    4. Einige Adapter starten nicht mehr
      Homoran Global Moderator Administrators @kalle-r last edited by Homoran
      @kalle-r sagte in Einige Adapter starten nicht mehr:
      Danach ist dann der Admin Adapter nicht mehr gestartet.
      was sagt iobroker update -i?
        kalle-r @Homoran last edited by
        Used repository: Beta (latest)
        Adapter    "admin"        : 6.2.4    , installed 6.2.4
        Adapter    "alexa2"       : 3.18.6   , installed 3.18.6
        Adapter    "backitup"     : 2.4.10   , installed 2.4.10
        Adapter    "daswetter"    : 3.1.3    , installed 3.1.3
        Adapter    "device-reminder": 1.2.9  , installed 1.2.9
        Adapter    "devices"      : 1.0.12   , installed 1.0.12
        Adapter    "discovery"    : 3.0.5    , installed 3.0.5
        Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
        Adapter    "flot"         : 1.11.0   , installed 1.11.0
        Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
        Adapter    "history"      : 2.2.0    , installed 2.2.0
        Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
        Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
        Adapter    "hs100"        : 2.0.7    , installed 2.0.7
        Adapter    "ical"         : 1.13.1   , installed 1.13.1
        Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
        Adapter    "info"         : 1.9.19   , installed 1.9.19
        Adapter    "iot"          : 1.11.9   , installed 1.11.9
        Adapter    "javascript"   : 6.0.0    , installed 6.0.0
        Adapter    "mihome"       : 1.4.0    , installed 1.4.0
        Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
        Adapter    "ping"         : 1.5.3    , installed 1.5.3
        Adapter    "pushover"     : 3.0.2    , installed 3.0.2
        Adapter    "samsung"      : 0.5.11   , installed 0.5.11
        Adapter    "shelly"       : 6.0.0    , installed 6.0.0
        Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
        Adapter    "socketio"     : 6.1.8    , installed 6.1.8
        Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
        Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
        Adapter    "synology"     : 2.1.9    , installed 2.1.9
        Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
        Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
        Adapter    "trashschedule": 2.0.3    , installed 2.0.3
        Adapter    "tuya"         : 3.6.15   , installed 3.6.15
        Adapter    "vis"          : 1.4.15   , installed 1.4.15
        Adapter    "vis-canvas-gauges": 0.1.5, installed 0.1.5
        Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
        Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
        Adapter    "vis-material" : 0.1.3    , installed 0.1.3
        Adapter    "vis-material-webfont": 0.0.3, installed 0.0.3
        Adapter    "web"          : 5.2.4    , installed 5.2.4
        Adapter    "ws"           : 2.1.3    , installed 2.1.3
        Adapter    "zigbee"       : 1.7.6    , installed 1.7.6
          Leider hab ich nur so ein gefährliches Halbwissen.
          und trotzdem (oder deshalb?) bist du als Betatester unterwegs?
          Da hab ich jetzt nich alle issues und Abhängigkeiten parat. Bin auch nur am Handy.
          Sorry
            Thomas Braun Most Active @kalle-r last edited by
            @kalle-r
            Wie bist du denn sonst unterwegs?
            sudo ln -s /usr/bin/node /usr/bin/nodejs
            uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
            cd /opt/iobroker
            npm ls | grep -E 'github|ERR'
            • Glasfaser
              Glasfaser @kalle-r last edited by Glasfaser
              NPM-Version:
              8.15.0
              Wieder selbst Hand angelegt !?
              EDIT :
              sieht auch danach aus :
              Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually
                Nein, normalerweise steht alles auf stable. Nachdem ich die Instanzen aber nicht zum starten gebracht habe
                hab ich mal im Beta nachgeschaut ob es evtl. Updates für die Adapter gibt und gehofft daß sich das Startproblem dabei löst. Es gab auch von manchen der betroffenen Adapter Updates, geholfen hat's nur leider nix.
                @Thomas-Braun
                ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
                pi@raspi4-iobroker:/opt/iobroker $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                armv7l
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                v16.16.0
                v16.16.0
                8.15.0
                pi
                /opt/iobroker
                OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                OK:2 http://archive.raspberrypi.org/debian buster InRelease
                OK:3 https://deb.nodesource.com/node_16.x buster InRelease
                Alle Pakete sind aktuell.
                nodejs:
                  Installiert:           16.16.0-deb-1nodesource1
                  Installationskandidat: 16.16.0-deb-1nodesource1
                  Versionstabelle:
                 *** 16.16.0-deb-1nodesource1 500
                        500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                        100 /var/lib/dpkg/status
                     10.24.0~dfsg-1~deb10u1 500
                pi@raspi4-iobroker:/opt/iobroker $ npm ls | grep -E 'github|ERR'
                ├── iobroker.sourceanalytix@0.4.14 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.sourceanalytix.git#42c45d3e9a581869b0ba9cf710dbecb42ca3e574)
                @Glasfaser
                Wie oben schon geschrieben: Ich hab halt viel gegoogelt und gemacht was ich da so alles an Fehlerbehebungen gefunden hab. Irgendwann kam dann daß es eine neue NPM Version gibt, da hab ich dann halt auch das upgedatet. Aber geändert hat sich dadurch leider nix. Ich hab die Ausgabe so interpretiert daß ich das im Verzeichnis von hm-rega machen soll:
                pi@raspi4-iobroker:/opt/iobroker/iobroker-data/files/hm-rega $ npm install --production
                npm WARN config production Use `--omit=dev` instead.
                > iobroker.inst@2.0.3 install
                > node lib/checkVersions.js
                NPM version: 8.15.0
                > iobroker.inst@2.0.3 postinstall
                > node lib/install.js
                lib/install.js is not being run as part of an installation - skipping...
                up to date in 10s
                wegen der Meldung hab ich dann auch npm install --omit=dev gemacht, hat aber auch nix geholfen...
                  sourceanalytix
                  iobroker stop
                  sudo apt install --reinstall nodejs
                  iobroker upgrade sourceanalytix@0.4.14
                  iobroker start
                  Homoran K 2 Replies Last reply Reply Quote 0
                    @thomas-braun sagte in Einige Adapter starten nicht mehr:
                    ohne --debug?
                      Ja, das soll nur vom git auf das Repo umgehoben werden.
                        kalle-r @Thomas Braun last edited by kalle-r
                        beim sourceanalytix kam eine Frage ob ich die Version nochmal installieren will. Hab das mit Ja bestätigt.
                        Leider keine Änderung, die betroffenen Instanzen starten nicht
                        bei allen die nicht starten ist "Verbunden mit Host" und "Lebenszeichen" inaktiv
                          @kalle-r
                          Und was haben die Adapter im Log File für Beschwerden?
                          iobroker logs --watch | uniq
                          und dann mal einen Adapter neustarten.
                            ich hab mal die betroffenen Adapter alle gestoppt und dann den Zigbee Adapter gestartet, das Log
                            host.raspi4-iobroker
                            	2022-07-24 20:09:39.568	info	Rebuild for adapter system.adapter.zigbee.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                            	2022-07-24 20:09:39.568	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            	2022-07-24 20:09:39.567	error	Caught by controller[0]: }
                            	2022-07-24 20:09:39.567	error	Caught by controller[0]: ]
                            	2022-07-24 20:09:39.567	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.zigbee/main.js'
                            	2022-07-24 20:09:39.567	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js',
                            	2022-07-24 20:09:39.567	error	Caught by controller[0]: '/opt/iobroker/node_modules/request/index.js',
                            	2022-07-24 20:09:39.567	error	Caught by controller[0]: '/opt/iobroker/node_modules/request/request.js',
                            	2022-07-24 20:09:39.567	error	Caught by controller[0]: '/opt/iobroker/node_modules/request/lib/har.js',
                            	2022-07-24 20:09:39.566	error	Caught by controller[0]: '/opt/iobroker/node_modules/har-validator/lib/promise.js',
                            	2022-07-24 20:09:39.566	error	Caught by controller[0]: '/opt/iobroker/node_modules/ajv/lib/ajv.js',
                            	2022-07-24 20:09:39.566	error	Caught by controller[0]: '/opt/iobroker/node_modules/ajv/lib/keyword.js',
                            	2022-07-24 20:09:39.566	error	Caught by controller[0]: '/opt/iobroker/node_modules/ajv/lib/definition_schema.js',
                            	2022-07-24 20:09:39.566	error	Caught by controller[0]: requireStack: [
                            	2022-07-24 20:09:39.565	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                            	2022-07-24 20:09:39.565	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1005:19) {
                            	2022-07-24 20:09:39.565	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:822:12)
                            	2022-07-24 20:09:39.565	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:981:32)
                            	2022-07-24 20:09:39.565	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10)
                            	2022-07-24 20:09:39.565	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1105:14)
                            	2022-07-24 20:09:39.564	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/ajv/lib/definition_schema.js:3:18)
                            	2022-07-24 20:09:39.564	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:102:18)
                            	2022-07-24 20:09:39.564	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1005:19)
                            	2022-07-24 20:09:39.564	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:778:27)
                            	2022-07-24 20:09:39.564	error	Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)
                            	2022-07-24 20:09:39.564	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/main.js
                            	2022-07-24 20:09:39.563	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js
                            	2022-07-24 20:09:39.563	error	Caught by controller[0]: - /opt/iobroker/node_modules/request/index.js
                            	2022-07-24 20:09:39.563	error	Caught by controller[0]: - /opt/iobroker/node_modules/request/request.js
                            	2022-07-24 20:09:39.563	error	Caught by controller[0]: - /opt/iobroker/node_modules/request/lib/har.js
                            	2022-07-24 20:09:39.563	error	Caught by controller[0]: - /opt/iobroker/node_modules/har-validator/lib/promise.js
                            	2022-07-24 20:09:39.562	error	Caught by controller[0]: - /opt/iobroker/node_modules/ajv/lib/ajv.js
                            	2022-07-24 20:09:39.562	error	Caught by controller[0]: - /opt/iobroker/node_modules/ajv/lib/keyword.js
                            	2022-07-24 20:09:39.562	error	Caught by controller[0]: - /opt/iobroker/node_modules/ajv/lib/definition_schema.js
                            	2022-07-24 20:09:39.562	error	Caught by controller[0]: Require stack:
                            	2022-07-24 20:09:39.562	error	Caught by controller[0]: Error: Cannot find module './refs/json-schema-draft-07.json'
                            	2022-07-24 20:09:39.561	error	Caught by controller[0]: ^
                            	2022-07-24 20:09:39.561	error	Caught by controller[0]: throw err;
                            	2022-07-24 20:09:39.561	error	Caught by controller[0]: node:internal/modules/cjs/loader:936
                            	2022-07-24 20:09:36.406	info	instance system.adapter.zigbee.0 started with pid 30827
                            	2022-07-24 20:09:35.845	info	"system.adapter.zigbee.0" enabled
                            das log vom Starten des hm-rega Adapters hängt ja ganz oben
                            • Glasfaser
                              @kalle-r
                              Da stimmt etwas nicht mit deiner Nodejs
                              den ( alle ) Adapter sind am mekern .
                              @Thomas-Braun
                              Eine Neuinstallation ( Raspberry ) , dann Backup einspielen briegt es besser , denn er hat alles in BETA sich reingeschaufelt
                                hier mal das Log vom Starten des Shelly Adapters
                                2022-07-24 20:13:27.171  - info: host.raspi4-iobroker "system.adapter.shelly.0" enabled
                                2022-07-24 20:13:27.898  - info: host.raspi4-iobroker instance system.adapter.shelly.0 started with pid 31107
                                2022-07-24 20:13:29.397  - error: host.raspi4-iobroker Caught by controller[0]: node:internal/modules/cjs/loader:361
                                2022-07-24 20:13:29.398  - error: host.raspi4-iobroker Caught by controller[0]:       throw err;
                                2022-07-24 20:13:29.398  - error: host.raspi4-iobroker Caught by controller[0]:       ^
                                2022-07-24 20:13:29.398  - error: host.raspi4-iobroker Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/process-nextick-args/index.js'. Please verify that the package.json has a valid "main" entry
                                2022-07-24 20:13:29.398  - error: host.raspi4-iobroker Caught by controller[0]:     at tryPackage (node:internal/modules/cjs/loader:353:19)
                                2022-07-24 20:13:29.399  - error: host.raspi4-iobroker Caught by controller[0]:     at Function.Module._findPath (node:internal/modules/cjs/loader:566:18)
                                2022-07-24 20:13:29.399  - error: host.raspi4-iobroker Caught by controller[0]:     at Function.Module._resolveFilename (node:internal/modules/cjs/loader:919:27)
                                2022-07-24 20:13:29.399  - error: host.raspi4-iobroker Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:778:27)
                                2022-07-24 20:13:29.399  - error: host.raspi4-iobroker Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1005:19)
                                2022-07-24 20:13:29.399  - error: host.raspi4-iobroker Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:102:18)
                                2022-07-24 20:13:29.399  - error: host.raspi4-iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/readable-stream/lib/_stream_readable.js:26:11)
                                2022-07-24 20:13:29.400  - error: host.raspi4-iobroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1105:14)
                                2022-07-24 20:13:29.400  - error: host.raspi4-iobroker Caught by controller[0]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10)
                                2022-07-24 20:13:29.400  - error: host.raspi4-iobroker Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32) {
                                2022-07-24 20:13:29.400  - error: host.raspi4-iobroker Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                                2022-07-24 20:13:29.400  - error: host.raspi4-iobroker Caught by controller[0]:   path: '/opt/iobroker/node_modules/process-nextick-args/package.json',
                                2022-07-24 20:13:29.401  - error: host.raspi4-iobroker Caught by controller[0]:   requestPath: 'process-nextick-args'
                                2022-07-24 20:13:29.401  - error: host.raspi4-iobroker Caught by controller[0]: }
                                2022-07-24 20:13:29.401  - error: host.raspi4-iobroker instance system.adapter.shelly.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                2022-07-24 20:13:29.401  - info: host.raspi4-iobroker Rebuild for adapter system.adapter.shelly.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                                Thomas Braun Glasfaser 2 Replies Last reply Reply Quote 0
                                  @kalle-r
                                  Ja, deine Kompliler wollen nicht mehr. Ich hab aber keinen Dunst warum.
                                  • Glasfaser
                                    @kalle-r
                                    Wie lange hast du gewartet mit dem Backup einspielen ,,, das sieht noch weiter so aus als hättest du nicht lang genug gewartet ... deshalb fehlt die hälfte
                                      Homoran Global Moderator Administrators @Glasfaser last edited by
                                      @glasfaser ich fürchte er hat sich mit npm 8.15 alles zerschossen.
                                      ichbweiß gar nicht ob @kalle-r wieder mit node/npm sauber unterwegs ist
                                      mein Holzhammer wäre dann
                                      package-lock.json löschen
                                      npm cache clean --force
                                      update und ggf rebuild
                                      Glasfaser K 2 Replies Last reply Reply Quote 0
                                        Homoran Global Moderator Administrators @Glasfaser last edited by Homoran
                                        @glasfaser sagte in Einige Adapter starten nicht mehr:
                                        doch, aber
                                        • Glasfaser
                                          Glasfaser @Homoran last edited by
                                          Er hat aber leider den Beta Status , auch noch dazu .
                                          Eher einen Neuanfang würde ich sagen ...
                                            kalle-r @Glasfaser last edited by
                                            @glasfaser
                                            gute Frage.... das hat eine ganze Weile gedauert....
                                            soll ich das einfach nochmal starten?
                                            Ich hab von jedem Tag ein Backup, ich kann z.B. ja auch mal eins von vor dem Urlaub einspielen
                                            als definitiv alles noch lief...
                                            1440
