2c        4.com>. All Rights Reserved.
        [   17.684181] smsc95xx 1-1.1:1.0 eth0: Link is Up - 100Mbps/Full - flow control        off
        [   17.684257] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
        [   18.807259] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net        .ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
        pi@raspberrypi:~ $
        @Glasfaser
        In der Cloud habe ich ein backup von Mai vom backitup Adapter. Auf dem Pi lokal hab ich noch nicht geschaut, ob da vielleicht noch länger etwas funktioniert hat. Aber nach etwas Überlegung ist der IOBroker vom Backup nicht meine größte Sorge. So wichtig/schwer ist die Konfig nicht wieder herzustellen. Aber normal würde ich dazu Raspi OS neu auf die SD-Karte schreiben und dann IOBroker neu installieren, aber dann ist meine Wireguard Konfiguration futsch. Hab mich zwar bemüht die Konfiguration zu dokumentieren, aber das war nicht inkomplex und die Routingtabellen etc. konnte ich nur mit großer Hilfe erstellen, insofern bin ich skeptisch und das wird mich sicher wieder Wochen kosten bis das läuft..... Kann ich IOBroker irgendwie "frisch hierüber bügeln"?
          apollon77 @Dieter_P last edited by
          @dieter_p sagte in Server Cannot start inMem-objects on port 9001:
          Das hast du mit den npm installs vom Controller quasi schon ... kannst jetzt nur noch iobroker-data löschen und "iob setup first" aufrufen. dann ist alles am cleansten ... Aber ich denke das es das nicht wirklich ist.
          Mal runterfahren und SD Karte prüfen?
            Dieter_P @apollon77 last edited by Dieter_P
            @apollon77
            hab mal versucht und nach dem Reboot fsck eingetragen in diese Datei um es beim Booten auszuführen. Gefühlt dauert der Reboot jetzt länger aber einen "Beweis" das dort etwas passiert habe ich nicht. Die boot.log Datei zeigt nichts bzgl. fsck.
            Sonst sehe ich derzeit mit gestoppten IOBroker wieder einen status und kann updaten (nicht no connection to db). Sobald ich aber starte wieder der Statusfehler und kein Zugriff auf den IOB über den Browser etc:
            pi@raspberrypi:~ $ iob stop
            pi@raspberrypi:~ $ iob status
            iobroker is not running on this host.
            Objects type: jsonl
            States  type: jsonl
            pi@raspberrypi:~ $ iob start
            Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iob        roker/iobroker-data/objects.jsonl"!
            pi@raspberrypi:~ $ iob update
            Used repository: stable
            Adapter    "admin"        : 5.3.8    , installed 5.3.8
            Adapter    "alias-manager": 1.2.4    , installed 1.2.4
            Adapter    "backitup"     : 2.4.9    , installed 2.4.9
            Adapter    "discovery"    : 3.0.3    , installed 3.0.3
            Adapter    "email"        : 1.1.3    , installed 1.1.3
            Adapter    "flot"         : 1.11.0   , installed 1.11.0
            Adapter    "history"      : 1.11.1   , installed 1.11.1
            Adapter    "info"         : 1.9.19   , installed 1.9.19
            Adapter    "javascript"   : 5.7.0    , installed 5.7.0
            Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
            Adapter    "vis"          : 1.4.15   , installed 1.4.15
            Adapter    "zigbee"       : 1.7.5    , installed 1.7.5
            pi@raspberrypi:~ $
              @dieter_p also ich bin weiterhin der Meinung das du ein Netzwerk issue hast.
              Weil das dieser Fehler bei iob status kommt wenn iob läuft bedeuteter versucht eine Neue dB zu öffnen was natürlich nicht geht weil schon eine läuft. Der Fehler ist damit korrekt.
              Hattest du mal auf 0.0.0.0 was listening angeht geändert in der iobroker.json??
                @apollon77
                In der /opt/iobroker/iobroker-data/iobroker.json?
                Ja, gerade nochmal geprüft und in states und objects steht 0.0.0.0 drin
                Vielen Dank. Ich glaube langsam muß ich mal gröbere Ansätze wählen. Ich pack später mal eine andere SD Karte rein und und teste mit dem Backup und einer neuen Installation. Klappt das probiere ich mein Glück mit Wireguard und klappt das auch, hätte ich eine Lösung. Erscheint mir der konstruktivere Ansatz, oder?
                  @dieter_p also ja. Prüfen das wireguard hier nicht der Auslöser der issues ist macht sehr viel Sinn. Inzwischen wäre das nämlich meine Vermutung nummeri uno
                    @apollon77
                    Thx. Woran es lag kann ich leider nicht sagen. Eine Neuinstallation auf frischer SD-Karte brachte den IOBroker wieder in Funktion. Die derzeitige 99% Installation von Wireguard funktioniert auch wieder. Bleibt für mich noch das Thema SourceNat und iptables aufzudröseln (wieder zu verahnen warum dies wie funktionieren muß) und irgendwie auf die aktuelle bullseye Installation mit nftables zu bringen, aber das hat nun nix mit IOBroker zu tun. Deswegen Danke und beste Grüße
                    radicalreel 1 Reply Last reply Reply Quote 1
                    • radicalreel
                      radicalreel @Dieter_P last edited by radicalreel
                      @dieter_p Habe den Fehler seit Heute auch. Habe ein Backup der SDKarte gemacht um danach updates zu starten. Als ich die SDKarte wieder eingesteckt habe ging nichts mehr. Habe das gezogene Backup auch mal auf eine andere Karte gepackt... ging leider auch nicht. Jetzt ist mirs aber zu spät... gehe erstmal pennen.
                        apollon77 @radicalreel last edited by
                        @radicalreel na dann bitte mehr Details und bitte mal ein „ls -la /opt/iobroker/iobroker-data“ zeigen
                        radicalreel 1 Reply Last reply Reply Quote 0
                        • radicalreel
                          radicalreel @apollon77 last edited by
                          @apollon77
                          Soo jetzt habe ich ein wenig Zeit. Also es läuft nur iobroker auf diesem RP pi 3. Bin direkt über ein LAN Kabel drin. Fix habe ich probiert.. hat leider nicht geholfen.
                          Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                          permitted by applicable law.
                          Last login: Mon Jul 25 16:43:30 2022 from 192.168.178.45
                          pi@ioBroker-Pi:~ $ ls -la /opt/iobroker/iobroker-data
                          insgesamt 548708
                          drwxrwxrwx+   8 iobroker iobroker      4096 Jul 25 16:53 .
                          drwxrwxrwx+   8 iobroker iobroker      4096 Jul 23 23:23 ..
                          drwxrwxr-x+   2 iobroker iobroker      4096 Mär 17 21:39 backitup
                          drwxrwxrwx+   2 iobroker iobroker     12288 Jul 23 20:28 backup-objects
                          drwxrwxrwx+  23 iobroker iobroker      4096 Mär  9 22:01 files
                          drwxrwxrwx+ 596 iobroker iobroker     20480 Jul 23 22:13 history
                          -rwxrwxrwx+   1 iobroker iobroker      3647 Mär 17 17:22 iobroker.json
                          -rw-rwxr--+   1 iobroker iobroker         3 Jul 23 22:13 notifications.json
                          -rw-rwxr--+   1 iobroker iobroker   6070113 Mär 17 17:17 objects.json.bak.migrated
                          -rw-rwxr--+   1 iobroker iobroker 546038178 Jul 23 22:13 objects.jsonl
                          drwxrwxr-x+   2 iobroker iobroker      4096 Jul 25 16:53 objects.jsonl.lock
                          -rw-rwxr--+   1 iobroker iobroker   6070754 Mär 17 17:22 objects.json.migrated
                          -rw-rwxr--+   1 iobroker iobroker    469250 Mär 17 17:20 states.json.bak.migrated
                          -rw-rwxr--+   1 iobroker iobroker         0 Feb 26 08:06 states.json.broken
                          -rw-rwxr--+   1 iobroker iobroker   2675918 Jul 23 22:13 states.jsonl
                          -rw-rwxr--+   1 iobroker iobroker    469394 Mär 17 17:22 states.json.migrated
                          drwxrwxrwx+   3 iobroker iobroker      4096 Apr 28  2019 tmp
                          pi@ioBroker-Pi:~ $
                            @radicalreel sagte in Server Cannot start inMem-objects on port 9001:
                            Ok ,, die ist recht groß UND es gibt eine objects.jsonl.lock ... die bitte mal löschen (letztere)
                            Damit wäre ich bei der Variante mal für einen Start den timeout bei objects hochzusetzen.-
                            Bei gestoppptem iobroker mal /opt/iobroker/iobroker-data/iobroker.json editieren und dort unter objects und am besten auch states (siehe https://forum.iobroker.net/topic/54570/gelöst-iob-update-no-connection-to-databases-possible).
                            Dann nach der Änderung mach mal nur "iob list instances" oder so. Geht das? Wenn ja wie groß ist die objects.jsonl dann?
                            Und stelle sicher das du js-controller 4.0.23 oder so hast ... also was aktuelles ... Du hast nicht gesagt was Du hast
                            • David G.
                              Heute hatte ich die besagt Meldung auch zum ersten mal im Log.
                              Mein System war heute morgen nicht mehr erreichbar. Auch nicht per ssh erreichbar.
                              Nach einem reboot war der Fehler der letzte im ioBroker Log bevor er offline war.
                              Vorher gab es noch eine Meldung vom js-Controller.
                              Finde aber nicht, wo er beendet worden sein soll.
                              2022-09-01 00:20:54.747 - info: host.pi iobroker.js-controller version 4.0.23 js-controller starting
                              2022-09-01 00:20:54.755 - info: host.pi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                              2022-09-01 00:20:54.756 - info: host.pi hostname: pi, node: v16.17.0
                              2022-09-01 00:20:54.757 - info: host.pi ip addresses:
                              2022-09-01 00:20:56.857 - error: host.pi-Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
                              pi@pi:~ $ iob v
                              4.0.23
                              pi@pi:~ $ node -v
                              v16.17.0
                              pi@pi:~ $ npm -v
                              8.15.0
                              pi@pi:~ $
                                apollon77 @David G. last edited by
                                @david-g Am Ende ist mehr Interessant was DAVOR passiert ist. Also wie hört das Log auf wo es stehen geblieben ist? Was steht ggf in /var/log/syslog? Wie gross sind die Dateien /opt/iobroker/iobroker-data/*.jsonl ?
                                Ingo
                                R David G. 2 Replies Last reply Reply Quote 0
                                  Rene 3 @apollon77 last edited by
                                  @apollon77 Hi, ich habe das gleiche Problem seit 28.08.2022 mit einem Raspi4 und einer SSD. Die Datei objects.jsonl.lock kann nicht gelöscht werden, wenn der iobroker läuft, wird sie bei mir gleich wieder erzeugt. Sie ist nur 4096 Byte groß ???
                                    apollon77 @Rene 3 last edited by
                                    @rene-3 Laaaangsam ... Ja diese Datei existiert sobald iobroker löuft oder irgendein prozess die Datenbank anbietet - weil es verhindert werden muss das ein weiterer prozess die DB öffnet. Das ist komplett korrekt so! Also das das File da ist ist per se kein Problem!
                                    Man muss jetzt schauen was genau das problem ist wenn Ihr diesenF ehler bekommt weil dann irgendetwas versucht die DB nochmals zu öffnen.
                                    Daher gleiche Fragen wie oben bitte beantworten!
                                      @apollon77 iob_error_5.JPG ... die letzten Einträge in /var/log/syslog sehen bei mir so aus.
                                        @rene-3 1.) Keine Grafiken, bitte text
                                        2.) mmeeehhhrrrrrrr Log 🙂
                                        Spontan sieht das nach nem Reboot aus ... Warumm ... mehr log
                                          @apollon77 ... da steht leider nicht mehr im Log ( /var/log/syslog ). Während bis zum 27.08.2022 immer wieder nur die Time Synchronisation hier regelmäßig eingetragen wurde, ist das ja seltsamerweise ab dem 28.08.2022 nicht mehr so zu sehen. Oder meinst du jetzt andere Logs ?
                                          iob fix scheint durchzulaufen und wird "erfolgreich" beendet aber alles andere scheitert.
                                          Komme nur über vnc an den Rasberrypi - über den Browser ist nichts mehr erreichbar.
                                            Thomas Braun Most Active @Rene 3 last edited by Thomas Braun
                                            @rene-3 sagte in Server Cannot start inMem-objects on port 9001:
                                            Per ssh...
                                            VNC ist "verboten"!
                                            Desktop ausschalten, kostet dich eh nur unnütz Ressourcen, die du anderweitig eher gebrauchen kannst.
                                            429
                                            81557
