    3. Off Topic
    4. [done] pihole update. pfade stimmen nicht, proxmox update
    • da_Woody
      da_Woody @crunchip last edited by
      @crunchip hmpf. 2x jetzt nano /etc/issue geändert. nach nem neustart kommt wieder die 1.35
      bin ich wirklich so dämlich? 🤕
        crunchip Forum Testing Most Active @da_Woody last edited by
        @da_woody schnell mal nachgelesen, das ist nicht persistent, da muss ebenfalls /etc/hosts angepasst werden, sonst wir es immer wieder überschrieben.
        da_Woody 2 Replies Last reply Reply Quote 1
        • da_Woody
          @crunchip thnx! schau ich mir nach der F1 an... 😉
            @da_woody bzw schau mal https://www.bachmann-lan.de/proxmox-login-banner-aendern/
            • da_Woody
              @crunchip werkstatt büro, F1, yellow flag... yeah, geklappt. 🙂
              root@Homeserver:~#  pve6to7 --full
              = CHECKING VERSION INFORMATION FOR PVE PACKAGES =
              Checking for package updates..
              WARN: updates for the following packages are available:
                pve-kernel-5.4, pve-kernel-5.4.195-1-pve, pve-kernel-helper
              Checking proxmox-ve package version..
              PASS: proxmox-ve package has version >= 6.4-1
              Checking running kernel version..
              PASS: expected running kernel '5.4.189-2-pve'.
              = CHECKING CLUSTER HEALTH/SETTINGS =
              SKIP: standalone node.
              = CHECKING HYPER-CONVERGED CEPH STATUS =
              SKIP: no hyper-converged ceph setup detected!
              = CHECKING CONFIGURED STORAGES =
              PASS: storage 'local' enabled and active.
              PASS: storage 'local-lvm' enabled and active.
              PASS: storage 'proxmoxbackup' enabled and active.
              = MISCELLANEOUS CHECKS =
              INFO: Checking common daemon services..
              PASS: systemd unit 'pveproxy.service' is in state 'active'
              PASS: systemd unit 'pvedaemon.service' is in state 'active'
              PASS: systemd unit 'pvestatd.service' is in state 'active'
              INFO: Checking for running guests..
              WARN: 4 running guest(s) detected - consider migrating or stopping them.
              INFO: Checking if the local node's hostname 'Homeserver' is resolvable..
              INFO: Checking if resolved IP is configured on local node..
              PASS: Resolved node IP '192.168.0.254' configured and active on single interface.
              INFO: Checking backup retention settings..
              PASS: no problems found.
              INFO: checking CIFS credential location..
              PASS: no CIFS credentials at outdated location found.
              INFO: Checking custom roles for pool permissions..
              INFO: Checking node and guest description/note legnth..
              PASS: All node config descriptions fit in the new limit of 64 KiB
              PASS: All guest config descriptions fit in the new limit of 8 KiB
              INFO: Checking container configs for deprecated lxc.cgroup entries
              PASS: No legacy 'lxc.cgroup' keys found.
              INFO: Checking storage content type configuration..
              INFO: Checking if the suite for the Debian security repository is correct..
              INFO: Make sure to change the suite of the Debian security repository from 'buster/updates' to 'bullseye-security' - in /etc/apt/sources.list:9
              SKIP: No containers on node detected.
              = SUMMARY =
              TOTAL:    20
              PASSED:   15
              SKIPPED:  3
              WARNINGS: 2
              FAILURES: 0
              ATTENTION: Please check the output for detailed information!
              root@Homeserver:~#
                @da_woody na also, dann steht dem upgrade ja nix mehr im Wege
                • da_Woody
                  da_Woody @crunchip last edited by da_Woody
                  @crunchip püh, mühsam nähert sich der eichhorn... 😉
                  irgend nen schwachsinn muss ich doch verbrochen haben...
                  denk mal, die unterste zeile wegklicken...
                  ah, zeile 3 und 5...
                  hmpf, geht nicht in proxmox...
                  crunchip Meister Mopper 2 Replies Last reply Reply Quote 0
                    crunchip Forum Testing Most Active @da_Woody last edited by crunchip
                    @da_woody sagte in pihole update. pfade stimmen nicht... proxmox update...:
                    ja den Haken entfernen bei enterprise list, die ober 4 müssen aktiv bleiben
                    was zurück bleibt ist die Meldung
                    weil du proxmox ja umsonst nutzt
                    früher musste man das per shell erledigen, mittlerweile bequem per Gui
                    • da_Woody
                      @crunchip siehe letzte zeile. lässt sich nicht wegklicken... hrnz, mit doppelklick kommt deaktivieren. ich werd wirklich alt... 😄
                      und das no subscription bekommt man temporär auch weg. irgendwo hab ich das mal gefunden. muss man nur nach jedem update neu machen. ob das mit 7.x auch noch funzt, k.a. ist aber egal.
                      schankedön für die geduld und hilfe! 🤙
                        @da_woody sagte in [done] pihole update. pfade stimmen nicht, proxmox update:
                        https://www.antary.de/2022/05/03/proxmox-meldung-no-valid-subscription-entfernen/#:~:text=Voraussetzung dazu ist der Zugriff,Proxmox VE 7.0 und höher.&text=Anschließend könnt ihr euch ausloggen,Anmeldung ist der Hinweis verschwunden.
                        sed -i.backup -z "s/res === null || res === undefined || \!res || res\n\t\t\t.data.status.toLowerCase() \!== 'active'/false/g" /usr/share/javascript/proxmox-widget-toolkit/proxmoxlib.js && systemctl restart pveproxy.service
                        da_Woody 1 Reply Last reply Reply Quote 1
                        • da_Woody
                          @crunchip danke! ein klick weniger.
                          ich gebs ja zu, bekennend fauler hund... 🐶
                            @da_woody mich stört das nicht, denn so oft ruf ich Proxmox auch nicht auf. Da gibt's schlimmeres, wie z.b. diese sche... cookie Meldungen😂
                            • da_Woody
                              @crunchip auch wieder wahr... 🙂
                                Marty56 @da_Woody last edited by
                                Meine Erfahrungen mit dem Promox Update 7 waren sehr negativ.
                                Ich hatte LXC Container verwendet und da ging gar nichts mehr und ich muss auf VMs umstellen.
                                Aber selbst als ich das gemacht hatte, hatte ich diverse Probleme u.a. konnte ich eine virtuelle Platte nicht wiederherstellen und hatte Datenverlust.
                                Ok, ich bin kein Promox Experte, aber ich habe mit der Umstellung 2 Tage verloren und hatte danach immer noch kleinere Probleme.
                                Nach mehreren super arroganten Reaktionen von irgendwelchen Supportern in Promox Forum, habe ich die Platte neu formatiert und alles ohne Virtualisierung aufgesetzt. Jetzt ist Stromverbrauch und Reaktion besser und die Komplexität meines System auch wieder etwas geringer.
                                Der Nachteil ist natürlich, dass das Backup der Linux Partitionen eine Riesenfummelei ist und ich das bisher noch nicht gemacht habe.
                                Auf der anderen Seite ist mein Setup nicht so komplex. Ich hatte meinen Server dank iobroker Backup in ca. 4 h komplett neu aufgesetzt.
                                crunchip da_Woody 2 Replies Last reply Reply Quote 0
                                  crunchip Forum Testing Most Active @Marty56 last edited by
                                  @marty56 sagte in [done] pihole update. pfade stimmen nicht, proxmox update:
                                  LXC Container sind nun mal vom Host abhängig und nutzen den selben Kernel. Im Gegensatz zu einer VM.
                                  Da muss man eben im Vorfeld sehen, das diese eben auch up to date sind.
                                  Natürlich ist es im Einzelfall auch abhängig, was da überhaupt in einem LXC läuft. Mit nem debian oder ubuntu, sollte es da aber normalerweise keine Probleme geben.
                                  Falls doch, kann man immer noch nen anderen/älteren Kernel laden, sodas die Problem Maschine wieder läuft.
                                  • Negalein
                                    Negalein Global Moderator @Thomas Braun last edited by
                                    Hallo Thomas!
                                    Ich wollte auch gerade Pihole updaten, bekomm aber folgende Meldungen.
                                    Kannst du weiterhelfen?
                                    nega@pihole:~$ pihole -up
                                      [✓] Root user check
                                            .ccccc:,.
                                             :cccclll:.      ..,,
                                              :ccccclll.   ;ooodc
                                               'ccll:;ll .oooodc
                                                 .;cll.;;looo:.
                                      [i] SELinux not detected
                                      [✗] Update local cache of available packages
                                       Error: Unable to update package cache. Please try "sudo apt update"
                                    nega@pihole:~$ sudo apt update
                                    Get:1 http://dl.google.com/linux/chrome/deb stable InRelease [1811 B]
                                    Err:1 http://dl.google.com/linux/chrome/deb stable InRelease
                                      The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 4EB27DB2A3B88B8B
                                    Hit:2 http://archive.ubuntu.com/ubuntu focal InRelease
                                    Hit:3 http://archive.ubuntu.com/ubuntu focal-updates InRelease
                                    Hit:4 http://archive.ubuntu.com/ubuntu focal-security InRelease
                                    Reading package lists... Done
                                    W: GPG error: http://dl.google.com/linux/chrome/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 4EB27DB2A3B88B8B
                                    E: The repository 'http://dl.google.com/linux/chrome/deb stable InRelease' is not signed.
                                    N: Updating from such a repository can't be done securely, and is therefore disabled by default.
                                    N: See apt-secure(8) manpage for repository creation and user configuration details.
                                    nega@pihole:~$
                                      Thomas Braun Most Active @Negalein last edited by
                                      @negalein sagte in [done] pihole update. pfade stimmen nicht, proxmox update:
                                      wget -q -O - https://dl-ssl.google.com/linux/linux_signing_key.pub | sudo apt-key add -
                                      oder
                                      wget -q -O - https://dl.google.com/linux/linux_signing_key.pub | sudo apt-key add -
                                      Aber warum chrome auf einem Server?
                                      • Negalein
                                        @thomas-braun sagte in [done] pihole update. pfade stimmen nicht, proxmox update:
                                        keine Ahnung.
                                        Brauche ich nicht. Hab den nicht installiert.
                                        Wie bring ich den wieder weg?
                                          @negalein
                                          apt policy chrome*
                                          • Negalein
                                            apt policy chrome*
                                            nega@pihole:~$ apt policy chrome*
                                            chrome-gnome-shell:
                                              Installed: (none)
                                              Candidate: 10.1-5
                                              Version table:
                                                 10.1-5 500
                                                    500 http://archive.ubuntu.com/ubuntu focal/universe amd64 Packages
                                            chromedriver:
                                              Installed: (none)
                                              Candidate: (none)
                                              Version table:
                                            nega@pihole:~$
                                            pihole iobroker proxmox
                                            5104
